commit ba50bf1ce9a51fc97db58b96d01306aa70bc3979 upstream.
fc96df16a1ce is good and can already fix the "return stack garbage" issue,
but let's also improve hv_ringbuffer_get_debuginfo(), which would silently
return stack garbage, if people forget to check channel->state or
ring_info->ring_buffer, when using the function in the future.
Having an error check in the function would eliminate the potential risk.
Add a Fixes tag to indicate the patch depdendency.
Fixes: fc96df16a1ce ("Drivers: hv: vmbus: Return -EINVAL for the sys files for unopened channels")
Cc: stable@vger.kernel.org
Cc: K. Y. Srinivasan <kys@microsoft.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
Signed-off-by: Dexuan Cui <decui@microsoft.com>
commit 37c2578c0c40e286bc0d30bdc05290b2058cf66e upstream.
vmbus_process_offer() mustn't call channel->sc_creation_callback()
directly for sub-channels, because sc_creation_callback() ->
vmbus_open() may never get the host's response to the
OPEN_CHANNEL message (the host may rescind a channel at any time,
e.g. in the case of hot removing a NIC), and vmbus_onoffer_rescind()
may not wake up the vmbus_open() as it's blocked due to a non-zero
vmbus_connection.offer_in_progress, and finally we have a deadlock.
The above is also true for primary channels, if the related device
drivers use sync probing mode by default.
And, usually the handling of primary channels and sub-channels can
depend on each other, so we should offload them to different
workqueues to avoid possible deadlock, e.g. in sync-probing mode,
NIC1's netvsc_subchan_work() can race with NIC2's netvsc_probe() ->
rtnl_lock(), and causes deadlock: the former gets the rtnl_lock
and waits for all the sub-channels to appear, but the latter
can't get the rtnl_lock and this blocks the handling of sub-channels.
The patch can fix the multiple-NIC deadlock described above for
v3.x kernels (e.g. RHEL 7.x) which don't support async-probing
of devices, and v4.4, v4.9, v4.14 and v4.18 which support async-probing
but don't enable async-probing for Hyper-V drivers (yet).
The patch can also fix the hang issue in sub-channel's handling described
above for all versions of kernels, including v4.19 and v4.20-rc4.
So actually the patch should be applied to all the existing kernels,
not only the kernels that have 8195b1396ec8.
Fixes: 8195b1396ec8 ("hv_netvsc: fix deadlock on hotplug")
Cc: Stephen Hemminger <sthemmin@microsoft.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit d3b26dd7cb0e3433bfd3c1d4dcf74c6039bb49fb upstream.
Before setting channel->rescind in vmbus_rescind_cleanup(), we should make
sure the channel callback won't run any more, otherwise a high-level
driver like pci_hyperv, which may be infinitely waiting for the host VSP's
response and notices the channel has been rescinded, can't safely give
up: e.g., in hv_pci_protocol_negotiation() -> wait_for_response(), it's
unsafe to exit from wait_for_response() and proceed with the on-stack
variable "comp_pkt" popped. The issue was originally spotted by
Michael Kelley <mikelley@microsoft.com>.
In vmbus_close_internal(), the patch also minimizes the range protected by
disabling/enabling channel->callback_event: we don't really need that for
the whole function.
Reviewed-by: Michael Kelley <mikelley@microsoft.com>
Cc: Michael Kelley <mikelley@microsoft.com>
commit 7fa32e5ec28b1609abc0b797b58267f725fc3964 upstream.
The current rescind processing code will not correctly handle
the case where the host immediately rescinds a channel that has
been offerred. In this case, we could be blocked in the open call and
since the channel is rescinded, the host will not respond and we could
be blocked forever in the vmbus open call.i Fix this problem.
This patch addresses the following bugs in the current rescind handling code:
1. Fixes a race condition where we may be invoking hv_process_channel_removal()
on an already freed channel.
2. Prevents indefinite wait when rescinding sub-channels by correctly setting
the probe_complete state.
I would like to thank Dexuan for patiently reviewing earlier versions of this
patch and identifying many of the issues fixed here.
Greg, please apply this to 4.14-final.
Fixes: '54a66265d675 ("Drivers: hv: vmbus: Fix rescind handling")'
Reviewed-by: Dexuan Cui <decui@microsoft.com>
Cc: stable@vger.kernel.org # (4.13 and above)
Pull x86 platform updates from Ingo Molnar:
"The main changes include various Hyper-V optimizations such as faster
hypercalls and faster/better TLB flushes - and there's also some
Intel-MID cleanups"
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tracing/hyper-v: Trace hyperv_mmu_flush_tlb_others()
x86/hyper-v: Support extended CPU ranges for TLB flush hypercalls
x86/platform/intel-mid: Make several arrays static, to make code smaller
MAINTAINERS: Add missed file for Hyper-V
x86/hyper-v: Use hypercall for remote TLB flush
hyper-v: Globalize vp_index
x86/hyper-v: Implement rep hypercalls
hyper-v: Use fast hypercall for HVCALL_SIGNAL_EVENT
x86/hyper-v: Introduce fast hypercall implementation
x86/hyper-v: Make hv_do_hypercall() inline
x86/hyper-v: Include hyperv/ only when CONFIG_HYPERV is set
x86/platform/intel-mid: Make 'bt_sfi_data' const
x86/platform/intel-mid: Make IRQ allocation a bit more flexible
x86/platform/intel-mid: Group timers callbacks together
Pull networking updates from David Miller:
1) Support ipv6 checksum offload in sunvnet driver, from Shannon
Nelson.
2) Move to RB-tree instead of custom AVL code in inetpeer, from Eric
Dumazet.
3) Allow generic XDP to work on virtual devices, from John Fastabend.
4) Add bpf device maps and XDP_REDIRECT, which can be used to build
arbitrary switching frameworks using XDP. From John Fastabend.
5) Remove UFO offloads from the tree, gave us little other than bugs.
6) Remove the IPSEC flow cache, from Florian Westphal.
7) Support ipv6 route offload in mlxsw driver.
8) Support VF representors in bnxt_en, from Sathya Perla.
9) Add support for forward error correction modes to ethtool, from
Vidya Sagar Ravipati.
10) Add time filter for packet scheduler action dumping, from Jamal Hadi
Salim.
11) Extend the zerocopy sendmsg() used by virtio and tap to regular
sockets via MSG_ZEROCOPY. From Willem de Bruijn.
12) Significantly rework value tracking in the BPF verifier, from Edward
Cree.
13) Add new jump instructions to eBPF, from Daniel Borkmann.
14) Rework rtnetlink plumbing so that operations can be run without
taking the RTNL semaphore. From Florian Westphal.
15) Support XDP in tap driver, from Jason Wang.
16) Add 32-bit eBPF JIT for ARM, from Shubham Bansal.
17) Add Huawei hinic ethernet driver.
18) Allow to report MD5 keys in TCP inet_diag dumps, from Ivan
Delalande.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1780 commits)
i40e: point wb_desc at the nvm_wb_desc during i40e_read_nvm_aq
i40e: avoid NVM acquire deadlock during NVM update
drivers: net: xgene: Remove return statement from void function
drivers: net: xgene: Configure tx/rx delay for ACPI
drivers: net: xgene: Read tx/rx delay for ACPI
rocker: fix kcalloc parameter order
rds: Fix non-atomic operation on shared flag variable
net: sched: don't use GFP_KERNEL under spin lock
vhost_net: correctly check tx avail during rx busy polling
net: mdio-mux: add mdio_mux parameter to mdio_mux_init()
rxrpc: Make service connection lookup always check for retry
net: stmmac: Delete dead code for MDIO registration
gianfar: Fix Tx flow control deactivation
cxgb4: Ignore MPS_TX_INT_CAUSE[Bubble] for T6
cxgb4: Fix pause frame count in t4_get_port_stats
cxgb4: fix memory leak
tun: rename generic_xdp to skb_xdp
tun: reserve extra headroom only when XDP is set
net: dsa: bcm_sf2: Configure IMP port TC2QOS mapping
net: dsa: bcm_sf2: Advertise number of egress queues
The only usage of vmbus_sendpacket_ctl was by vmbus_sendpacket.
The function vmbus_sendpacket_pagebuffer_ctl was never used directly.
Just have vmbus_send_pagebuffer
This function is not used anywhere in current code.
This patch handles the following issues that were observed when we are
handling racing channel offer message and rescind message for the same
offer:
1. Since the host does not respond to messages on a rescinded channel,
in the current code, we could be indefinitely blocked on the vmbus_open() call.
2. When a rescinded channel is being closed, if there is a pending interrupt on the
channel, we could end up freeing the channel that the interrupt handler would run on.
Tested-by: Dexuan Cui <decui@microsoft.com>
To support implementing remote TLB flushing on Hyper-V with a hypercall
we need to make vp_index available outside of vmbus module. Rename and
globalize.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Reviewed-by: Stephen Hemminger <sthemmin@microsoft.com>
Cc: Jork Loeser <Jork.Loeser@microsoft.com>
Cc: Simon Xiao <sixiao@microsoft.com>
Cc: devel@linuxdriverproject.org
Link: http://lkml.kernel.org/r/20170802160921.21791-7-vkuznets@redhat.com
We need to pass only 8 bytes of input for HvSignalEvent which makes it a
perfect fit for fast hypercall. hv_input_signal_event_buffer is not needed
any more and hv_input_signal_event is converted to union for convenience.
Link: http://lkml.kernel.org/r/20170802160921.21791-5-vkuznets@redhat.com
We have only three call sites for hv_do_hypercall() and we're going to
change HVCALL_SIGNAL_EVENT to doing fast hypercall so we can inline this
function for optimization.
Hyper-V top level functional specification states that r9-r11 registers
and flags may be clobbered by the hypervisor during hypercall and with
inlining this is somewhat important, add the clobbers.
Link: http://lkml.kernel.org/r/20170802160921.21791-3-vkuznets@redhat.com
Don't need cached read index anymore now that packet iterator
is used. The iterator has the original read index until the
visible read_index is updated.
The function hv_signal_on_read was defined in hyperv.h and
only used in one place in ring_buffer code. Clearer to just
move it inline there.
The elements ring_data_start_offset and priv_write_index
are not used.
In storvsc driver, inbound messages do not go through inbound lock. The
only effect of this lock was is to provide a barrier for connect and
remove logic.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here is the big set of new char/misc driver drivers and features for
4.12-rc1.
There's lots of new drivers added this time around, new firmware
drivers from Google, more auxdisplay drivers, extcon drivers, fpga
drivers, and a bunch of other driver updates. Nothing major, except if
you happen to have the hardware for these drivers, and then you will
be happy :)
All of these have been in linux-next for a while with no reported
issues"
* tag 'char-misc-4.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (136 commits)
firmware: google memconsole: Fix return value check in platform_memconsole_init()
firmware: Google VPD: Fix return value check in vpd_platform_init()
goldfish_pipe: fix build warning about using too much stack.
goldfish_pipe: An implementation of more parallel pipe
fpga fr br: update supported version numbers
fpga: region: release FPGA region reference in error path
fpga altera-hps2fpga: disable/unprepare clock on error in alt_fpga_bridge_probe()
mei: drop the TODO from samples
firmware: Google VPD sysfs driver
firmware: Google VPD: import lib_vpd source files
misc: lkdtm: Add volatile to intentional NULL pointer reference
eeprom: idt_89hpesx: Add OF device ID table
misc: ds1682: Add OF device ID table
misc: tsl2550: Add OF device ID table
w1: Remove unneeded use of assert() and remove w1_log.h
w1: Use kernel common min() implementation
uio_mf624: Align memory regions to page size and set correct offsets
uio_mf624: Refactor memory info initialization
uio: Allow handling of non page-aligned memory regions
hangcheck-timer: Fix typo in comment
Mostly simple cases of overlapping changes (adding code nearby,
a function whose name changes, for example).
We want the char-misc fixes in here as well.
Allow driver to get debug information about state of the ring.
Minor changes to align hyper-v vmbus include files with current
linux kernel style.
No need for empty return at end of void function
With the recent introduction of per-channel tasklet, we need to update
the way we handle the 3 concurrency issues:
1. hv_process_channel_removal -> percpu_channel_deq vs.
vmbus_chan_sched -> list_for_each_entry(..., percpu_list);
2. vmbus_process_offer -> percpu_channel_enq/deq vs. vmbus_chan_sched.
3. vmbus_close_internal vs. the per-channel tasklet vmbus_on_event;
The first 2 issues can be handled by Stephen's recent patch
"vmbus: use rcu for per-cpu channel list", and the third issue
can be handled by calling tasklet_disable in vmbus_close_internal here.
We don't need the original hv_event_tasklet_disable/enable since we
now use per-channel tasklet instead of the previous per-CPU tasklet,
and actually we must remove them due to the side effect now:
vmbus_process_offer -> hv_event_tasklet_enable -> tasklet_schedule will
start the per-channel callback prematurely, cauing NULL dereferencing
(the channel may haven't been properly configured to run the callback yet).
Fixes: 631e63a9f346 ("vmbus: change to per channel tasklet")
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Tested-by: Vitaly Kuznetsov <vkuznets@redhat.com>
The per-cpu channel list is now referred to in the interrupt
routine. This is mostly safe since the host will not normally generate
an interrupt when channel is being deleted but if it did then there
would be a use after free problem.
To solve, this use RCU protection on ther per-cpu list.
This is mostly just a refactoring of previous functions
(get_pkt_next_raw, put_pkt_raw and commit_rd_index) to make it easier
to use for other drivers and NAPI.
Functions that just query state of ring buffer can have parameters
marked const.
In order to implement NAPI in netvsc, the driver needs access to
control host interrupt mask.
All current usage of vmbus write uses the acquire_lock flag, therefore
having it be optional is unnecessary. This also fixes a sparse warning
since sparse doesn't like when a function has conditional locking.
Change the simple boolean batched_reading into a tri-value.
For future NAPI support in netvsc driver, the callback needs to
occur directly in interrupt handler.
Batched mode is also changed to disable host interrupts immediately
in interrupt routine (to avoid unnecessary host signals), and the
tasklet is rescheduled if more data is detected.
Make the event handling tasklet per channel rather than per-cpu.
This allows for better fairness when getting lots of data on the same
cpu.
The callback is done via tasklet not workqueue.
Since sendpacket no longer uses kickq argument remove it.
Remove it no longer used xmit_more in sendpacket in netvsc as well.
The explicit signal policy is no longer used. A different mechanism
will be added later when xmit_more is supported.
We want the hv and other fixes in here as well to handle merge and
testing issues.
Previously, we were assuming that each IC protocol version was tied to a
specific host version. For example, some Windows 10 preview hosts only
support v3 TimeSync even though driver assumes v4 is supported by all
Windows 10 hosts.
The guest will stop trying to negotiate even though older supported
versions may still be offered by the host.
Make IC version negotiation more robust by going through all versions
that are supported by the guest.
Fixes: 3da0401b4d0e ("Drivers: hv: utils: Fix the mapping between host
version and protocol to use")
Reported-by: Rolf Neugebauer <rolf.neugebauer@docker.com>
Signed-off-by: Alex Ng <alexng@messages.microsoft.com>
Commit a389fcfd2cb5 ("Drivers: hv: vmbus: Fix signaling logic in
hv_need_to_signal_on_read()")
added the proper mb(), but removed the test "prev_write_sz < pending_sz"
when making the signal decision.
As a result, the guest can signal the host unnecessarily,
and then the host can throttle the guest because the host
thinks the guest is buggy or malicious; finally the user
running stress test can perceive intermittent freeze of
the guest.
This patch brings back the test, and properly handles the
in-place consumption APIs used by NetVSC (see get_next_pkt_raw(),
put_pkt_raw() and commit_rd_index()).
Fixes: a389fcfd2cb5 ("Drivers: hv: vmbus: Fix signaling logic in
Tested-by: Rolf Neugebauer <rolf.neugebauer@docker.com>
Cc: <stable@vger.kernel.org>
The host can rescind a channel that has been offered to the
guest and once the channel is rescinded, the host does not
respond to any requests on that channel. Deal with the case where
the guest may be blocked waiting for a response from the host.
This patch adds sysfs interface to dynamically bind new UUID values
to existing VMBus device. This is useful for generic UIO driver to
act similar to uio_pci_generic.
Changed it to HV_UNKNOWN
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
We want those fixes in here as well.
Signal the host when we determine the host is to be signaled -
on th read path. The currrent code determines the need to signal in the
ringbuffer code and actually issues the signal elsewhere. This can result
in the host viewing this interrupt as spurious since the host may also
poll the channel. Make the necessary adjustments.
Signal the host when we determine the host is to be signaled.
The currrent code determines the need to signal in the ringbuffer
get_next_pkt_raw() (v2)
With wrap around mappings in place we can always provide drivers with
direct links to packets on the ring buffer, even when they wrap around.
Do the required updates to get_next_pkt_raw()/put_pkt_raw()
The first version of this commit was reverted (65a532f3d50a) to deal with
cross-tree merge issues which are (hopefully) resolved now.
This reverts commit e3f74b841d48
("hv_netvsc: report vmbus name in ethtool")'
because of problem introduced by commit f9a56e5d6a0ba
("Drivers: hv: make VMBus bus ids persistent").
This changed the format of the vmbus name and this new format is too
long to fit in the bus_info field of ethtool.
1) BBR TCP congestion control, from Neal Cardwell, Yuchung Cheng and
co. at Google. https://lwn.net/Articles/701165/
2) Do TCP Small Queues for retransmits, from Eric Dumazet.
3) Support collect_md mode for all IPV4 and IPV6 tunnels, from Alexei
Starovoitov.
4) Allow cls_flower to classify packets in ip tunnels, from Amir Vadai.
5) Support DSA tagging in older mv88e6xxx switches, from Andrew Lunn.
6) Support GMAC protocol in iwlwifi mwm, from Ayala Beker.
7) Support ndo_poll_controller in mlx5, from Calvin Owens.
8) Move VRF processing to an output hook and allow l3mdev to be
loopback, from David Ahern.
9) Support SOCK_DESTROY for UDP sockets. Also from David Ahern.
10) Congestion control in RXRPC, from David Howells.
11) Support geneve RX offload in ixgbe, from Emil Tantilov.
12) When hitting pressure for new incoming TCP data SKBs, perform a
partial rathern than a full purge of the OFO queue (which could be
huge). From Eric Dumazet.
13) Convert XFRM state and policy lookups to RCU, from Florian Westphal.
14) Support RX network flow classification to igb, from Gangfeng Huang.
15) Hardware offloading of eBPF in nfp driver, from Jakub Kicinski.
16) New skbmod packet action, from Jamal Hadi Salim.
17) Remove some inefficiencies in snmp proc output, from Jia He.
18) Add FIB notifications to properly propagate route changes to
hardware which is doing forwarding offloading. From Jiri Pirko.
19) New dsa driver for qca8xxx chips, from John Crispin.
20) Implement RFC7559 ipv6 router solicitation backoff, from Maciej
Żenczykowski.
21) Add L3 mode to ipvlan, from Mahesh Bandewar.
22) Support 802.1ad in mlx4, from Moshe Shemesh.
23) Support hardware LRO in mediatek driver, from Nelson Chang.
24) Add TC offloading to mlx5, from Or Gerlitz.
25) Convert various drivers to ethtool ksettings interfaces, from
Philippe Reynes.
26) TX max rate limiting for cxgb4, from Rahul Lakkireddy.
27) NAPI support for ath10k, from Rajkumar Manoharan.
28) Support XDP in mlx5, from Rana Shahout and Saeed Mahameed.
29) UDP replicast support in TIPC, from Richard Alpe.
30) Per-queue statistics for qed driver, from Sudarsana Reddy Kalluru.
31) Support BQL in thunderx driver, from Sunil Goutham.
32) TSO support in alx driver, from Tobias Regnery.
33) Add stream parser engine and use it in kcm.
34) Support async DHCP replies in ipconfig module, from Uwe
Kleine-König.
35) DSA port fast aging for mv88e6xxx driver, from Vivien Didelot.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1715 commits)
mlxsw: switchx2: Fix misuse of hard_header_len
mlxsw: spectrum: Fix misuse of hard_header_len
net/faraday: Stop NCSI device on shutdown
net/ncsi: Introduce ncsi_stop_dev()
net/ncsi: Rework the channel monitoring
net/ncsi: Allow to extend NCSI request properties
net/ncsi: Rework request index allocation
net/ncsi: Don't probe on the reserved channel ID (0x1f)
net/ncsi: Introduce NCSI_RESERVED_CHANNEL
net/ncsi: Avoid unused-value build warning from ia64-linux-gcc
net: Add netdev all_adj_list refcnt propagation to fix panic
net: phy: Add Edge-rate driver for Microsemi PHYs.
vmxnet3: Wake queue from reset work
i40e: avoid NULL pointer dereference and recursive errors on early PCI error
qed: Add RoCE ll2 & GSI support
qed: Add support for memory registeration verbs
qed: Add support for QP verbs
qed: PD,PKEY and CQ verb support
qed: Add support for RoCE hw init
qede: Add qedr framework
The auto incremented counter is not being used anymore, get rid of it.
These functions are used by other code misc-next tree.
This reverts commit 30d1de08c87ddde6f73936c3350e7e153988fe02.
This enables support for more accurate TimeSync v4 samples when hosted
under Windows Server 2016 and newer hosts.
The new time samples include a "vmreferencetime" field that represents
the guest's TSC value when the host generated its time sample. This value
lets the guest calculate the latency in receiving the time sample. The
latency is added to the sample host time prior to updating the clock.
