path: root/include/linux/latencytop.h
2011-11-17sched: Make separate sched*.c translation unitsPeter Zijlstra
Since once needs to do something at conferences and fixing compile warnings doesn't actually require much if any attention I decided to break up the sched.c #include "*.c" fest. This further modularizes the scheduler code. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-x0fcd3mnp8f9c99grcpewmhi@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-11sched, latencytop: incorporate review feedback from Andrew MortonArjan van de Ven
Andrew had some suggestions for the latencytop file; this patch takes care of most of these: * Add documentation * Turn account_scheduler_latency into an inline function * Don't report negative values to userspace * Make the file operations struct const * Fix a few checkpatch.pl warnings Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-25sched: latencytop supportArjan van de Ven
LatencyTOP kernel infrastructure; it measures latencies in the scheduler and tracks it system wide and per process. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
