path: root/include/linux/jbd2.h
2007-07-18jbd2: Move jbd2-debug file to debugfsJose R. Santos
The jbd2-debug file used to be located in /proc/sys/fs/jbd2-debug, but it incorrectly used create_proc_entry() instead of the sysctl routines, and no proc entry was ever created. Instead of fixing this we might as well move the jbd2-debug file to debugfs which would be the preferred location for this kind of tunable. The new location is now /sys/kernel/debug/jbd2/jbd2-debug. Signed-off-by: Jose R. Santos <jrs@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2007-07-18jbd2: Fix CONFIG_JBD_DEBUG ifdef to be CONFIG_JBD2_DEBUGJose R. Santos
When the JBD code was forked to create the new JBD2 code base, the references to CONFIG_JBD_DEBUG where never changed to CONFIG_JBD2_DEBUG. This patch fixes that. Signed-off-by: Jose R. Santos <jrs@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2006-12-07[PATCH] make fs/jbd2/transaction.c:__kbd2_journal_temp_unlink_buffer() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: switch blks_type from sector_t to ullMingming Cao
Similar to ext4, change blocks in JBD2 from sector_t to unsigned long long. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: sector_t conversionMingming Cao
JBD layer in-kernel block varibles type fixes to support >32 bit block number and convert to sector_t type. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] 64-bit jbd2 coreZach Brown
Here is the patch to JBD to handle 64 bit block numbers, originally from Zach Brown. This patch is useful only after adding support for 64-bit block numbers in the filesystem. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: rename jbd2 symbols to avoid duplication of jbd symbolsMingming Cao
Mingming Cao originally did this work, and Shaggy reproduced it using some scripts from her. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: initial copy of files from jbdDave Kleikamp
This is a simple copy of the files in fs/jbd to fs/jbd2 and /usr/incude/linux/[ext4_]jbd.h to /usr/include/[ext4_]jbd2.h Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
