path: root/include/linux/firmware.h
2008-03-10firmware: provide stubs for the FW_LOADER=n caseJames Bottomley
libsas has a case where it uses the firmware loader to provide services, but doesn't want to select it all the time. This currently causes a compile failure in libsas if FW_LOADER=n. Fix this by providing error stubs for the firmware loader API in the FW_LOADER=n case. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-05-21[PATCH] drivers/base/firmware_class.c: cleanupsAdrian Bunk
- remove the following global function that is both unused and unimplemented: - register_firmware() - make the following needlessly global function static: - firmware_class_uevent() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-07[PATCH] modified firmware_class.c to support no hotplugAbhay Salunke
Upgrade the request_firmware_nowait function to not start the hotplug action on a firmware update. This patch is tested along with dell_rbu driver on i386 and x86-64 systems. Signed-off-by: Abhay Salunke <Abhay_Salunke@dell.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
