path: root/include/linux/kvm_para.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2011-12-27KVM: Fix whitespace in kvm_para.hAlexander Graf
When syncing KVM headers with QEMU I (or whoever applies the diff) end up automatically fixing whitespaces. One of them is in kvm_para.h. It's a lot more consistent for people who don't do the whitespace fixups automatically to already have fixed headers in Linux. So remove the sparse empty line at the end of kvm_para.h and everyone's happy. Reported-by: Blue Swirl <blauwirbel@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2010-10-24KVM: Move kvm_guest_init out of generic codeAlexander Graf
Currently x86 is the only architecture that uses kvm_guest_init(). With PowerPC we're getting a second user, but the signature is different there and we don't need to export it, as it uses the normal kernel init framework. So let's move the x86 specific definition of that function over to the x86 specfic header file. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: First magic page stepsAlexander Graf
We will be introducing a method to project the shared page in guest context. As soon as we're talking about this coupling, the shared page is colled magic page. This patch introduces simple defines, so the follow-up patches are easier to read. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: PPC: Implement hypervisor interfaceAlexander Graf
To communicate with KVM directly we need to plumb some sort of interface between the guest and KVM. Usually those interfaces use hypercalls. This hypercall implementation is described in the last patch of the series in a special documentation file. Please read that for further information. This patch implements stubs to handle KVM PPC hypercalls on the host and guest side alike. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: x86: Disallow hypercalls for guest callers in rings > 0Jan Kiszka
So far unprivileged guest callers running in ring 3 can issue, e.g., MMU hypercalls. Normally, such callers cannot provide any hand-crafted MMU command structure as it has to be passed by its physical address, but they can still crash the guest kernel by passing random addresses. To close the hole, this patch considers hypercalls valid only if issued from guest ring 0. This may still be relaxed on a per-hypercall base in the future once required. Cc: stable@kernel.org Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-04-27KVM: MMU: hypercall based pte updates and TLB flushesMarcelo Tosatti
Hypercall based pte updates are faster than faults, and also allow use of the lazy MMU mode to batch operations. Don't report the feature if two dimensional paging is enabled. [avi: - one mmu_op hypercall instead of one per op - allow 64-bit gpa on hypercall - don't pass host errors (-ENOMEM) to guest] [akpm: warning fix on i386] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-27x86: KVM guest: add basic paravirt supportMarcelo Tosatti
Add basic KVM paravirt support. Avoid vm-exits on IO delays. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Put kvm_para.h include outside __KERNEL__Glauber de Oliveira Costa
kvm_para.h potentially contains definitions that are to be used by userspace, so it should not be included inside the __KERNEL__ block. To protect its own data structures, kvm_para.h already includes its own __KERNEL__ block. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Acked-by: Amit Shah <amit.shah@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Accelerated apic supportAvi Kivity
This adds a mechanism for exposing the virtual apic tpr to the guest, and a protocol for letting the guest update the tpr without causing a vmexit if conditions allow (e.g. there is no interrupt pending with a higher priority than the new tpr). Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Per-architecture hypercall definitionsChristian Borntraeger
Currently kvm provides hypercalls only for x86* architectures. To provide hypercall infrastructure for other kvm architectures I split kvm_para.h into a generic header file and architecture specific definitions. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-01-30KVM: Refactor hypercall infrastructure (v3)Anthony Liguori
This patch refactors the current hypercall infrastructure to better support live migration and SMP. It eliminates the hypercall page by trapping the UD exception that would occur if you used the wrong hypercall instruction for the underlying architecture and replacing it with the right one lazily. A fall-out of this patch is that the unhandled hypercalls no longer trap to userspace. There is very little reason though to use a hypercall to communicate with userspace as PIO or MMIO can be used. There is no code in tree that uses userspace hypercalls. [avi: fix #ud injection on vmx] Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2007-03-04KVM: Add host hypercall support for vmxIngo Molnar
2007-03-04KVM: add MSR based hypercall APIIngo Molnar
This adds a special MSR based hypercall API to KVM. This is to be used by paravirtual kernels and virtual drivers. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Avi Kivity <avi@qumranet.com>
