path: root/include/linux/libata.h
2010-04-06libata: unlock HPA if device shrunkTejun Heo
Some BIOSes don't configure HPA during boot but do so while resuming. This causes harddrives to shrink during resume making libata detach and reattach them. This can be worked around by unlocking HPA if old size equals native size. Add ATA_DFLAG_UNLOCK_HPA so that HPA unlocking can be controlled per-device and update ata_dev_revalidate() such that it sets ATA_DFLAG_UNLOCK_HPA and fails with -EIO when the above condition is detected. This patch fixes the following bug. https://bugzilla.kernel.org/show_bug.cgi?id=15396 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Oleksandr Yermolenko <yaa.bta@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-01libata: Pass host flags into the pci helperAlan Cox
This allows parallel scan and the like to be set without having to stop using the existing full helper functions. This patch merely adds the argument and fixes up the callers. It doesn't undo the special cases already in the tree or add any new parallel callers. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-03-01libata: implement spurious irq handling for SFF and apply it to piixTejun Heo
Traditional IDE interface sucks in that it doesn't have a reliable IRQ pending bit, so if the controller raises IRQ while the driver is expecting it not to, the IRQ won't be cleared and eventually the IRQ line will be killed by interrupt subsystem. Some controllers have non-standard mechanism to indicate IRQ pending so that this condition can be detected and worked around. This patch adds an optional operation ->sff_irq_check() which will be called for each port from the ata_sff_interrupt() if an unexpected interrupt is received. If the operation returns %true, ->sff_check_status() and ->sff_irq_clear() will be cleared for the port. Note that this doesn't mark the interrupt as handled so it won't prevent IRQ subsystem from killing the IRQ if this mechanism fails to clear the spurious IRQ. This patch also implements ->sff_irq_check() for ata_piix. Note that this adds slight overhead to shared IRQ operation as IRQs which are destined for other controllers will trigger extra register accesses to check whether IDE interrupt is pending but this solves rare screaming IRQ cases and for some curious reason also helps weird BIOS related glitch on Samsung n130 as reported in bko#14314. http://bugzilla.kernel.org/show_bug.cgi?id=14314 * piix_base_ops dropped as suggested by Sergei. * Spurious IRQ detection doesn't kick in anymore if polling qc is in progress. This provides less protection but some controllers have possible data corruption issues if the wrong register is accessed while a command is in progress. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Johannes Stezenbach <js@sig21.net> Reported-by: Hans Werner <hwerner4@gmx.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2010-01-12libata: retry link resume if necessaryTejun Heo
Interestingly, when SIDPR is used in ata_piix, writes to DET in SControl sometimes get ignored leading to detection failure. Update sata_link_resume() such that it reads back SControl after clearing DET and retry if it's not clear. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: fengxiangjun <fengxiangjun@neusoft.com> Reported-by: Jim Faulkner <jfaulkne@ccs.neu.edu> Cc: stable@kernel.org Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (222 commits) [SCSI] zfcp: Remove flag ZFCP_STATUS_FSFREQ_TMFUNCNOTSUPP [SCSI] zfcp: Activate fc4s attributes for zfcp in FC transport class [SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED [SCSI] zfcp: Update FSF error reporting [SCSI] zfcp: Improve ELS ADISC handling [SCSI] zfcp: Simplify handling of ct and els requests [SCSI] zfcp: Remove ZFCP_DID_MASK [SCSI] zfcp: Move WKA port to zfcp FC code [SCSI] zfcp: Use common code definitions for FC CT structs [SCSI] zfcp: Use common code definitions for FC ELS structs [SCSI] zfcp: Update FCP protocol related code [SCSI] zfcp: Dont fail SCSI commands when transitioning to blocked fc_rport [SCSI] zfcp: Assign scheduled work to driver queue [SCSI] zfcp: Remove STATUS_COMMON_REMOVE flag as it is not required anymore [SCSI] zfcp: Implement module unloading [SCSI] zfcp: Merge trace code for fsf requests in one function [SCSI] zfcp: Access ports and units with container_of in sysfs code [SCSI] zfcp: Remove suspend callback [SCSI] zfcp: Remove global config_mutex [SCSI] zfcp: Replace local reference counting with common kref ...
2009-12-04[SCSI] modify change_queue_depth to take in reason why it is being calledMike Christie
This patch modifies scsi_host_template->change_queue_depth so that it takes an argument indicating why it is being called. This will be used so that if a LLD needs to do some extra processing when handling queue fulls or later ramp ups, it can do so. This is a simple port of the drivers setting a change_queue_depth callback. In the patch I just have these LLDs adjust the queue depth if the user was requesting it. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> [Vasu.Dev: v2 Also converted pmcraid_change_queue_depth and then verified all modules compile using "make allmodconfig" for any new build warnings on X86_64. Updated original description after combing two original patches from Mike to make this patch git bisectable.] Signed-off-by: Vasu Dev <vasu.dev@intel.com> [jejb: fixed up 53c700] Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-12-03libata: add private driver field to struct ata_deviceBartlomiej Zolnierkiewicz
This brings struct ata_device in-line with struct ata_{port,host}. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-12-03libata: retry failed FLUSH if device didn't fail itTejun Heo
If ATA device failed FLUSH, it means that the device failed to write out some amount of data and the error needs to be reported to upper layers. As retries can't recover the lost data, FLUSH failures need to be reported immediately in general. However, if FLUSH fails due to transmission errors, the FLUSH needs to be retried; otherwise, filesystems may switch to RO mode and/or raid array may drop a drive for a random transmission glitch. This condition can be rather easily reproduced on certain ahci controllers which go through a PHY event after powersave mode switch + ext4 combination. Powersave mode switch is often closely followed by flush from the filesystem failing the FLUSH with ATA bus error which makes the filesystem code believe that data is lost and drop to RO mode. This was reported in the following bugzilla bug. http://bugzilla.kernel.org/show_bug.cgi?id=14543 This patch makes libata EH retry FLUSH if it wasn't failed by the device. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Andrey Vihrov <andrey.vihrov@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06libata: make gtf_filter per-devTejun Heo
Add ->gtf_filter to ata_device and set it to ata_acpi_gtf_filter when initializing ata_link. This is to allow quirks which apply different gtf filters. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06libata: implement more acpi filtering optionsTejun Heo
Currently libata-acpi can only filter DIPM among SATA feature enables via _GTF. This patch adds the capability to filter out FPDMA non-zero offset, in-order guarantee and auto-activation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-10-06libata: cosmetic updatesTejun Heo
We're about to add more SATA_* and ATA_ACPI_FILTER_* constants. Reformat them in preparation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01libata: remove spindown skipping and warningTejun Heo
This was a hack to give userland shutdown tools time to drop manual spindown. All popular distros updated quite some time ago and the due is well passed. Drop it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jaswinder Singh Rajput <jaswinder@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-09-01[libata] add DMA setup FIS auto-activate featureShaohua Li
Hopefully results in fewer on-the-wire FIS's and no breakage. We'll see! Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-07-28libata: accept late unlocking of HPATejun Heo
On certain configurations, HPA isn't or can't be unlocked during probing but it somehow ends up unlocked afterwards. In the following thread, the problem can be reliably reproduced after resuming from STR. The BIOS turns on HPA during boot but forgets to do it during resume. http://thread.gmane.org/gmane.linux.kernel/858310 This patch updates libata revalidation such that it considers native n_sectors. If the device size has increased to match native n_sectors, it's assumed that HPA has been unlocked involuntarily and the device is recognized as the same one. This should be fairly safe while nicely working around the problem. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Christof Warlich <christof@warlich.name> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-07-14libata: implement and use HORKAGE_NOSETXFER, take#2Tejun Heo
PIONEER DVD-RW DVRTD08 times out SETXFER if no media is present. The device is SATA and simply skipping SETXFER works around the problem. Implement ATA_HORKAGE_NOSETXFER and apply it to the device. Reported by Moritz Rigler in the following thread. http://thread.gmane.org/gmane.linux.ide/36790 and by Lars in bko#9540. Updated to whine and ignore NOSETXFER if PATA component is detected as suggested by Alan Cox. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Moritz Rigler <linux-ide@momail.e4ward.com> Reported-by: Lars <lars21ce@gmx.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-16ata: Report 16/32bit PIO as best we canAlan Cox
The legacy old IDE ioctl API for this is a bit primitive so we try and map stuff sensibly onto it. - Set PIO over DMA devices to report 32bit - Add ability to change the PIO32 settings if the controller permits it - Add that functionality into the sff drivers - Add that functionality into the VLB legacy driver - Turn on the 32bit PIO on the ninja32 and add support there Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-30trivial: Fix misspelling of firmwareNick Andrew
Fix misspelling of firmware. Signed-off-by: Nick Andrew <nick@nick-andrew.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-24[libata] Improve timeout handlingAlan Cox
On a timeout call a device specific handler early in the recovery so that we can complete and process successful commands which timed out due to IRQ loss or the like rather more elegantly. [Revised to exclude the timeout handling on a few devices that inherit from SFF but are not SFF enough to use the default timeout handler] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] Drain data on errorsAlan Cox
If the device is signalling that there is data to drain after an error we should read the bytes out and throw them away. Without this some devices and controllers get wedged and don't recover. Based on earlier work by Mark Lord Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-24[libata] Export ata_pio_queue_task() so that it can be used from sata_mv.Mark Lord
Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-05libata: align ap->sector_bufTejun Heo
ap->sector_buf is used as DMA target and should at least be aligned on cacheline. This caused problems on some embedded machines. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-05libata: fix dma_unmap_sg misuseFUJITA Tomonori
libata passes the returned value of dma_map_sg() to dma_unmap_sg(),which is the misuse of dma_unmap_sg(). DMA-mapping.txt says: To unmap a scatterlist, just call: pci_unmap_sg(pdev, sglist, nents, direction); Again, make sure DMA activity has already finished. PLEASE NOTE: The 'nents' argument to the pci_unmap_sg call must be the _same_ one you passed into the pci_map_sg call, it should _NOT_ be the 'count' value _returned_ from the pci_map_sg call. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-03-05libata: change drive ready wait after hard reset to 5sStuart Hayes
This fixes problems during resume with drives that take longer than 1s to be ready. The ATA-6 spec appears to allow 5 seconds for a drive to be ready. On one affected system, this patch changes "PM: resume devices took..." message from 17 seconds to 4 seconds, and gets rid of a lot of ugly timeout/error messages. Without this patch, the libata code moves on after 1s, tries to send a soft reset (which the drive doesn't see because it isn't ready) which also times out, then an IDENTIFY command is sent to the drive which times out, and finally the error handler will try to send another hard reset which will finally get things working. Signed-off-by: Stuart Hayes <stuart_hayes@dell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-02-02libata: implement HORKAGE_1_5_GBPS and apply it to WD My BookTejun Heo
3Gbps is often much more prone to transmission failures. It's usually okay to let EH handle speed down after transmission failures but some WD My Book drives completely shutdown after certain transmission failures and after it only power cycling can revive them. Combined with the fact that external drives often end up with cable assembly which is longer than usual and more likely to have intervening gender, this makes these drives very likely to shutdown under certain configurations virtually rendering them unusable. This patch implements HOARKGE_1_5_GBPS and applies it to WD My Book such that 1.5Gbps is forced once the device is identified. Please take a look at the following bz for related reports. http://bugzilla.kernel.org/show_bug.cgi?id=9913 Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-02-02libata: clear dev->ering in smarter wayTejun Heo
dev->ering used to be cleared together with the rest of ata_device in ata_dev_init() which is called whenever a probing event occurs. dev->ering is about to be used to track probing failures so it needs to remain persistent over multiple porbing events. This patch achieves this by doing the following. * Instead of CLEAR_OFFSET, define CLEAR_BEGIN and CLEAR_END and only clear between BEGIN and END. ering is moved after END. The split of persistent area is to allow hotter items remain at the head. * ering is explicitly cleared on ata_dev_disable() and when device attach succeeds. So, ering is persistent throug a device's life time (unless explicitly cleared of course) and also through periods inbetween disablement of an attached device and successful detection of the next one. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-27SATA: Blacklisting of systems that spin off disks during ACPI power offRafael J. Wysocki
Introduce new libata flags ATA_FLAG_NO_POWEROFF_SPINDOWN and ATA_FLAG_NO_HIBERNATE_SPINDOWN that, if set, will prevent disks from being spun off during system power off and hibernation, respectively (to handle the hibernation case we need the new system state SYSTEM_HIBERNATE_ENTER that can be checked against by libata, in analogy with SYSTEM_POWER_OFF). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16libata: Add another column to the ata_timing table.David Daney
The forthcoming OCTEON SOC Compact Flash driver needs an additional timing value that was not available in the ata_timing table. I add a new column for dmack_hold time. The values were obtained from the Compact Flash specification Rev 4.1. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-16[libata] get-identity ioctl: Fix use of invalid memory pointerJeff Garzik
for SAS drivers. Caught by Ke Wei (and team?) at Marvell. Also, move the ata_scsi_ioctl export to libata-scsi.c, as that seems to be the general trend. Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-01-10libata: Add a per-host flag to opt-in into parallel port probesArjan van de Ven
This patch adds a per host flag that allows drivers to opt in into having its busses scanned in parallel. Drivers that do not set this flag get their ports scanned in the "original" sequence. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08libata: Add 32bit PIO supportAlan Cox
This matters for some controllers and in one or two cases almost doubles PIO performance. Add a bmdma32 operations set we can inherit and activate it for some controllers Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-28libata: perform port detach in EHTejun Heo
ata_port_detach() first made sure EH saw ATA_PFLAG_UNLOADING and then assumed EH context belongs to it and performed detach operation itself. However, UNLOADING doesn't disable all of EH and this could lead to problems including triggering WARN_ON()'s in EH path. This patch makes port detach behave more like other EH actions such that ata_port_detach() requests EH to detach and waits for completion. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-28libata: beef up iteratorsTejun Heo
There currently are the following looping constructs. * __ata_port_for_each_link() for all available links * ata_port_for_each_link() for edge links * ata_link_for_each_dev() for all devices * ata_link_for_each_dev_reverse() for all devices in reverse order Now there's a need for looping construct which is similar to __ata_port_for_each_link() but iterates over PMP links before the host link. Instead of adding another one with long name, do the following cleanup. * Implement and export ata_link_next() and ata_dev_next() which take @mode parameter and can be used to build custom loop. * Implement ata_for_each_link() and ata_for_each_dev() which take looping mode explicitly. The following iteration modes are implemented. * ATA_LITER_EDGE : loop over edge links * ATA_LITER_HOST_FIRST : loop over all links, host link first * ATA_LITER_PMP_FIRST : loop over all links, PMP links first * ATA_DITER_ENABLED : loop over enabled devices * ATA_DITER_ENABLED_REVERSE : loop over enabled devices in reverse order * ATA_DITER_ALL : loop over all devices * ATA_DITER_ALL_REVERSE : loop over all devices in reverse order This change removes exlicit device enabledness checks from many loops and makes it clear which ones are iterated over in which direction. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-12-01libata: blacklist Seagate drives which time out FLUSH_CACHE when used with NCQTejun Heo
Some recent Seagate harddrives have firmware bug which causes FLUSH CACHE to timeout under certain circumstances if NCQ is being used. This can be worked around by disabling NCQ and fixed by updating the firmware. Implement ATA_HORKAGE_FIRMWARE_UPDATE and blacklist these devices. The wiki page has been updated to contain information on this issue. http://ata.wiki.kernel.org/index.php/Known_issues Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-10libata: revert convert-to-block-tagging patchesTejun Heo
This patch reverts the following three commits which convert libata to use block layer tagging. 43a49cbdf31e812c0d8f553d433b09b421f5d52c e013e13bf605b9e6b702adffbe2853cfc60e7806 2fca5ccf97d2c28bcfce44f5b07d85e74e3cd18e Although using block layer tagging is the right direction, due to the tight coupling among tag number, data structure allocation and hardware command slot allocation, libata doesn't work correctly with the current conversion. The biggest problem is guaranteeing that tag 0 is always used for non-NCQ commands. Due to the way blk-tag is implemented and how SCSI starts and finishes requests, such guarantee can't be made. I'm not sure whether this would actually break any low level driver but it doesn't look like a good idea to break such assumption given the frailty of ATA controllers. So, for the time being, keep using the old dumb in-libata qc allocation. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jens Axobe <jens.axboe@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-04libata: implement ATA_HORKAGE_ATAPI_MOD16_DMA and apply itTejun Heo
libata always uses PIO for ATAPI commands when the number of bytes to transfer isn't multiple of 16 but quantum DAT72 chokes on odd bytes PIO transfers. Implement a horkage to skip the mod16 check and apply it to the quantum device. This is reported by John Clark in the following thread. http://thread.gmane.org/gmane.linux.ide/34748 Signed-off-by: Tejun Heo <tj@kernel.org> Cc: John Clark <clarkjc@runbox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-31libata: add whitelist for devices with known good pata-sata bridgesJens Axboe
libata currently imposes a UDMA5 max transfer rate and 200 sector max transfer size for SATA devices that sit behind a pata-sata bridge. Lots of devices have known good bridges that don't need this limit applied. The MTRON SSD disks are such devices. Transfer rates are increased by 20-30% with the restriction removed. So add a "blacklist" entry for the MTRON devices, with a flag indicating that the bridge is known good. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-23libata: switch to using block layer tagging supportJens Axboe
libata currently has a pretty dumb ATA_MAX_QUEUE loop for finding a free tag to use. Instead of fixing that up, convert libata to using block layer tagging - gets rid of code in libata, and is also much faster. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-22libata: transfer EHI control flags to slave ehc.iTejun Heo
ATA_EHI_NO_AUTOPSY and ATA_EHI_QUIET are used to control the behavior of EH. As only the master link is visible outside EH, these flags are set only for the master link although they should also apply to the slave link, which causes spurious EH messages during probe and suspend/resume. This patch transfers those two flags to slave ehc.i before performing slave autopsy and reporting. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: reorder ata_device to remove 8 bytes of padding on 64 bitsRichard Kennedy
reduce size by 8 bytes from 1160 to 1152 allowing it to fit in 1 fewer cachelines. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: Implement disk shock protection supportElias Oltmanns
On user request (through sysfs), the IDLE IMMEDIATE command with UNLOAD FEATURE as specified in ATA-7 is issued to the device and processing of the request queue is stopped thereafter until the specified timeout expires or user space asks to resume normal operation. This is supposed to prevent the heads of a hard drive from accidentally crashing onto the platter when a heavy shock is anticipated (like a falling laptop expected to hit the floor). In fact, the whole port stops processing commands until the timeout has expired in order to avoid any resets due to failed commands on another device. Signed-off-by: Elias Oltmanns <eo@nebensachen.de> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: implement slave_linkTejun Heo
Explanation taken from the comment of ata_slave_link_init(). In libata, a port contains links and a link contains devices. There is single host link but if a PMP is attached to it, there can be multiple fan-out links. On SATA, there's usually a single device connected to a link but PATA and SATA controllers emulating TF based interface can have two - master and slave. However, there are a few controllers which don't fit into this abstraction too well - SATA controllers which emulate TF interface with both master and slave devices but also have separate SCR register sets for each device. These controllers need separate links for physical link handling (e.g. onlineness, link speed) but should be treated like a traditional M/S controller for everything else (e.g. command issue, softreset). slave_link is libata's way of handling this class of controllers without impacting core layer too much. For anything other than physical link handling, the default host link is used for both master and slave. For physical link handling, separate @ap->slave_link is used. All dirty details are implemented inside libata core layer. From LLD's POV, the only difference is that prereset, hardreset and postreset are called once more for the slave link, so the reset sequence looks like the following. prereset(M) -> prereset(S) -> hardreset(M) -> hardreset(S) -> softreset(M) -> postreset(M) -> postreset(S) Note that softreset is called only for the master. Softreset resets both M/S by definition, so SRST on master should handle both (the standard method will work just fine). As slave_link excludes PMP support and only code paths which deal with the attributes of physical link are affected, all the changes are localized to libata.h, libata-core.c and libata-eh.c. * ata_is_host_link() updated so that slave_link is considered as host link too. * iterator extended to iterate over the slave_link when using the underbarred version. * force param handling updated such that devno 16 is mapped to the slave link/device. * ata_link_on/offline() updated to return the combined result from master and slave link. ata_phys_link_on/offline() are the direct versions. * EH autopsy and report are performed separately for master slave links. Reset is udpated to implement the above described reset sequence. Except for reset update, most changes are minor, many of them just modifying dev->link to ata_dev_phys_link(dev) or using phys online test instead. After this update, LLDs can take full advantage of per-dev SCR registers by simply turning on slave link. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: misc updates to prepare for slave linkTejun Heo
* Add ATA_EH_ALL_ACTIONS. * Make sata_link_{on|off}_line() return bool instead of int. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: reimplement link iteratorTejun Heo
Implement __ata_port_next_link() and reimplement __ata_port_for_each_link() and ata_port_for_each_link() using it. This removes relatively large inlined code and makes iteration easier to extend. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-29libata: make SCR access ops per-linkTejun Heo
Logically, SCR access ops should take @link; however, there was no compelling reason to convert all SCR access ops when adding @link abstraction as there's one-to-one mapping between a port and a non-PMP link. However, that assumption won't hold anymore with the scheduled addition of slave link. Make SCR access ops per-link. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22libata: Fix a large collection of DMA mode mismatchesAlan Cox
Dave Müller sent a diff for the pata_oldpiix that highlighted a problem where a lot of the ATA drivers assume dma_mode == 0 means "no DMA" while the core code uses 0xFF. This turns out to have other consequences such as code doing >= XFER_UDMA_0 also catching 0xFF as UDMAlots. Fortunately it doesn't generally affect set_dma_mode, although some drivers call back into their own set mode code from other points. Having been through the drivers I've added helpers for using_udma/using_mwdma dma_enabled so that people don't open code ranges that may change (eg if UDMA8 appears somewhere) Thanks to David for the initial bits [and added fix for pata_oldpiix from and signed-off-by Dave Mueller <dave.mueller@gmx.ch> -jg] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22libata: restore SControl on detachTejun Heo
Save SControl during probing and restore it on detach. This prevents adjustments made by libata drivers to seep into the next driver which gets attached (be it a libata one or not). It's not clear whether SControl also needs to be restored on suspend. The next system to have control (ACPI or kexec'd kernel) would probably like to see the original SControl value but there's no guarantee that a link is gonna keep working after SControl is adjusted without a reset and adding a reset and modified recovery cycle soley for this is an overkill. For now, do it only for detach. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-22libata: implement no[hs]rst force paramsTejun Heo
Implement force params nohrst, nosrst and norst. This is to work around reset related problems and ease debugging. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-31pata_it821x: Driver updates and reworkingAlan Cox
- Add support for the RDC 1010 variant - Rework the core library to have a read_id method. This allows the hacky bits of it821x to go and prepares us for pata_hd - Switch from WARN to BUG in ata_id_string as it will reboot if you get it wrong so WARN won't be seen - Allow the issue of command 0xFC on the 821x. This is needed to query rebuild status. - Tidy up printk formatting - Do more ident rewriting on RAID volumes to handle firmware provided ident data which is rather wonky - Report the firmware revision and device layout in RAID mode - Don't try and disable raid on the 8211 or RDC - they don't have the relevant bits Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-31libata.h: replace __FUNCTION__ with __func__Alexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-14libata/ahci: enclosure management supportKristen Carlson Accardi
Add Enclosure Management support to libata and ahci. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
