path: root/include/linux/fb.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-06-01Merge tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6Linus Torvalds
Pull fbdev updates from Florian Tobias Schandinat: - driver for AUO-K1900 and AUO-K1901 epaper controller - large updates for OMAP (e.g. decouple HDMI audio and video) - some updates for Exynos and SH Mobile - various other small fixes and cleanups * tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6: (130 commits) video: bfin_adv7393fb: Fix cleanup code video: exynos_dp: reduce delay time when configuring video setting video: exynos_dp: move sw reset prioir to enabling sw defined function video: exynos_dp: use devm_ functions fb: handle NULL pointers in framebuffer release OMAPDSS: HDMI: OMAP4: Update IRQ flags for the HPD IRQ request OMAPDSS: Apply VENC timings even if panel is disabled OMAPDSS: VENC/DISPC: Delay dividing Y resolution for managers connected to VENC OMAPDSS: DISPC: Support rotation through TILER OMAPDSS: VRFB: remove compiler warnings when CONFIG_BUG=n OMAPFB: remove compiler warnings when CONFIG_BUG=n OMAPDSS: remove compiler warnings when CONFIG_BUG=n OMAPDSS: DISPC: fix usage of dispc_ovl_set_accu_uv OMAPDSS: use DSI_FIFO_BUG workaround only for manual update displays OMAPDSS: DSI: Support command mode interleaving during video mode blanking periods OMAPDSS: DISPC: Update Accumulator configuration for chroma plane drivers/video: fsl-diu-fb: don't initialize the THRESHOLDS registers video: exynos mipi dsi: support reverse panel type video: exynos mipi dsi: Properly interpret the interrupt source flags video: exynos mipi dsi: Avoid races in probe() ...
2012-05-29fbdev: add events for early fb event supportInki Dae
Add FB_EARLY_EVENT_BLANK and FB_R_EARLY_EVENT_BLANK event mode supports. first, fb_notifier_call_chain() is called with FB_EARLY_EVENT_BLANK and fb_blank() of specific fb driver is called and then fb_notifier_call_chain() is called with FB_EVENT_BLANK again at fb_blank(). and if fb_blank() was failed then fb_nitifier_call_chain() would be called with FB_R_EARLY_EVENT_BLANK to revert the previous effects. Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-29fb_defio: add first_io callbackHeiko Stübner
With this optional callback the driver is notified when the first page is entered into the pagelist and a new deferred_io call is scheduled. A possible use-case for this is runtime-pm. In the first_io call pm_runtime_get() could be called, which starts an asynchronous runtime_resume of the device. In the deferred_io callback a call to pm_runtime_barrier() makes the sure, the device is resumed by then and a pm_runtime_put() may put the device back to sleep. Also, some SoCs may use the runtime-pm system to determine if they are able to enter deeper idle states. Therefore it is necessary to keep the use-count from the first written page until the conclusion of the screen update, to prevent the system from going to sleep before completing the pending update. Two users of defio were using kmalloc to allocate the structure. These allocations are changed to kzalloc, to prevent uninitialised .first_io members in those drivers. Signed-off-by: Heiko Stübner <heiko@sntech.de> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-03-24Merge tag 'device-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull <linux/device.h> avoidance patches from Paul Gortmaker: "Nearly every subsystem has some kind of header with a proto like: void foo(struct device *dev); and yet there is no reason for most of these guys to care about the sub fields within the device struct. This allows us to significantly reduce the scope of headers including headers. For this instance, a reduction of about 40% is achieved by replacing the include with the simple fact that the device is some kind of a struct. Unlike the much larger module.h cleanup, this one is simply two commits. One to fix the implicit <linux/device.h> users, and then one to delete the device.h includes from the linux/include/ dir wherever possible." * tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: device.h: audit and cleanup users in main include dir device.h: cleanup users outside of linux/include (C files)
2012-03-16device.h: audit and cleanup users in main include dirPaul Gortmaker
The <linux/device.h> header includes a lot of stuff, and it in turn gets a lot of use just for the basic "struct device" which appears so often. Clean up the users as follows: 1) For those headers only needing "struct device" as a pointer in fcn args, replace the include with exactly that. 2) For headers not really using anything from device.h, simply delete the include altogether. 3) For headers relying on getting device.h implicitly before being included themselves, now explicitly include device.h 4) For files in which doing #1 or #2 uncovers an implicit dependency on some other header, fix by explicitly adding the required header(s). Any C files that were implicitly relying on device.h to be present have already been dealt with in advance. Total removals from #1 and #2: 51. Total additions coming from #3: 9. Total other implicit dependencies from #4: 7. As of 3.3-rc1, there were 110, so a net removal of 42 gives about a 38% reduction in device.h presence in include/* Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-03-15udlfb: remove sysfs framebuffer device with USB .disconnect()Kay Sievers
The USB graphics card driver delays the unregistering of the framebuffer device to a workqueue, which breaks the userspace visible remove uevent sequence. Recent userspace tools started to support USB graphics card hotplug out-of-the-box and rely on proper events sent by the kernel. The framebuffer device is a direct child of the USB interface which is removed immediately after the USB .disconnect() callback. But the fb device in /sys stays around until its final cleanup, at a time where all the parent devices have been removed already. To work around that, we remove the sysfs fb device directly in the USB .disconnect() callback and leave only the cleanup of the internal fb data to the delayed work. Before: add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb) add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb) add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb0 (graphics) remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb) remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb) remove /2-1.2:1.0/graphics/fb0 (graphics) After: add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb) add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb) add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb1 (graphics) remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb1 (graphics) remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb) remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb) Cc: stable@vger.kernel.org Tested-by: Bernie Thompson <bernie@plugable.com> Acked-by: Bernie Thompson <bernie@plugable.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2011-12-19fbdev: Add FOURCC-based format configuration APILaurent Pinchart
This API will be used to support YUV frame buffer formats in a standard way. Last but not least, create a much needed fbdev API documentation and document the format setting APIs. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-12fbcon: add lifetime refcount to opened frame buffersLinus Torvalds
This just adds the refcount and the new registration lock logic. It does not (for example) actually change the read/write/ioctl routines to actually use the frame buffer that was opened: those function still end up alway susing whatever the current frame buffer is at the time of the call. Without this, if something holds the frame buffer open over a framebuffer switch, the close() operation after the switch will access a fb_info that has been free'd by the unregistering of the old frame buffer. (The read/write/ioctl operations will normally not cause problems, because they will - illogically - pick up the new fbcon instead. But a switch that happens just as one of those is going on might see problems too, the window is just much smaller: one individual op rather than the whole open-close sequence.) This use-after-free is apparently fairly easily triggered by the Ubuntu 11.04 boot sequence. Acked-by: Tim Gardner <tim.gardner@canonical.com> Tested-by: Daniel J Blueman <daniel.blueman@gmail.com> Tested-by: Anca Emanuel <anca.emanuel@gmail.com> Cc: Bruno Prémont <bonbons@linux-vserver.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Dave Airlie <airlied@redhat.com> Cc: Andy Whitcroft <andy.whitcroft@canonical.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17unicore32 machine related: add frame buffer driver for pkunity-v3 socGuanXuetao
change from original version -- by advice of Paul Mundt 1. remove videomemorysize definitions 2. remove unifb_enable and unifb_setup 3. use dev_warn instead of printk in fb driver 4. remove judgement for FB_ACCEL_PUV3_UNIGFX 5. adjust clk_get and clk_set_rate calls 6. add resources definitions 7. remove unifb_option 8. adjust register for platform_device 9. adjust unifb_ops position and unifb_regs assignment position Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-12-22Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2010-11-17fbcmap: integer overflow bugDan Carpenter
There is an integer overflow in fb_set_user_cmap() because cmap->len * 2 can wrap. It's basically harmless. Your terminal will be messed up until you type reset. This patch does three things to fix the bug. First, it checks the return value of fb_copy_cmap() in fb_alloc_cmap(). That is enough to fix address the overflow. Second it checks for the integer overflow in fb_set_user_cmap(). Lastly I wanted to cap "cmap->len" in fb_set_user_cmap() much lower because it gets used to determine the size of allocation. Unfortunately no one knows what the limit should be. Instead what this patch does is makes the allocation happen with GFP_KERNEL instead of GFP_ATOMIC and lets the kmalloc() decide what values of cmap->len are reasonable. To do this, the patch introduces a function called fb_alloc_cmap_gfp() which is like fb_alloc_cmap() except that it takes a GFP flag. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-15fbdev: when parsing E-EDID blocks, also use SVD entriesGuennadi Liakhovetski
Add parsing of E-EDID SVD entries. In this first version only a few CEA/EIA-861E modes are implemented, more can be added as needed. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-15video: add fb_edid_add_monspecs for parsing extended edid informationErik Gilling
Modern monitors/tvs have more extended EDID information blocks which can contain extra detailed modes. This adds a fb_edid_add_monspecs function which drivers can use to parse those additions blocks. Signed-off-by: Erik Gilling <konkers@android.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-10-27fbmem: fix fb_read, fb_write unaligned accessesJames Hogan
fb_{read,write} access the framebuffer using lots of fb_{read,write}l's but don't check that the file position is aligned which can cause problems on some architectures which do not support unaligned accesses. Since the operations are essentially memcpy_{from,to}io, new fb_memcpy_{from,to}fb macros have been defined and these are used instead. For Sparc, fb_{read,write} macros use sbus_{read,write}, so this defines new sbus_memcpy_{from,to}io functions the same as memcpy_{from,to}io but using sbus_{read,write}b instead of {read,write}b. Signed-off-by: James Hogan <james@albanarts.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10vt/console: try harder to print output when panicingJesse Barnes
Jesse's initial patch commit said: "At panic time (i.e. when oops_in_progress is set) we should try a bit harder to update the screen and make sure output gets to the VT, since some drivers are capable of flipping back to it. So make sure we try to unblank and update the display if called from a panic context." I've enhanced this to add a flag to the vc that console layer can set to indicate they want this behaviour to occur. This also adds support to fbcon for that flag and adds an fb flag for drivers to indicate they want to use the support. It enables this for KMS drivers. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: James Simmons <jsimmons@infradead.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-05fb: add hooks to handle KDB enter/exitJesse Barnes
Add fb ops to handle enter/exit of the kernel debugger. If present, the fb core will register them with KGDB and they'll be called when the debugger is entered and exited. The new functions are responsible for switching to an appropriate debug framebuffer and restoring the interrupted state at exit time. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-07-20fb: handle allocation failure in alloc_apertures()Dan Carpenter
If the kzalloc() fails we should return NULL. All the places that call alloc_apertures() check for this already. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: James Simmons <jsimmons@infradead.org> Acked-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-01fb: fix colliding defines for fb flags.Dave Airlie
When I added the flags I must have been using a 25 line terminal and missed the following flags. The collided with flag has one user in staging despite being in-tree for 5 years. I'm happy to push this via my drm tree unless someone really wants to do it. Signed-off-by: Dave Airlie <airlied@redhat.com> Cc: stable@kernel.org
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-25fbdev: move FBIO_WAITFORVSYNC to linux/fb.hGrazvydas Ignotas
FBIO_WAITFORVSYNC is currently implemented by matroxfb, atyfb, intelfb and more. All of them keep redefining the same FBIO_WAITFORVSYNC macro over and over again, so move it to linux/fb.h and clean up those duplicate defines. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Maik Broemme <mbroemme@plusserver.de> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: "Hiremath, Vaibhav" <hvaibhav@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-18vga16fb, drm: vga16fb->drm handoffMarcin Slusarz
let vga16fb claim 0xA0000+0x10000 region as its aperture; drm drivers don't use it, so we have to detect it and kick vga16fb manually - but only if drm is driving the primary card Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Dave Airlie <airlied@redhat.com> Cc: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-18fbmem, drm/nouveau: kick firmware framebuffers as soon as possibleMarcin Slusarz
Currently vesafb/efifb/... is kicked when hardware driver is registering framebuffer. To do it hardware must be fully functional, so there's a short window between start of initialisation and framebuffer registration when two drivers touch the hardware. Unfortunately sometimes it breaks nouveau initialisation. Fix it by kicking firmware driver(s) before we start touching the hardware. Reported-by: Didier Spaier <didier.spaier@epsm.fr> Tested-by: Didier Spaier <didier.spaier@epsm.fr> Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Peter Jones <pjones@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-18fbdev: allow passing more than one aperture for handoffMarcin Slusarz
It removes a hack from nouveau code which had to detect which region to pass to kick vesafb/efifb. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Eric Anholt <eric@anholt.net> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: Dave Airlie <airlied@redhat.com> Cc: Peter Jones <pjones@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-01vga_switcheroo: initial implementation (v15)Dave Airlie
Many new laptops now come with 2 gpus, one to be used for low power modes and one for gaming/on-ac applications. These GPUs are typically wired to the laptop panel and VGA ports via a multiplexer unit which is controlled via ACPI methods. 4 combinations of systems typically exist - with 2 ACPI methods. Intel/ATI - Lenovo W500/T500 - use ATPX ACPI method ATI/ATI - some ASUS - use ATPX ACPI Method Intel/Nvidia - - use _DSM ACPI method Nvidia/Nvidia - - use _DSM ACPI method. TODO: This patch adds support for the ATPX method and initial bits for the _DSM methods that need to written by someone with access to the hardware. Add a proper non-debugfs interface - need to get some proper testing first. v2: add power up/down support for both devices on W500 puts i915/radeon into D3 and cuts power to radeon. v3: redo probing methods, no DMI list, drm devices call to register with switcheroo, it tries to find an ATPX method on any device and once there is two devices + ATPX it inits the switcher. v4: ATPX msg handling using buffers - should work on more machines v5: rearchitect after more mjg59 discussion - move ATPX handling to radeon driver. v6: add file headers + initial nouveau bits (to be filled out). v7: merge delayed switcher code. v8: avoid suspend/resume of gpu that is off v9: rearchitect - mjg59 is always right. - move all ATPX code to radeon, should allow simpler DSM also proper ATRM handling v10: add ATRM support for radeon BIOS, add mutex to lock vgasr_priv v11: fix bug in resuming Intel for 2nd time. v12: start fixing up nvidia code blindly. v13: blindly guess at finishing nvidia code v14: remove radeon audio hacks - fix up intel resume more like upstream v15: clean up printks + remove unnecessary igd/dis pointers mount debugfs /sys/kernel/debug/vgaswitcheroo/switch - should exist if ATPX detected + 2 cards. DIS - immediate change to discrete IGD - immediate change to IGD DDIS - delayed change to discrete DIGD - delayed change to IGD ON - turn on not in use OFF - turn off not in use Tested on W500 (Intel/ATI) and T500 (Intel/ATI) Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-10Merge branch 'xen/fbdev' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'xen/fbdev' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: xen pvfb: Inhibit VM_IO flag to be set on vmalloc-ed framebuffers. fb-defio: Inhibit VM_IO flag to be set on vmalloc-ed framebuffers. fb-defio: If FBINFO_VIRTFB is defined, do not set VM_IO flag. Fix toogle whether xenbus driver should be built as module or part of kernel.
2009-12-03fb-defio: If FBINFO_VIRTFB is defined, do not set VM_IO flag.Konrad Rzeszutek Wilk
Most users (except sh_mobile_lcdcfb.c) get their framebuffer from vmalloc. Setting VM_IO is not necessary as the memory obtained from vmalloc is System RAM type and is not susceptible to PCI memory constraints. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Jaya Kumar <jayakumar.lkml@gmail.com>
2009-11-12fb: remove fb_save_state() and fb_restore_state operationsKrzysztof Helt
Remove fb_save_state() and fb_restore_state operations from frame buffer layer. They are used only in two drivers: 1. savagefb - and cause bug #11248 2. uvesafb Usage of these operations is misunderstood in both drivers so kill these operations, fix the bug #11248 and avoid confusion in the future. Tested on Savage 3D/MV card and the patch fixes the bug #11248. The frame buffer layer uses these funtions during switch between graphics and text mode of the console, but these drivers saves state before switching of the frame buffer (in the fb_open) and after releasing it (in the fb_release). This defeats the purpose of these operations. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=11248 Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reported-by: Jochen Hein <jochen@jochen.org> Tested-by: Jochen Hein <jochen@jochen.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Januszewski <spock@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-12[ARM] pxafb: add accelerator ID for PXA3xx GCUDaniel Mack
Add ID 99 for PXA3xx frame buffers and report it in the pxa frame buffer conditionally, depending on a new flag in struct pxafb_mach_info. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: linux-fbdev-devel@lists.sourceforge.net Cc: Dennis Oliver Kropp <dok@directfb.org> Cc: Sven Neumann <s.neumann@raumfeld.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-06-30fbdev: add mutex for fb_mmap lockingKrzysztof Helt
Add a mutex to avoid a circular locking problem between the mm layer semaphore and fbdev ioctl mutex through the fb_mmap() call. Also, add mutex to all places where smem_start and smem_len fields change so the mutex inside the fb_mmap() is actually used. Changing of these fields before calling the framebuffer_register() are not mutexed. This is 2.6.31 material. It removes one lockdep (fb_mmap() and register_framebuffer()) but there is still another one (fb_release() and register_framebuffer()). It also cleans up handling of the smem_start and smem_len fields used by mutexed section of the fb_mmap(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: blackfin has __raw I/O accessors, so use them in fb.hMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: add support for handoff from firmware to hw framebuffersDave Airlie
With KMS we have ran into an issue where we really want the KMS fb driver to be the one running the console, so panics etc can be shown by switching out of X etc. However with vesafb/efifb built-in, we end up with those on fb0 and the KMS fb driver on fb1, driving the same piece of hw, so this adds an fb info flag to denote a firmware fbdev, and adds a new aperture base/size range which can be compared when the hw drivers are installed to see if there is a conflict with a firmware driver, and if there is the firmware driver is unregistered and the hw driver takes over. It uses new aperture_base/size members instead of comparing on the fix smem_start/length, as smem_start/length might for example only cover the first 1MB of the PCI aperture, and we could allocate the kms fb from 8MB into the aperture, thus they would never overlap. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Airlie <airlied@redhat.com> Acked-by: Peter Jones <pjones@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-13fbdev: fix color component field length documentationMichal Januszewski
The documentation about the meaning of the color component bitfield lengths in pseudocolor modes is inconsistent. Fix it, so that it indicates the correct interpretation everywhere, i.e. that 1 << length is the number of palette entries. Signed-off-by: Michal Januszewski <spock@gentoo.org> Acked-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: <syrjala@sci.fi> Acked-by: Geert Uytterhoeven <geert.uytterhoeven@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01fbdev: uninline lock_fb_info()Andrew Morton
Before: text data bss dec hex filename 3648 2910 32 6590 19be drivers/video/backlight/backlight.o 3226 2812 32 6070 17b6 drivers/video/backlight/lcd.o 30990 16688 8480 56158 db5e drivers/video/console/fbcon.o 15488 8400 24 23912 5d68 drivers/video/fbmem.o After: text data bss dec hex filename 3537 2870 32 6439 1927 drivers/video/backlight/backlight.o 3131 2772 32 5935 172f drivers/video/backlight/lcd.o 30876 16648 8480 56004 dac4 drivers/video/console/fbcon.o 15506 8400 24 23930 5d7a drivers/video/fbmem.o Cc: Andrea Righi <righi.andrea@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01cirrusfb: add accelerator constantKrzysztof Helt
Add an accelerator constant so almost all Cirrus are recognized as accelerators by the fbset command. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-05fbmem: don't call copy_from/to_user() with mutex heldAndrea Righi
Avoid calling copy_from/to_user() with fb_info->lock mutex held in fbmem ioctl(). fb_mmap() is called under mm->mmap_sem (A) held, that also acquires fb_info->lock (B); fb_ioctl() takes fb_info->lock (B) and does copy_from/to_user() that might acquire mm->mmap_sem (A), causing a deadlock. NOTE: it doesn't push down the fb_info->lock in each own driver's fb_ioctl(), so there are still potential deadlocks elsewhere. Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: Dave Jones <davej@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Johannes Weiner <hannes@saeurebad.de> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Harvey Harrison <harvey.harrison@gmail.com> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15include of <linux/types.h> is preferred over <asm/types.h>Jaswinder Singh Rajput
Impact: fix 15 make headers_check warnings: include of <linux/types.h> is preferred over <asm/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-22fb: SH-5 uses __raw I/O accessors now also, drop the special casing.Paul Mundt
2008-10-20fb: convert lock/unlock_kernel() into local fb mutexKrzysztof Helt
Change lock_kernel()/unlock_kernel() to local fb mutex. Each frame buffer instance has its own mutex. The one line try_to_load() function is unrolled to request_module() in two places for readability. [righi.andrea@gmail.com: fb: fix NULL pointer BUG dereference in fb_open()] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-20fbdefio: add set_page_dirty handler to deferred IO FBIan Campbell
Fixes kernel BUG at lib/radix-tree.c:473. Previously the handler was incidentally provided by tmpfs but this was removed with: commit 14fcc23fdc78e9d32372553ccf21758a9bd56fa1 Author: Hugh Dickins <hugh@veritas.com> Date: Mon Jul 28 15:46:19 2008 -0700 tmpfs: fix kernel BUG in shmem_delete_inode relying on this behaviour was incorrect in any case and the BUG also appeared when the device node was on an ext3 filesystem. v2: override a_ops at open() time rather than mmap() time to minimise races per AKPM's concerns. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Cc: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Cc: Johannes Weiner <hannes@saeurebad.de> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Kel Modderman <kel@otaku42.de> Cc: Markus Armbruster <armbru@redhat.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: <stable@kernel.org> [14fcc23fd is in 2.6.25.14 and 2.6.26.1] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24video/fb: cleanup FB_MAJOR usagePhilippe De Muyter
Currently, linux/major.h defines a GRAPHDEV_MAJOR (29) that nobody uses, and linux/fb.h defines the real FB_MAJOR (also 29), that only fbmem.c needs. Drop GRAPHDEV_MAJOR from major.h, move FB_MAJOR definition from fb.h to major.h, and fix fbmem.c to use major.h's definition. Signed-off-by: Philippe De Muyter <phdm@macqel.be> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: acceleration constants changeKrzysztof Helt
This patch replaces deprecated constant FB_ACCELF_TEXT with FBINFO_HWACCEL_DISABLED and adds constants for Trident families of accelerators. The FBINFO_HWACCEL_DISABLED is correctly used so noaccel parameter works now. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fb: add support for foreign endiannessAnton Vorontsov
Add support for the framebuffers with non-native endianness. This is done via FBINFO_FOREIGN_ENDIAN flag that will be used by the drivers. Depending on the host endianness this flag will be overwritten by FBINFO_BE_MATH internal flag, or cleared. Tested to work on MPC8360E-RDK (BE) + Fujitsu MINT framebuffer (LE). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: <Valdis.Kletnieks@vt.edu> Cc: Clemens Koller <clemens.koller@anagramm.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fb: move and rename extern declaration for global_mode_optionGeert Uytterhoeven
Move the extern declaration for global_mode_option to <linux/fb.h> and rename the variable to fb_mode_option. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Intel FB: more interlaced mode supportKrzysztof Halasa
Intel FB: allow odd- and even-field-first in interlaced modes, and proper sync to vertical retrace Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: <sylvain.meyer@worldonline.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: Support for byte-reversed framebuffer formatsPavel Pisa
Allow generic frame-buffer code to correctly write texts and blit images for 1, 2 and 4 bit per pixel frame-buffer organizations when pixels in bytes are organized to in opposite order than bytes in long type. Overhead should be reasonable. If option is not selected, than compiler should eliminate completely all overhead. The feature is disabled at compile time if CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set. [adaplas] Convert helper functions to macros if feature is not enabled. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17OMAP: add TI OMAP1610 accelerator entry.Imre Deak
Signed-off-by: Trilok Soni <soni.trilok@gmail.com> Cc: Tony Lindgren <tony@atomide.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fbdev: fbcon: console unregistration from unregister_framebufferJesse Barnes
This allows for proper console unregistration via the VT layer, and updates the FB layer to use it. This makes debugging new console drivers much easier, since you can properly clean them up before unloading. [adaplas] unregister_framebuffer() is typically called as part of the driver's module_exit(). Doing so otherwise will freeze the machine as the VT layer is holding reference counts on fbcon, and fbcon on the driver. With this change, it allows unregister_framebuffer() to be called safely anywhere as needed. Additions from the original: If multiple drivers are used by fbcon, and if one of them unregisters, a driver will take over the consoles vacated by the outgoing one (via set_con2fb_map). Once only the outgoing driver remains, then fbcon will unbind from the VT layer (if CONFIG_HW_CONSOLE_UNBINDING is set to y). It is important that these drivers implement fb_open() and fb_release() just to ensure that no other process is using the driver. Likewise, these drivers _must_ check the return value of unregister_framebuffer(). [akpm@linux-foundation.org: make fbcon_unbind() stub inline] Signed-off-by: Jesse Barnes <jesse.barnes@intel.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
