path: root/include/linux/if_ppp.h
2011-03-18headers: use __aligned_xx types for userspaceMike Frysinger
Now that we finally have __aligned_xx exported to userspace, convert the headers that get exported over to the proper type. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30headers_check fix: linux/if_ppp.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/if_ppp.h:96: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[L2TP]: Changes to existing ppp and socket kernel headers for L2TPJames Chapman
Add struct sockaddr_pppol2tp to carry L2TP-specific address information for the PPPoX (PPPoL2TP) socket. Unfortunately we can't use the union inside struct sockaddr_pppox because the L2TP-specific data is larger than the current size of the union and we must preserve the size of struct sockaddr_pppox for binary compatibility. Also add a PPPIOCGL2TPSTATS ioctl to allow userspace to obtain L2TP counters and state from the kernel. Add new if_pppol2tp.h header. [ Modified to use aligned_u64 in statistics structure -DaveM ] Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[PPP]: add PPP MPPE encryption moduleMatt Domsch
From: Matt Domsch <Matt_Domsch@dell.com> The patch below implements the Microsoft Point-to-Point Encryption method as a PPP compressor/decompressor. This is necessary for Linux clients and servers to interoperate with Microsoft Point-to-Point Tunneling Protocol (PPTP) servers (either Microsoft PPTP servers or the poptop project) which use MPPE to encrypt data when creating a VPN. This patch differs from the kernel_ppp_mppe DKMS pacakge at pptpclient.sourceforge.net by utilizing the kernel crypto routines rather than providing its own SHA1 and arcfour implementations. Minor changes to ppp_generic.c try to prevent a link from disabling compression (in our case, the encryption) after it has started using compression (encryption). Feedback to <pptpclient-devel@lists.sourceforge.net> please. Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Cc: James Cameron <james.cameron@hp.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Brice Goglin <Brice.Goglin@ens-lyon.org> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
