git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
fs: simplify iget & friends
fs: pull inode->i_lock up out of writeback_single_inode
fs: rename inode_lock to inode_hash_lock
fs: move i_wb_list out from under inode_lock
fs: move i_sb_list out from under inode_lock
fs: remove inode_lock from iput_final and prune_icache
fs: Lock the inode LRU list separately
fs: factor inode disposal
fs: protect inode->i_state with inode->i_lock
autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd()
autofs4 - remove autofs4_lock
autofs4 - fix d_manage() return on rcu-walk
autofs4 - fix autofs4_expire_indirect() traversal
autofs4 - fix dentry leak in autofs4_expire_direct()
autofs4 - reinstate last used update on access
vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
Protect inode state transitions and validity checks with the
inode->i_lock. This enables us to make inode state transitions
independently of the inode_lock and is the first step to peeling
away the inode_lock from the code.
This requires that __iget() is done atomically with i_state checks
during list traversals so that we don't race with another thread
marking the inode I_FREEING between the state check and grabbing the
reference.
Also remove the unlock_new_inode() memory barrier optimisation
required to avoid taking the inode_lock when clearing I_NEW.
Simplify the code by simply taking the inode->i_lock around the
state change and wakeup. Because the wakeup is no longer tricky,
remove the wake_up_inode() function and open code the wakeup where
necessary.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
And give it a kernel-doc comment.
[akpm@linux-foundation.org: btrfs changed in linux-next]
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
Cheat for now and say all files belong to init_user_ns. Next step will be
to let superblocks belong to a user_ns, and derive inode_userns(inode)
from inode->i_sb->s_user_ns. Finally we'll introduce more flexible
arrangements.
Changelog:
Feb 15: make is_owner_or_cap take const struct inode
Feb 23: make is_owner_or_cap bool
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
Re-ordering struct block_inode to remove 8 bytes of padding on 64 bit
builds, which also shrinks bdev_inode by 8 bytes (776 -> 768) allowing it
to fit into one fewer cache lines.
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
not needed anymore, since all users (->get_sb() instances) are gone.
* 'mnt_devname' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
vfs: bury ->get_sb()
nfs: switch NFS from ->get_sb() to ->mount()
nfs: stop mangling ->mnt_devname on NFS
vfs: new superblock methods to override /proc/*/mount{s,info}
nfs: nfs_do_{ref,sub}mount() superblock argument is redundant
nfs: make nfs_path() work without vfsmount
nfs: store devname at disconnected NFS roots
nfs: propagate devname to nfs{,4}_get_root()
This is an ex-parrot.
a) ->show_devname(m, mnt) - what to put into devname columns in mounts,
mountinfo and mountstats
b) ->show_path(m, mnt) - what to put into relative path column in mountinfo
Leaving those NULL gives old behaviour. NFS switched to using those.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits)
AppArmor: kill unused macros in lsm.c
AppArmor: cleanup generated files correctly
KEYS: Add an iovec version of KEYCTL_INSTANTIATE
KEYS: Add a new keyctl op to reject a key with a specified error code
KEYS: Add a key type op to permit the key description to be vetted
KEYS: Add an RCU payload dereference macro
AppArmor: Cleanup make file to remove cruft and make it easier to read
SELinux: implement the new sb_remount LSM hook
LSM: Pass -o remount options to the LSM
SELinux: Compute SID for the newly created socket
SELinux: Socket retains creator role and MLS attribute
SELinux: Auto-generate security_is_socket_class
TOMOYO: Fix memory leak upon file open.
Revert "selinux: simplify ioctl checking"
selinux: drop unused packet flow permissions
selinux: Fix packet forwarding checks on postrouting
selinux: Fix wrong checks for selinux_policycap_netpeer
selinux: Fix check for xfrm selinux context algorithm
ima: remove unnecessary call to ima_must_measure
IMA: remove IMA imbalance checking
New flag for open(2) - O_PATH. Semantics:
* pathname is resolved, but the file itself is _NOT_ opened
as far as filesystem is concerned.
* almost all operations on the resulting descriptors shall
fail with -EBADF. Exceptions are:
1) operations on descriptors themselves (i.e.
close(), dup(), dup2(), dup3(), fcntl(fd, F_DUPFD),
fcntl(fd, F_DUPFD_CLOEXEC, ...), fcntl(fd, F_GETFD),
fcntl(fd, F_SETFD, ...))
2) fcntl(fd, F_GETFL), for a common non-destructive way to
check if descriptor is open
3) "dfd" arguments of ...at(2) syscalls, i.e. the starting
points of pathname resolution
* closing such descriptor does *NOT* affect dnotify or
posix locks.
* permissions are checked as usual along the way to file;
no permission checks are applied to the file itself. Of course,
giving such thing to syscall will result in permission checks (at
the moment it means checking that starting point of ....at() is
a directory and caller has exec permissions on it).
fget() and fget_light() return NULL on such descriptors; use of
fget_raw() and fget_raw_light() is needed to get them. That protects
existing code from dealing with those things.
There are two things still missing (they come in the next commits):
one is handling of symlinks (right now we refuse to open them that
way; see the next commit for semantics related to those) and another
is descriptor passing via SCM_RIGHTS datagrams.
We add a per superblock uuid field. File systems should
update the uuid in the fill_super callback
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
The syscall also return mount id which can be used
to lookup file system specific information such as uuid
in /proc/<pid>/mountinfo
New helpers: user_statfs() and fd_statfs(), taking userland pathname and
descriptor resp. and filling struct kstatfs. Syscalls of statfs family
(native, compat and foreign - osf and hpux on alpha and parisc resp.)
switched to those. Removes some boilerplate code, simplifies cleanup
on errors...
new function: file_open_root(dentry, mnt, name, flags) opens the file
vfs_path_lookup would arrive to.
Note that name can be empty; in that case the usual requirement that
dentry should be a directory is lifted.
open-coded equivalents switched to it, may_open() got down exactly
one caller and became static.
take calculation of open_flags by open(2) arguments into new helper
in fs/open.c, move filp_open() over there, have it and do_sys_open()
use that helper, switch exec.c callers of do_filp_open() to explicit
(and constant) struct open_flags.
block/blk-core.c
block/blk-flush.c
drivers/md/raid1.c
drivers/md/raid10.c
drivers/md/raid5.c
fs/nilfs2/btnode.c
fs/nilfs2/mdt.c
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
With the plugging now being explicitly controlled by the
submitter, callers need not pass down unplugging hints
to the block layer. If they want to unplug, it's because they
manually plugged on their own - in which case, they should just
unplug at will.
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
* 'for-linus' of git://neil.brown.name/md:
md: Fix - again - partition detection when array becomes active
Fix over-zealous flush_disk when changing device size.
md: avoid spinlock problem in blk_throtl_exit
md: correctly handle probe of an 'mdp' device.
md: don't set_capacity before array is active.
md: Fix raid1->raid0 takeover
There are two cases when we call flush_disk.
In one, the device has disappeared (check_disk_change) so any
data will hold becomes irrelevant.
In the oter, the device has changed size (check_disk_size_change)
so data we hold may be irrelevant.
In both cases it makes sense to discard any 'clean' buffers,
so they will be read back from the device if needed.
In the former case it makes sense to discard 'dirty' buffers
as there will never be anywhere safe to write the data. In the
second case it *does*not* make sense to discard dirty buffers
as that will lead to file system corruption when you simply enlarge
the containing devices.
flush_disk calls __invalidate_devices.
__invalidate_device calls both invalidate_inodes and invalidate_bdev.
invalidate_inodes *does* discard I_DIRTY inodes and this does lead
to fs corruption.
invalidate_bev *does*not* discard dirty pages, but I don't really care
about that at present.
So this patch adds a flag to __invalidate_device (calling it
__invalidate_device2) to indicate whether dirty buffers should be
killed, and this is passed to invalidate_inodes which can choose to
skip dirty inodes.
flusk_disk then passes true from check_disk_change and false from
check_disk_size_change.
dm avoids tripping over this problem by calling i_size_write directly
rathher than using check_disk_size_change.
md does use check_disk_size_change and so is affected.
This regression was introduced by commit 608aeef17a which causes
check_disk_size_change to call flush_disk, so it is suitable for any
kernel since 2.6.27.
Cc: stable@kernel.org
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Cc: Andrew Patterson <andrew.patterson@hp.com>
Signed-off-by: NeilBrown <neilb@suse.de>
Michael Leun reported that running parallel opens on a fuse filesystem
can trigger a "kernel BUG at mm/truncate.c:475"
Gurudas Pai reported the same bug on NFS.
The reason is, unmap_mapping_range() is not prepared for more than
one concurrent invocation per inode. For example:
thread1: going through a big range, stops in the middle of a vma and
stores the restart address in vm_truncate_count.
thread2: comes in with a small (e.g. single page) unmap request on
the same vma, somewhere before restart_address, finds that the
vma was already unmapped up to the restart address and happily
returns without doing anything.
Another scenario would be two big unmap requests, both having to
restart the unmapping and each one setting vm_truncate_count to its
own value. This could go on forever without any of them being able to
finish.
Truncate and hole punching already serialize with i_mutex. Other
callers of unmap_mapping_range() do not, and it's difficult to get
i_mutex protection for all callers. In particular ->d_revalidate(),
which calls invalidate_inode_pages2_range() in fuse, may be called
with or without i_mutex.
This patch adds a new mutex to 'struct address_space' to prevent
running multiple concurrent unmap_mapping_range() on the same mapping.
[ We'll hopefully get rid of all this with the upcoming mm
preemptibility series by Peter Zijlstra, the "mm: Remove i_mmap_mutex
lockbreak" patch in particular. But that is for 2.6.39 ]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Reported-by: Michael Leun <lkml20101129@newton.leun.net>
Reported-by: Gurudas Pai <gurudas.pai@oracle.com>
Tested-by: Gurudas Pai <gurudas.pai@oracle.com>
Define i_readcount_inc/dec() functions to be called from the VFS layer.
Changelog:
- renamed iget/iput_readcount to i_readcount_inc/dec (Dave Chinner's suggestion)
- removed i_lock in iput_readcount() (based on comments:Dave Chinner,Eric Paris)
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
Acked-by: Eric Paris <eparis@redhat.com>
Convert the inode's i_readcount from an unsigned int to atomic.
FMODE_EXEC is a constant type of fmode_t but was used with normal integer
constants. This results in following warnings from sparse. Fix it using
new macro __FMODE_EXEC.
fs/exec.c:116:58: warning: restricted fmode_t degrades to integer
fs/exec.c:689:58: warning: restricted fmode_t degrades to integer
fs/fcntl.c:777:9: warning: restricted fmode_t degrades to integer
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
AND-ing FMODE_* constant with normal integer results in following
sparse warnings. Fix it.
fs/open.c:662:21: warning: restricted fmode_t degrades to integer
fs/anon_inodes.c:123:34: warning: restricted fmode_t degrades to integer
The fi_extents_start field of struct fiemap_extent_info is a
user pointer but was not marked as __user. This makes sparse
emit following warnings:
CHECK fs/ioctl.c
fs/ioctl.c:114:26: warning: incorrect type in argument 1 (different address spaces)
fs/ioctl.c:114:26: expected void [noderef] <asn:1>*dst
fs/ioctl.c:114:26: got struct fiemap_extent *[assigned] dest
fs/ioctl.c:202:14: warning: incorrect type in argument 1 (different address spaces)
fs/ioctl.c:202:14: expected void const volatile [noderef] <asn:1>*<noident>
fs/ioctl.c:202:14: got struct fiemap_extent *[assigned] fi_extents_start
fs/ioctl.c:212:27: warning: incorrect type in argument 1 (different address spaces)
fs/ioctl.c:212:27: expected void [noderef] <asn:1>*dst
fs/ioctl.c:212:27: got char *<noident>
Also add 'ufiemap' variable to eliminate unnecessary casts.
Currently all filesystems except XFS implement fallocate asynchronously,
while XFS forced a commit. Both of these are suboptimal - in case of O_SYNC
I/O we really want our allocation on disk, especially for the !KEEP_SIZE
case where we actually grow the file with user-visible zeroes. On the
other hand always commiting the transaction is a bad idea for fast-path
uses of fallocate like for example in recent Samba versions. Given
that block allocation is a data plane operation anyway change it from
an inode operation to a file operation so that we have the file structure
available that lets us check for O_SYNC.
This also includes moving the code around for a few of the filesystems,
and remove the already unnedded S_ISDIR checks given that we only wire
up fallocate for regular files.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (23 commits)
sanitize vfsmount refcounting changes
fix old umount_tree() breakage
autofs4: Merge the remaining dentry ops tables
Unexport do_add_mount() and add in follow_automount(), not ->d_automount()
Allow d_manage() to be used in RCU-walk mode
Remove a further kludge from __do_follow_link()
autofs4: Bump version
autofs4: Add v4 pseudo direct mount support
autofs4: Fix wait validation
autofs4: Clean up autofs4_free_ino()
autofs4: Clean up dentry operations
autofs4: Clean up inode operations
autofs4: Remove unused code
autofs4: Add d_manage() dentry operation
autofs4: Add d_automount() dentry operation
Remove the automount through follow_link() kludge code from pathwalk
CIFS: Use d_automount() rather than abusing follow_link()
NFS: Use d_automount() rather than abusing follow_link()
AFS: Use d_automount() rather than abusing follow_link()
Add an AT_NO_AUTOMOUNT flag to suppress terminal automount
Add a dentry op (d_automount) to handle automounting directories rather than
abusing the follow_link() inode operation. The operation is keyed off a new
dentry flag (DCACHE_NEED_AUTOMOUNT).
This also makes it easier to add an AT_ flag to suppress terminal segment
automount during pathwalk and removes the need for the kludge code in the
pathwalk algorithm to handle directories with follow_link() semantics.
The ->d_automount() dentry operation:
struct vfsmount *(*d_automount)(struct path *mountpoint);
takes a pointer to the directory to be mounted upon, which is expected to
provide sufficient data to determine what should be mounted. If successful, it
should return the vfsmount struct it creates (which it should also have added
to the namespace using do_add_mount() or similar). If there's a collision with
another automount attempt, NULL should be returned. If the directory specified
by the parameter should be used directly rather than being mounted upon,
-EISDIR should be returned. In any other case, an error code should be
returned.
The ->d_automount() operation is called with no locks held and may sleep. At
this point the pathwalk algorithm will be in ref-walk mode.
Within fs/namei.c itself, a new pathwalk subroutine (follow_automount()) is
added to handle mountpoints. It will return -EREMOTE if the automount flag was
set, but no d_automount() op was supplied, -ELOOP if we've encountered too many
symlinks or mountpoints, -EISDIR if the walk point should be used without
mounting and 0 if successful. The path will be updated to point to the mounted
filesystem if a successful automount took place.
__follow_mount() is replaced by follow_managed() which is more generic
(especially with the patch that adds ->d_manage()). This handles transits from
directories during pathwalk, including automounting and skipping over
mountpoints (and holding processes with the next patch).
__follow_mount_rcu() will jump out of RCU-walk mode if it encounters an
automount point with nothing mounted on it.
follow_dotdot*() does not handle automounts as you don't want to trigger them
whilst following "..".
I've also extracted the mount/don't-mount logic from autofs4 and included it
here. It makes the mount go ahead anyway if someone calls open() or creat(),
tries to traverse the directory, tries to chdir/chroot/etc. into the directory,
or sticks a '/' on the end of the pathname. If they do a stat(), however,
they'll only trigger the automount if they didn't also say O_NOFOLLOW.
I've also added an inode flag (S_AUTOMOUNT) so that filesystems can mark their
inodes as automount points. This flag is automatically propagated to the
dentry as DCACHE_NEED_AUTOMOUNT by __d_instantiate(). This saves NFS and could
save AFS a private flag bit apiece, but is not strictly necessary. It would be
preferable to do the propagation in d_set_d_op(), but that doesn't normally
have access to the inode.
[AV: fixed breakage in case if __follow_mount_rcu() fails and nameidata_drop_rcu()
succeeds in RCU case of do_lookup(); we need to fall through to non-RCU case after
that, rather than just returning with ungrabbed *path]
Was-Acked-by: Ian Kent <raven@themaw.net>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: restore multiple bd_link_disk_holder() support
block cfq: compensate preempted queue even if it has no slice assigned
block cfq: make queue preempt work for queues from different workload
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: (62 commits)
nfsd4: fix callback restarting
nfsd: break lease on unlink, link, and rename
nfsd4: break lease on nfsd setattr
nfsd: don't support msnfs export option
nfsd4: initialize cb_per_client
nfsd4: allow restarting callbacks
nfsd4: simplify nfsd4_cb_prepare
nfsd4: give out delegations more quickly in 4.1 case
nfsd4: add helper function to run callbacks
nfsd4: make sure sequence flags are set after destroy_session
nfsd4: re-probe callback on connection loss
nfsd4: set sequence flag when backchannel is down
nfsd4: keep finer-grained callback status
rpc: allow xprt_class->setup to return a preexisting xprt
rpc: keep backchannel xprt as long as server connection
rpc: move sk_bc_xprt to svc_xprt
nfsd4: allow backchannel recovery
nfsd4: support BIND_CONN_TO_SESSION
nfsd4: modify session list under cl_lock
Documentation: fl_mylease no longer exists
Fix up conflicts in fs/nfsd/vfs.c with the vfs-scale work. The
vfs-scale work touched some msnfs cases, and this merge removes support
for that entirely, so the conflict was trivial to resolve.
Commit e09b457b (block: simplify holder symlink handling) incorrectly
assumed that there is only one link at maximum. dm may use multiple
links and expects block layer to track reference count for each link,
which is different from and unrelated to the exclusive device holder
identified by @holder when the device is opened.
Remove the single holder assumption and automatic removal of the link
and revive the per-link reference count tracking. The code
essentially behaves the same as before commit e09b457b sans the
unnecessary kobject reference count dancing.
While at it, note that this facility should not be used by anyone else
than the current ones. Sysfs symlinks shouldn't be abused like this
and the whole thing doesn't belong in the block layer at all.
Reported-by: Milan Broz <mbroz@redhat.com>
Cc: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Cc: Neil Brown <neilb@suse.de>
Cc: linux-raid@vger.kernel.org
Cc: Kay Sievers <kay.sievers@vrfy.org>
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits)
block: ensure that completion error gets properly traced
blktrace: add missing probe argument to block_bio_complete
block cfq: don't use atomic_t for cfq_group
block cfq: don't use atomic_t for cfq_queue
block: trace event block fix unassigned field
block: add internal hd part table references
block: fix accounting bug on cross partition merges
kref: add kref_test_and_get
bio-integrity: mark kintegrityd_wq highpri and CPU intensive
block: make kblockd_workqueue smarter
Revert "sd: implement sd_check_events()"
block: Clean up exit_io_context() source code.
Fix compile warnings due to missing removal of a 'ret' variable
fs/block: type signature of major_to_index(int) to major_to_index(unsigned)
block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p)
cfq-iosched: don't check cfqg in choose_service_tree()
fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors
cdrom: export cdrom_check_events()
sr: implement sr_check_events()
Remove kobject.h from files which don't need it, notably,
sched.h and fs.h.
We can turn the dcache hash locking from a global dcache_hash_lock into
per-bucket locking.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Put dentry and inode fields into top of data structure. This allows RCU path
traversal to perform an RCU dentry lookup in a path walk by touching only the
first 56 bytes of the dentry.
We also fit in 8 bytes of inline name in the first 64 bytes, so for short
names, only 64 bytes needs to be touched to perform the lookup. We should
get rid of the hash->prev pointer from the first 64 bytes, and fit 16 bytes
of name in there, which will take care of 81% rather than 32% of the kernel
tree.
inode is also rearranged so that RCU lookup will only touch a single cacheline
in the inode, plus one in the i_ops structure.
This is important for directory component lookups in RCU path walking. In the
kernel source, directory names average is around 6 chars, so this works.
When we reach the last element of the lookup, we need to lock it and take its
refcount which requires another cacheline access.
Align dentry and inode operations structs, so members will be at predictable
offsets and we can group common operations into head of structure.
Pseudo filesystems that don't put inode on RCU list or reachable by
rcu-walk dentries do not need to RCU free their inodes.
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
dcache_lock no longer protects anything. remove it.
The nfs server only supports read delegations for now, so we don't care
how conflicts are determined. All we care is that unlocks are
recognized as matching the leases they are meant to remove. After the
last patch, a comparison of struct files will work for that purpose. So
we no longer need this callback.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Currently, media presence polling for removeable block devices is done
from userland. There are several issues with this.
* Polling is done by periodically opening the device. For SCSI
devices, the command sequence generated by such action involves a
few different commands including TEST_UNIT_READY. This behavior,
while perfectly legal, is different from Windows which only issues
single command, GET_EVENT_STATUS_NOTIFICATION. Unfortunately, some
ATAPI devices lock up after being periodically queried such command
sequences.
* There is no reliable and unintrusive way for a userland program to
tell whether the target device is safe for media presence polling.
For example, polling for media presence during an on-going burning
session can make it fail. The polling program can avoid this by
opening the device with O_EXCL but then it risks making a valid
exclusive user of the device fail w/ -EBUSY.
* Userland polling is unnecessarily heavy and in-kernel implementation
is lighter and better coordinated (workqueue, timer slack).
This patch implements framework for in-kernel disk event handling,
which includes media presence polling.
* bdops->check_events() is added, which supercedes ->media_changed().
It should check whether there's any pending event and return if so.
Currently, two events are defined - DISK_EVENT_MEDIA_CHANGE and
DISK_EVENT_EJECT_REQUEST. ->check_events() is guaranteed not to be
called parallelly.
* gendisk->events and ->async_events are added. These should be
initialized by block driver before passing the device to add_disk().
The former contains the mask of all supported events and the latter
the mask of all events which the device can report without polling.
/sys/block/*/events[_async] export these to userland.
* Kernel parameter block.events_dfl_poll_msecs controls the system
polling interval (default is 0 which means disable) and
/sys/block/*/events_poll_msecs control polling intervals for
individual devices (default is -1 meaning use system setting). Note
that if a device can report all supported events asynchronously and
its polling interval isn't explicitly set, the device won't be
polled regardless of the system polling interval.
* If a device is opened exclusively with write access, event checking
is automatically disabled until all write exclusive accesses are
released.
* There are event 'clearing' events. For example, both of currently
defined events are cleared after the device has been successfully
opened. This information is passed to ->check_events() callback
using @clearing argument as a hint.
* Event checking is always performed from system_nrt_wq and timer
slack is set to 25% for polling.
* Nothing changes for drivers which implement ->media_changed() but
not ->check_events(). Going forward, all drivers will be converted
to ->check_events() and ->media_change() will be dropped.
Cc: Jan Kara <jack@suse.cz>
NFS needs to be able to release objects that are stored in the page
cache once the page itself is no longer visible from the page cache.
This patch adds a callback to the address space operations that allows
filesystems to perform page cleanups once the page has been removed
Original patch by: Linus Torvalds <torvalds@linux-foundation.org>
[trondmy: cover the cases of invalidate_inode_pages2() and
truncate_inode_pages()]
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
dpkg uses fiemap but didn't particularly need to include stdint.h so far.
Since 367a51a33902 ("fs: Add FITRIM ioctl"), build of linux/fs.h failed in
dpkg with:
In file included from ../../src/filesdb.c:27:0:
/usr/include/linux/fs.h:37:2: error: expected specifier-qualifier-list before 'uint64_t'
Use exportable type __u64 to avoid the dependency on stdint.h.
b31d42a5af18 ("Fix compile brekage with !CONFIG_BLOCK") fixed only the
kernel build by including linux/types.h, but this also fixed "make
headers_check", so don't revert it.
Signed-off-by: Loïc Minier <loic.minier@linaro.org>
Tested-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Cc: Lukas Czerner <lczerner@redhat.com>
Cc: Dmitry Monakhov <dmonakhov@openvz.org>
Cc: Theodore Ts'o <tytso@mit.edu>
There was concern that FITRIM ioctl is not common enough to be included
in core vfs ioctl, as Christoph Hellwig pointed out there's no real point
in dispatching this out to a separate vector instead of just through
->ioctl.
So this commit removes ioctl_fstrim() from vfs ioctl and trim_fs
from super_operation structure.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
