path: root/include/linux/extcon
2015-09-30extcon: gpio: Fix minor coding style and remove the unused fields.Chanwoo Choi
This patch fixes the minor coding style about indentation and removes the unused fields from struct gpio_extcon_platform_data. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2015-09-30extcon: gpio: Add the missing supported_cable parameter to ↵Chanwoo Choi
devm_extcon_dev_allocate() The commit 2a9de9c0 ("extcon: Use the unique id for external connector instead of string") defines the unique id of each external connector to identify the type of external connector instead of string name. So, devm_extcon_dev_allocate() should include the second parameter (unsigned int *supported_cable). This patch adds the supported_cable parameter which is passed by platform data. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2015-05-22extcon: Use the unique id for external connector instead of stringChanwoo Choi
This patch uses the unique id to identify the type of external connector instead of string name. The string name have the many potential issues. So, this patch defines the 'extcon' enumeration which includes all supported external connector on EXTCON subsystem. If new external connector is necessary, the unique id of new connector have to be added in 'extcon' enumeration. There are current supported external connector in 'enum extcon' as following: enum extcon { EXTCON_NONE = 0x0, /* USB external connector */ EXTCON_USB = 0x1, EXTCON_USB_HOST = 0x2, /* Charger external connector */ EXTCON_TA = 0x10, EXTCON_FAST_CHARGER = 0x11, EXTCON_SLOW_CHARGER = 0x12, EXTCON_CHARGE_DOWNSTREAM = 0x13, /* Audio and video external connector */ EXTCON_LINE_IN = 0x20, EXTCON_LINE_OUT = 0x21, EXTCON_MICROPHONE = 0x22, EXTCON_HEADPHONE = 0x23, EXTCON_HDMI = 0x30, EXTCON_MHL = 0x31, EXTCON_DVI = 0x32, EXTCON_VGA = 0x33, EXTCON_SPDIF_IN = 0x34, EXTCON_SPDIF_OUT = 0x35, EXTCON_VIDEO_IN = 0x36, EXTCON_VIDEO_OUT = 0x37, /* Miscellaneous external connector */ EXTCON_DOCK = 0x50, EXTCON_JIG = 0x51, EXTCON_MECHANICAL = 0x52, EXTCON_END, }; For example in extcon-arizona.c: To use unique id removes the potential issue about handling the inconsistent name of external connector with string. - Previously, use the string to register the type of arizona jack connector static const char *arizona_cable[] = { "Mechanical", "Microphone", "Headphone", "Line-out", }; - Newly, use the unique id to register the type of arizona jack connector static const enum extcon arizona_cable[] = { EXTCON_MECHANICAL, EXTCON_MICROPHONE, EXTCON_HEADPHONE, EXTCON_LINE_OUT, EXTCON_NONE, }; And this patch modify the prototype of extcon_{get|set}_cable_state_() which uses the 'enum extcon id' instead of 'cable_index'. Because although one more extcon drivers support USB cable, each extcon driver might has the differnt 'cable_index' for USB cable. All extcon drivers can use the unique id number for same external connector with modified extcon_{get|set}_cable_state_(). - Previously, use 'cable_index' on these functions: extcon_get_cable_state_(struct extcon_dev*, int cable_index) extcon_set_cable_state_(struct extcon_dev*, int cable_index, bool state) -Newly, use 'enum extcon id' on these functions: extcon_get_cable_state_(struct extcon_dev*, enum extcon id) extcon_set_cable_state_(struct extcon_dev*, enum extcon id, bool state) Cc: Arnd Bergmann <arnd@arndb.de> Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Roger Quadros <rogerq@ti.com> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Ramakrishna Pallala <ramakrishna.pallala@intel.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> [arnd: Report the build break about drivers/usb/phy/phy-tahvo.c after using the unique id for external connector insteadf of string] Reported-by: Arnd Bergmann <arnd@arndb.de> [dan.carpenter: Report the build warning of extcon_{set|get}_cable_state_()] Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
2014-09-22extcon: gpio: Fix code cleanupGeorge Cherian
This patch fixes following minor cleanup: - Order the include files in alphabetical order. - Fix description of state_off in extcon_gpio.h - Add a descrition for check_on_resume in extcon_gpio.h Signed-off-by: George Cherian <george.cherian@ti.com> [Modify the name/description of patch to keep standary codiyg style by Chanwoo Choi] Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-09-22extcon: sm5502: Move sm5502.h header file to extcon directoryChanwoo Choi
This patch move sm5502.h header file from 'include/linux/extcon' to 'driver/extcon' because sm5502.h is used for driver/extcon/extcon-sm5502.c. and remove duplicate license description. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-07-23extcon: sm5502: Change internal hardware switch according to cable typeChanwoo Choi
This patch changes internal hardware DP_CON/DM_CON switch according to cable type. The SM5502 MUIC device can set hardware switch as following: - OPEN (not connected state) / USB / UART / AUDIO Also, this patch set VBUSIN switch according to cable type. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-07-23extcon: sm5502: Add support new SM5502 extcon device driverChanwoo Choi
This patch add new SM5502 MUIC(Micro-USB Interface Controller) device by using EXTCON subsystem. The extcon-sm5502 driver is capable of identifying the type of the external power source and attached accessory. An external power sources, such as Deticated Charger or a standard USB port, are able to charge the battery in the smart phone via the connector. Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2014-03-19extcon: Move OF helper function to extcon core and change function nameChanwoo Choi
This patch move simply OF helper function to extcon core and change function name as following: - of_extcon_get_extcon_dev() -> extcon_get_edev_by_phandle() Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Acked-by: Felipe Balbi <balbi@ti.com>
2014-01-09extcon: gpio: Add power resume supportRongjun Ying
When system on the suspend state, Some SoC can't get gpio interrupt. After system resume, need send extcon uevent to userspace. Signed-off-by: Rongjun Ying <rongjun.ying@csr.com> Reviewed-by: Barry Song <Baohua.Song@csr.com> Acked-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: gpio: Add support for active-low presence to detect pinsGuenter Roeck
This patch add 'gpio_active_low' field to 'struct gpio_extcon_data' to check whether gpio active state is 1(high) or 0(low). Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
2013-09-27extcon: Fix indentation coding style to improve readabilityChanwoo Choi
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
2013-08-05extcon: Add an API to get extcon device from dt nodeKishon Vijay Abraham I
Added an API of_extcon_get_extcon_dev() to be used by drivers to get extcon device in the case of dt boot (this can be used instead of extcon_get_extcon_dev()). Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com>
2013-02-13extcon: gpio: Rename filename of extcon-gpio.c according to kernel naming styleChanwoo Choi
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-05extcon: adc_jack: adc-jack driver to support 3.5 pi or simliar devicesanish kumar
External connector devices that decides connection information based on ADC values may use adc-jack device driver. The user simply needs to provide a table of adc range and connection states. Then, extcon framework will automatically notify others. Changes in V1: added Lars-Peter Clausen suggested changes: Using macros to get rid of boiler plate code such as devm_kzalloc and module_platform_driver.Other changes suggested are related to coding guidelines. Changes in V2: Removed some unnecessary checks and changed the way we are un-regitering extcon and freeing the irq while removing. Changes in V3: Renamed the files to comply with extcon naming. Changes in V4: Added the cancel_work_sync during removing of driver. Changes in V5: Added the dependency of IIO in Kconfig. Changes in V6: Some nitpicks related to naming. Changes in this version: V6 patch version patch broke the build: ERROR: "extcon_cable_name" [drivers/extcon/extcon-adc-jack.ko] undefined! Fixed it in this version. Acked-by: Jonathan Cameron <jic23@kernel.org> Reviewed-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: anish kumar <anish.singh@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16Revert "Extcon: adc_jack: adc-jack driver to support 3.5 pi or simliar devices"Greg Kroah-Hartman
This reverts commit 980d7929816236476967218645c30acc022042eb as it breaks the build with the error: ERROR: "extcon_cable_name" [drivers/extcon/extcon-adc-jack.ko] undefined! Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: anish kumar <anish.singh@samsung.com> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16Extcon: adc_jack: adc-jack driver to support 3.5 pi or simliar devicesanish kumar
External connector devices that decides connection information based on ADC values may use adc-jack device driver. The user simply needs to provide a table of adc range and connection states. Then, extcon framework will automatically notify others. Changes in V1: added Lars-Peter Clausen suggested changes: Using macros to get rid of boiler plate code such as devm_kzalloc and module_platform_driver.Other changes suggested are related to coding guidelines. Changes in V2: Removed some unnecessary checks and changed the way we are un-regitering extcon and freeing the irq while removing. Changes in V3: Renamed the files to comply with extcon naming. Changes in V4: Added the cancel_work_sync during removing of driver. Changes in V5: Added the dependency of IIO in Kconfig. Changes in V6: Some nitpicks related to naming. Reviewed-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: anish kumar <anish.singh@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-17extcon: spelling of detach in function docPeter Meerwald
Signed-off-by: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-20Extcon: support generic GPIO extcon driverMyungJoo Ham
The generic GPIO extcon driver (an external connector device based on GPIO control) and imported from Android kernel. switch: switch class and GPIO drivers. (splitted) Author: Mike Lockwood <lockwood@android.com> switch: gpio: Don't call request_irq with interrupts disabled Author: Arve Hjønnevåg <arve@android.com> switch_gpio: Add missing #include <linux/interrupt.h> Author: Mike Lockwood <lockwood@android.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> -- Changed from v7: - Style updates mentioned by Stephen Boyd and Mark Brown Changed from v5: - Splitted at v5 from the main extcon patch. - Added debounce time for irq handlers. - Use request_any_context_irq instead of request_irq - User needs to specify irq flags for GPIO interrupts (was fixed to IRQF_TRIGGER_LOW before) - Use module_platform_driver(). Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
