path: root/include/linux/fuse.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-07-18fuse: add missing INIT flag descriptionsMiklos Szeredi
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2012-07-18fuse: add missing INIT flagsMiklos Szeredi
Add missing flags that userspace derived from the protocol version number. This makes the protocol more flexible. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2012-07-18fuse: add FUSE_AUTO_INVAL_DATA init flagBrian Foster
FUSE_AUTO_INVAL_DATA is provided to enable updated/auto cache invalidation logic. Signed-off-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2012-04-25fuse: add FALLOCATE operationAnatol Pomozov
fallocate filesystem operation preallocates media space for the given file. If fallocate returns success then any subsequent write to the given range never fails with 'not enough space' error. Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2012-04-12fuse: use flexible array in fuse.hMiklos Szeredi
Use the ISO C standard compliant form instead of the gcc extension in the interface definition. Reported-by: Shachar Sharon <ssnail@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-12-13FUSE: Notifying the kernel of deletion.John Muir
Allows a FUSE file-system to tell the kernel when a file or directory is deleted. If the specified dentry has the specified inode number, the kernel will unhash it. The current 'fuse_notify_inval_entry' does not cause the kernel to clean up directories that are in use properly, and as a result the users of those directories see incorrect semantics from the file-system. The error condition seen when 'fuse_notify_inval_entry' is used to notify of a deleted directory is avoided when 'fuse_notify_delete' is used instead. The following scenario demonstrates the difference: 1. User A chdirs into 'testdir' and starts reading 'testfile'. 2. User B rm -rf 'testdir'. 3. User B creates 'testdir'. 4. User C chdirs into 'testdir'. If you run the above within the same machine on any file-system (including fuse file-systems), there is no problem: user C is able to chdir into the new testdir. The old testdir is removed from the dentry tree, but still open by user A. If operations 2 and 3 are performed via the network such that the fuse file-system uses one of the notify functions to tell the kernel that the nodes are gone, then the following error occurs for user C while user A holds the original directory open: muirj@empacher:~> ls /test/testdir ls: cannot access /test/testdir: No such file or directory The issue here is that the kernel still has a dentry for testdir, and so it is requesting the attributes for the old directory, while the file-system is responding that the directory no longer exists. If on the other hand, if the file-system can notify the kernel that the directory is deleted using the new 'fuse_notify_delete' function, then the above ls will find the new directory as expected. Signed-off-by: John Muir <john@jmuir.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-12-13fuse: support ioctl on directoriesMiklos Szeredi
Multiplexing filesystems may want to support ioctls on the underlying files and directores (e.g. FS_IOC_{GET,SET}FLAGS). Ioctl support on directories was missing so add it now. Reported-by: Antonio SJ Musumeci <bile@landofbile.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-08-08fuse: fix flockMiklos Szeredi
Commit a9ff4f87 "fuse: support BSD locking semantics" overlooked a number of issues with supporing flock locks over existing POSIX locking infrastructure: - it's not backward compatible, passing flock(2) calls to userspace unconditionally (if userspace sets FUSE_POSIX_LOCKS) - it doesn't cater for the fact that flock locks are automatically unlocked on file release - it doesn't take into account the fact that flock exclusive locks (write locks) don't need an fd opened for write. The last one invalidates the original premise of the patch that flock locks can be emulated with POSIX locks. This patch fixes the first two issues. The last one needs to be fixed in userspace if the filesystem assumed that a write lock will happen only on a file operned for write (as in the case of the current fuse library). Reported-by: Sebastian Pipping <webmaster@hartwork.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2010-12-07fuse: fix ioctl ABIMiklos Szeredi
In kernel ABI version 7.16 and later FUSE_IOCTL_RETRY reply from a unrestricted IOCTL request shall return with an array of 'struct fuse_ioctl_iovec' instead of 'struct iovec'. This fixes the ABI ambiguity of 32bit vs. 64bit. Reported-by: "ccmail111" <ccmail111@yahoo.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: Tejun Heo <tj@kernel.org>
2010-12-07fuse: allow batching of FORGET requestsMiklos Szeredi
Terje Malmedal reports that a fuse filesystem with 32 million inodes on a machine with lots of memory can take up to 30 minutes to process FORGET requests when all those inodes are evicted from the icache. To solve this, create a BATCH_FORGET request that allows up to about 8000 FORGET requests to be sent in a single message. This request is only sent if userspace supports interface version 7.16 or later, otherwise fall back to sending individual FORGET messages. Reported-by: Terje Malmedal <terje.malmedal@usit.uio.no> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2010-07-12fuse: add retrieve requestMiklos Szeredi
Userspace filesystem can request data to be retrieved from the inode's mapping. This request is synchronous and the retrieved data is queued as a new request. If the write to the fuse device returns an error then the retrieve request was not completed and a reply will not be sent. Only present pages are returned in the retrieve reply. Retrieving stops when it finds a non-present page and only data prior to that is returned. This request doesn't change the dirty state of pages. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2010-07-12fuse: add store requestMiklos Szeredi
Userspace filesystem can request data to be stored in the inode's mapping. This request is synchronous and has no reply. If the write to the fuse device returns an error then the store request was not fully completed (but may have updated some pages). If the stored data overflows the current file size, then the size is extended, similarly to a write(2) on the filesystem. Pages which have been completely stored are marked uptodate. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2010-05-25fuse: support splice() writing to fuse deviceMiklos Szeredi
Allow userspace filesystem implementation to use splice() to write to the fuse device. The semantics of using splice() are: 1) buffer the message header and data in a temporary pipe 2) with a *single* splice() call move the message from the temporary pipe to the fuse device The READ reply message has the most interesting use for this, since now the data from an arbitrary file descriptor (which could be a regular file, a block device or a socket) can be tranferred into the fuse device without having to go through a userspace buffer. It will also allow zero copy moving of pages. One caveat is that the protocol on the fuse device requires the length of the whole message to be written into the header. But the length of the data transferred into the temporary pipe may not be known in advance. The current library implementation works around this by using vmplice to write the header and modifying the header after splicing the data into the pipe (error handling omitted): struct fuse_out_header out; iov.iov_base = &out; iov.iov_len = sizeof(struct fuse_out_header); vmsplice(pip[1], &iov, 1, 0); len = splice(input_fd, input_offset, pip[1], NULL, len, 0); /* retrospectively modify the header: */ out.len = len + sizeof(struct fuse_out_header); splice(pip[0], NULL, fuse_chan_fd(req->ch), NULL, out.len, flags); This works since vmsplice only saves a pointer to the data, it does not copy the data itself. Since pipes are currently limited to 16 pages and messages need to be spliced atomically, the length of the data is limited to 15 pages (or 60kB for 4k pages). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2009-07-08fuse: document protocol version negotiationMiklos Szeredi
Clarify how the protocol version should be negotiated between kernel and userspace. Notably libfuse didn't correctly handle the case when the supported major versions didn't match. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2009-07-07fuse: make the number of max background requests and congestion threshold ↵Csaba Henk
tunable The practical values for these limits depend on the design of the filesystem server so let userspace set them at initialization time. Signed-off-by: Csaba Henk <csaba@gluster.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2009-06-30fuse: invalidation reverse callsJohn Muir
Add notification messages that allow the filesystem to invalidate VFS caches. Two notifications are added: 1) inode invalidation - invalidate cached attributes - invalidate a range of pages in the page cache (this is optional) 2) dentry invalidation - try to invalidate a subtree in the dentry cache Care must be taken while accessing the 'struct super_block' for the mount, as it can go away while an invalidation is in progress. To prevent this, introduce a rw-semaphore, that is taken for read during the invalidation and taken for write in the ->kill_sb callback. Cc: Csaba Henk <csaba@gluster.com> Cc: Anand Avati <avati@zresearch.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2009-06-30fuse: allow umask processing in userspaceMiklos Szeredi
This patch lets filesystems handle masking the file mode on creation. This is needed if filesystem is using ACLs. - The CREATE, MKDIR and MKNOD requests are extended with a "umask" parameter. - A new FUSE_DONT_MASK flag is added to the INIT request/reply. With this the filesystem may request that the create mode is not masked. CC: Jean-Pierre André <jean-pierre.andre@wanadoo.fr> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2009-06-09CUSE: implement CUSE - Character device in UserspaceTejun Heo
CUSE enables implementing character devices in userspace. With recent additions of ioctl and poll support, FUSE already has most of what's necessary to implement character devices. All CUSE has to do is bonding all those components - FUSE, chardev and the driver model - nicely. When client opens /dev/cuse, kernel starts conversation with CUSE_INIT. The client tells CUSE which device it wants to create. As the previous patch made fuse_file usable without associated fuse_inode, CUSE doesn't create super block or inodes. It attaches fuse_file to cdev file->private_data during open and set ff->fi to NULL. The rest of the operation is almost identical to FUSE direct IO case. Each CUSE device has a corresponding directory /sys/class/cuse/DEVNAME (which is symlink to /sys/devices/virtual/class/DEVNAME if SYSFS_DEPRECATED is turned off) which hosts "waiting" and "abort" among other things. Those two files have the same meaning as the FUSE control files. The only notable lacking feature compared to in-kernel implementation is mmap support. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-12-01fuse: update interface versionMiklos Szeredi
Change interface version to 7.11 after adding the IOCTL and POLL messages. Also clean up the <linux/fuse.h> header a bit: - update copyright date to 2008 - fix checkpatch warning: WARNING: Use #include <linux/types.h> instead of <asm/types.h> - remove FUSE_MAJOR define, which is not being used any more Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-11-26fuse: implement poll supportTejun Heo
Implement poll support. Polled files are indexed using kh in a RB tree rooted at fuse_conn->polled_files. Client should send FUSE_NOTIFY_POLL notification once after processing FUSE_POLL which has FUSE_POLL_SCHEDULE_NOTIFY set. Sending notification unconditionally after the latest poll or everytime file content might have changed is inefficient but won't cause malfunction. fuse_file_poll() can sleep and requires patches from the following thread which allows f_op->poll() to sleep. http://thread.gmane.org/gmane.linux.kernel/726176 Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-11-26fuse: implement unsolicited notificationTejun Heo
Clients always used to write only in response to read requests. To implement poll efficiently, clients should be able to issue unsolicited notifications. This patch implements basic notification support. Zero fuse_out_header.unique is now accepted and considered unsolicited notification and the error field contains notification code. This patch doesn't implement any actual notification. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-11-26fuse: implement ioctl supportTejun Heo
Generic ioctl support is tricky to implement because only the ioctl implementation itself knows which memory regions need to be read and/or written. To support this, fuse client can request retry of ioctl specifying memory regions to read and write. Deep copying (nested pointers) can be implemented by retrying multiple times resolving one depth of dereference at a time. For security and cleanliness considerations, ioctl implementation has restricted mode where the kernel determines data transfer directions and sizes using the _IOC_*() macros on the ioctl command. In this mode, retry is not allowed. For all FUSE servers, restricted mode is enforced. Unrestricted ioctl will be used by CUSE. Plese read the comment on top of fs/fuse/file.c::fuse_file_do_ioctl() for more information. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-11-26fuse: move FUSE_MINOR to miscdevice.hTejun Heo
Move FUSE_MINOR to miscdevice.h. While at it, de-uglify the file. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-10-16fuse: implement nonseekable openTejun Heo
Let the client request nonseekable open using FOPEN_NONSEEKABLE and call nonseekable_open() on the file if requested. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-10-16fuse: add include protectorsTejun Heo
Add include protectors to include/linux/fuse.h and fs/fuse/fuse_i.h. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-07-25fuse: nfs export special lookupsMiklos Szeredi
Implement the get_parent export operation by sending a LOOKUP request with ".." as the name. Implement looking up an inode by node ID after it has been evicted from the cache. This is done by seding a LOOKUP request with "." as the name (for all file types, not just directories). The filesystem can set the FUSE_EXPORT_SUPPORT flag in the INIT reply, to indicate that it supports these special lookups. Thanks to John Muir for the original implementation of this feature. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13fuse: add flag to turn on big writesMiklos Szeredi
Prior to 2.6.26 fuse only supported single page write requests. In theory all fuse filesystem should be able support bigger than 4k writes, as there's nothing in the API to prevent it. Unfortunately there's a known case in NTFS-3G where big writes cause filesystem corruption. There could also be other filesystems, where the lack of testing with big write requests would result in bugs. To prevent such problems on a kernel upgrade, disable big writes by default, but let filesystems set a flag to turn it on. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Szabolcs Szakacsits <szaka@ntfs-3g.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29fuse: pass open flags to read and writeMiklos Szeredi
Some open flags (O_APPEND, O_DIRECT) can be changed with fcntl(F_SETFL, ...) after open, but fuse currently only sends the flags to userspace in open. To make it possible to correcly handle changing flags, send the current value to userspace in each read and write. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18fuse: add blksize field to fuse_attrMiklos Szeredi
There are cases when the filesystem will be passed the buffer from a single read or write call, namely: 1) in 'direct-io' mode (not O_DIRECT), read/write requests don't go through the page cache, but go directly to the userspace fs 2) currently buffered writes are done with single page requests, but if Nick's ->perform_write() patch goes it, it will be possible to do larger write requests. But only if the original write() was also bigger than a page. In these cases the filesystem might want to give a hint to the app about the optimal I/O size. Allow the userspace filesystem to supply a blksize value to be returned by stat() and friends. If the field is zero, it defaults to the old PAGE_CACHE_SIZE value. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18fuse: add support for mandatory lockingMiklos Szeredi
For mandatory locking the userspace filesystem needs to know the lock ownership for read, write and truncate operations. This patch adds the necessary fields to the protocol. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18fuse: add helper for asynchronous writesMiklos Szeredi
This patch adds a new helper function fuse_write_fill() which makes it possible to send WRITE requests asynchronously. A new flag for WRITE requests is also added which indicates that this a write from the page cache, and not a "normal" file write. This patch is in preparation for writable mmap support. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18fuse: support BSD locking semanticsMiklos Szeredi
It is trivial to add support for flock(2) semantics to the existing protocol, by setting the lock owner field to the file pointer, and passing a new FUSE_LK_FLOCK flag with the locking request. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18fuse: add atomic open+truncate supportMiklos Szeredi
This patch allows fuse filesystems to implement open(..., O_TRUNC) as a single request, instead of separate truncate and open requests. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18fuse: improve utimes supportMiklos Szeredi
Add two new flags for setattr: FATTR_ATIME_NOW and FATTR_MTIME_NOW. These mean, that atime or mtime should be changed to the current time. Also it is now possible to update atime or mtime individually, not just together. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18fuse: add file handle to getattr operationMiklos Szeredi
Add necessary protocol changes for supplying a file handle with the getattr operation. Step the API version to 7.9. This patch doesn't actually supply the file handle, because that needs some kind of VFS support, which we haven't yet been able to agree upon. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fuse warning fixAndrew Morton
gcc-4.3: fs/fuse/dir.c: In function 'parse_dirfile': fs/fuse/dir.c:833: warning: cast from pointer to integer of different size fs/fuse/dir.c:835: warning: cast from pointer to integer of different size [miklos@szeredi.hu: use offsetof] Acked-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] fuse: add DESTROY operationMiklos Szeredi
Add a DESTROY operation for block device based filesystems. With the help of this operation, such a filesystem can flush dirty data to the device synchronously before the umount returns. This is needed in situations where the filesystem is assumed to be clean immediately after unmount (e.g. ejecting removable media). Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] fuse: add bmap supportMiklos Szeredi
Add support for the BMAP operation for block device based filesystems. This is needed to support swap-files and lilo. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] fuse: update userspace interface to version 7.8Miklos Szeredi
Add a flag to the RELEASE message which specifies that a FLUSH operation should be performed as well. This interface update is needed for the FreeBSD port, and doesn't actually touch the Linux implementation at all. Also rename the unused 'flush_flags' in the FLUSH message to 'unused'. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fuse: add request interruptionMiklos Szeredi
Add synchronous request interruption. This is needed for file locking operations which have to be interruptible. However filesystem may implement interruptibility of other operations (e.g. like NFS 'intr' mount option). Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fuse: add POSIX file locking supportMiklos Szeredi
This patch adds POSIX file locking support to the fuse interface. This implementation doesn't keep any locking state in kernel. Unlocking on close() is handled by the FLUSH message, which now contains the lock owner id. Mandatory locking is not supported. The filesystem may enfoce mandatory locking in userspace if needed. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fuse: use MISC_MAJORJan Engelhardt
The following patches add POSIX file locking to the fuse interface. Additional changes ralated to this are: - asynchronous interrupt of requests by SIGKILL no longer supported - separate control filesystem, instead of using sysfs objects - add support for synchronously interrupting requests Details are documented in Documentation/filesystems/fuse.txt throughout the patches. This patch: Have fuse.h use MISC_MAJOR rather than a hardcoded '10'. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] fuse: fix async read for legacy filesystemsMiklos Szeredi
While asynchronous reads mean a performance improvement in most cases, if the filesystem assumed that reads are synchronous, then async reads may degrade performance (filesystem may receive reads out of order, which can confuse it's own readahead logic). With sshfs a 1.5 to 4 times slowdown can be measured. There's also a need for userspace filesystems to know whether asynchronous reads are supported by the kernel or not. To achive these, negotiate in the INIT request whether async reads will be used and the maximum readahead value. Update interface version to 7.6 If userspace uses a version earlier than 7.6, then disable async reads, and set maximum readahead value to the maximum read size, as done in previous versions. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] fuse: make maximum write data configurableMiklos Szeredi
Make the maximum size of write data configurable by the filesystem. The previous fixed 4096 limit only worked on architectures where the page size is less or equal to this. This change make writing work on other architectures too, and also lets the filesystem receive bigger write requests in direct_io mode. Normal writes which go through the page cache are still limited to a page sized chunk per request. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] fuse: clean up request size limit checkingMiklos Szeredi
Change the way a too large request is handled. Until now in this case the device read returned -EINVAL and the operation returned -EIO. Make it more flexibible by not returning -EINVAL from the read, but restarting it instead. Also remove the fixed limit on setxattr data and let the filesystem provide as large a read buffer as it needs to handle the extended attribute data. The symbolic link length is already checked by VFS to be less than PATH_MAX, so the extra check against FUSE_SYMLINK_MAX is not needed. The check in fuse_create_open() against FUSE_NAME_MAX is not needed, since the dentry has already been looked up, and hence the name already checked. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] fuse: add frsize to statfs replyMiklos Szeredi
Add 'frsize' member to the statfs reply. I'm not sure if sending f_fsid will ever be needed, but just in case leave some space at the end of the structure, so less compatibility mess would be required. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] fuse: bump interface versionMiklos Szeredi
Change interface version to 7.4. Following changes will need backward compatibility support, so store the minor version returned by userspace. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] FUSE: pass file handle in setattrMiklos Szeredi
This patch passes the file handle supplied in iattr to userspace, in case the ->setattr() was invoked from sys_ftruncate(). This solves the permission checking (or lack thereof) in ftruncate() for the class of filesystems served by an unprivileged userspace process. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] FUSE: atomic create+openMiklos Szeredi
This patch adds an atomic create+open operation. This does not yet work if the file type changes between lookup and create+open, but solves the permission checking problems for the separte create and open methods. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
