path: root/include/linux/lockd
2008-04-25lockd: unlock lockd locks held for a certain filesystemWendy Cheng
Add /proc/fs/nfsd/unlock_filesystem, which allows e.g.: shell> echo /mnt/sfs1 > /proc/fs/nfsd/unlock_filesystem so that a filesystem can be unmounted before allowing a peer nfsd to take over nfs service for the filesystem. Signed-off-by: S. Wendy Cheng <wcheng@redhat.com> Cc: Lon Hohberger <lhh@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> fs/lockd/svcsubs.c | 66 +++++++++++++++++++++++++++++++++++++++----- fs/nfsd/nfsctl.c | 65 +++++++++++++++++++++++++++++++++++++++++++ include/linux/lockd/lockd.h | 7 ++++ 3 files changed, 131 insertions(+), 7 deletions(-)
2008-04-25lockd: unlock lockd locks associated with a given server ipWendy Cheng
For high-availability NFS service, we generally need to be able to drop file locks held on the exported filesystem before moving clients to a new server. Currently the only way to do that is by shutting down lockd entirely, which is often undesireable (for example, if you want to continue exporting other filesystems). This patch allows the administrator to release all locks held by clients accessing the client through a given server ip address, by echoing that address to a new file, /proc/fs/nfsd/unlock_ip, as in: shell> echo 10.1.1.2 > /proc/fs/nfsd/unlock_ip The expected sequence of events can be: 1. Tear down the IP address 2. Unexport the path 3. Write IP to /proc/fs/nfsd/unlock_ip to unlock files 4. Signal peer to begin take-over. For now we only support IPv4 addresses and NFSv2/v3 (NFSv4 locks are not affected). Also, if unmounting the filesystem is required, we assume at step 3 that clients using the given server ip are the only clients holding locks on the given filesystem; otherwise, an additional patch is required to allow revoking all locks held by lockd on a given filesystem. Signed-off-by: S. Wendy Cheng <wcheng@redhat.com> Cc: Lon Hohberger <lhh@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> fs/lockd/svcsubs.c | 66 +++++++++++++++++++++++++++++++++++++++----- fs/nfsd/nfsctl.c | 65 +++++++++++++++++++++++++++++++++++++++++++ include/linux/lockd/lockd.h | 7 ++++ 3 files changed, 131 insertions(+), 7 deletions(-)
2008-04-19NLM/lockd: Add a reference counter to struct nlm_rqstTrond Myklebust
When we replace the existing synchronous RPC calls with asynchronous calls, the reference count will be needed in order to allow us to examine the result of the RPC call. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-19lockd: introduce new function to encode private argument in SM_MON requestsChuck Lever
Clean up: refactor the encoding of the opaque 16-byte private argument in xdr_encode_mon(). This will be updated later to support IPv6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-19lockd: bring a few function declarations up to dateChuck Lever
Clean-up: replace __inline__ and use up-to-date function declaration conventions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-19NLM: NLM protocol version numbers are u32Chuck Lever
Clean up: RPC protocol version numbers are u32. Make sure we use an appropriate type for NLM version numbers when calling nlm_lookup_host(). Eliminates a harmless mixed sign comparison in nlm_host_lookup(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01NLM: Fix sign of length of NLM variable length stringsChuck Lever
According to The Open Group's NLM specification, NLM callers are variable length strings. XDR variable length strings use an unsigned 32 bit length. And internally, negative string lengths are not meaningful for the Linux NLM implementation. Clean up: Make nlm_lock.len and nlm_reboot.len unsigned integers. This makes the sign of NLM string lengths consistent with the sign of xdr_netobj lengths. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Acked-By: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-01-30NLM: Introduce an arguments structure for nlmclnt_init()Chuck Lever
Clean up: pass 5 arguments to nlmclnt_init() in a structure similar to the new nfs_client_initdata structure. Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
2008-01-30NLM/NFS: Use cached nlm_host when calling nlmclnt_proc()Chuck Lever
Now that each NFS mount point caches its own nlm_host structure, it can be passed to nlmclnt_proc() for each lock request. By pinning an nlm_host for each mount point, we trade the overhead of looking up or creating a fresh nlm_host struct during every NLM procedure call for a little extra memory. We also restrict the nlmclnt_proc symbol to limit the use of this call to in-tree modules. Note that nlm_lookup_host() (just removed from the client's per-request NLM processing) could also trigger an nlm_host garbage collection. Now client-side nlm_host garbage collection occurs only during NFS mount processing. Since the NFS client now holds a reference on these nlm_host structures, they wouldn't have been affected by garbage collection anyway. Given that nlm_lookup_host() reorders the global nlm_host chain after every successful lookup, and that a garbage collection could be triggered during the call, we've removed a significant amount of per-NLM-request CPU processing overhead. Sidebar: there are only a few remaining references to the internals of NFS inodes in the client-side NLM code. The only references I found are related to extracting or comparing the inode's file handle via NFS_FH(). One is in nlmclnt_grant(); the other is in nlmclnt_setlockargs(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NLM: Introduce external nlm_host set-up and tear-down functionsChuck Lever
We would like to remove the per-lock-operation nlm_lookup_host() call from nlmclnt_proc(). The new architecture pins an nlm_host structure to each NFS client superblock that has the "lock" mount option set. The NFS client passes in the pinned nlm_host structure during each call to nlmclnt_proc(). NFS client unmount processing "puts" the nlm_host so it can be garbage- collected later. This patch introduces externally callable NLM functions that handle mount-time nlm_host set up and tear-down. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-17knfsd: lockd: nfsd4: use same grace period for lockd and nfsd4Marc Eshel
Both lockd and (in the nfsv4 case) nfsd enforce a "grace period" after reboot, during which clients may reclaim locks from the previous server instance, but may not acquire new locks. Currently the lockd and nfsd enforce grace periods of different lengths. This may cause problems when we reboot a server with both v2/v3 and v4 clients. For example, if the lockd grace period is shorter (as is likely the case), then a v3 client might acquire a new lock that conflicts with a lock already held (but not yet reclaimed) by a v4 client. This patch calculates a lease time that lockd and nfsd can both use. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10NLM: fix source address of callback to clientFrank van Maarseveen
Use the destination address of the original NLM request as the source address in callbacks to the client. Signed-off-by: Frank van Maarseveen <frankvm@frankvm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-14NLM: Fix sparse warningsTrond Myklebust
- fs/lockd/xdr4.c:140:27: warning: incorrect type in argument 2 (different explicit signedness) - fs/lockd/xdr4.c:141:27: warning: incorrect type in argument 2 (different explicit signedness) - fs/lockd/xdr4.c:432:28: warning: incorrect type in argument 2 (different explicit signedness) - fs/lockd/xdr4.c:433:28: warning: incorrect type in argument 2 (different explicit signedness) - fs/lockd/xdr4.c:587:20: warning: symbol 'nlm_version4' was not declared. Should it be static? Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-07Merge branch 'server-cluster-locking-api' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'server-cluster-locking-api' of git://linux-nfs.org/~bfields/linux: gfs2: nfs lock support for gfs2 lockd: add code to handle deferred lock requests lockd: always preallocate block in nlmsvc_lock() lockd: handle test_lock deferrals lockd: pass cookie in nlmsvc_testlock lockd: handle fl_grant callbacks lockd: save lock state on deferral locks: add fl_grant callback for asynchronous lock return nfsd4: Convert NFSv4 to new lock interface locks: add lock cancel command locks: allow {vfs,posix}_lock_file to return conflicting lock locks: factor out generic/filesystem switch from setlock code locks: factor out generic/filesystem switch from test_lock locks: give posix_test_lock same interface as ->lock locks: make ->lock release private data before returning in GETLK case locks: create posix-to-flock helper functions locks: trivial removal of unnecessary parentheses
2007-05-06lockd: pass cookie in nlmsvc_testlockMarc Eshel
Change NLM internal interface to pass more information for test lock; we need this to make sure the cookie information is pushed down to the place where we do request deferral, which is handled for testlock by the following patch. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-05-06lockd: save lock state on deferralMarc Eshel
We need to keep some state for a pending asynchronous lock request, so this patch adds that state to struct nlm_block. This also adds a function which defers the request, by calling rqstp->rq_chandle.defer and storing the resulting deferred request in a nlm_block structure which we insert into lockd's global block list. That new function isn't called yet, so it's dead code until a later patch. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-04-30NLM: Shrink the maximum request size of NLM4 requestsChuck Lever
NLM version 4 requests estimate the call and reply header sizes rather conservatively, using the very maximum size allowed in the protocol even though Linux always uses only a small fraction of the allowable space. Reduce the size of caller and lock arguments to conserve RPC buffer space while XDR encoding NLM4 arguments. Add compile-time checks to ensure the hostname string won't overflow NLM protocol maximums. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-13[PATCH] lockd endianness annotationsAl Viro
Annotated, all places switched to keeping status net-endian. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert lockdJosef Sipek
2006-12-07[PATCH] fs/lockd/host.c: make 2 functions staticAdrian Bunk
Make the following needlessly global functions static: - nlm_lookup_host() - nsm_find() Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] lockd endianness annotationsAl Viro
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] knfsd: Allow lockd to drop replies as appropriateNeilBrown
It is possible for the ->fopen callback from lockd into nfsd to find that an answer cannot be given straight away (an upcall is needed) and so the request has to be 'dropped', to be retried later. That error status is not currently propagated back. So: Change nlm_fopen to return nlm error codes (rather than a private protocol) and define a new nlm_drop_reply code. Cause nlm_drop_reply to cause the rpc request to get rpc_drop_reply when this error comes back. Cause svc_process to drop a request which returns a status of rpc_drop_reply. [akpm@osdl.org: fix warning storm] Cc: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] Convert lockd to use the newer mutex instead of the older semaphoreNeil Brown
Both the (recently introduces) nsm_sema and the older f_sema are converted over. Cc: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: export nsm_local_state to user space via sysctlOlaf Kirch
Every NLM call includes the client's NSM state. Currently, the Linux client always reports 0 - which seems not to cause any problems, but is not what the protocol says. This patch exposes the kernel's internal variable to user space via a sysctl, which can be set at system boot time by statd. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: match GRANTED_RES replies using cookiesOlaf Kirch
When we send a GRANTED_MSG call, we current copy the NLM cookie provided in the original LOCK call - because in 1996, some broken clients seemed to rely on this bug. However, this means the cookies are not unique, so that when the client's GRANTED_RES message comes back, we cannot simply match it based on the cookie, but have to use the client's IP address in addition. Which breaks when you have a multi-homed NFS client. The X/Open spec explicitly mentions that clients should not expect the same cookie; so one may hope that any clients that were broken in 1996 have either been fixed or rendered obsolete. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: make nlmclnt_next_cookie SMP safeOlaf Kirch
The way we incremented the NLM cookie in nlmclnt_next_cookie was not thread safe. This patch changes the counter to an atomic_t Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: optionally use hostnames for identifying peersOlaf Kirch
This patch adds the nsm_use_hostnames sysctl and module param. If set, lockd will use the client's name (as given in the NLM arguments) to find the NSM handle. This makes recovery work when the NFS peer is multi-homed, and the reboot notification arrives from a different IP than the original lock calls. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: simplify nlmsvc_invalidate_allNeilBrown
As a result of previous patches, the loop in nlmsvc_invalidate_all just sets h_expires for all client/hosts to 0 (though does it in a very complicated way). This was possibly meant to trigger early garbage collection but half the time '0' is in the future and so it infact delays garbage collection. Pre-aging the 'hosts' is not really needed at this point anyway so we throw out the loop and nlm_find_client which is no longer needed. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: make nlm_traverse_* more flexibleOlaf Kirch
This patch makes nlm_traverse{locks,blocks,shares} and friends use a function pointer rather than a "action" enum. This function pointer is given two nlm_hosts (one given by the caller, the other taken from the lock/block/share currently visited), and is free to do with them as it wants. If it returns a non-zero value, the lockd/block/share is released. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: change nlm_file to use a hlistOlaf Kirch
This changes struct nlm_file and the nlm_files hash table to use a hlist instead of the home-grown lists. This allows us to remove f_hash which was only used to find the right hash chain to delete an entry from. It also increases the size of the nlm_files hash table from 32 to 128. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: Change list of blocked list to list_nodeOlaf Kirch
This patch changes the nlm_blocked list to use a list_node instead of homegrown linked list handling. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: make the hash chains use a hlist_nodeOlaf Kirch
Get rid of the home-grown singly linked lists for the nlm_host hash table. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: make the nsm upcalls use the nsm_handleOlaf Kirch
This converts the statd upcalls to use the nsm_handle This means that we only register each host once with statd, rather than registering each host/vers/protocol triple. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: Make nlm_host_rebooted use the nsm_handleOlaf Kirch
This patch makes the SM_NOTIFY handling understand and use the nsm_handle. To make it a bit clear what is happening: nlmclent_prepare_reclaim and nlmclnt_finish_reclaim get open-coded into 'reclaimer' The result is tidied up. Then some of that functionality is moved out into nlm_host_rebooted (which calls nlmclnt_recovery which starts a thread which runs reclaimer). Also host_rebooted now finds an nsm_handle rather than a host, then then iterates over all hosts and deals with each host that shares that nsm_handle. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: lockd: introduce nsm_handleOlaf Kirch
This patch introduces the nsm_handle, which is shared by all nlm_host objects referring to the same client. With this patch applied, all nlm_hosts from the same address will share the same nsm_handle. A future patch will add sharing by name. Note: this patch changes h_name so that it is no longer guaranteed to be an IP address of the host. When the host represents an NFS server, h_name will be the name passed in the mount call. When the host represents a client, h_name will be the name presented in the lock request received from the client. A h_name is only used for printing informational messages, this change should not be significant. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: when looking up a lockd host, pass hostname & lengthOlaf Kirch
This patch adds the peer's hostname (and name length) to all calls to nlm*_lookup_host functions. A subsequent patch will make use of these (is requested by a sysctl). Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] knfsd: consolidate common code for statd->lockd notificationOlaf Kirch
Common code from nlm4svc_proc_sm_notify and nlmsvc_proc_sm_notify is moved into a new nlm_host_rebooted. This is in preparation of a patch that will change the reboot notification handling entirely. Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-02[PATCH] namespaces: utsname: switch to using uts namespacesSerge E. Hallyn
Replace references to system_utsname to the per-process uts namespace where appropriate. This includes things like uname. Changes: Per Eric Biederman's comments, use the per-process uts namespace for ELF_PLATFORM, sunrpc, and parts of net/ipv4/ipconfig.c [jdike@addtoit.com: UML fix] [clg@fr.ibm.com: cleanup] [akpm@osdl.org: build fix] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: be more selective in which sockets lockd listens onNeilBrown
Currently lockd listens on UDP always, and TCP if CONFIG_NFSD_TCP is set. However as lockd performs services of the client as well, this is a problem. If CONFIG_NfSD_TCP is not set, and a tcp mount is used, the server will not be able to call back to lockd. So: - add an option to lockd_up saying which protocol is needed - Always open sockets for which an explicit port was given, otherwise only open a socket of the type required - Change nfsd to do one lockd_up per socket rather than one per thread. This - removes the dependancy on CONFIG_NFSD_TCP - means that lockd may open sockets other than at startup - means that lockd will *not* listen on UDP if the only mounts are TCP mount (and nfsd hasn't started). The latter is the only one that concerns me at all - I don't know if this might be a problem with some servers. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-03NLM/lockd: remove b_doneJ. Bruce Fields
We never actually set the b_done field any more; it's always zero. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> (cherry picked from af8412d4283ef91356e65e0ed9b025b376aebded commit)
2006-06-20Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: include/linux/nfs_fs.h Fixed up conflict with kernel header updates.
2006-06-09NLM: Fix reclaim racesTrond Myklebust
Currently it is possible for a task to remove its locks at the same time as the NLM recovery thread is trying to recover them. This quickly leads to an Oops. Protect the locks using an rw semaphore while they are being recovered. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09NLM: sem to mutex conversionTrond Myklebust
2006-06-09locks.c: add the fl_owner to nlm_compare_locksMarc Eshel
Add the fl_owner to NLM compare locks. Since two different client can present the same pid to the server it is not enough to distinguish locks from different clients. The fl_owner field is a pointer to the struct nlm_host which is unique for each client. Signed-off-by: Marc Eshel <eshel@almaden.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-20LOCKD: Make nlmsvc_traverse_shares return voidJ. Bruce Fields
The nlmsvc_traverse_shares return value is always zero, hence useless. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20LOCKD: nlmsvc_traverse_blocks return is unusedJ. Bruce Fields
Note that we never return non-zero. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20lockd: Add helper for *_RES callbacksTrond Myklebust
2006-03-20NLM: Add nlmclnt_release_callTrond Myklebust
Add a helper function to simplify the freeing of NLM client requests. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
