path: root/include/linux/init_task.h
2011-07-12fixlet: Remove fs_excl from struct task.Justin TerAvest
fs_excl is a poor man's priority inheritance for filesystems to hint to the block layer that an operation is important. It was never clearly specified, not widely adopted, and will not prevent starvation in many cases (like across cgroups). fs_excl was introduced with the time sliced CFQ IO scheduler, to indicate when a process held FS exclusive resources and thus needed a boost. It doesn't cover all file systems, and it was never fully complete. Lets kill it. Signed-off-by: Justin TerAvest <teravest@google.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-26cgroups: read-write lock CLONE_THREAD forking per threadgroupBen Blum
Adds functionality to read/write lock CLONE_THREAD fork()ing per-threadgroup Add an rwsem that lives in a threadgroup's signal_struct that's taken for reading in the fork path, under CONFIG_CGROUPS. If another part of the kernel later wants to use such a locking mechanism, the CONFIG_CGROUPS ifdefs should be changed to a higher-up flag that CGROUPS and the other system would both depend on. This is a pre-patch for cgroup-procs-write.patch. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Matt Helsley <matthltc@us.ibm.com> Reviewed-by: Paul Menage <menage@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24Merge branch 'next' into for-linusJames Morris
2011-04-24sched: Get rid of lock_depthJonathan Corbet
Neil Brown pointed out that lock_depth somehow escaped the BKL removal work. Let's get rid of it now. Note that the perf scripting utilities still have a bunch of code for dealing with common_lock_depth in tracepoints; I have left that in place in case anybody wants to use that code with older kernels. Suggested-by: Neil Brown <neilb@suse.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20110422111910.456c0e84@bike.lwn.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-04capabilities: delete all CAP_INIT macrosEric Paris
The CAP_INIT macros of INH, BSET, and EFF made sense at one point in time, but now days they aren't helping. Just open code the logic in the init_cred. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2011-01-06Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) sched: Change wait_for_completion_*_timeout() to return a signed long sched, autogroup: Fix reference leak sched, autogroup: Fix potential access to freed memory sched: Remove redundant CONFIG_CGROUP_SCHED ifdef sched: Fix interactivity bug by charging unaccounted run-time on entity re-weight sched: Move periodic share updates to entity_tick() printk: Use this_cpu_{read|write} api on printk_pending sched: Make pushable_tasks CONFIG_SMP dependant sched: Add 'autogroup' scheduling feature: automated per session task groups sched: Fix unregister_fair_sched_group() sched: Remove unused argument dest_cpu to migrate_task() mutexes, sched: Introduce arch_mutex_cpu_relax() sched: Add some clock info to sched_debug cpu: Remove incorrect BUG_ON cpu: Remove unused variable sched: Fix UP build breakage sched: Make task dump print all 15 chars of proc comm sched: Update tg->shares after cpu.shares write sched: Allow update_cfs_load() to update global load sched: Implement demand based update_cfs_load() ...
2010-12-23Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
2010-12-08sched: Make pushable_tasks CONFIG_SMP dependantDario Faggioli
As noted by Peter Zijlstra at https://lkml.org/lkml/2010/11/10/391 (while reviewing other stuff, though), tracking pushable tasks only makes sense on SMP systems. Signed-off-by: Dario Faggioli <raistlin@linux.it> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1291143093.2697.298.camel@Palantir> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-29rcu: priority boosting for TINY_PREEMPT_RCUPaul E. McKenney
Add priority boosting, but only for TINY_PREEMPT_RCU. This is enabled by the default-off RCU_BOOST kernel parameter. The priority to which to boost preempted RCU readers is controlled by the RCU_BOOST_PRIO kernel parameter (defaulting to real-time priority 1) and the time to wait before boosting the readers blocking a given grace period is controlled by the RCU_BOOST_DELAY kernel parameter (defaulting to 500 milliseconds). Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-10-27signals: move cred_guard_mutex from task_struct to signal_structKOSAKI Motohiro
Oleg Nesterov pointed out we have to prevent multiple-threads-inside-exec itself and we can reuse ->cred_guard_mutex for it. Yes, concurrent execve() has no worth. Let's move ->cred_guard_mutex from task_struct to signal_struct. It naturally prevent multiple-threads-inside-exec. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-20rcu: Add a TINY_PREEMPT_RCUPaul E. McKenney
Implement a small-memory-footprint uniprocessor-only implementation of preemptible RCU. This implementation uses but a single blocked-tasks list rather than the combinatorial number used per leaf rcu_node by TREE_PREEMPT_RCU, which reduces memory consumption and greatly simplifies processing. This version also takes advantage of uniprocessor execution to accelerate grace periods in the case where there are no readers. The general design is otherwise broadly similar to that of TREE_PREEMPT_RCU. This implementation is a step towards having RCU implementation driven off of the SMP and PREEMPT kernel configuration variables, which can happen once this implementation has accumulated sufficient experience. Removed ACCESS_ONCE() from __rcu_read_unlock() and added barrier() as suggested by Steve Rostedt in order to avoid the compiler-reordering issue noted by Mathieu Desnoyers (http://lkml.org/lkml/2010/8/16/183). As can be seen below, CONFIG_TINY_PREEMPT_RCU represents almost 5Kbyte savings compared to CONFIG_TREE_PREEMPT_RCU. Of course, for non-real-time workloads, CONFIG_TINY_RCU is even better. CONFIG_TREE_PREEMPT_RCU text data bss dec filename 13 0 0 13 kernel/rcupdate.o 6170 825 28 7023 kernel/rcutree.o ---- 7026 Total CONFIG_TINY_PREEMPT_RCU text data bss dec filename 13 0 0 13 kernel/rcupdate.o 2081 81 8 2170 kernel/rcutiny.o ---- 2183 Total CONFIG_TINY_RCU (non-preemptible) text data bss dec filename 13 0 0 13 kernel/rcupdate.o 719 25 0 744 kernel/rcutiny.o --- 757 Total Requested-by: Loïc Minier <loic.minier@canonical.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-19kernel: __rcu annotationsArnd Bergmann
This adds annotations for RCU operations in core kernel components Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-06-01Merge branch 'for-35' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-35' of git://repo.or.cz/linux-kbuild: (81 commits) kbuild: Revert part of e8d400a to resolve a conflict kbuild: Fix checking of scm-identifier variable gconfig: add support to show hidden options that have prompts menuconfig: add support to show hidden options which have prompts gconfig: remove show_debug option gconfig: remove dbg_print_ptype() and dbg_print_stype() kconfig: fix zconfdump() kconfig: some small fixes add random binaries to .gitignore kbuild: Include gen_initramfs_list.sh and the file list in the .d file kconfig: recalc symbol value before showing search results .gitignore: ignore *.lzo files headerdep: perlcritic warning scripts/Makefile.lib: Align the output of LZO kbuild: Generate modules.builtin in make modules_install Revert "kbuild: specify absolute paths for cscope" kbuild: Do not unnecessarily regenerate modules.builtin headers_install: use local file handles headers_check: fix perl warnings export_report: fix perl warnings ...
2010-05-27INIT_SIGHAND: use SIG_DFL instead of NULLOleg Nesterov
Cosmetic, no changes in the compiled code. Just s/NULL/SIG_DFL/ to make it more readable and grep-friendly. Note: probably SIG_IGN makes more sense, we could kill ignore_signals(). But then kernel_init() should do flush_signal_handlers() before exec(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Mathias Krause <Mathias.Krause@secunet.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27pids: init_struct_pid.tasks should never see the swapper processOleg Nesterov
"statically initialize struct pid for swapper" commit 820e45db says: Statically initialize a struct pid for the swapper process (pid_t == 0) and attach it to init_task. This is needed so task_pid(), task_pgrp() and task_session() interfaces work on the swapper process also. OK, but: - it doesn't make sense to add init_task.pids[].node into init_struct_pid.tasks[], and in fact this just wrong. idle threads are special, they shouldn't be visible on any global list. In particular do_each_pid_task(init_struct_pid) shouldn't see swapper. This is the actual reason why kill(0, SIGKILL) from /sbin/init (which starts with 0,0 special pids) crashes the kernel. The signal sent to pgid/sid == 0 must never see idle threads, even if the previous patch fixed the crash itself. - we have other idle threads running on the non-boot CPUs, see the next patch. Change INIT_STRUCT_PID/INIT_PID_LINK to create the empty/unhashed hlist_head/hlist_node. Like any other idle thread swapper can never exit, so detach_pid()->__hlist_del() is not possible, but we could change INIT_PID_LINK() to set pprev = &next if needed. All we need is the valid swapper->pids[].pid == &init_struct_pid. Reported-by: Mathias Krause <mathias.krause@secunet.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Mathias Krause <Mathias.Krause@secunet.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27INIT_TASK() should initialize ->thread_group listOleg Nesterov
The trivial /sbin/init doing int main(void) { kill(0, SIGKILL) } crashes the kernel. This happens because __kill_pgrp_info(init_struct_pid) also sends SIGKILL to the swapper process which runs with the uninitialized ->thread_group. Change INIT_TASK() to initialize ->thread_group properly. Note: the real problem is that the swapper process must not be visible to signals, see the next patch. But this change is right anyway and fixes the crash. Reported-and-tested-by: Mathias Krause <mathias.krause@secunet.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Mathias Krause <Mathias.Krause@secunet.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27proc: turn signal_struct->count into "int nr_threads"Oleg Nesterov
No functional changes, just s/atomic_t count/int nr_threads/. With the recent changes this counter has a single user, get_nr_threads() And, none of its callers need the really accurate number of threads, not to mention each caller obviously races with fork/exit. It is only used to report this value to the user-space, except first_tid() uses it to avoid the unnecessary while_each_thread() loop in the unlikely case. It is a bit sad we need a word in struct signal_struct for this, perhaps we can change get_nr_threads() to approximate the number of threads using signal->live and kill ->nr_threads later. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-11rcu: remove all rcu head initializations, except on_stack initializationsPaul E. McKenney
Remove all rcu head inits. We don't care about the RCU head state before passing it to call_rcu() anyway. Only leave the "on_stack" variants so debugobjects can keep track of objects on stack. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-03-12nsproxy: remove INIT_NSPROXY()Alexey Dobriyan
Remove INIT_NSPROXY(), use C99 initializer. Remove INIT_IPC_NS(), INIT_NET_NS() while I'm at it. Note: headers trim will be done later, now it's quite pointless because results will be invalidated by merge window. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-03Rename .data.init_task to .data..init_task.Tim Abbott
Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-17Revert "task_struct: make journal_info conditional"Linus Torvalds
This reverts commit e4c570c4cb7a95dbfafa3d016d2739bf3fdfe319, as requested by Alexey: "I think I gave a good enough arguments to not merge it. To iterate: * patch makes impossible to start using ext3 on EXT3_FS=n kernels without reboot. * this is done only for one pointer on task_struct" None of config options which define task_struct are tristate directly or effectively." Requested-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits) clockevents: Convert to raw_spinlock clockevents: Make tick_device_lock static debugobjects: Convert to raw_spinlocks perf_event: Convert to raw_spinlock hrtimers: Convert to raw_spinlocks genirq: Convert irq_desc.lock to raw_spinlock smp: Convert smplocks to raw_spinlocks rtmutes: Convert rtmutex.lock to raw_spinlock sched: Convert pi_lock to raw_spinlock sched: Convert cpupri lock to raw_spinlock sched: Convert rt_runtime_lock to raw_spinlock sched: Convert rq->lock to raw_spinlock plist: Make plist debugging raw_spinlock aware bkl: Fixup core_lock fallout locking: Cleanup the name space completely locking: Further name space cleanups alpha: Fix fallout from locking changes locking: Implement new raw_spinlock locking: Convert raw_rwlock functions to arch_rwlock locking: Convert raw_rwlock to arch_rwlock ...
2009-12-15task_struct: make journal_info conditionalHiroshi Shimamoto
journal_info in task_struct is used in journaling file system only. So introduce CONFIG_FS_JOURNAL_INFO and make it conditional. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14sched: Convert pi_lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-11-24remove CONFIG_SECURITY_FILE_CAPABILITIES compile optionSerge E. Hallyn
As far as I know, all distros currently ship kernels with default CONFIG_SECURITY_FILE_CAPABILITIES=y. Since having the option on leaves a 'no_file_caps' option to boot without file capabilities, the main reason to keep the option is that turning it off saves you (on my s390x partition) 5k. In particular, vmlinux sizes came to: without patch fscaps=n: 53598392 without patch fscaps=y: 53603406 with this patch applied: 53603342 with the security-next tree. Against this we must weigh the fact that there is no simple way for userspace to figure out whether file capabilities are supported, while things like per-process securebits, capability bounding sets, and adding bits to pI if CAP_SETPCAP is in pE are not supported with SECURITY_FILE_CAPABILITIES=n, leaving a bit of a problem for applications wanting to know whether they can use them and/or why something failed. It also adds another subtly different set of semantics which we must maintain at the risk of severe security regressions. So this patch removes the SECURITY_FILE_CAPABILITIES compile option. It drops the kernel size by about 50k over the stock SECURITY_FILE_CAPABILITIES=y kernel, by removing the cap_limit_ptraced_target() function. Changelog: Nov 20: remove cap_limit_ptraced_target() as it's logic was ifndef'ed. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Andrew G. Morgan" <morgan@kernel.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-29rcu: Create rcutree plugins to handle hotplug CPU for multi-level treesPaul E. McKenney
When offlining CPUs from a multi-level tree, there is the possibility of offlining the last CPU from a given node when there are preempted RCU read-side critical sections that started life on one of the CPUs on that node. In this case, the corresponding tasks will be enqueued via the task_struct's rcu_node_entry list_head onto one of the rcu_node's blocked_tasks[] lists. These tasks need to be moved somewhere else so that they will prevent the current grace period from ending. That somewhere is the root rcu_node. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <20090827215816.GA30472@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Remove CONFIG_PREEMPT_RCUPaul E. McKenney
Now that CONFIG_TREE_PREEMPT_RCU is in place, there is no further need for CONFIG_PREEMPT_RCU. Remove it, along with whatever subtle bugs it may (or may not) contain. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <125097461396-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Merge preemptable-RCU functionality into hierarchical RCUPaul E. McKenney
Create a kernel/rcutree_plugin.h file that contains definitions for preemptable RCU (or, under the #else branch of the #ifdef, empty definitions for the classic non-preemptable semantics). These definitions fit into plugins defined in kernel/rcutree.c for this purpose. This variant of preemptable RCU uses a new algorithm whose read-side expense is roughly that of classic hierarchical RCU under CONFIG_PREEMPT. This new algorithm's update-side expense is similar to that of classic hierarchical RCU, and, in absence of read-side preemption or blocking, is exactly that of classic hierarchical RCU. Perhaps more important, this new algorithm has a much simpler implementation, saving well over 1,000 lines of code compared to mainline's implementation of preemptable RCU, which will hopefully be retired in favor of this new algorithm. The simplifications are obtained by maintaining per-task nesting state for running tasks, and using a simple lock-protected algorithm to handle accounting when tasks block within RCU read-side critical sections, making use of lessons learned while creating numerous user-level RCU implementations over the past 18 months. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746134003-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-27Add new __init_task_data macro to be used in arch init_task.c files.Tim Abbott
This patch is preparation for replacing most ".data.init_task" in the kernel with macros, so that the section name can later be changed without having to touch a lot of the kernel. The long-term goal here is to be able to change the kernel's magic section names to those that are compatible with -ffunction-sections -fdata-sections. This requires renaming all magic sections with names of the form ".data.foo". Signed-off-by: Tim Abbott <tabbott@ksplice.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-06-16mm: consolidate init_mm definitionAlexey Dobriyan
* create mm/init-mm.c, move init_mm there * remove INIT_MM, initialize init_mm with C99 initializer * unexport init_mm on all arches: init_mm is already unexported on x86. One strange place is some OMAP driver (drivers/video/omap/) which won't build modular, but it's already wants get_vm_area() export. Somebody should look there. [akpm@linux-foundation.org: add missing #includes] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11Merge branch 'perfcounters-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (574 commits) perf_counter: Turn off by default perf_counter: Add counter->id to the throttle event perf_counter: Better align code perf_counter: Rename L2 to LL cache perf_counter: Standardize event names perf_counter: Rename enums perf_counter tools: Clean up u64 usage perf_counter: Rename perf_counter_limit sysctl perf_counter: More paranoia settings perf_counter: powerpc: Implement generalized cache events for POWER processors perf_counters: powerpc: Add support for POWER7 processors perf_counter: Accurate period data perf_counter: Introduce struct for sample data perf_counter tools: Normalize data using per sample period data perf_counter: Annotate exit ctx recursion perf_counter tools: Propagate signals properly perf_counter tools: Small frequency related fixes perf_counter: More aggressive frequency adjustment perf_counter/x86: Fix the model number of Intel Core2 processors perf_counter, x86: Correct some event and umask values for Intel processors ...
2009-06-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (44 commits) nommu: Provide mmap_min_addr definition. TOMOYO: Add description of lists and structures. TOMOYO: Remove unused field. integrity: ima audit dentry_open failure TOMOYO: Remove unused parameter. security: use mmap_min_addr indepedently of security models TOMOYO: Simplify policy reader. TOMOYO: Remove redundant markers. SELinux: define audit permissions for audit tree netlink messages TOMOYO: Remove unused mutex. tomoyo: avoid get+put of task_struct smack: Remove redundant initialization. integrity: nfsd imbalance bug fix rootplug: Remove redundant initialization. smack: do not beyond ARRAY_SIZE of data integrity: move ima_counts_get integrity: path_check update IMA: Add __init notation to ima functions IMA: Minimal IMA policy and boot param for TCB IMA policy selinux: remove obsolete read buffer limit from sel_read_bool ...
2009-06-11Merge branch 'linus' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/irqinit.c arch/x86/kernel/irqinit_64.c arch/x86/kernel/traps.c arch/x86/mm/fault.c include/linux/sched.h kernel/exit.c
2009-05-24perf_counter: Change pctrl() behaviourPeter Zijlstra
Instead of en/dis-abling all counters acting on a particular task, en/dis- able all counters we created. [ v2: fix crash on first counter enable ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: John Kacur <jkacur@redhat.com> LKML-Reference: <20090523163012.916937244@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-22perf_counter: Dynamically allocate tasks' perf_counter_context structPaul Mackerras
This replaces the struct perf_counter_context in the task_struct with a pointer to a dynamically allocated perf_counter_context struct. The main reason for doing is this is to allow us to transfer a perf_counter_context from one task to another when we do lazy PMU switching in a later patch. This has a few side-benefits: the task_struct becomes a little smaller, we save some memory because only tasks that have perf_counters attached get a perf_counter_context allocated for them, and we can remove the inclusion of <linux/perf_counter.h> in sched.h, meaning that we don't end up recompiling nearly everything whenever perf_counter.h changes. The perf_counter_context structures are reference-counted and freed when the last reference is dropped. A context can have references from its task and the counters on its task. Counters can outlive the task so it is possible that a context will be freed well after its task has exited. Contexts are allocated on fork if the parent had a context, or otherwise the first time that a per-task counter is created on a task. In the latter case, we set the context pointer in the task struct locklessly using an atomic compare-and-exchange operation in case we raced with some other task in creating a context for the subject task. This also removes the task pointer from the perf_counter struct. The task pointer was not used anywhere and would make it harder to move a context from one task to another. Anything that needed to know which task a counter was attached to was already using counter->ctx->task. The __perf_counter_init_context function moves up in perf_counter.c so that it can be called from find_get_context, and now initializes the refcount, but is otherwise unchanged. We were potentially calling list_del_counter twice: once from __perf_counter_exit_task when the task exits and once from __perf_counter_remove_from_context when the counter's fd gets closed. This adds a check in list_del_counter so it doesn't do anything if the counter has already been removed from the lists. Since perf_counter_task_sched_in doesn't do anything if the task doesn't have a context, and leaves cpuctx->task_ctx = NULL, this adds code to __perf_install_in_context to set cpuctx->task_ctx if necessary, i.e. in the case where the current task adds the first counter to itself and thus creates a context for itself. This also adds similar code to __perf_counter_enable to handle a similar situation which can arise when the counters have been disabled using prctl; that also leaves cpuctx->task_ctx = NULL. [ Impact: refactor counter context management to prepare for new feature ] Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <18966.10075.781053.231153@cargo.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-11CRED: Rename cred_exec_mutex to reflect that it's a guard against ptraceDavid Howells
Rename cred_exec_mutex to reflect that it's a guard against foreign intervention on a process's credential state, such as is made by ptrace(). The attachment of a debugger to a process affects execve()'s calculation of the new credential state - _and_ also setprocattr()'s calculation of that state. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-07Merge branch 'linus' into tracing/coreIngo Molnar
Merge reason: tracing/core was on a .30-rc1 base and was missing out on on a handful of tracing fixes present in .30-rc5-almost. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-29Merge branch 'linus' into perfcounters/coreIngo Molnar
Merge reason: This brach was on -rc1, refresh it to almost-rc4 to pick up the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-17tracing: add same level recursion detectionSteven Rostedt
The tracing infrastructure allows for recursion. That is, an interrupt may interrupt the act of tracing an event, and that interrupt may very well perform its own trace. This is a recursive trace, and is fine to do. The problem arises when there is a bug, and the utility doing the trace calls something that recurses back into the tracer. This recursion is not caused by an external event like an interrupt, but by code that is not expected to recurse. The result could be a lockup. This patch adds a bitmask to the task structure that keeps track of the trace recursion. To find the interrupt depth, the following algorithm is used: level = hardirq_count() + softirq_count() + in_nmi; Here, level will be the depth of interrutps and softirqs, and even handles the nmi. Then the corresponding bit is set in the recursion bitmask. If the bit was already set, we know we had a recursion at the same level and we warn about it and fail the writing to the buffer. After the data has been committed to the buffer, we clear the bit. No atomics are needed. The only races are with interrupts and they reset the bitmask before returning anywy. [ Impact: detect same irq level trace recursion ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-13aio: remove INIT_KIOCTXAlexey Dobriyan
Unused after 20dcae32439384b6863c626bb3b2a09bed65b33e aka "[PATCH] aio: remove kioctx from mm_struct". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-08Merge commit 'v2.6.30-rc1' into perfcounters/coreIngo Molnar
Conflicts: arch/powerpc/include/asm/systbl.h arch/powerpc/include/asm/unistd.h include/linux/init_task.h Merge reason: the conflicts are non-trivial: PowerPC placement of sys_perf_counter_open has to be mixed with the new preadv/pwrite syscalls. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: branch tracer, intel-iommu: fix build with CONFIG_BRANCH_TRACER=y branch tracer: Fix for enabling branch profiling makes sparse unusable ftrace: Correct a text align for event format output Update /debug/tracing/README tracing/ftrace: alloc the started cpumask for the trace file tracing, x86: remove duplicated #include ftrace: Add check of sched_stopped for probe_sched_wakeup function-graph: add proper initialization for init task tracing/ftrace: fix missing include string.h tracing: fix incorrect return type of ns2usecs() tracing: remove CALLER_ADDR2 from wakeup tracer blktrace: fix pdu_len when tracing packet command requests blktrace: small cleanup in blk_msg_write() blktrace: NUL-terminate user space messages tracing: move scripts/trace/power.pl to scripts/tracing/power.pl
2009-04-07Merge branch 'tracing/urgent' into tracing/ftraceIngo Molnar
2009-04-07function-graph: add proper initialization for init taskSteven Rostedt
Impact: fix to crash going to kexec The init task did not properly initialize the function graph pointers. Altough these pointers are NULL, they can not be assumed to be NULL for the init task, and must still be properly initialize. This usually is not an issue since a problem only arises when a task exits, and the init tasks do not usually exit. But when doing tests with kexec, the init tasks do exit, and the bug appears. This patch properly initializes the init tasks function graph data structures. Reported-and-Tested-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <alpine.DEB.2.00.0903252053080.5675@gandalf.stny.rr.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-06perf_counter: fix uninitialized usage of event_listPeter Zijlstra
Impact: fix boot crash When doing the generic context switch event I ran into some early boot hangs, which were caused by inf func recursion (event, fault, event, fault). I eventually tracked it down to event_list not being initialized at the time of the first event. Fix this. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Steven Rostedt <rostedt@goodmis.org> Orig-LKML-Reference: <20090319194233.195392657@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-06Merge branch 'linus' into perfcounters/core-v2Ingo Molnar
Merge reason: we have gathered quite a few conflicts, need to merge upstream Conflicts: arch/powerpc/kernel/Makefile arch/x86/ia32/ia32entry.S arch/x86/include/asm/hardirq.h arch/x86/include/asm/unistd_32.h arch/x86/include/asm/unistd_64.h arch/x86/kernel/cpu/common.c arch/x86/kernel/irq.c arch/x86/kernel/syscall_table_32.S arch/x86/mm/iomap_32.c include/linux/sched.h kernel/Makefile Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-15Merge branch 'sched/urgent'; commit 'v2.6.29-rc5' into sched/coreIngo Molnar
2009-02-13Merge branch 'linus' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/acpi/boot.c
2009-02-11Merge commit 'v2.6.29-rc4' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/setup_percpu.c arch/x86/mm/fault.c drivers/acpi/processor_idle.c kernel/irq/handle.c
