path: root/include/linux/fib_rules.h
2007-04-25[IPV6] FIB6RULE: Find source address during looking up route.YOSHIFUJI Hideaki
When looking up route for destination with rules with source address restrictions, we may need to find a source address for the traffic if not given. Based on patch from Noriaki TAKAMIYA <takamiya@po.ntts.co.jp>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] fib_rules: Add no-operation actionThomas Graf
The use of nop rules simplifies the usage of goto rules and adds more flexibility as they allow targets to remain while the actual content of the branches can change easly. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] fib_rules: Mark rules detached from the deviceThomas Graf
Rules which match against device names in their selector can remain while the device itself disappears, in fact the device doesn't have to present when the rule is added in the first place. The device name is resolved by trying when the rule is added and later by listening to NETDEV_REGISTER/UNREGISTER notifications. This patch adds the flag FIB_RULE_DEV_DETACHED which is set towards userspace when a rule contains a device match which is unresolved at the moment. This eases spotting the reason why certain rules seem not to function properly. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] fib_rules: goto rule actionThomas Graf
This patch adds a new rule action FR_ACT_GOTO which allows to skip a set of rules by jumping to another rule. The rule to jump to is specified via the FRA_GOTO attribute which carries a rule preference. Referring to a rule which doesn't exists is explicitely allowed. Such goto rules are marked with the flag FIB_RULE_UNRESOLVED and will act like a rule with a non-matching selector. The rule will become functional as soon as its target is present. The goto action enables performance optimizations by reducing the average number of rules that have to be passed per lookup. Example: 0: from all lookup local 40: not from all to 192.168.23.128 goto 32766 41: from all fwmark 0xa blackhole 42: from all fwmark 0xff blackhole 32766: from all lookup main Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET] rules: Add support to invert selectorsThomas Graf
Introduces a new flag FIB_RULE_INVERT causing rules to apply if the specified selector doesn't match. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET] rules: Protocol independant mark selectorThomas Graf
Move mark selector currently implemented per protocol into the protocol independant part. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV4]: Add support for fwmark masks in routing rulesPatrick McHardy
Add a FRA_FWMASK attributes for fwmark masks. For compatibility a mask of 0xFFFFFFFF is used when a mark value != 0 is sent without a mask. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[IPV6] ROUTE: Routing by FWMARK.YOSHIFUJI Hideaki
Based on patch by Jean Lorchat <lorchat@sfc.wide.ad.jp>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2006-09-22[NET]: Introduce RTA_TABLE/FRA_TABLE attributesPatrick McHardy
Introduce RTA_TABLE route attribute and FRA_TABLE routing rule attribute to hold 32 bit routing table IDs. Usespace compatibility is provided by continuing to accept and send the rtm_table field, but because of its limited size it can only carry the low 8 bits of the table ID. This implies that if larger IDs are used, _all_ userspace programs using them need to use RTA_TABLE. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Protocol Independant Policy Routing Rules FrameworkThomas Graf
Derived from net/ipv/fib_rules.c Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
