git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- add build_{menu,n,g,x}config targets for compile-testing Kconfig
- fix and improve recursive dependency detection in Kconfig
- fix parallel building of menuconfig/nconfig
- fix syntax error in clang-version.sh
- suppress distracting log from syncconfig
- remove obsolete "rpm" target
- remove VMLINUX_SYMBOL(_STR) macro entirely
- fix microblaze build with CONFIG_DYNAMIC_FTRACE
- move compiler test for dead code/data elimination to Kconfig
- rename well-known LDFLAGS variable to KBUILD_LDFLAGS
- misc fixes and cleanups
* tag 'kbuild-v4.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
kbuild: rename LDFLAGS to KBUILD_LDFLAGS
kbuild: pass LDFLAGS to recordmcount.pl
kbuild: test dead code/data elimination support in Kconfig
initramfs: move gen_initramfs_list.sh from scripts/ to usr/
vmlinux.lds.h: remove stale <linux/export.h> include
export.h: remove VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR()
Coccinelle: remove pci_alloc_consistent semantic to detect in zalloc-simple.cocci
kbuild: make sorting initramfs contents independent of locale
kbuild: remove "rpm" target, which is alias of "rpm-pkg"
kbuild: Fix LOADLIBES rename in Documentation/kbuild/makefiles.txt
kconfig: suppress "configuration written to .config" for syncconfig
kconfig: fix "Can't open ..." in parallel build
kbuild: Add a space after `!` to prevent parsing as file pattern
scripts: modpost: check memory allocation results
kconfig: improve the recursive dependency report
kconfig: report recursive dependency involving 'imply'
kconfig: error out when seeing recursive dependency
kconfig: add build-only configurator targets
scripts/dtc: consolidate include path options in Makefile
An ordinary arm64 defconfig build has ~64 KB worth of __ksymtab entries,
each consisting of two 64-bit fields containing absolute references, to
the symbol itself and to a char array containing its name, respectively.
When we build the same configuration with KASLR enabled, we end up with an
additional ~192 KB of relocations in the .init section, i.e., one 24 byte
entry for each absolute reference, which all need to be processed at boot
time.
Given how the struct kernel_symbol that describes each entry is completely
local to module.c (except for the references emitted by EXPORT_SYMBOL()
itself), we can easily modify it to contain two 32-bit relative references
instead. This reduces the size of the __ksymtab section by 50% for all
64-bit architectures, and gets rid of the runtime relocations entirely for
architectures implementing KASLR, either via standard PIE linking (arm64)
or using custom host tools (x86).
Note that the binary search involving __ksymtab contents relies on each
section being sorted by symbol name. This is implemented based on the
input section names, not the names in the ksymtab entries, so this patch
does not interfere with that.
Given that the use of place-relative relocations requires support both in
the toolchain and in the module loader, we cannot enable this feature for
all architectures. So make it dependent on whether
CONFIG_HAVE_ARCH_PREL32_RELOCATIONS is defined.
Link: http://lkml.kernel.org/r/20180704083651.24360-4-ard.biesheuvel@linaro.org
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Jessica Yu <jeyu@kernel.org>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: James Morris <james.morris@microsoft.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Nicolas Pitre <nico@linaro.org>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: "Serge E. Hallyn" <serge@hallyn.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Thomas Garnier <thgarnie@google.com>
To allow existing C code to be incorporated into the decompressor or the
UEFI stub, introduce a CPP macro that turns all EXPORT_SYMBOL_xxx
declarations into nops, and #define it in places where such exports are
undesirable. Note that this gets rid of a rather dodgy redefine of
linux/export.h's header guard.
Link: http://lkml.kernel.org/r/20180704083651.24360-3-ard.biesheuvel@linaro.org
Acked-by: Nicolas Pitre <nico@linaro.org>
Cc: Jessica Yu <jeyu@kernel.org>
With the special case handling for Blackfin and Metag was removed by
commit 94e58e0ac312 ("export.h: remove code for prefixing symbols with
underscore"), VMLINUX_SYMBOL() is no-op.
Replace the remaining usages, then remove the definition of
VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR().
CONFIG_HAVE_UNDERSCORE_SYMBOL_PREFIX was selected by BLACKFIN, METAG.
They were removed by commit 4ba66a976072 ("arch: remove blackfin port"),
commit bb6fb6dfcc17 ("metag: Remove arch/metag/"), respectively.
No more architecture enables CONFIG_HAVE_UNDERSCORE_SYMBOL_PREFIX.
Clean up the export.h headers. I am keeping VMLINUX_SYMBOL() and
VMLINUX_SYMBOL_STR() because they are widely used.
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
The previous patch introduced a separate inline asm version of the
krcrctab declaration template for use with 64-bit architectures, which
cannot refer to ELF symbols using 32-bit quantities.
This declaration should be equivalent to the C one for 32-bit
architectures, but just in case - unify them in a separate patch, which
can simply be dropped if it turns out to break anything.
The modversion symbol CRCs are emitted as ELF symbols, which allows us
to easily populate the kcrctab sections by relying on the linker to
associate each kcrctab slot with the correct value.
This has a couple of downsides:
- Given that the CRCs are treated as memory addresses, we waste 4 bytes
for each CRC on 64 bit architectures,
- On architectures that support runtime relocation, a R_<arch>_RELATIVE
relocation entry is emitted for each CRC value, which identifies it
as a quantity that requires fixing up based on the actual runtime
load offset of the kernel. This results in corrupted CRCs unless we
explicitly undo the fixup (and this is currently being handled in the
core module code)
- Such runtime relocation entries take up 24 bytes of __init space
each, resulting in a x8 overhead in [uncompressed] kernel size for
CRCs.
Switching to explicit 32 bit values on 64 bit architectures fixes most
of these issues, given that 32 bit values are not treated as quantities
that require fixing up based on the actual runtime load offset. Note
that on some ELF64 architectures [such as PPC64], these 32-bit values
are still emitted as [absolute] runtime relocatable quantities, even if
the value resolves to a build time constant. Since relative relocations
are always resolved at build time, this patch enables MODULE_REL_CRCS on
powerpc when CONFIG_RELOCATABLE=y, which turns the absolute CRC
references into relative references into .rodata where the actual CRC
value is stored.
So redefine all CRC fields and variables as u32, and redefine the
__CRC_SYMBOL() macro for 64 bit builds to emit the CRC reference using
inline assembler (which is necessary since 64-bit C code cannot use
32-bit types to hold memory addresses, even if they are ultimately
resolved using values that do not exceed 0xffffffff). To avoid
potential problems with legacy 32-bit architectures using legacy
toolchains, the equivalent C definition of the kcrctab entry is retained
for 32-bit architectures.
Note that this mostly reverts commit d4703aefdbc8 ("module: handle ppc64
relocating kcrctabs when CONFIG_RELOCATABLE=y")
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
- EXPORT_SYMBOL for asm source by Al Viro.
This does bring a regression, because genksyms no longer generates
checksums for these symbols (CONFIG_MODVERSIONS). Nick Piggin is
working on a patch to fix this.
Plus, we are talking about functions like strcpy(), which rarely
change prototypes.
- Fixes for PPC fallout of the above by Stephen Rothwell and Nick
Piggin
- fixdep speedup by Alexey Dobriyan.
- preparatory work by Nick Piggin to allow architectures to build with
-ffunction-sections, -fdata-sections and --gc-sections
- CONFIG_THIN_ARCHIVES support by Stephen Rothwell
- fix for filenames with colons in the initramfs source by me.
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: (22 commits)
initramfs: Escape colons in depfile
ppc: there is no clear_pages to export
powerpc/64: whitelist unresolved modversions CRCs
kbuild: -ffunction-sections fix for archs with conflicting sections
kbuild: add arch specific post-link Makefile
kbuild: allow archs to select link dead code/data elimination
kbuild: allow architectures to use thin archives instead of ld -r
kbuild: Regenerate genksyms lexer
kbuild: genksyms fix for typeof handling
fixdep: faster CONFIG_ search
ia64: move exports to definitions
sparc32: debride memcpy.S a bit
[sparc] unify 32bit and 64bit string.h
sparc: move exports to definitions
ppc: move exports to definitions
arm: move exports to definitions
s390: move exports to definitions
m68k: move exports to definitions
alpha: move exports to actual definitions
x86: move exports to actual definitions
Kernel source files need not include <linux/kconfig.h> explicitly
because the top Makefile forces to include it with:
-include $(srctree)/include/linux/kconfig.h
This commit removes explicit includes except the following:
* arch/s390/include/asm/facilities_src.h
* tools/testing/radix-tree/linux/kernel.h
These two are used for host programs.
Link: http://lkml.kernel.org/r/1473656164-11929-1-git-send-email-yamada.masahiro@socionext.com
Introduce LD_DEAD_CODE_DATA_ELIMINATION option for architectures to
select to build with -ffunction-sections, -fdata-sections, and link
with --gc-sections. It requires some work (documented) to ensure all
unreferenced entrypoints are live, and requires toolchain and build
verification, so it is made a per-arch option for now.
On a random powerpc64le build, this yelds a significant size saving,
it boots and runs fine, but there is a lot I haven't tested as yet, so
these savings may be reduced if there are bugs in the link.
text data bss dec filename
11169741 1180744 1923176 14273661 vmlinux
10445269 1004127 1919707 13369103 vmlinux.dce
~700K text, ~170K data, 6% removed from kernel image size.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Signed-off-by: Michal Marek <mmarek@suse.com>
Here the need is for a macro that checks whether the given symbol is
defined or not, which has nothing to do with config.
The new macro __is_defined() is a better fit for this case.
Like with kconfig options, we now have the ability to compile in and
out individual EXPORT_SYMBOL() declarations based on the content of
include/generated/autoksyms.h. However we don't want the entire
world to be rebuilt whenever that file is touched.
Let's apply the same build dependency trick used for CONFIG_* symbols
where the time stamp of empty files whose paths matching those symbols
is used to trigger fine grained rebuilds. In our case the key is the
symbol name passed to EXPORT_SYMBOL().
However, unlike config options, we cannot just use fixdep to parse
the source code for EXPORT_SYMBOL(ksym) because several variants exist
and parsing them all in a separate tool, and keeping it in synch, is
not trivially maintainable. Furthermore, there are variants such as
EXPORT_SYMBOL_GPL(pci_user_read_config_##size);
that are instanciated via a macro for which we can't easily determine
the actual exported symbol name(s) short of actually running the
preprocessor on them.
Storing the symbol name string in a special ELF section doesn't work
for targets that output assembly or preprocessed source.
So the best way is really to leverage the preprocessor by having it
output actual symbol names anchored by a special sequence that can be
easily filtered out. Then the list of symbols is simply fed to fixdep
to be merged with the other dependencies.
That implies the preprocessor is executed twice for each source file.
A previous attempt relied on a warning pragma for each EXPORT_SYMBOL()
instance that was filtered apart from stderr by the build system with
a sed script during the actual compilation pass. Unfortunately the
preprocessor/compiler diagnostic output isn't stable between versions
and this solution, although more efficient, was deemed too fragile.
Because of the lowercasing performed by fixdep, there might be name
collisions triggering spurious rebuilds for similar symbols. But this
shouldn't be a big issue in practice. (This is the case for CONFIG_*
symbols and I didn't want to be different here, whatever the original
reason for doing so.)
To avoid needless build overhead, the exported symbol name gathering is
performed only when CONFIG_TRIM_UNUSED_KSYMS is selected.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Similar to include/generated/autoconf.h, include/generated/autoksyms.h
will contain a list of defines for each EXPORT_SYMBOL() that we want
active. The format is:
#define __KSYM_<symbol_name> 1
This list will be auto-generated with another patch. For now we only
include the preprocessor magic to automatically create or omit the
corresponding struct kernel_symbol declaration.
Given the content of include/generated/autoksyms.h may not be known in
advance, an empty file is created early on to let the build proceed.
sparse complains about any __ksymtab symbols with the following:
warning: symbol '__ksymtab_...' was not declared. Should it be static?
due to Andi's patch making it non-static.
Mollify sparse by declaring the symbol extern, otherwise we get
drowned in sparse warnings for anything that uses EXPORT_SYMBOL
in the sources, making it easy to miss real warnings.
Fixes: e0f244c63fc9 ("asmlinkage, module: Make ksymtab [...] __visible")
Acked-by: Andi Kleen <ak@linux.intel.com>
Make the ksymtab symbols for EXPORT_SYMBOL visible.
This prevents the LTO compiler from adding a .NUMBER prefix,
which avoids various problems in later export processing.
Cc: rusty@rustcorp.com.au
We have CONFIG_SYMBOL_PREFIX, which three archs define to the string
"_". But Al Viro broke this in "consolidate cond_syscall and
SYSCALL_ALIAS declarations" (in linux-next), and he's not the first to
do so.
Using CONFIG_SYMBOL_PREFIX is awkward, since we usually just want to
prefix it so something. So various places define helpers which are
defined to nothing if CONFIG_SYMBOL_PREFIX isn't set:
1) include/asm-generic/unistd.h defines __SYMBOL_PREFIX.
2) include/asm-generic/vmlinux.lds.h defines VMLINUX_SYMBOL(sym)
3) include/linux/export.h defines MODULE_SYMBOL_PREFIX.
4) include/linux/kernel.h defines SYMBOL_PREFIX (which differs from #7)
5) kernel/modsign_certificate.S defines ASM_SYMBOL(sym)
6) scripts/modpost.c defines MODULE_SYMBOL_PREFIX
7) scripts/Makefile.lib defines SYMBOL_PREFIX on the commandline if
CONFIG_SYMBOL_PREFIX is set, so that we have a non-string version
for pasting.
(arch/h8300/include/asm/linkage.h defines SYMBOL_NAME(), too).
Let's solve this properly:
1) No more generic prefix, just CONFIG_HAVE_UNDERSCORE_SYMBOL_PREFIX.
2) Make linux/export.h usable from asm.
3) Define VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR().
4) Make everyone use them.
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Tested-by: James Hogan <james.hogan@imgtec.com> (metag)
A lot of files pull in module.h when all they are really
looking for is the basic EXPORT_SYMBOL functionality. The
recent data from Ingo[1] shows that this is one of several
instances that has a significant impact on compile times,
and it should be targeted for factoring out (as done here).
Note that several commonly used header files in include/*
directly include <linux/module.h> themselves (some 34 of them!)
The most commonly used ones of these will have to be made
independent of module.h before the full benefit of this change
can be realized.
We also transition THIS_MODULE from module.h to export.h,
since there are lots of files with subsystem structs that
in turn will have a struct module *owner and only be doing:
.owner = THIS_MODULE;
and absolutely nothing else modular. So, we also want to have
the THIS_MODULE definition present in the lightweight header.
[1] https://lkml.org/lkml/2011/5/23/76
