path: root/include/linux/iio/adc/ad_sigma_delta.h
2013-03-17iio:adc:ad_sigma_delta move to info_mask_(shared_by_type/separate)Jonathan Cameron
The original info_mask is going away in favour of the broken out versions. Signed-off-by: Jonathan Cameron <jic23@kernel.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de>
2012-08-27iio:adc: Add common code for ADI Sigma Delta devicesLars-Peter Clausen
Most devices from the Analog Devices Sigma Delta family use a similar scheme for communication with the device. This includes register access, as well as trigger handling. But each device sub-family has different features and different register layouts (some even have no registers at all) and thus it is impractical to try to support all of the devices by the same driver. This patch adds a common base library for Sigma Delta converter devices. It will be used by individual drivers. This code is mostly based on the three existing Sigma Delta drivers the AD7192, AD7780 and AD7793, but has been improved for more robustness and flexibility. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
