path: root/include/linux/fcntl.h
2017-07-15fs: add a VALID_OPEN_FLAGSChristoph Hellwig
commit 80f18379a7c350c011d30332658aa15fe49a8fa5 upstream. Add a central define for all valid open flags, and use it in the uniqueness check. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2011-03-14New AT_... flag: AT_EMPTY_PATHAl Viro
For name_to_handle_at(2) we'll want both ...at()-style syscall that would be usable for non-directory descriptors (with empty relative pathname). Introduce new flag (AT_EMPTY_PATH) to deal with that and corresponding LOOKUP_EMPTY; teach user_path_at() and path_init() to deal with the latter. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add an AT_NO_AUTOMOUNT flag to suppress terminal automountDavid Howells
Add an AT_NO_AUTOMOUNT flag to suppress terminal automounting of automount point directories. This can be used by fstatat() users to permit the gathering of attributes on an automount point and also prevent mass-automounting of a directory of automount points by ls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21pipe: add support for shrinking and growing pipesJens Axboe
This patch adds F_GETPIPE_SZ and F_SETPIPE_SZ fcntl() actions for growing and shrinking the size of a pipe and adjusts pipe.c and splice.c (and relay and network splice) usage to work with these larger (or smaller) pipes. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-17F_DUPFD_CLOEXEC implementationUlrich Drepper
One more small change to extend the availability of creation of file descriptors with FD_CLOEXEC set. Adding a new command to fcntl() requires no new system call and the overall impact on code size if minimal. If this patch gets accepted we will also add this change to the next revision of the POSIX spec. To test the patch, use the following little program. Adjust the value of F_DUPFD_CLOEXEC appropriately. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <errno.h> #include <fcntl.h> #include <stdio.h> #include <stdlib.h> #include <unistd.h> #ifndef F_DUPFD_CLOEXEC # define F_DUPFD_CLOEXEC 12 #endif int main (int argc, char *argv[]) { if (argc > 1) { if (fcntl (3, F_GETFD) == 0) { puts ("descriptor not closed"); exit (1); } if (errno != EBADF) { puts ("error not EBADF"); exit (1); } exit (0); } int fd = fcntl (STDOUT_FILENO, F_DUPFD_CLOEXEC, 0); if (fd == -1 && errno == EINVAL) { puts ("F_DUPFD_CLOEXEC not supported"); return 0; } if (fd != 3) { puts ("program called with descriptors other than 0,1,2"); return 1; } execl ("/proc/self/exe", "/proc/self/exe", "1", NULL); puts ("execl failed"); return 1; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-06locks: add lock cancel commandMarc Eshel
Lock managers need to be able to cancel pending lock requests. In the case where the exported filesystem manages its own locks, it's not sufficient just to call posix_unblock_lock(); we need to let the filesystem know what's happening too. We do this by adding a new fcntl lock command: FL_CANCELLK. Some day this might also be made available to userspace applications that could benefit from an asynchronous locking api. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu>
2006-06-25[PATCH] Implement AT_SYMLINK_FOLLOW flag for linkatUlrich Drepper
When the linkat() syscall was added the flag parameter was added in the last minute but it wasn't used so far. The following patch should change that. My tests show that this is all that's needed. If OLDNAME is a symlink setting the flag causes linkat to follow the symlink and create a hardlink with the target. This is actually the behavior POSIX demands for link() as well but Linux wisely does not do this. With this flag (which will most likely be in the next POSIX revision) the programmer can choose the behavior, defaulting to the safe variant. As a side effect it is now possible to implement a POSIX-compliant link(2) function for those who are interested. touch file ln -s file symlink linkat(fd, "symlink", fd, "newlink", 0) -> newlink is hardlink of symlink linkat(fd, "symlink", fd, "newlink", AT_SYMLINK_FOLLOW) -> newlink is hardlink of file The value of AT_SYMLINK_FOLLOW is determined by the definition we already use in glibc. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] vfs: *at functions: coreUlrich Drepper
Here is a series of patches which introduce in total 13 new system calls which take a file descriptor/filename pair instead of a single file name. These functions, openat etc, have been discussed on numerous occasions. They are needed to implement race-free filesystem traversal, they are necessary to implement a virtual per-thread current working directory (think multi-threaded backup software), etc. We have in glibc today implementations of the interfaces which use the /proc/self/fd magic. But this code is rather expensive. Here are some results (similar to what Jim Meyering posted before). The test creates a deep directory hierarchy on a tmpfs filesystem. Then rm -fr is used to remove all directories. Without syscall support I get this: real 0m31.921s user 0m0.688s sys 0m31.234s With syscall support the results are much better: real 0m20.699s user 0m0.536s sys 0m20.149s The interfaces are for obvious reasons currently not much used. But they'll be used. coreutils (and Jeff's posixutils) are already using them. Furthermore, code like ftw/fts in libc (maybe even glob) will also start using them. I expect a patch to make follow soon. Every program which is walking the filesystem tree will benefit. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] Don't force O_LARGEFILE for 32 bit processes on ia64Yoav Zach
In ia64 kernel, the O_LARGEFILE flag is forced when opening a file. This is problematic for execution of 32 bit processes, which are not largefile aware, either by SW emulation or by HW execution. For such processes, the problem is two-fold: 1) When trying to open a file that is larger than 4G the operation should fail, but it's not 2) Writing to offset larger than 4G should fail, but it's not The proposed patch takes advantage of the way 32 bit processes are identified in ia64 systems. Such processes have PER_LINUX32 for their personality. With the patch, the ia64 kernel will not enforce the O_LARGEFILE flag if the current process has PER_LINUX32 set. The behavior for all other architectures remains unchanged. Signed-off-by: Yoav Zach <yoav.zach@intel.com> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
