path: root/include/linux/iocontext.h
2011-07-12CFQ: move think time check variables to a separate structShaohua Li
Move the variables to do think time check to a sepatate struct. This is to prepare adding think time check for service tree and group. No functional change. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-11block: remove unused copy_io_context()Jens Axboe
Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-19kernel: __rcu annotationsArnd Bergmann
This adds annotations for RCU operations in core kernel components Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-05-24cfq-iosched: remove dead_key from cfq_io_contextKonstantin Khlebnikov
Remove ->dead_key field from cfq_io_context to shrink its size to 128 bytes. (64 bytes for 32-bit hosts) Use lower bit in ->key as dead-mark, instead of moving key to separate field. After this for dead cfq_io_context we got cic->key != cfqd automatically. Thus, io_context's last-hit cache should work without changing. Now to check ->key for non-dead state compare it with cfqd, instead of checking ->key for non-null value as it was before. Plus remove obsolete race protection in cfq_cic_lookup. This race gone after v2.6.24-1728-g4ac845a Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-12cgroups: blkio subsystem as moduleBen Blum
Modify the Block I/O cgroup subsystem to be able to be built as a module. As the CFQ disk scheduler optionally depends on blk-cgroup, config options in block/Kconfig, block/Kconfig.iosched, and block/blk-cgroup.h are enhanced to support the new module dependency. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-26block: remove padding from io_context on 64bit buildsRichard Kennedy
On 64 bit builds when CONFIG_BLK_CGROUP=n (the default) this removes 8 bytes of padding from structure io_context and drops its size from 72 to 64 bytes, so needing one fewer cachelines and allowing more objects per slab in it's kmem_cache. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> ---- patch against 2.6.33 compiled & test on x86_64 AMDX2 regards Richard Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-01-11block: removed unused as_io_contextKirill Afonshin
It isn't used anymore, since AS was deleted. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-04block: Fix io_context leak after failure of clone with CLONE_IOLouis Rilling
With CLONE_IO, parent's io_context->nr_tasks is incremented, but never decremented whenever copy_process() fails afterwards, which prevents exit_io_context() from calling IO schedulers exit functions. Give a task_struct to exit_io_context(), and call exit_io_context() instead of put_io_context() in copy_process() cleanup path. Signed-off-by: Louis Rilling <louis.rilling@kerlabs.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-03blkio: Introduce blkio controller cgroup interfaceVivek Goyal
o This is basic implementation of blkio controller cgroup interface. This is the common interface visible to user space and should be used by different IO control policies as we implement those. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-26cfq: calculate the seek_mean per cfq_queue not per cfq_io_contextJeff Moyer
async cfq_queue's are already shared between processes within the same priority, and forthcoming patches will change the mapping of cic to sync cfq_queue from 1:1 to 1:N. So, calculate the seekiness of a process based on the cfq_queue instead of the cfq_io_context. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-31io context: fix ref countingLi Zefan
Commit d9c7d394a8ebacb60097b192939ae9f15235225e ("block: prevent possible io_context->refcount overflow") mistakenly changed atomic_inc(&ioc->nr_tasks) to atomic_long_inc(&ioc->refcount). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-10block: prevent possible io_context->refcount overflowNikanth Karthikesan
Currently io_context has an atomic_t(32-bit) as refcount. In the case of cfq, for each device against whcih a task does I/O, a reference to the io_context would be taken. And when there are multiple process sharing io_contexts(CLONE_IO) would also have a reference to the same io_context. Theoretically the possible maximum number of processes sharing the same io_context + the number of disks/cfq_data referring to the same io_context can overflow the 32-bit counter on a very high-end machine. Even though it is an improbable case, let us make it atomic_long_t. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-07-03block: blkdev.h cleanup, move iocontext stuff to iocontext.hJens Axboe
2008-04-15io context: increment task attachment count in ioc_task_link()Jens Axboe
Thanks to Nikanth Karthikesan <knikanth@suse.de> for reporting this. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-02cfq-iosched: fix rcu freeing of cfq io contextsFabio Checconi
SLAB_DESTROY_BY_RCU is not a direct substitute for normal call_rcu() freeing, since it'll page freeing but NOT object freeing. So change cfq to do the freeing on its own. Signed-off-by: Fabio Checconi <fabio@gandalf.sssup.it> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19cfq-iosched: add hlist for browsing parallel to the radix treeJens Axboe
It's cumbersome to browse a radix tree from start to finish, especially since we modify keys when a process exits. So add a hlist for the single purpose of browsing over all known cfq_io_contexts, used for exit, io prio change, etc. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=9948 Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28block: cfq: make the io contect sharing locklessJens Axboe
The io context sharing introduced a per-ioc spinlock, that would protect the cfq io context lookup. That is a regression from the original, since we never needed any locking there because the ioc/cic were process private. The cic lookup is changed from an rbtree construct to a radix tree, which we can then use RCU to make the reader side lockless. That is the performance critical path, modifying the radix tree is only done on process creation (when that process first does IO, actually) and on process exit (if that process has done IO). As it so happens, radix trees are also much faster for this type of lookup where the key is a pointer. It's a very sparse tree. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28io context sharing: preliminary supportJens Axboe
Detach task state from ioc, instead keep track of how many processes are accessing the ioc. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28ioprio: move io priority from task_struct to io_contextJens Axboe
This is where it belongs and then it doesn't take up space for a process that doesn't do IO. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
