path: root/include/linux/fs.h
2006-10-19[PATCH] Add lockless helpers for remove_suid()Jens Axboe
Right now users have to grab i_mutex before calling remove_suid(), in the unlikely event that a call to ->setattr() may be needed. Split up the function in two parts: - One to check if we need to remove suid - One to actually remove it The first we can call lockless. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-10-19[PATCH] Introduce generic_file_splice_write_nolock()Mark Fasheh
This allows file systems to manage their own i_mutex locking while still re-using the generic_file_splice_write() logic. OCFS2 in particular wants this so that it can order cluster locks within i_mutex. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-10-19[PATCH] Take i_mutex in splice_from_pipe()Mark Fasheh
The splice_actor may be calling ->prepare_write() and ->commit_write(). We want i_mutex on the inode being written to before calling those so that we don't race i_size changes. The double locking behavior is done elsewhere in splice.c, and if we eventually want _nolock variants of generic_file_splice_write(), fs modules might have to replicate the nasty locking code. We introduce inode_double_lock() and inode_double_unlock() to consolidate the locking rules into one set of functions. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-10-17[PATCH] document i_size_write locking rulesMiklos Szeredi
Unless someone reads the documentation for write_seqcount_{begin,end} it is not obvious, that i_size_write() needs locking. Especially, that lack of such locking can result in a system hang. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6: (292 commits) [GFS2] Fix endian bug for de_type [GFS2] Initialize SELinux extended attributes at inode creation time. [GFS2] Move logging code into log.c (mostly) [GFS2] Mark nlink cleared so VFS sees it happen [GFS2] Two redundant casts removed [GFS2] Remove uneeded endian conversion [GFS2] Remove duplicate sb reading code [GFS2] Mark metadata reads for blktrace [GFS2] Remove iflags.h, use FS_ [GFS2] Fix code style/indent in ops_file.c [GFS2] streamline-generic_file_-interfaces-and-filemap gfs fix [GFS2] Remove readv/writev methods and use aio_read/aio_write instead (gfs bits) [GFS2] inode-diet: Eliminate i_blksize from the inode structure [GFS2] inode_diet: Replace inode.u.generic_ip with inode.i_private (gfs) [GFS2] Fix typo in last patch [GFS2] Fix direct i/o logic in filemap.c [GFS2] Fix bug in Makefiles for lock modules [GFS2] Remove (extra) fs_subsys declaration [GFS2/DLM] Fix trailing whitespace [GFS2] Tidy up meta_io code ...
2006-10-03[PATCH] dm: export blkdev_driver_ioctlAlasdair G Kergon
Export blkdev_driver_ioctl for device-mapper. If we get as far as the device-mapper ioctl handler, we know the ioctl is not a standard block layer BLK* one, so we don't need to check for them a second time and can call blkdev_driver_ioctl() directly. Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[GFS2] Remove iflags.h, use FS_Steven Whitehouse
Update GFS2 in the light of David Howells' patch: [PATCH] BLOCK: Move common FS-specific ioctls to linux/fs.h [try #6] 36695673b012096228ebdc1b39a6a5850daa474e which calls the filesystem independant flags FS_..._FL. As a result we no longer need the flags.h file and the conversion routine is moved into the GFS2 source code. Userland programs which used to include iflags.h should now include fs.h and use the new flag names. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-10-02[PATCH] file: modify struct fown_struct to use a struct pidEric W. Biederman
File handles can be requested to send sigio and sigurg to processes. By tracking the destination processes using struct pid instead of pid_t we make the interface safe from all potential pid wrap around problems. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Some cleanup in the pipe codeAndi Kleen
Split the big and hard to read do_pipe function into smaller pieces. This creates new create_write_pipe/free_write_pipe/create_read_pipe functions. These functions are made global so that they can be used by other parts of the kernel. The resulting code is more generic and easier to read and has cleaner error handling and less gotos. [akpm@osdl.org: cleanup] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: monitor zeroing of i_nlinkDave Hansen
Some filesystems, instead of simply decrementing i_nlink, simply zero it during an unlink operation. We need to catch these in addition to the decrement operations. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Add vector AIO supportBadari Pulavarty
This work is initially done by Zach Brown to add support for vectored aio. These are the core changes for AIO to support IOCB_CMD_PREADV/IOCB_CMD_PWRITEV. [akpm@osdl.org: huge build fix] Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Vectorize aio_read/aio_write fileop methodsBadari Pulavarty
This patch vectorizes aio_read() and aio_write() methods to prepare for collapsing all aio & vectored operations into one interface - which is aio_read()/aio_write(). Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move common FS-specific ioctls to linux/fs.h [try #6]David Howells
Move common FS-specific ioctls from linux/ext2_fs.h to linux/fs.h as FS_IOC_* and FS_IOC32_* and have the users of them use those as a base. Also move the GETFLAGS/SETFLAGS flags to linux/fs.h as FS_*_FL macros, and then have the other users use them as a base. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move functions out of buffer code [try #6]David Howells
Move some functions out of the buffering code that aren't strictly buffering specific. This is a precursor to being able to disable the block layer. (*) Moved some stuff out of fs/buffer.c: (*) The file sync and general sync stuff moved to fs/sync.c. (*) The superblock sync stuff moved to fs/super.c. (*) do_invalidatepage() moved to mm/truncate.c. (*) try_to_release_page() moved to mm/filemap.c. (*) Moved some related declarations between header files: (*) declarations for do_invalidatepage() and try_to_release_page() moved to linux/mm.h. (*) __set_page_dirty_buffers() moved to linux/buffer_head.h. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] Allow file systems to differentiate between data and meta readsJens Axboe
We can use this information for making more intelligent priority decisions, and it will also be useful for blktrace. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-09-30[PATCH] Kill various deprecated/unused block layer defines/functionsJens Axboe
2006-09-29[PATCH] fs.h: ifdef security fieldsAlexey Dobriyan
[assuming BSD security levels are deleted] The only user of i_security, f_security, s_security fields is SELinux, however, quite a few security modules are trying to get into kernel. So, wrap them under CONFIG_SECURITY. Adding config option for each security field is likely an overkill. Following Stephen Smalley's suggestion, i_security initialization is moved to security_inode_alloc() to not clutter core code with ifdefs and make alloc_inode() codepath tiny little bit smaller and faster. The user of (highly greppable) struct fown_struct::security field is still to be found. I've checked every "fown_struct" and every "f_owner" occurence. Additionally it's removal doesn't break i386 allmodconfig build. struct inode, struct file, struct super_block, struct fown_struct become smaller. P.S. Combined with two reiserfs inode shrinking patches sent to linux-fsdevel, I can finally suck 12 reiserfs inodes into one page. /proc/slabinfo -ext2_inode_cache 388 10 +ext2_inode_cache 384 10 -inode_cache 280 14 +inode_cache 276 14 -proc_inode_cache 296 13 +proc_inode_cache 292 13 -reiser_inode_cache 336 11 +reiser_inode_cache 332 12 <= -shmem_inode_cache 372 10 +shmem_inode_cache 368 10 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] ifdef ->quota_read, ->quota_writeAlexey Dobriyan
All suppliers of ->quota_read, ->quota_write (I've found ext2, ext3, UFS, reiserfs) already have them properly ifdeffed. All callers of ->quota_read, ->quota_write are under CONFIG_QUOTA umbrella, so... Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode-diet: Move i_cdev into a unionTheodore Ts'o
Move the i_cdev pointer in struct inode into a union. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode-diet: Move i_bdev into a unionTheodore Ts'o
Move the i_bdev pointer in struct inode into a union. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode-diet: Move i_pipe into a unionTheodore Ts'o
Move the i_pipe pointer into a union that will be shared with i_bdev and i_cdev. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-24[PATCH] Allow file systems to manually d_move() inside of ->rename()Mark Fasheh
Some file systems want to manually d_move() the dentries involved in a rename. We can do this by making use of the FS_ODD_RENAME flag if we just have nfs_rename() unconditionally do the d_move(). While there, we rename the flag to be more descriptive. OCFS2 uses this to protect that part of the rename operation with a cluster lock. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-08-27[PATCH] lockdep: annotate reiserfsIngo Molnar
reiserfs seems to have another locking level layer for the i_mutex due to the xattrs-are-a-directory thing. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] FDPIC: Define SEEK_* constants in the Linux kernel headersDavid Howells
Add definitions for SEEK_SET, SEEK_CUR and SEEK_END to the kernel header files. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-05VFS: Allow caller to determine if BSD or posix locks were actually freedTrond Myklebust
Change posix_lock_file_conf(), and flock_lock_file() so that if called with an F_UNLCK argument, and the FL_EXISTS flag they will indicate whether or not any locks were actually freed by returning 0 or -ENOENT. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-07-03[PATCH] lockdep: annotate blkdev nestingIngo Molnar
Teach special (recursive) locking code to the lock validator. Effects on non-lockdep kernels: - the introduction of the following function variants: extern struct block_device *open_partition_by_devnum(dev_t, unsigned); extern int blkdev_put_partition(struct block_device *); static int blkdev_get_whole(struct block_device *bdev, mode_t mode, unsigned flags); which on non-lockdep are the same as open_by_devnum(), blkdev_put() and blkdev_get(). - a subclass parameter to do_open(). [unused on non-lockdep] - a subclass parameter to __blkdev_put(), which is a new internal function for the main blkdev_put*() functions. [parameter unused on non-lockdep kernels, except for two sanity check WARN_ON()s] these functions carry no semantical difference - they only express object dependencies towards the lockdep subsystem. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate sb ->s_umountArjan van de Ven
The s_umount rwsem needs to be classified as per-superblock since it's perfectly legit to keep multiple of those recursively in the VFS locking rules. Has no effect on non-lockdep kernels. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate ->s_lockIngo Molnar
Teach special (per-filesystem) locking code to the lock validator. Minimal effect on non-lockdep kernels: one extra parameter to alloc_super(). Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate i_mutexIngo Molnar
Teach special (recursive) locking code to the lock validator. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: fs/nfs/inode.c fs/super.c Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch 'VFS: Permit filesystem to override root dentry on mount'
2006-06-23[PATCH] fs/locks.c: make posix_locks_deadlock() staticAdrian Bunk
We can now make posix_locks_deadlock() static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] vfs: add lock owner argument to flush operationMiklos Szeredi
Pass the POSIX lock owner ID to the flush operation. This is useful for filesystems which don't want to store any locking state in inode->i_flock but want to handle locking/unlocking POSIX locks internally. FUSE is one such filesystem but I think it possible that some network filesystems would need this also. Also add a flag to indicate that a POSIX locking request was generated by close(), so filesystems using the above feature won't send an extra locking request in this case. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] page migration cleanup: pass "mapping" to migration functionsChristoph Lameter
Change handling of address spaces. Pass a pointer to the address space in which the page is migrated to all migration function. This avoids repeatedly having to retrieve the address space pointer from the page and checking it for validity. The old page mapping will change once migration has gone to a certain step, so it is less confusing to have the pointer always available. Move the setting of the mapping and index for the new page into migrate_pages(). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] remove steal_locks()Miklos Szeredi
This patch removes the steal_locks() function. steal_locks() doesn't work correctly with any filesystem that does it's own lock management, including NFS, CIFS, etc. In addition it has weird semantics on local filesystems in case tasks sharing file-descriptor tables are doing POSIX locking operations in parallel to execve(). The steal_locks() function has an effect on applications doing: clone(CLONE_FILES) /* in child */ lock execve lock POSIX locks acquired before execve (by "child", "parent" or any further task sharing files_struct) will after the execve be owned exclusively by "child". According to Chris Wright some LSB/LTP kind of suite triggers without the stealing behavior, but there's no known real-world application that would also fail. Apps using NPTL are not affected, since all other threads are killed before execve. Apps using LinuxThreads are only affected if they - have multiple threads during exec (LinuxThreads doesn't kill other threads, the app may do it with pthread_kill_other_threads_np()) - rely on POSIX locks being inherited across exec Both conditions are documented, but not their interaction. Apps using clone() natively are affected if they - use clone(CLONE_FILES) - rely on POSIX locks being inherited across exec The above scenarios are unlikely, but possible. If the patch is vetoed, there's a plan B, that involves mostly keeping the weird stealing semantics, but changing the way lock ownership is handled so that network and local filesystems work consistently. That would add more complexity though, so this solution seems to be preferred by most people. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Matthew Wilcox <willy@debian.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: include/linux/nfs_fs.h Fixed up conflict with kernel header updates.
2006-06-09VFS: Remove dependency of ->umount_begin() call on MNT_FORCETrond Myklebust
Allow filesystems to decide to perform pre-umount processing whether or not MNT_FORCE is set. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09VFS: Unexport do_kern_mount() and clean up simple_pin_fs()Trond Myklebust
Replace all module uses with the new vfs_kern_mount() interface, and fix up simple_pin_fs(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-05-24Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: include/asm-powerpc/unistd.h include/asm-sparc/unistd.h include/asm-sparc64/unistd.h Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-23[PATCH] sys_sync_file_range(): move exported flags outside __KERNEL__Andrew Morton
These flags are needed by userspace - move them outside __KERNEL__ (Pointed out by dwmw2) Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
