path: root/include/linux/lguest_launcher.h
2008-03-28lguest: comment documentation update.Rusty Russell
Took some cycles to re-read the Lguest Journey end-to-end, fix some rot and tighten some phrases. Only comments change. No new jokes, but a couple of recycled old jokes. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: simplify config mechanism.Rusty Russell
Previously we used a type/len pair within the config space, but this seems overkill. We now simply define a structure which represents the layout in the config space: the config space can now only be extended at the end. The main driver-visible changes: 1) We indicate what fields are present with an explicit feature bit. 2) Virtqueues are explicitly numbered, and not in the config space. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-25lguest: documentation updateRusty Russell
Went through the documentation doing typo and content fixes. This patch contains only comment and whitespace changes. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-25lguest: clean up lguest_launcher.hRusty Russell
Remove now-unused defines. Fix old idempotent #ifndef _ASM_LGUEST_USER name. Fix comment on use of lguest_req. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Lguest support for VirtioRusty Russell
This makes lguest able to use the virtio devices. We change the device descriptor page from a simple array to a variable length "type, config_len, status, config data..." format, and implement virtio_config_ops to read from that config data. We use the virtio ring implementation for an efficient Guest <-> Host virtqueue mechanism, and the new LHCALL_NOTIFY hypercall to kick the host when it changes. We also use LHCALL_NOTIFY on kernel addresses for very very early console output. We could have another hypercall, but this hack works quite well. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Remove old lguest I/O infrrasructure.Rusty Russell
This patch gets rid of the old lguest host I/O infrastructure and replaces it with a single hypercall "LHCALL_NOTIFY" which takes an address. The main change is the removal of io.c: that mainly did inter-guest I/O, which virtio doesn't yet support. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Remove old lguest bus and drivers.Rusty Russell
This gets rid of the lguest bus, drivers and DMA mechanism, to make way for a generic virtio mechanism. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Make lguest_launcher.h types userspace-friendlyRusty Russell
lguest_launcher.h uses "u32" not "__u32", which sets a bad example. Fix that, and include <linux/types.h>. This means we need to use -I on the Launcher build line so types.h is found. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-07-26lguest: documentation III: DriversRusty Russell
Documentation: The Drivers Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19lguest: the host codeRusty Russell
This is the code for the "lg.ko" module, which allows lguest guests to be launched. [akpm@linux-foundation.org: update for futex-new-private-futexes] [akpm@linux-foundation.org: build fix] [jmorris@namei.org: lguest: use hrtimers] [akpm@linux-foundation.org: x86_64 build fix] Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
