path: root/include/linux/genhd.h
2006-03-27[PATCH] dm-md-dependency-tree-in-sysfs-holders-slaves-subdirectory-tidyAndrew Morton
Remove all the CONFIG_SYSFS stuff. That's supposed to all be implemented up in header files. Yes, the CONFIG_SYSFS=n data structures will be a little larger than necessary, but that's a tradeoff we can decide to make. Cc: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm/md dependency tree in sysfs: holders/slaves subdirectoryJun'ichi Nomura
Creating "slaves" and "holders" directories in /sys/block/<disk> and creating "holders" directory under /sys/block/<disk>/<partition> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[BLOCK] increase size of disk stat countersBen Woodard
The kernel's representation of the disk statistics uses the type unsigned which is 32b on both 32b and 64b platforms. Unfortunately, most system tools that work with these numbers that are exported in /proc/diskstats including iostat read these numbers into unsigned longs. This works fine on 32b platforms and when the number of IO transactions are small on 64b platforms. However, when the numbers wrap on 64b platforms & you read the numbers into unsigned longs, and compare the numbers to previous readings, then you get an unsigned representation of a negative number. This looks like a very large 64b number & gives you bizarre readouts in iostat: ilc4: Device: rrqm/s wrqm/s r/s w/s rsec/s wsec/s rkB/s wkB/s avgrq-sz avgqu-sz await svctm %util ilc4: sda 5.50 0.00 143.96 0.00 307496983987862656.00 0.00 153748491993931328.00 0.00 2136028725038430.00 7.94 55.12 5.59 80.42 Though fixing iostat in user space is possible, and a quick survey indicates that several other similar tools also use unsigned longs when processing /proc/diskstats. Therefore, it seems like a better approach would be to extend the length of the disk_stats structure on 64b architectures to 64b. The following patch does that. It should not affect the operation on 32b platforms. Signed-off-by: Ben Woodard <woodard@redhat.com> Cc: Rick Lindsley <ricklind@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-12[BLOCK] Document the READ/WRITE splitup of the disk statsJens Axboe
Use the symbolic name where appropriate and add a comment to the disk_stats structure. Signed-off-by: Jens Axboe <axboe@suse.de>
2005-11-01[BLOCK] Unify the seperate read/write io stat fields into arraysJens Axboe
Instead of having ->read_sectors and ->write_sectors, combine the two into ->sectors[2] and similar for the other fields. This saves a branch several places in the io path, since we don't have to care for what the actual io direction is. On my x86-64 box, that's 200 bytes less text in just the core (not counting the various drivers). Signed-off-by: Jens Axboe <axboe@suse.de>
2005-10-28Merge ../bleed-2.6Greg KH
2005-10-28[PATCH] add sysfs attr to re-emit device hotplug eventKay Sievers
A "coldplug + udevstart" can be simple like this: for i in /sys/block/*/*/uevent; do echo 1 > $i; done for i in /sys/class/*/*/uevent; do echo 1 > $i; done for i in /sys/bus/*/devices/*/uevent; do echo 1 > $i; done Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[patch] remove gendisk->stamp_idle fieldChen, Kenneth W
struct gendisk has these two fields: stamp, stamp_idle. Update to stamp_idle is always in sync with stamp and they are always the same. Therefore, it does not add any value in having two fields tracking same timestamp. Suggest to remove it. Also, we should only update gendisk stats with non-zero value. Advantage is that we don't have to needlessly calculate memory address, and then add zero to the content. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-06-23[PATCH] add check to /proc/devices read routinesNeil Horman
Patch to add check to get_chrdev_list and get_blkdev_list to prevent reads of /proc/devices from spilling over the provided page if more than 4096 bytes of string data are generated from all the registered character and block devices in a system Signed-off-by: Neil Horman <nhorman@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] NUMA aware block device control structure allocationChristoph Lameter
Patch to allocate the control structures for for ide devices on the node of the device itself (for NUMA systems). The patch depends on the Slab API change patch by Manfred and me (in mm) and the pcidev_to_node patch that I posted today. Does some realignment too. Signed-off-by: Justin M. Forbes <jmforbes@linuxtx.org> Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Pravin Shelar <pravin@calsoftinc.com> Signed-off-by: Shobhit Dayal <shobhit@calsoftinc.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
