path: root/include/linux/hpet.h
2008-04-04x86: revert assign IRQs to hpet timerThomas Gleixner
The commits: commit 37a47db8d7f0f38dac5acf5a13abbc8f401707fa Author: Balaji Rao <balajirrao@gmail.com> Date: Wed Jan 30 13:30:03 2008 +0100 x86: assign IRQs to HPET timers, fix and commit e3f37a54f690d3e64995ea7ecea08c5ab3070faf Author: Balaji Rao <balajirrao@gmail.com> Date: Wed Jan 30 13:30:03 2008 +0100 x86: assign IRQs to HPET timers have been identified to cause a regression on some platforms due to the assignement of legacy IRQs which makes the legacy devices connected to those IRQs disfunctional. Revert them. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=10382 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: nuke a ton of dead hpet codeThomas Gleixner
No users, just ballast Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: assign IRQs to HPET timersBalaji Rao
The userspace API for the HPET (see Documentation/hpet.txt) did not work. The HPET_IE_ON ioctl was failing as there was no IRQ assigned to the timer device. This patch fixes it by allocating IRQs to timer blocks in the HPET. arch/x86/kernel/hpet.c | 13 +++++-------- drivers/char/hpet.c | 45 ++++++++++++++++++++++++++++++++++++++------- include/linux/hpet.h | 2 +- 3 files changed, 44 insertions(+), 16 deletions(-) Signed-off-by: Balaji Rao <balajirrao@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-03-26[PATCH] hpet header sanitizationRandy Dunlap
Add __KERNEL__ block. Use __KERNEL__ to allow ioctl interface to be usable. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
