Add an ioctl, EVIOCSSUSPENDBLOCK, to enable a wakelock that will block
suspend while the event queue is not empty. This allows userspace code to
process input events while the device appears to be asleep.
The current code holds the wakelock for up 5 seconds for every input
device and client. This can prevent suspend if sensor with a high data
rate is active, even when that sensor is not capable of waking the
device once it is suspended.
Change-Id: I624d66ef30a0b3abb543685c343382b8419b42b9
Signed-off-by: Arve Hjønnevåg <arve@android.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: xen-kbdfront - fix mouse getting stuck after save/restore
Input: estimate number of events per packet
Input: evdev - indicate buffer overrun with SYN_DROPPED
Input: document event types and codes and their intended use
Input: add KEY_IMAGES specifically for AL Image Browser
Input: twl4030_keypad - fix potential NULL dereference in twl4030_kp_probe()
Input: h3600_ts - fix error handling at connect
Input: twl4030_keypad - avoid potential NULL-pointer dereference
Add a new EV_SYN code, SYN_DROPPED, to inform the client when input
events have been dropped from the evdev input buffer due to a
buffer overrun. The client should use this event as a hint to
reset its state or ignore all following events until the next
packet begins.
Signed-off-by: Jeff Brown <jeffbrown@android.com>
[dtor@mail.ru: Implement Henrik's suggestion and drop old events in
case of overflow.]
Many media center remotes have buttons intended for jumping straight to
one type of media browser or another -- commonly, images/photos/pictures,
audio/music, television, and movies. At present, remotes with an images
or photos or pictures button use any number of different keycodes which
sort of maybe fit. I've seen at least KEY_MEDIA, KEY_CAMERA,
KEY_GRAPHICSEDITOR and KEY_PRESENTATION. None of those seem quite right.
In my mind, KEY_MEDIA should be something more like a media center
application launcher (and I'd like to standardize on that for things
like the windows media center button on the mce remotes). KEY_CAMERA is
used in a lot of webcams, and typically means "take a picture now".
KEY_GRAPHICSEDITOR implies an editor, not a browser. KEY_PRESENTATION
might be the closest fit here, if you think "photo slide show", but it
may well be more intended for "run application in full-screen
presentation mode" or to launch something like magicpoint, I dunno.
And thus, I'd like to have a KEY_IMAGES, which matches the HID Usage AL
Image Browser, the meaning of which I think is crystal-clear. I believe
AL Audio Browser is already covered by KEY_AUDIO, and AL Movie Browser
by KEY_VIDEO, so I'm also adding appropriate comments next to those
keys.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
These keys are supposed to be handled by any software
using the camera (like webKam or cheese...). They can
also be used to actually move the camera when possible.
Signed-off-by: Corentin Chary <corentincj@iksaif.net>
All users of old style get/setkeycode methids have been converted so
it is time to retire them.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Input: add SW_ROTATE_LOCK switch type
Input: fix force feedback capability query example
Input: wacom_w8001 - add single-touch support
Input: add Austria Microsystem AS5011 joystick driver
Input: remove aaed2000 keyboard driver
Input: i8042 - introduce 'notimeout' blacklist for Dell Vostro V13
Input: cy8ctmg110_ts - Convert to dev_pm_ops
Input: migor_ts - convert to dev_pm_ops
Input: mcs5000_ts - convert to dev_pm_ops
Input: eeti_ts - convert to dev_pm_ops
Input: ad7879 - convert I2C to dev_pm_ops
This switch is used to signal that user want to disable screen
transitions from portrait to landscape mode and back.
Signed-off-by: Jekyll Lai <jekyll_lai@wistron.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (58 commits)
Input: wacom_w8001 - support pen or touch only devices
Input: wacom_w8001 - use __set_bit to set keybits
Input: bu21013_ts - fix misuse of logical operation in place of bitop
Input: i8042 - add Acer Aspire 5100 to the Dritek list
Input: wacom - add support for digitizer in Lenovo W700
Input: psmouse - disable the synaptics extension on OLPC machines
Input: psmouse - fix up Synaptics comment
Input: synaptics - ignore bogus mt packet
Input: synaptics - add multi-finger and semi-mt support
Input: synaptics - report clickpad property
input: mt: Document interface updates
Input: fix double equality sign in uevent
Input: introduce device properties
hid: egalax: Add support for Wetab (726b)
Input: include MT library as source for kerneldoc
MAINTAINERS: Update input-mt entry
hid: egalax: Add support for Samsung NB30 netbook
hid: egalax: Document the new devices in Kconfig
hid: egalax: Convert to MT slots
Fixed up trivial conflict in drivers/input/keyboard/Kconfig
include/linux/input.h
The patch fixes the rc-tbs-nec table after converting
drivers/media/video/cx88 to ir-core
(commit ba7e90c9f878e0ac3c0614a5446fe5c62ccc33ec).
It is also adds two missing buttons (10- and 10+) with
its definition (KEY_10CHANNELSUP and KEY_10CHANNELSDOWN).
[mchehab@redhat.com: move keycode numbers to 0x1b8/0x1b9 as requested by the input Maintainer]
Signed-off-by: Mariusz Białończyk <manio@skyboo.net>
git://git.kernel.org/pub/scm/linux/kernel/git/rydberg/input-mt into next
Today, userspace sets up an input device based on the data it emits.
This is not always enough; a tablet and a touchscreen may emit exactly
the same data, for instance, but the former should be set up with a
pointer whereas the latter does not need to. Recently, a new type of
touchpad has emerged where the buttons are under the pad, which
changes logic without changing the emitted data. This patch introduces
a new ioctl, EVIOCGPROP, which enables user access to a set of device
properties useful during setup. The properties are given as a bitmap
in the same fashion as the event types, and are also made available
via sysfs, uevent and /proc/bus/input/devices.
Acked-by: Ping Cheng <pingc@wacom.com>
Acked-by: Chase Douglas <chase.douglas@canonical.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
drivers/input/Makefile
Touch devices capable of hovering, i.e., fingers detected a
distance from the surface, are not supported by the current
input MT protocol. This patch adds ABS_MT_DISTANCE, which may
be used to indicate the distance between the contact and the
surface.
The drivers using the type B protocol all report tracking information
the same way. The contact id is semantically equivalent to
ABS_MT_SLOT, and the handling of ABS_MT_TRACKING_ID only complicates
the driver. The situation can be improved upon by providing a common
pointer emulation code, thereby removing the need for the tracking id
in the driver. This patch moves all tracking event handling over to
the input core, simplifying both the existing drivers and the ones
currently in preparation.
In preparation for common code to handle a larger set of MT slots
devices, move the slots handling over to a separate file.
The desire to keep old names for the EVIOCGKEYCODE/EVIOCSKEYCODE while
extending them to support large scancodes was a mistake. While we tried
to keep ABI intact (and we succeeded in doing that, programs compiled
on older kernels will work on newer ones) there is still a problem with
recompiling existing software with newer kernel headers.
New kernel headers will supply updated ioctl numbers and kernel will
expect that userspace will use struct input_keymap_entry to set and
retrieve keymap data. But since the names of ioctls are still the same
userspace will happily compile even if not adjusted to make use of the
new structure and will start miraculously fail in the field.
To avoid this issue let's revert EVIOCGKEYCODE/EVIOCSKEYCODE definitions
and add EVIOCGKEYCODE_V2/EVIOCSKEYCODE_V2 so that userspace can explicitly
select the style of ioctls it wants to employ.
Reviewed-by: Henrik Rydberg <rydberg@euromail.se>
Acked-by: Jarod Wilson <jarod@redhat.com>
Add documentation for struct input_absinfo that is used in EVIOCGABS
and EVIOCSABS ioctl and specify units of measure used for reporting
resolution for an axis.
Acked-by: Henrik Rydberg <rydberg@euromail.se>
Some laptops will have a "touchpad toggle" soft button, which expects
user-space to turn off the touchpad themselves, some other devices will
do this in hardware, but send key events telling us that the touchpad
has been turned off/on.
KEY_TOUCHPAD_ON/KEY_TOUCHPAD_OFF will be used by user-space to show a
popup with the status of the touchpad.
Signed-off-by: Bastien Nocera <hadess@hadess.net>
KGDB, much like the resume process, needs to be able to mark all keys that
were pressed at the time we dropped into the debuggers as "released", since
it is unlikely that the keys stay pressed for the entire duration of the
debug session.
Also we need to make sure that input_reset_device() and input_dev_suspend()
only attempt to change state of currenlt opened devices since closed devices
may not be ready to accept IO requests.
Tested-by: Jason Wessel <jason.wessel@windriver.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (75 commits)
Input: wacom - specify Cinitq supported tools
Input: ab8500-ponkey - fix IRQ freeing in error path
Input: adp5588-keys - use more obvious i2c_device_id name string
Input: ad7877 - switch to using threaded IRQ
Input: ad7877 - use attribute group to control visibility of attributes
Input: serio - add support for PS2Mult multiplexer protocol
Input: wacom - properly enable runtime PM
Input: ad7877 - filter events where pressure is beyond the maximum
Input: ad7877 - implement EV_KEY:BTN_TOUCH reporting
Input: ad7877 - implement specified chip select behavior
Input: hp680_ts_input - use cancel_delayed_work_sync()
Input: mousedev - correct lockdep annotation
Input: ads7846 - switch to using threaded IRQ
Input: serio - support multiple child devices per single parent
Input: synaptics - simplify pass-through port handling
Input: add ROHM BU21013 touch panel controller support
Input: omap4-keypad - wake-up on events & long presses
Input: omap4-keypad - fix interrupt line configuration
Input: omap4-keypad - SYSCONFIG register configuration
Input: omap4-keypad - use platform device helpers
Several devices use a high number of bits for scancodes. One important
group is the Remote Controllers. Some new protocols like RC-6 define a
scancode space of 64 bits.
The current EVIO[CS]GKEYCODE ioctls allow replace the scancode/keycode
translation tables, but it is limited to up to 32 bits for scancode.
Also, if userspace wants to clean the existing table, replacing it by
a new one, it needs to run a loop calling the ioctls over the entire
sparse scancode space.
To solve those problems, this patch extends the ioctls to allow drivers
handle scancodes up to 32 bytes long (the length could be extended in
the future should such need arise) and allow userspace to query and set
scancode to keycode mappings not only by scancode but also by index.
Compatibility code were also added to handle the old format of
EVIO[CS]GKEYCODE ioctls.
Folded fixes by:
- Dan Carpenter: locking fixes for the original implementation
- Jarod Wilson: fix crash when setting keycode and wiring up get/set
handlers in original implementation.
- Dmitry Torokhov: rework to consolidate old and new scancode handling,
provide options to act either by index or scancode.
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
As all callers are now changed to only use the input_abs_*() access
helpers, switching over to dynamically allocated ABS information is
easy. This reduces size of struct input_dev from 3152 to 1640 on
64 bit architectures.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
In preparation for dynamically allocated ABS axis, introduce a number of
static inline access helpers. This should make the transition less
painful.
With the rapidly increasing number of intelligent multi-contact and
multi-user devices, the need to send digested, filtered information
from a set of different sources within the same device is imminent.
This patch adds the concept of slots to the MT protocol. The slots
enumerate a set of identified sources, such that all MT events
can be passed independently and selectively per identified source.
The protocol works like this: Instead of sending a SYN_MT_REPORT
event immediately after the contact data, one sends an ABS_MT_SLOT
event immediately before the contact data. The input core will only
emit events for slots with modified MT events. It is assumed that
the same slot is used for the duration of an initiated contact.
Acked-by: Rafi Rubin <rafi@seas.upenn.edu>
Some devices, in particular MT devices, produce a lot of data. This
may lead to overflowing of the event queues in evdev driver, which
by default are fairly small. Let the drivers hint the average number
of events per packet generated by the device, and use that information
when computing the buffer size evdev should use for the device.
AD7142 and AD7147 are integrated capacitance-to-digital converters
(CDCs) with on-chip environmental calibration for use in systems
requiring a novel user input method. The AD7142 and AD7147 can interface
to external capacitance sensors implementing functions such as buttons,
scrollwheels, sliders, touchpads and so on.
The chips don't restrict the specific usage. Depending on the hardware
connection, one special target board can include one or several these
components. The platform_data for the device's "struct device" holds
these information. The data-struct defined in head file descript the
hardware feature of button/scrollwheel/slider/touchpad components on
target boards, which need be filled in the arch/mach-/.
As the result, the driver is independent of boards. It gets the
components layout from the platform_data, registers related devices,
fullfills the algorithms and state machines for these components and
report related input events to up level.
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Barry Song <21cnbao@gmail.com>
The HID layer has some scan codes of the form 0xffbc0000 for logitech
devices which do not work if scancode is typed as signed int, so we need
to switch to unsigned it instead. While at it keycode being signed does
not make much sense either.
Acked-by: Márton Németh <nm127@freemail.hu>
Acked-by: Matthew Garrett <mjg@redhat.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (62 commits)
Input: atkbd - release previously reserved keycodes 248 - 254
Input: add KEY_WPS_BUTTON definition
Input: ads7846 - add regulator support
Input: winbond-cir - fix suspend/resume
Input: gamecon - use pr_err() and friends
Input: gamecon - constify some of the setup structures
Input: gamecon - simplify pad type handling
Input: gamecon - simplify coordinate calculation for PSX
Input: gamecon - fix some formatting issues
Input: gamecon - add rumble support for N64 pads
Input: wacom - add device type to device name string
Input: s3c24xx_ts - report touch only when stylus is down
Input: s3c24xx_ts - re-enable IRQ on resume
Input: wacom - constify product features data
Input: wacom - use per-device instance of wacom_features
Input: sh_keysc - enable building on SH-Mobile ARM
Input: wacom - get features from driver info
Input: rotary-encoder - set gpio direction for each requested gpio
Input: sh_keysc - update the driver with mode 6
Input: sh_keysc - switch to using bitmaps
Keycodes in 248 - 254 range were reserved for special needs (scrolling)
of atkbd driver. Now that the driver has been switched to use unsigned
short keycodes instead of unsigned char we can release this range back
into pull. We keep code 255 (ATKBD_KEY_NULL) reserved since users may
have been using it to silence keys they do not care about since atkbd
silently drops scancodes mapped to this keycode.
The new key definition is supposed to be used for buttons that initiate
WiFi Protected setup sequence:
http://en.wikipedia.org/wiki/Wi-Fi_Protected_Setup
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (41 commits)
HID: usbhid: initialize interface pointers early enough
HID: extend mask for BUTTON usage page
HID: hid-ntrig: Single touch mode tap
HID: hid-ntrig: multitouch cleanup and fix
HID: n-trig: remove unnecessary tool switching
HID: hid-ntrig add multi input quirk and clean up
HID: usbhid: introduce timeout for stuck ctrl/out URBs
HID: magicmouse: coding style and probe failure fixes
HID: remove MODULE_VERSION from new drivers
HID: fix up Kconfig entry for MagicMouse
HID: add a device driver for the Apple Magic Mouse.
HID: Export hid_register_report
HID: Support for MosArt multitouch panel
HID: add pressure support for the Stantum multitouch panel
HID: fixed bug in single-touch emulation on the stantum panel
HID: fix typo in error message
HID: add mapping for "AL Network Chat" usage
HID: use multi input quirk for TouchPack touchscreen
HID: make full-fledged hid-bus drivers properly selectable
HID: make Wacom modesetting failures non-fatal
Most laptops have keys that are intended to toggle all device state, not
just wifi. These are currently generally mapped to KEY_WLAN. As a result,
rfkill will only kill or enable wifi in response to the key press. This
confuses users and can make it difficult for them to enable bluetooth
and wwan devices.
This patch adds a new keycode, KEY_RFKILL. It indicates that the system
should toggle the state of all rfkillable devices.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Get rid of blacklist in input handler structure and instead allow
handlers to define their own match() method to perform fine-grained
filtering of supported devices.
drivers/hid/hid-ids.h
Sometimes it is desirable to suppress certain events from reaching
input handlers and thus user space. One such example is Mac mouse
button emulation code which catches certain key presses and converts
them into button clicks as if they were emitted by a virtual mouse.
The original key press events should be completely suppressed,
otherwise user space will be confused, and while keyboard driver
does it on its own evdev is blissfully unaware of this arrangement.
This patch adds notion of 'filter' to the standard input handlers,
which may flag event as filtered thus preventing it from reaching
other input handlers. Filters don't (nor will they ever) have a
notion of priority relative to each other, input core will run all
of them first and any one of them may mark event as filtered.
This patch is inspired by similar patch by Matthew Garret but the
implementation and intended usage are quite different.
For pressure-based multi-touch devices, a direct way to send sensor
intensity data per finger is needed. This patch adds the ABS_MT_PRESSURE
event to the MT protocol.
Requested-by: Yoonyoung Shim <jy0922.shim@samsung.com>
Requested-by: Mika Kuoppala <mika.kuoppala@nokia.com>
Requested-by: Peter Hutterer <peter.hutterer@who-t.net>
Current HID code doesn't properly handle HID joysticks which have
larger number of buttons than what fits into current range reserved
for BTN_JOYSTICK.
One such joystick reported to not work properly is Saitek X52 Pro
Flight System.
We can't extend the range to fit more buttons in, because of backwards
compatibility reasons.
Therefore this patch introduces a new BTN_TRIGGER_HAPPY range, and
uses these to map the buttons which are over BTN_JOYSTICK limit.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> [for the input.h part]
Keyboard handler should not attempt to traverse handler->h_list on
its own, without any locking, otherwise it races with registering
and unregistering of input handles which leads to crashes.
Introduce input_handler_for_each_handle() helper that allows safely
iterate over all handles attached to a particular handler and switch
keyboard handler to use it.
Reported-by: Jim Paradis <jparadis@redhat.com>
Make sure that polled input device and matrix keypad APIs are included
with the rest of input API when generating kernel documentation. Also
description of absres was missing as well.
Now that input core acquires dev->event_lock spinlock and disables
interrupts when propagating input events, using spin_lock_bh() in
ff-memless driver is not allowed. Actually, the timer_lock itself
is not needed anymore, we should simply use dev->event_lock
as well.
Also do a small cleanup in force-feedback core.
Reported-by: kerneloops.org
Reported-by: http://www.kerneloops.org/searchweek.php?search=ml_ff_set_gain
Reported-by: Arjan van de Ven <arjan@linux.intel.com>
Add new codes for camera focus key, and camera lens cover, keypad slide,
front proximity switches.
Signed-off-by: Jani Nikula <ext-jani.1.nikula@nokia.com>
