path: root/include/linux/ide.h
2008-12-02amd74xx: workaround unreliable AltStatus register for nVidia controllersBartlomiej Zolnierkiewicz
It seems that on some nVidia controllers using AltStatus register can be unreliable so default to Status register if the PCI device is in Compatibility Mode. In order to achieve this: * Add ide_pci_is_in_compatibility_mode() inline helper to <linux/ide.h>. * Add IDE_HFLAG_BROKEN_ALTSTATUS host flag and set it in amd74xx host driver for nVidia controllers in Compatibility Mode. * Teach actual_try_to_identify() and drive_is_ready() about the new flag. This fixes the regression caused by removal of CONFIG_IDEPCI_SHARE_IRQ config option in 2.6.25 and using AltStatus register unconditionally when available (kernel.org bugs #11659 and #10216). [ Moreover for CONFIG_IDEPCI_SHARE_IRQ=y (which is what most people and distributions use) it never worked correctly. ] Thanks to Remy LABENE and Lars Winterfeld for help with debugging the problem. More info at: http://bugzilla.kernel.org/show_bug.cgi?id=11659 http://bugzilla.kernel.org/show_bug.cgi?id=10216 Reported-by: Remy LABENE <remy.labene@free.fr> Tested-by: Remy LABENE <remy.labene@free.fr> Tested-by: Lars Winterfeld <lars.winterfeld@tu-ilmenau.de> Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-21[PATCH] switch ide_disk_ops ->ioctl() to sane prototypeAl Viro
2008-10-21[PATCH] lose the unused file argument in generic_ide_ioctl()Al Viro
2008-10-17ide: add generic ATA/ATAPI disk driverBartlomiej Zolnierkiewicz
* Add struct ide_disk_ops containing protocol specific methods. * Add 'struct ide_disk_ops *' to ide_drive_t. * Convert ide-{disk,floppy} drivers to use struct ide_disk_ops. * Merge ide-{disk,floppy} drivers into generic ide-gd driver. While at it: - ide_disk_init_capacity() -> ide_disk_get_capacity() Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: allow device drivers to specify per-device type /proc settingsBartlomiej Zolnierkiewicz
Turn ide_driver_t's 'proc' field into ->proc_entries method (and also 'settings' field into ->proc_devsets method). Then update all device drivers accordingly. There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: remove IDE_AFLAG_NO_DOORLOCKINGBartlomiej Zolnierkiewicz
Just use IDE_DFLAG_DOORLOCKING instead. There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-17ide: IDE_AFLAG_FORMAT_IN_PROGRESS -> IDE_DFLAG_FORMAT_IN_PROGRESSBartlomiej Zolnierkiewicz
2008-10-17ide: IDE_AFLAG_WP -> IDE_DFLAG_WPBartlomiej Zolnierkiewicz
2008-10-17ide: IDE_AFLAG_MEDIA_CHANGED -> IDE_DFLAG_MEDIA_CHANGEDBartlomiej Zolnierkiewicz
2008-10-13ide: Implement disk shock protection support (v4)Elias Oltmanns
On user request (through sysfs), the IDLE IMMEDIATE command with UNLOAD FEATURE as specified in ATA-7 is issued to the device and processing of the request queue is stopped thereafter until the specified timeout expires or user space asks to resume normal operation. This is supposed to prevent the heads of a hard drive from accidentally crashing onto the platter when a heavy shock is anticipated (like a falling laptop expected to hit the floor). Port resets are deferred whenever a device on that port is in the parked state. v3: Elias Oltmanns <eo@nebensachen.de> wrote: [...] > >> 1. Make sure that no negative value is being passed to > >> jiffies_to_msecs() in ide_park_show(). > >> 2. Drop the superfluous variable hwif in ide_special_rq(). > >> 3. Skip initialisation of task and tf in ide_special_rq() if we are not > >> handling a (un)park request. > > > > Well, #3 should have been done differently because we donn't want to > > check for REQ_(UN)?PARK_HEADS more often than is necessary. > > While preparing the backport to 2.6.27, it has just occurred to me that > we need to clear the IDE_DFLAG_PARKED flag in ide_disk_pre_reset() > because this flag must not be set after *any* sort of access to the > device. v4: Fix a memory leak due to a missing blk_put_request() in issue_park_cmd(). Additionally, we should plug the queue when enqueueing the unpark request because there is no guarantee that the park timeout has not expired by then. Even though the chance for that to happen is very slim, the request might end up hanging in the queue until the next I/O operation is queued up. While at it, clean up the code a little: - make issue_park_cmd() a function of type void since nobody cares for the return value anyway; - use blk_start_queueing() instead of __blk_run_queue() since we don't have to worry about recursion; - remove a superfluous pointer deference in task_no_data_intr(). Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Cc: Jeff Garzik <jeff@garzik.org>, Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add ide_drive_t.dma flagBorislav Petkov
This flag is to accomodate ide-cd functionality into ide atapi. There should be no functionality change resulting from this patch. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: move SFF DMA code to ide-dma-sff.cBartlomiej Zolnierkiewicz
2008-10-13ide: switch to DMA-mapping API part #2Bartlomiej Zolnierkiewicz
Follow-up to commit 5c05ff68b9a9b40a9be949497e0aa980185565cf ("ide: switch to DMA-mapping API"): * pci_{alloc,free}_consistent() -> dma_{alloc,free}_coherent() in ide_{allocate,release}_dma_engine(). * Add ->prd_max_nents and ->prd_ent_size fields to ide_hwif_t (+ set default values in ide_allocate_dma_engine()). * Make ide_{allocate,release}_dma_engine() available also for CONFIG_BLK_DEV_IDEDMA_SFF=n. Then convert au1xxx-ide.c, scc_pata.c and sgiioc4.c to use them. * Add missing ->init_dma method to scc_pata. This patch also fixes: - ->dmatable_cpu leak for au1xxx-ide - too early realease of ->dmatable_cpu for scc_pata - wrong amount of ->dmatable_cpu memory being freed for sgiioc4 While at it: - remove superfluous ->dma_base check from ide_unregister() - return -ENOMEM on error in ide_release_dma_engine() - beautify error message in ide_release_dma_engine() Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: make ide_dma_timeout() available also for CONFIG_BLK_DEV_IDEDMA_SFF=nBartlomiej Zolnierkiewicz
Make ide_dma_timeout() available also for CONFIG_BLK_DEV_IDEDMA_SFF=n and convert {ics,au1xxx-}ide.c to use it. While at it: - dump ATA Status register content on error - use EXPORT_SYMBOL_GPL() to match the rest of SFF DMA functions Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: make ide_dma_lost_irq() available also for CONFIG_BLK_DEV_IDEDMA_SFF=nBartlomiej Zolnierkiewicz
Make ide_dma_lost_irq() available also for CONFIG_BLK_DEV_IDEDMA_SFF=n and convert {ics,au1xxx-}ide.c to use it. While at it: - use EXPORT_SYMBOL_GPL() to match the rest of SFF DMA functions Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: __ide_dma_end() -> ide_dma_end()Bartlomiej Zolnierkiewicz
2008-10-13ide-disk: move all ioctl handling to ide-disk_ioctl.cBartlomiej Zolnierkiewicz
While at it: - idedisk_ioctl() -> ide_disk_ioctl() Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: remove ide_host_alloc_all()Bartlomiej Zolnierkiewicz
* Remove no longer used ide_host_alloc_all(). * Add MAX_HOST_PORTS define and use it instead of MAX_HWIFS as the maximum number of host ports possible. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: ->ide_dma_clear_irq() -> ->clear_irq()Bartlomiej Zolnierkiewicz
* Rename ->ide_dma_clear_irq method to ->clear_irq and move it from ide_hwif_t to struct ide_port_ops. * Move ->waiting_for_dma check inside ->clear_irq method. * Move ->dma_base check inside ->clear_irq method. piix.c: * Add ich_port_ops and remove init_hwif_ich() wrapper. There should be no functional changes caused by this patch. Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: merge all TASKFILE_NO_DATA data phase handlers into taskfile_no_intr()Bartlomiej Zolnierkiewicz
* Add 'struct task_s' to ide_hwif_t and init it to the current command in do_rw_taskfile(). * Merge all TASKFILE_NO_DATA data phase handlers into taskfile_no_intr(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: convert 'pio_mode' device setting to use DS_SYNC flagBartlomiej Zolnierkiewicz
* Convert 'pio_mode' device setting to use DS_SYNC flag. * Remove unused special_t.b.{set_tune,serviced} and ide_drive_t.tune_req. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: remove [ata_]select_tBartlomiej Zolnierkiewicz
* Use 'drive->dn & 1' in ide_init_disk(). * remove [ata_]select_t. While at it: * Use ATA_DEVICE_OBS define in ide_port_init_devices_data(). Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: sanitize ide*_pm_* enumsBartlomiej Zolnierkiewicz
* Move ide*_pm_* enums from ide-io.c to <linux/ide.h>. * idedisk_pm_* -> ide_pm_* * ide_pm_state_* -> ide_pm_* * No need to set ide_pm_* enums to the fixed values. * Uppercase ide_pm_* enums. * Fix/update comments. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: fix HDIO_DRIVE_TASK[FILE] ioctls for CHS commands on LBA devicesBartlomiej Zolnierkiewicz
Add IDE_DFLAG_LBA device flag and use it instead of ->select.b.lba. Since ->tf_load uses ->select.all for ATA Device/Head register this fixes HDIO_DRIVE_TASK[FILE] ioctls for CHS commands on LBA devices. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: remove superfluous ->dma field from ide_hwif_tBartlomiej Zolnierkiewicz
2008-10-13ide: remove superfluous ->media field from ide_driver_tBartlomiej Zolnierkiewicz
2008-10-13ide: DMA_PIO_RETRY -> IDE_DFLAG_DMA_PIO_RETRYBartlomiej Zolnierkiewicz
Add IDE_DFLAG_DMA_PIO_RETRY and use it instead of ide_drive_t.state + DMA_PIO_RETRY. There should be no functional changes cause by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add device flagsBartlomiej Zolnierkiewicz
Add 'unsigned long dev_flags' to ide_drive_t and convert bitfields to IDE_DFLAG_* flags. While at it: - IDE_DFLAG_ADDRESSING -> IDE_DFLAG_LBA48 - fixup some comments - remove needless g->flags zeroing from ide*_probe() There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide-disk: set_addressing() fixesBartlomiej Zolnierkiewicz
* Return -EIO if arg > 0 and LBA48 is unsupported. * No need to reset ->addressing. * Make ->addressing a single bit flag. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add a driver-wide debugging macroBorislav Petkov
Add __ide_debug_log() debugging macro which is controlled by drive->debug_mask. The macro has to have the macro DRV_NAME defined in each driver before use. Also, add different debugging levels depending on the functionality debugged. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add drive->debug_mask switchBorislav Petkov
Add a debugging on/off switch for controlling driver debugging messages dynamically. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: unify conversion macrosBorislav Petkov
Introduce to_ide_drv() and ide_drv_g() macros and replace the respective definitions of similar ones in each driver. There should be no functionality change resulting from this patch. Signed-off-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: make ide_transfer_pc() staticBartlomiej Zolnierkiewicz
* Move ->ticks field from struct ide_floppy_obj to ide_drive_t. * Move idefloppy_transfer_pc() to ide-atapi.c and make ide_transfer_pc() use it. * Always use ide_transfer_pc as a handler in ide_issue_pc(). * Remove no longer used idefloppy_start_pc_transfer(), ide*_transfer_pc() and 'handler' argument from ide_issue_pc(). * Make ide_transfer_pc() static. While at it: * idefloppy_transfer_pc() -> ide_delayed_transfer_pc() * IDEFLOPPY_TICKS_DELAY -> IDEFLOPPY_PC_DELAY * ->ticks -> ->pc_delay There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: make ide_pc_intr() staticBartlomiej Zolnierkiewicz
* Always use ide_pc_intr as a handler in ide_pc_intr(). * Remove no longer used ide*_pc_intr() and 'handler' argument from ide_{transfer_pc,pc_intr}(). * Make ide_pc_intr() static. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add ->pc_{update,io}_buffers methodsBartlomiej Zolnierkiewicz
Add ->pc_{update,io}_buffers methods to ide_drive_t and use them instead of {update,io}_buffers ide_pc_intr() arguments. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add ide_retry_pc() helperBartlomiej Zolnierkiewicz
* Add ide_create_request_sense_cmd() and ide_retry_pc() helpers and convert ide-{atapi,floppy,tape}.c to use them. * Remove no longer used ide*_create_request_sense_cmd(), ide*_retry_pc() and 'retry_pc' argument from ide_pc_intr(). * Make ide_queue_pc_head() static. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add request_sense_{pc,rq} to ide_drive_tBartlomiej Zolnierkiewicz
Add 'struct ide_atapi_pc request_sense_pc' and 'request request_sense_rq' to ide_drive_t and use them instead of fields in struct ide_{floppy,tape}_obj. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: drop 'timeout' and 'expiry' arguments from ide_pc_intr()Bartlomiej Zolnierkiewicz
* Move idescsi_expiry() to ide-atapi.c. * Move get_timeout() to <linux/ide.h>. * Drop 'timeout' and 'expiry' arguments from ide_pc_intr(). While at it: * idescsi_expiry() -> ide_scsi_expiry() * get_timeout() -> ide_scsi_get_timeout() There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: add pointer to the current packet command to ide_drive_tBartlomiej Zolnierkiewicz
* Add pointer to the current packet command (struct ide_atapi_pc *pc) to ide_drive_t and use it instead of the pointer in struct ide_*_obj. * Use drive->pc in ide_{issue,transfer}_pc() and ide_pc_intr() instead of 'pc' argument. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-13ide: drop dsc_handle argument from ide_pc_intr()Bartlomiej Zolnierkiewicz
* Add 'int dsc' argument to ->pc_callback method. * Call ide_tape_handle_dsc() internally in ide_tape_callback() if dsc argument is set and update ide_pc_intr() accordingly. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: Remove ide_spin_wait_hwgroup() and use special requests insteadElias Oltmanns
Use a special request for serialisation purposes and get rid of the awkward ide_spin_wait_hwgroup(). This also involves converting the ide_devset structure so it can be shared by the /proc and the ioctl code. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> [bart: use rq->cmd[] directly] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: move IDE{FLOPPY,TAPE}_WAIT_CMD defines to <linux/ide.h>Bartlomiej Zolnierkiewicz
While at it: * IDE{FLOPPY,TAPE}_WAIT_CMD -> WAIT_{FLOPPY,TAPE}_CMD * Use enum for WAIT_* defines. There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_do_test_unit_ready() helperBartlomiej Zolnierkiewicz
* Add ide_do_test_unit_ready() helper and convert ide-{floppy,tape}.c to use it. * Remove no longer used idetape_create_test_unit_ready_cmd(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_do_start_stop() helperBartlomiej Zolnierkiewicz
* Add ide_do_start_stop() helper and convert ide-{floppy,tape}.c to use it. * Remove no longer used idefloppy_create_start_stop_cmd() and idetape_create_load_unload_cmd(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_set_media_lock() helperBartlomiej Zolnierkiewicz
* Set IDE_AFLAG_NO_DOORLOCK in idetape_get_mode_sense_result(), check it in ide_tape_set_media_lock() and cleanup idetape_create_prevent_cmd(). * Set IDE_AFLAG_NO_DOORLOCK in ide_floppy_create_read_capacity_cmd() and check it instead of IDE_AFLAG_CLIK_DRIVE in ide_floppy_set_media_lock(). * Add ide_set_media_lock() helper and convert ide-{floppy,tape}.c to use it. * Remove no longer used ide*_create_prevent_cmd()/ide*_set_media_lock(). * Update comment in <linux/ide.h> accordingly. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide-floppy: ->{srfp,wp} -> IDE_AFLAG_{SRFP,WP}Bartlomiej Zolnierkiewicz
Add IDE_AFLAG_{SRFP,WP} drive->atapi_flags and use them instead of ->{srfp,wp} struct ide_floppy_obj fields. There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_queue_pc_tail() helperBartlomiej Zolnierkiewicz
* Add ide_queue_pc_tail() and convert ide-{floppy,tape}.c to use it instead of ide*_queue_pc_tail(). * Remove no longer used ide*_queue_pc_tail(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_queue_pc_head() helperBartlomiej Zolnierkiewicz
* Move REQ_IDETAPE_* enums to <linux/ide.h>. * Add ide_queue_pc_head() and convert ide-{floppy,tape}.c to use it instead of ide*_queue_pc_head(). * Remove no longer used ide*_queue_pc_head(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_init_pc() helperBartlomiej Zolnierkiewicz
* Add IDE_PC_BUFFER_SIZE define. * Add ide_init_pc() and convert ide-{floppy,tape}.c to use it instead of ide*_init_pc(). * Remove no longer used IDE*_PC_BUFFER_SIZE and ide*_init_pc(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-10ide: add ide_io_buffers() helperBartlomiej Zolnierkiewicz
* Make ->io_buffers method return number of bytes transferred. * Use ide_end_request() instead of idefloppy_end_request() in ide_floppy_io_buffers() and then move the call out to ide_pc_intr(). * Add ide_io_buffers() helper and convert ide-{floppy,scsi}.c to use it instead of ide*_io_buffers(). There should be no functional changes caused by this patch. Acked-by: Borislav Petkov <petkovbb@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
