path: root/include/linux/ext3_fs_sb.h
2007-10-17ext3: show all mount optionsMiklos Szeredi
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16ext3: statfs speed upBadari Pulavarty
This is a patch that speeds up statfs. It is very simple - the "overhead" calculation, which takes a huge amount of time for large filesystems, never changes unless the size of the filesystem itself changes. That means we can store it in memory and only recalculate if the filesystem has been resized (almost never). It also fixes a minor problem that we never update the on-disk superblock free blocks/inodes counts until the filesystem is unmounted. While not fatal, we may as well update that on disk when we have the information, and it makes things like debugfs and dumpe2fs report a bit more accurate info. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
