path: root/include/linux/integrity.h
2013-03-27Remove spurious _H suffixes from ifdef commentsPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-09-07ima: allocating iint improvementsDmitry Kasatkin
With IMA-appraisal's removal of the iint mutex and taking the i_mutex instead, allocating the iint becomes a lot simplier, as we don't need to be concerned with two processes racing to allocate the iint. This patch cleans up and improves performance for allocating the iint. - removed redundant double i_mutex locking - combined iint allocation with tree search Changelog v2: - removed the rwlock/read_lock changes from this patch Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2011-09-14evm: permit mode bits to be updatedMimi Zohar
Before permitting 'security.evm' to be updated, 'security.evm' must exist and be valid. In the case that there are no existing EVM protected xattrs, it is safe for posix acls to update the mode bits. To differentiate between no 'security.evm' xattr and no xattrs used to calculate 'security.evm', this patch defines INTEGRITY_NOXATTR. Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2011-07-18evm: add support for different security.evm data typesDmitry Kasatkin
EVM protects a file's security extended attributes(xattrs) against integrity attacks. The current patchset maintains an HMAC-sha1 value across the security xattrs, storing the value as the extended attribute 'security.evm'. We anticipate other methods for protecting the security extended attributes. This patch reserves the first byte of 'security.evm' as a place holder for the type of method. Changelog v6: - move evm_ima_xattr_type definition to security/integrity/integrity.h - defined a structure for the EVM xattr called evm_ima_xattr_data (based on Serge Hallyn's suggestion) - removed unnecessary memset Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@nokia.com> Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
2011-07-18evm: re-releaseMimi Zohar
EVM protects a file's security extended attributes(xattrs) against integrity attacks. This patchset provides the framework and an initial method. The initial method maintains an HMAC-sha1 value across the security extended attributes, storing the HMAC value as the extended attribute 'security.evm'. Other methods of validating the integrity of a file's metadata will be posted separately (eg. EVM-digital-signatures). While this patchset does authenticate the security xattrs, and cryptographically binds them to the inode, coming extensions will bind other directory and inode metadata for more complete protection. To help simplify the review and upstreaming process, each extension will be posted separately (eg. IMA-appraisal, IMA-appraisal-directory). For a general overview of the proposed Linux integrity subsystem, refer to Dave Safford's whitepaper: http://downloads.sf.net/project/linux-ima/linux-ima/Integrity_overview.pdf. EVM depends on the Kernel Key Retention System to provide it with a trusted/encrypted key for the HMAC-sha1 operation. The key is loaded onto the root's keyring using keyctl. Until EVM receives notification that the key has been successfully loaded onto the keyring (echo 1 > <securityfs>/evm), EVM can not create or validate the 'security.evm' xattr, but returns INTEGRITY_UNKNOWN. Loading the key and signaling EVM should be done as early as possible. Normally this is done in the initramfs, which has already been measured as part of the trusted boot. For more information on creating and loading existing trusted/encrypted keys, refer to Documentation/keys-trusted-encrypted.txt. A sample dracut patch, which loads the trusted/encrypted key and enables EVM, is available from http://linux-ima.sourceforge.net/#EVM. Based on the LSMs enabled, the set of EVM protected security xattrs is defined at compile. EVM adds the following three calls to the existing security hooks: evm_inode_setxattr(), evm_inode_post_setxattr(), and evm_inode_removexattr. To initialize and update the 'security.evm' extended attribute, EVM defines three calls: evm_inode_post_init(), evm_inode_post_setattr() and evm_inode_post_removexattr() hooks. To verify the integrity of a security xattr, EVM exports evm_verifyxattr(). Changelog v7: - Fixed URL in EVM ABI documentation Changelog v6: (based on Serge Hallyn's review) - fix URL in patch description - remove evm_hmac_size definition - use SHA1_DIGEST_SIZE (removed both MAX_DIGEST_SIZE and evm_hmac_size) - moved linux include before other includes - test for crypto_hash_setkey failure - fail earlier for invalid key - clear entire encrypted key, even on failure - check xattr name length before comparing xattr names Changelog: - locking based on i_mutex, remove evm_mutex - using trusted/encrypted keys for storing the EVM key used in the HMAC-sha1 operation. - replaced crypto hash with shash (Dmitry Kasatkin) - support for additional methods of verifying the security xattrs (Dmitry Kasatkin) - iint not allocated for all regular files, but only for those appraised - Use cap_sys_admin in lieu of cap_mac_admin - Use __vfs_setxattr_noperm(), without permission checks, from EVM Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
2011-07-18integrity: move ima inode integrity data managementMimi Zohar
Move the inode integrity data(iint) management up to the integrity directory in order to share the iint among the different integrity models. Changelog: - don't define MAX_DIGEST_SIZE - rename several globally visible 'ima_' prefixed functions, structs, locks, etc to 'integrity_' - replace '20' with SHA1_DIGEST_SIZE - reflect location change in appropriate Kconfig and Makefiles - remove unnecessary initialization of iint_initialized to 0 - rebased on current ima_iint.c - define integrity_iint_store/lock as static There should be no other functional changes. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serge.hallyn@ubuntu.com>
