path: root/include/linux/if_pppox.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-05-01pppox: Replace __attribute__((packed)) in if_pppox.hJames Chapman
Checkpatch warns about the use of __attribute__((packed)). So use the recommended __packed syntax instead. Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-28net/l2tp: add support for L2TP over IPv6 UDPBenjamin LaHaise
Now that encap_rcv() works on IPv6 UDP sockets, wire L2TP up to IPv6. Support has been tested with and without hardware offloading. This version fixes the L2TP over localhost issue with incorrect checksums being reported. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-26headers, net: Use __kernel_sa_family_t in more definitions shared with userlandBen Hutchings
Complete the work started with commit 6602a4baf4d1a73cc4685a39ef859e1c5ddf654c ('net: Make userland include of netlink.h more sane'). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-26headers, pppox: Add missing #include to <linux/if_pppox.h>Ben Hutchings
<linux/if_ppox.h> uses ETH_ALEN, defined in <linux/if_ether.h>. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-21net: constify some ppp/pptp structsEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-22Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: include/linux/if_pppox.h Fix conflict between Changli's __packed header file fixes and the new PPTP driver. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-22header: fix broken headers for user spaceChangli Gao
__packed is only defined in kernel space, so we should use __attribute__((packed)) for the code shared between kernel and user space. Two __attribute() annotations are replaced with __attribute__() too. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-22net: use __be16 instead of u16 for the userspace codeChangli Gao
2010-08-21PPTP: PPP over IPv4 (Point-to-Point Tunneling Protocol)Dmitry Kozlov
PPP: introduce "pptp" module which implements point-to-point tunneling protocol using pppox framework NET: introduce the "gre" module for demultiplexing GRE packets on version criteria (required to pptp and ip_gre may coexists) NET: ip_gre: update to use the "gre" module This patch introduces then pptp support to the linux kernel which dramatically speeds up pptp vpn connections and decreases cpu usage in comparison of existing user-space implementation (poptop/pptpclient). There is accel-pptp project (https://sourceforge.net/projects/accel-pptp/) to utilize this module, it contains plugin for pppd to use pptp in client-mode and modified pptpd (poptop) to build high-performance pptp NAS. There was many changes from initial submitted patch, most important are: 1. using rcu instead of read-write locks 2. using static bitmap instead of dynamically allocated 3. using vmalloc for memory allocation instead of BITS_PER_LONG + __get_free_pages 4. fixed many coding style issues Thanks to Eric Dumazet. Signed-off-by: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in net/ and include/ (except netfilter) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03l2tp: Update PPP-over-L2TP driver to work over L2TPv3James Chapman
This patch makes changes to the L2TP PPP code for L2TPv3. The existing code has some assumptions about the L2TP header which are broken by L2TPv3. Also the sockaddr_pppol2tp structure of the original code is too small to support the increased size of the L2TPv3 tunnel and session id, so a new sockaddr_pppol2tpv3 structure is needed. In the socket calls, the size of this structure is used to tell if the operation is for L2TPv2 or L2TPv3. Signed-off-by: James Chapman <jchapman@katalix.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-14net: replace __constant_{endian} uses in net headersHarvey Harrison
Base versions handle constant folding now. For headers exposed to userspace, we must only expose the __ prefixed versions. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-15include of <linux/types.h> is preferred over <asm/types.h>Jaswinder Singh Rajput
Impact: fix 15 make headers_check warnings: include of <linux/types.h> is preferred over <asm/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18include: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they (or some user of them) rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have to fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-10-10pppoe: endiannessAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[L2TP]: Changes to existing ppp and socket kernel headers for L2TPJames Chapman
Add struct sockaddr_pppol2tp to carry L2TP-specific address information for the PPPoX (PPPoL2TP) socket. Unfortunately we can't use the union inside struct sockaddr_pppox because the L2TP-specific data is larger than the current size of the union and we must preserve the size of struct sockaddr_pppox for binary compatibility. Also add a PPPIOCGL2TPSTATS ioctl to allow userspace to obtain L2TP counters and state from the kernel. Add new if_pppol2tp.h header. [ Modified to use aligned_u64 in statistics structure -DaveM ] Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: bridge-nf: filter bridged IPv4/IPv6 encapsulated in pppoe trafficMichael Milner
The attached patch by Michael Milner adds support for using iptables and ip6tables on bridged traffic encapsulated in ppoe frames, similar to what's already supported for vlan. Signed-off-by: Michael Milner <milner@blissisland.ca> Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PPPOE]: Introduce pppoe_hdr()Arnaldo Carvalho de Melo
For consistency with all the other skb->nh.raw accessors. Also do some really obvious simplifications in pppoe_recvmsg, well the kfree_skb one is not so obvious, but free() and kfree() have the same behaviour (hint :-) ). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-05[PPPOE]: Use ifindex instead of device pointer in key lookups.Florian Zumbiehl
Otherwise we can potentially try to dereference a NULL device pointer in some cases. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[PPPOX]: Fix assignment into const proto_ops.David S. Miller
And actually, with this, the whole pppox layer can basically be removed and subsumed into pppoe.c, no other pppox sub-protocol implementation exists and we've had this thing for at least 4 years. Signed-off-by: David S. Miller <davem@davemloft.net>
