Pull NOHZ changes from Ingo Molnar:
"This tree adds full dynticks support to KVM guests (support the
disabling of the timer tick on the guest). The main missing piece was
the recognition of guest execution as RCU extended quiescent state and
related changes"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
kvm,rcu,nohz: use RCU extended quiescent state when running KVM guest
context_tracking: Export context_tracking_user_enter/exit
context_tracking: Run vtime_user_enter/exit only when state == CONTEXT_USER
context_tracking: Add stub context_tracking_is_enabled
context_tracking: Generalize context tracking APIs to support user and guest
context_tracking: Rename context symbols to prepare for transition state
ppc: Remove unused cpp symbols in kvm headers
After reset, the CPU can change the BSP, which will be used upon INIT. Reset
should return the BSP which QEMU asked for, and therefore handled accordingly.
To quote: "If the MP protocol has completed and a BSP is chosen, subsequent
INITs (either to a specific processor or system wide) do not cause the MP
protocol to be repeated."
[Intel SDM 8.4.2: MP Initialization Protocol Requirements and Restrictions]
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
Message-Id: <1427933438-12782-3-git-send-email-namit@cs.technion.ac.il>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into 'kvm-next'
KVM/ARM changes for v4.1:
- fixes for live migration
- irqfd support
- kvm-io-bus & vgic rework to enable ioeventfd
- page ageing for stage-2 translation
- various cleanups
This is needed in e.g. ARM vGIC emulation, where the MMIO handling
depends on the VCPU that does the access.
Signed-off-by: Nikolay Nikolaev <n.nikolaev@virtualopensystems.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Acked-by: Christoffer Dall <christoffer.dall@linaro.org>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Introduce __KVM_HAVE_ARCH_INTC_INITIALIZED define and
associated kvm_arch_intc_initialized function. This latter
allows to test whether the virtual interrupt controller is initialized
and ready to accept virtual IRQ injection. On some architectures,
the virtual interrupt controller is dynamically instantiated, justifying
that kind of check.
The new function can now be used by irqfd to check whether the
virtual interrupt controller is ready on KVM_IRQFD request. If not,
KVM_IRQFD returns -EAGAIN.
Signed-off-by: Eric Auger <eric.auger@linaro.org>
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
kvm_kvfree() provides exactly the same functionality as the
new common kvfree() function - so let's simply replace the
kvm function with the common function.
Signed-off-by: Thomas Huth <thuth@linux.vnet.ibm.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
The host kernel is not doing anything while the CPU is executing
a KVM guest VCPU, so it can be marked as being in an extended
quiescent state, identical to that used when running user space
code.
The only exception to that rule is when the host handles an
interrupt, which is already handled by the irq code, which
calls rcu_irq_enter and rcu_irq_exit.
The guest_enter and guest_exit functions already switch vtime
accounting independent of context tracking. Leave those calls
where they are, instead of moving them into the context tracking
code.
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Will deacon <will.deacon@arm.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Pull KVM update from Paolo Bonzini:
"Fairly small update, but there are some interesting new features.
Common:
Optional support for adding a small amount of polling on each HLT
instruction executed in the guest (or equivalent for other
architectures). This can improve latency up to 50% on some
scenarios (e.g. O_DSYNC writes or TCP_RR netperf tests). This
also has to be enabled manually for now, but the plan is to
auto-tune this in the future.
ARM/ARM64:
The highlights are support for GICv3 emulation and dirty page
tracking
s390:
Several optimizations and bugfixes. Also a first: a feature
exposed by KVM (UUID and long guest name in /proc/sysinfo) before
it is available in IBM's hypervisor! :)
MIPS:
Bugfixes.
x86:
Support for PML (page modification logging, a new feature in
Broadwell Xeons that speeds up dirty page tracking), nested
virtualization improvements (nested APICv---a nice optimization),
usual round of emulation fixes.
There is also a new option to reduce latency of the TSC deadline
timer in the guest; this needs to be tuned manually.
Some commits are common between this pull and Catalin's; I see you
have already included his tree.
Powerpc:
Nothing yet.
The KVM/PPC changes will come in through the PPC maintainers,
because I haven't received them yet and I might end up being
offline for some part of next week"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (130 commits)
KVM: ia64: drop kvm.h from installed user headers
KVM: x86: fix build with !CONFIG_SMP
KVM: x86: emulate: correct page fault error code for NoWrite instructions
KVM: Disable compat ioctl for s390
KVM: s390: add cpu model support
KVM: s390: use facilities and cpu_id per KVM
KVM: s390/CPACF: Choose crypto control block format
s390/kernel: Update /proc/sysinfo file with Extended Name and UUID
KVM: s390: reenable LPP facility
KVM: s390: floating irqs: fix user triggerable endless loop
kvm: add halt_poll_ns module parameter
kvm: remove KVM_MMIO_SIZE
KVM: MIPS: Don't leak FPU/DSP to guest
KVM: MIPS: Disable HTW while in guest
KVM: nVMX: Enable nested posted interrupt processing
KVM: nVMX: Enable nested virtual interrupt delivery
KVM: nVMX: Enable nested apic register virtualization
KVM: nVMX: Make nested control MSRs per-cpu
KVM: nVMX: Enable nested virtualize x2apic mode
KVM: nVMX: Prepare for using hardware MSR bitmap
Use the more generic get_user_pages_unlocked which has the additional
benefit of passing FAULT_FLAG_ALLOW_RETRY at the very first page fault
(which allows the first page fault in an unmapped area to be always able
to block indefinitely by being allowed to release the mmap_sem).
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com>
Reviewed-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Peter Feiner <pfeiner@google.com>
After f78146b0f923, "KVM: Fix page-crossing MMIO", and
87da7e66a405, "KVM: x86: fix vcpu->mmio_fragments overflow",
actually KVM_MMIO_SIZE is gone.
Signed-off-by: Tiejun Chen <tiejun.chen@intel.com>
dirty
We don't have to write protect guest memory for dirty logging if architecture
supports hardware dirty logging, such as PML on VMX, so rename it to be more
generic.
Signed-off-by: Kai Huang <kai.huang@linux.intel.com>
Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into kvm-next
KVM: s390: fixes and features for kvm/next (3.20)
1. Generic
- sparse warning (make function static)
- optimize locking
- bugfixes for interrupt injection
- fix MVPG addressing modes
2. hrtimer/wakeup fun
A recent change can cause KVM hangs if adjtime is used in the host.
The hrtimer might wake up too early or too late. Too early is fatal
as vcpu_block will see that the wakeup condition is not met and
sleep again. This CPU might never wake up again.
This series addresses this problem. adjclock slowing down the host
clock will result in too late wakeups. This will require more work.
In addition to that we also change the hrtimer from REALTIME to
MONOTONIC to avoid similar problems with timedatectl set-time.
3. sigp rework
We will move all "slow" sigps to QEMU (protected with a capability that
can be enabled) to avoid several races between concurrent SIGP orders.
4. Optimize the shadow page table
Provide an interface to announce the maximum guest size. The kernel
will use that to make the pagetable 2,3,4 (or theoretically) 5 levels.
5. Provide an interface to set the guest TOD
We now use two vm attributes instead of two oneregs, as oneregs are
vcpu ioctl and we don't want to call them from other threads.
6. Protected key functions
The real HMC allows to enable/disable protected key CPACF functions.
Lets provide an implementation + an interface for QEMU to activate
this the protected key instructions.
The return value of kvm_arch_vcpu_postcreate is not checked in its
caller. This is okay, because only x86 provides vcpu_postcreate right
now and it could only fail if vcpu_load failed. But that is not
possible during KVM_CREATE_VCPU (kvm_arch_vcpu_load is void, too), so
just get rid of the unchecked return value.
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
With everything separated and prepared, we implement a model of a
GICv3 distributor and redistributors by using the existing framework
to provide handler functions for each register group.
Currently we limit the emulation to a model enforcing a single
security state, with SRE==1 (forcing system register access) and
ARE==1 (allowing more than 8 VCPUs).
We share some of the functions provided for GICv2 emulation, but take
the different ways of addressing (v)CPUs into account.
Save and restore is currently not implemented.
Similar to the split-off of the GICv2 specific code, the new emulation
code goes into a new file (vgic-v3-emul.c).
Currently we unconditionally register the GICv2 emulation device
during the host's KVM initialization. Since with GICv3 support we
may end up with only v2 or only v3 or both supported, we move the
registration into the GIC probing function, where we will later know
which combination is valid.
kvm_get_dirty_log() provides generic handling of dirty bitmap, currently reused
by several architectures. Building on that we intrdoduce
kvm_get_dirty_log_protect() adding write protection to mark these pages dirty
for future write access, before next KVM_GET_DIRTY_LOG ioctl call from user
space.
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Mario Smarduch <m.smarduch@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD
Second round of changes for KVM for arm/arm64 for v3.19; fixes reboot
problems, clarifies VCPU init, and fixes a regression concerning the
VGIC init flow.
arch/ia64/kvm/kvm-ia64.c [deleted in HEAD and modified in kvmarm]
Current linear search doesn't scale well when
large amount of memslots is used and looked up slot
is not in the beginning memslots array.
Taking in account that memslots don't overlap, it's
possible to switch sorting order of memslots array from
'npages' to 'base_gfn' and use binary search for
memslot lookup by GFN.
As result of switching to binary search lookup times
are reduced with large amount of memslots.
Following is a table of search_memslot() cycles
during WS2008R2 guest boot.
boot, boot + ~10 min
mostly same of using it,
slot lookup randomized lookup
max average average
cycles cycles cycles
13 slots : 1450 28 30
13 slots : 1400 30 40
binary search
117 slots : 13000 30 460
117 slots : 2000 35 180
binary search
Signed-off-by: Igor Mammedov <imammedo@redhat.com>
In typical guest boot workload only 2-3 memslots are used
extensively, and at that it's mostly the same memslot
lookup operation.
Adding LRU cache improves average lookup time from
46 to 28 cycles (~40%) for this workload.
Memory regions may be incoherent with the caches, typically when the
guest has mapped a host system RAM backed memory region as uncached.
Add a flag KVM_MEMSLOT_INCOHERENT so that we can tag these memslots
and handle them appropriately when mapping them.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
This reverts commit 85c8555ff0 ("KVM: check for !is_zero_pfn() in
kvm_is_mmio_pfn()") and renames the function to kvm_is_reserved_pfn.
The problem being addressed by the patch above was that some ARM code
based the memory mapping attributes of a pfn on the return value of
kvm_is_mmio_pfn(), whose name indeed suggests that such pfns should
be mapped as device memory.
However, kvm_is_mmio_pfn() doesn't do quite what it says on the tin,
and the existing non-ARM users were already using it in a way which
suggests that its name should probably have been 'kvm_is_reserved_pfn'
from the beginning, e.g., whether or not to call get_page/put_page on
it etc. This means that returning false for the zero page is a mistake
and the patch above should be reverted.
Create a new header, and hide the device assignment functions there.
Move struct kvm_assigned_dev_kernel to assigned-dev.c by modifying
arch/x86/kvm/iommu.c to take a PCI device struct.
Based on a patch by Radim Krcmar <rkrcmark@redhat.com>.
Now that ia64 is gone, we can hide deprecated device assignment in x86.
Notable changes:
- kvm_vm_ioctl_assigned_device() was moved to x86/kvm_arch_vm_ioctl()
The easy parts were removed from generic kvm code, remaining
- kvm_iommu_(un)map_pages() would require new code to be moved
- struct kvm_assigned_dev_kernel depends on struct kvm_irq_ack_notifier
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
ia64 does not need them anymore. Ack notifiers become x86-specific
too.
Suggested-by: Gleb Natapov <gleb@kernel.org>
Reviewed-by: Radim Krcmar <rkrcmar@redhat.com>
After commit 80ce163 (KVM: VFIO: register kvm_device_ops dynamically),
kvm_device_ops of vfio can be registered dynamically. Commit 3c3c29fd
(kvm-vfio: do not use module_init) move the dynamic register invoked by
kvm_init in order to fix broke unloading of the kvm module. However,
kvm_device_ops of vfio is unregistered after rmmod kvm-intel module
which lead to device type collision detection warning after kvm-intel
module reinsmod.
WARNING: CPU: 1 PID: 10358 at /root/cathy/kvm/arch/x86/kvm/../../../virt/kvm/kvm_main.c:3289 kvm_init+0x234/0x282 [kvm]()
Modules linked in: kvm_intel(O+) kvm(O) nfsv3 nfs_acl auth_rpcgss oid_registry nfsv4 dns_resolver nfs fscache lockd sunrpc pci_stub bridge stp llc autofs4 8021q cpufreq_ondemand ipv6 joydev microcode pcspkr igb i2c_algo_bit ehci_pci ehci_hcd e1000e i2c_i801 ixgbe ptp pps_core hwmon mdio tpm_tis tpm ipmi_si ipmi_msghandler acpi_cpufreq isci libsas scsi_transport_sas button dm_mirror dm_region_hash dm_log dm_mod [last unloaded: kvm_intel]
CPU: 1 PID: 10358 Comm: insmod Tainted: G W O 3.17.0-rc1 #2
Hardware name: Intel Corporation S2600CP/S2600CP, BIOS RMLSDP.86I.00.29.D696.1311111329 11/11/2013
0000000000000cd9 ffff880ff08cfd18 ffffffff814a61d9 0000000000000cd9
0000000000000000 ffff880ff08cfd58 ffffffff810417b7 ffff880ff08cfd48
ffffffffa045bcac ffffffffa049c420 0000000000000040 00000000000000ff
Call Trace:
[<ffffffff814a61d9>] dump_stack+0x49/0x60
[<ffffffff810417b7>] warn_slowpath_common+0x7c/0x96
[<ffffffffa045bcac>] ? kvm_init+0x234/0x282 [kvm]
[<ffffffff810417e6>] warn_slowpath_null+0x15/0x17
[<ffffffffa045bcac>] kvm_init+0x234/0x282 [kvm]
[<ffffffffa016e995>] vmx_init+0x1bf/0x42a [kvm_intel]
[<ffffffffa016e7d6>] ? vmx_check_processor_compat+0x64/0x64 [kvm_intel]
[<ffffffff810002ab>] do_one_initcall+0xe3/0x170
[<ffffffff811168a9>] ? __vunmap+0xad/0xb8
[<ffffffff8109c58f>] do_init_module+0x2b/0x174
[<ffffffff8109d414>] load_module+0x43e/0x569
[<ffffffff8109c6d8>] ? do_init_module+0x174/0x174
[<ffffffff8109c75a>] ? copy_module_from_user+0x39/0x82
[<ffffffff8109b7dd>] ? module_sect_show+0x20/0x20
[<ffffffff8109d65f>] SyS_init_module+0x54/0x81
[<ffffffff814a9a12>] system_call_fastpath+0x16/0x1b
---[ end trace 0626f4a3ddea56f3 ]---
The bug can be reproduced by:
rmmod kvm_intel.ko
insmod kvm_intel.ko
without rmmod/insmod kvm.ko
This patch fixes the bug by unregistering kvm_device_ops of vfio when the
kvm-intel module is removed.
Reported-by: Liu Rongrong <rongrongx.liu@intel.com>
Fixes: 3c3c29fd0d7cddc32862c350d0700ce69953e3bd
Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-next
Changes for KVM for arm/arm64 for 3.18
This includes a bunch of changes:
- Support read-only memory slots on arm/arm64
- Various changes to fix Sparse warnings
- Correctly detect write vs. read Stage-2 faults
- Various VGIC cleanups and fixes
- Dynamic VGIC data strcuture sizing
- Fix SGI set_clear_pend offset bug
- Fix VTTBR_BADDR Mask
- Correctly report the FSC on Stage-2 faults
virt/kvm/eventfd.c
[duplicate, different patch where the kvm-arm version broke x86.
The kvm tree instead has the right one]
Currently, the APIC access page is pinned by KVM for the entire life
of the guest. We want to make it migratable in order to make memory
hot-unplug available for machines that run KVM.
This patch prepares to handle this in generic code, through a new
request bit (that will be set by the MMU notifier) and a new hook
that is called whenever the request bit is processed.
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
it non-static
Different architectures need different requests, and in fact we
will use this function in architecture-specific code later. This
will be outside kvm_main.c, so make it non-static and rename it to
kvm_make_all_cpus_request().
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
When KVM handles a tdp fault it uses FOLL_NOWAIT. If the guest memory
has been swapped out or is behind a filemap, this will trigger async
readahead and return immediately. The rationale is that KVM will kick
back the guest with an "async page fault" and allow for some other
guest process to take over.
If async PFs are enabled the fault is retried asap from an async
workqueue. If not, it's retried immediately in the same code path. In
either case the retry will not relinquish the mmap semaphore and will
block on the IO. This is a bad thing, as other mmap semaphore users
now stall as a function of swap or filemap latency.
This patch ensures both the regular and async PF path re-enter the
fault allowing for the mmap semaphore to be relinquished in the case
of IO wait.
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
Signed-off-by: Andres Lagar-Cavilla <andreslc@google.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
arch/arm64/include/asm/kvm_host.h
virt/kvm/arm/vgic.c
Now that we have a dynamic means to register kvm_device_ops, use that
for the VFIO kvm device, instead of relying on the static table.
This is achieved by a module_init call to register the ops with KVM.
Cc: Gleb Natapov <gleb@kernel.org>
Acked-by: Alex Williamson <Alex.Williamson@redhat.com>
Using the new kvm_register_device_ops() interface makes us get rid of
an #ifdef in common code.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
for the ARM VGIC, instead of relying on the static table.
kvm_ioctl_create_device currently has knowledge of all the device types
and their associated ops. This is fairly inflexible when adding support
for new in-kernel device emulations, so move what we currently have out
into a table, which can support dynamic registration of ops by new
drivers for virtual hardware.
Cc: Alex Williamson <Alex.Williamson@redhat.com>
Cc: Alex Graf <agraf@suse.de>
Cc: Marc Zyngier <marc.zyngier@arm.com>
In the beggining was on_each_cpu(), which required an unused argument to
kvm_arch_ops.hardware_{en,dis}able, but this was soon forgotten.
Remove unnecessary arguments that stem from this.
Signed-off-by: Radim KrÄmář <rkrcmar@redhat.com>
Opaque KVM structs are useful for prototypes in asm/kvm_host.h, to avoid
"'struct foo' declared inside parameter list" warnings (and consequent
breakage due to conflicting types).
Move them from individual files to a generic place in linux/kvm_types.h.
To support read-only memory regions on arm and arm64, we have a need to
resolve a gfn to an hva given a pointer to a memslot to avoid looping
through the memslots twice and to reuse the hva error checking of
gfn_to_hva_prot(), add a new gfn_to_hva_memslot_prot() function and
refactor gfn_to_hva_prot() to use this function.
Introduce preempt notifiers for architecture specific code.
Advantage over creating a new notifier in every arch is slightly simpler
code and guaranteed call order with respect to kvm_sched_in.
Commits e4d57e1ee1ab (KVM: Move irq notifier implementation into
eventfd.c, 2014-06-30) included the irq notifier code unconditionally
in eventfd.c, while it was under CONFIG_HAVE_KVM_IRQCHIP before.
Similarly, commit 297e21053a52 (KVM: Give IRQFD its own separate enabling
Kconfig option, 2014-06-30) moved code from CONFIG_HAVE_IRQ_ROUTING
to CONFIG_HAVE_KVM_IRQFD but forgot to move the pieces that used to be
under CONFIG_HAVE_KVM_IRQCHIP.
Together, this broke compilation without CONFIG_KVM_XICS. Fix by adding
or changing the #ifdefs so that they point at CONFIG_HAVE_KVM_IRQFD.
Currently, the IRQFD code is conditional on CONFIG_HAVE_KVM_IRQ_ROUTING.
So that we can have the IRQFD code compiled in without having the
IRQ routing code, this creates a new CONFIG_HAVE_KVM_IRQFD, makes
the IRQFD code conditional on it instead of CONFIG_HAVE_KVM_IRQ_ROUTING,
and makes all the platforms that currently select HAVE_KVM_IRQ_ROUTING
also select HAVE_KVM_IRQFD.
Tested-by: Eric Auger <eric.auger@linaro.org>
Tested-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Now that struct _irqfd does not keep a reference to storage pointed
to by the irq_routing field of struct kvm, we can move the statement
that updates it out from under the irqfds.lock and put it in
kvm_set_irq_routing() instead. That means we then have to take a
srcu_read_lock on kvm->irq_srcu around the irqfd_update call in
kvm_irqfd_assign(), since holding the kvm->irqfds.lock no longer
ensures that that the routing can't change.
Combined with changing kvm_irq_map_gsi() and kvm_irq_map_chip_pin()
to take a struct kvm * argument instead of the pointer to the routing
table, this allows us to to move all references to kvm->irq_routing
into irqchip.c. That in turn allows us to move the definition of the
kvm_irq_routing_table struct into irqchip.c as well.
This provides accessor functions for the KVM interrupt mappings, in
order to reduce the amount of code that accesses the fields of the
kvm_irq_routing_table struct, and restrict that code to one file,
virt/kvm/irqchip.c. The new functions are kvm_irq_map_gsi(), which
maps from a global interrupt number to a set of IRQ routing entries,
and kvm_irq_map_chip_pin, which maps from IRQ chip and pin numbers to
a global interrupt number.
This also moves the update of kvm_irq_routing_table::chip[][]
into irqchip.c, out of the various kvm_set_routing_entry
implementations. That means that none of the kvm_set_routing_entry
implementations need the kvm_irq_routing_table argument anymore,
so this removes it.
This does not change any locking or data lifetime rules.
In preparation to make the check_extension function available to VM scope
we add a struct kvm * argument to the function header and rename the function
accordingly. It will still be called from the /dev/kvm fd, but with a NULL
argument for struct kvm *.
Pull more scheduler updates from Ingo Molnar:
"Second round of scheduler changes:
- try-to-wakeup and IPI reduction speedups, from Andy Lutomirski
- continued power scheduling cleanups and refactorings, from Nicolas
Pitre
- misc fixes and enhancements"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/deadline: Delete extraneous extern for to_ratio()
sched/idle: Optimize try-to-wake-up IPI
sched/idle: Simplify wake_up_idle_cpu()
sched/idle: Clear polling before descheduling the idle thread
sched, trace: Add a tracepoint for IPI-less remote wakeups
cpuidle: Set polling in poll_idle
sched: Remove redundant assignment to "rt_rq" in update_curr_rt(...)
sched: Rename capacity related flags
sched: Final power vs. capacity cleanups
sched: Remove remaining dubious usage of "power"
sched: Let 'struct sched_group_power' care about CPU capacity
sched/fair: Disambiguate existing/remaining "capacity" usage
sched/fair: Change "has_capacity" to "has_free_capacity"
sched/fair: Remove "power" from 'struct numa_stats'
sched: Fix signedness bug in yield_to()
sched/fair: Use time_after() in record_wakee()
sched/balancing: Reduce the rate of needless idle load balancing
sched/fair: Fix unlocked reads of some cfs_b->quota/period
yield_to() is supposed to return -ESRCH if there is no task to
yield to, but because the type is bool that is the same as returning
true.
The only place I see which cares is kvm_vcpu_on_spin().
Reviewed-by: Raghavendra <raghavendra.kt@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: kvm@vger.kernel.org
Link: http://lkml.kernel.org/r/20140523102042.GA7267@mwanda
When starting lots of dataplane devices the bootup takes very long on
Christian's s390 with irqfd patches. With larger setups he is even
able to trigger some timeouts in some components. Turns out that the
KVM_SET_GSI_ROUTING ioctl takes very long (strace claims up to 0.1 sec)
when having multiple CPUs. This is caused by the synchronize_rcu and
the HZ=100 of s390. By changing the code to use a private srcu we can
speed things up. This patch reduces the boot time till mounting root
from 8 to 2 seconds on my s390 guest with 100 disks.
Uses of hlist_for_each_entry_rcu, hlist_add_head_rcu, hlist_del_init_rcu
are fine because they do not have lockdep checks (hlist_for_each_entry_rcu
uses rcu_dereference_raw rather than rcu_dereference, and write-sides
do not do rcu lockdep at all).
Note that we're hardly relying on the "sleepable" part of srcu. We just
want SRCU's faster detection of grace periods.
Testing was done by Andrew Theurer using netperf tests STREAM, MAERTS
and RR. The difference between results "before" and "after" the patch
has mean -0.2% and standard deviation 0.6%. Using a paired t-test on the
data points says that there is a 2.5% probability that the patch is the
cause of the performance difference (rather than a random fluctuation).
(Restricting the t-test to RR, which is the most likely to be affected,
changes the numbers to respectively -0.3% mean, 0.7% stdev, and 8%
probability that the numbers actually say something about the patch.
The probability increases mostly because there are fewer data points).
Cc: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> # s390
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
This patch enables the IBS facility when a single VCPU is running.
The facility is dynamically turned on/off as soon as other VCPUs
enter/leave the stopped state.
When this facility is operating, some instructions can be executed
faster for single-cpu guests.
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Reviewed-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
This reverts commit 5befdc385ddb2d5ae8995ad89004529a3acf58fc.
Since we will allow flush tlb out of mmu-lock in the later
patch
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into queue
Lazy storage key handling
Linux does not use the ACC and F bits of the storage key. Newer Linux
versions also do not use the storage keys for dirty and reference
tracking. We can optimize the guest handling for those guests for faults
as well as page-in and page-out by simply not caring about the guest
visible storage key. We trap guest storage key instruction to enable
those keys only on demand.
Migration bitmap
Until now s390 never provided a proper dirty bitmap. Let's provide a
proper migration bitmap for s390. We also change the user dirty tracking
to a fault based mechanism. This makes the host completely independent
from the storage keys. Long term this will allow us to back guest memory
with large pages.
per-VM device attributes
To avoid the introduction of new ioctls, let's provide the
attribute semanantic also on the VM-"device".
Userspace controlled CMMA
The CMMA assist is changed from "always on" to "on if requested" via
per-VM device attributes. In addition a callback to reset all usage
states is provided.
Proper guest DAT handling for intercepts
While instructions handled by SIE take care of all addressing aspects,
KVM/s390 currently does not care about guest address translation of
intercepts. This worked out fine, because
- the s390 Linux kernel has a 1:1 mapping between kernel virtual<->real
for all pages up to memory size
- intercepts happen only for a small amount of cases
- all of these intercepts happen to be in the kernel text for current
distros
Of course we need to be better for other intercepts, kernel modules etc.
We provide the infrastructure and rework all in-kernel intercepts to work
on logical addresses (paging etc) instead of real ones. The code has
been running internally for several months now, so it is time for going
public.
GDB support
We provide breakpoints, single stepping and watchpoints.
Fixes/Cleanups
- Improve program check delivery
- Factor out the handling of transactional memory on program checks
- Use the existing define __LC_PGM_TDB
- Several cleanups in the lowcore structure
- Documentation
NOTES
- All patches touching base s390 are either ACKed or written by the s390
maintainers
- One base KVM patch "KVM: add kvm_is_error_gpa() helper"
- One patch introduces the notion of VM device attributes
include/uapi/linux/kvm.h
It's quite common (in the s390 guest access code) to test if a guest
physical address points to a valid guest memory area or not.
So add a simple helper function in common code, since this might be
of interest for other architectures as well.
Reviewed-by: Thomas Huth <thuth@linux.vnet.ibm.com>
