path: root/include/linux/htirq.h
2015-04-24x86/htirq: Use hierarchical irqdomain to manage Hypertransport interruptsJiang Liu
We have slightly changed the architecture interfaces to support htirq PCI driver. It's safe because currently Hypertransport interrupt is only enabled on x86 platforms. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Cohen <david.a.cohen@linux.intel.com> Cc: Sander Eikelenboom <linux@eikelenboom.it> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dimitri Sivanich <sivanich@sgi.com> Link: http://lkml.kernel.org/r/1428905519-23704-22-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-24x86/htirq: Use new irqdomain interfaces to allocate/free IRQJiang Liu
Use new irqdomain interfaces to allocate/free IRQ for HTIRQ, so we can remove GENERIC_IRQ_LEGACY_ALLOC_HWIRQ later. This patch changes the interfaces between arch independent PCI driver and arch specific code. Currently HT_IRQ is only enabled on x86, so it does not affect other architectures. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Cohen <david.a.cohen@linux.intel.com> Cc: Sander Eikelenboom <linux@eikelenboom.it> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dimitri Sivanich <sivanich@sgi.com> Link: http://lkml.kernel.org/r/1428905519-23704-7-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-10-12ht: Convert to new irq_chip functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Ingo Molnar <mingo@elte.hu> Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
2006-11-08[PATCH] htirq: allow buggy drivers of buggy hardware to write the registersEric W. Biederman
This patch adds a variant of ht_create_irq __ht_create_irq that takes an aditional parameter update that is a function that is called whenever we want to write to a drivers htirq configuration registers. This is needed to support the ipath_iba6110 because it's registers in the proper location are not actually conected to the hardware that controlls interrupt delivery. [bos@serpentine.com: fixes] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Cc: <olson@pathscale.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Bryan O'Sullivan <bryan.osullivan@qlogic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] htirq: refactor so we only have one function that writes to the chipEric W. Biederman
This refactoring actually optimizes the code a little by caching the value that we think the device is programmed with instead of reading it back from the hardware. Which simplifies the code a little and should speed things up a bit. This patch introduces the concept of a ht_irq_msg and modifies the architecture read/write routines to update this code. There is a minor consistency fix here as well as x86_64 forgot to initialize the htirq as masked. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <ak@suse.de> Acked-by: Bryan O'Sullivan <bos@pathscale.com> Cc: <olson@pathscale.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] htirq: tidy up the htirq codeEric W. Biederman
This moves the declarations for the architecture helpers into include/linux/htirq.h from the generic include/linux/pci.h. Hopefully this will make this distinction clearer. htirq.h is included where it is needed. The dependency on the msi code is fixed and removed. The Makefile is tidied up. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tony Luck <tony.luck@intel.com> Cc: Andi Kleen <ak@suse.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Greg KH <greg@kroah.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
