path: root/include/linux/fs_struct.h
2008-02-14Make set_fs_{root,pwd} take a struct pathJan Blunck
In nearly all cases the set_fs_{root,pwd}() calls work on a struct path. Change the function to reflect this and use path_get() here. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Use struct path in fs_structJan Blunck
* Use struct path in fs_struct. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] Move fs_cachep to linux/fs_struct.hChristoph Lameter
fs_cachep is only used in kernel/exit.c and in kernel/fork.c. It is used to store fs_struct items so it should be placed in linux/fs_struct.h Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
