commit 13c07b0286d340275f2d97adf085cecda37ede37 upstream.
Exactly like roundup_pow_of_two(1), the rounddown version was buggy for
the case of a compile-time constant '1' argument. Probably because it
originated from the same code, sharing history with the roundup version
from before the bugfix (for that one, see commit 1a06a52ee1b0: "Fix
roundup_pow_of_two(1)").
However, unlike the roundup version, the fix for rounddown is to just
remove the broken special case entirely. It's simply not needed - the
generic code
1UL << ilog2(n)
does the right thing for the constant '1' argment too. The only reason
roundup needed that special case was because rounding up does so by
subtracting one from the argument (and then adding one to the result)
causing the obvious problems with "ilog2(0)".
But rounddown doesn't do any of that, since ilog2() naturally truncates
(ie "rounds down") to the right rounded down value. And without the
ilog2(0) case, there's no reason for the special case that had the wrong
value.
tl;dr: rounddown_pow_of_two(1) should be 1, not 0.
Acked-by: Dmitry Torokhov <dtor@vmware.com>
Given a number of places in the tree that need to calculate this value
explicitly, might as well just create a macro for it.
(akpm: must be implemented as a macro for callee typeof() usage)
To go along with the existing "roundup_pow_of_two" routine, add one for
rounding down since that operation appears to crop up on a regular basis in
the source tree.
[m.kozlowski@tuxland.pl: fix unbalanced parentheses]
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
1 is a power of two, therefore roundup_pow_of_two(1) should return 1. It does
in case the argument is a variable but in case it's a constant it behaves
wrong and returns 0. Probably nobody ever did it so this was never noticed.
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
Single typo correction in include/linux/log2.h.
Signed-Off-By: David Howells <dhowells@redhat.com>
Add the inline function "is_power_of_2()" to log2.h, where the value
zero is *not* considered to be a power of two.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
constant
Alter roundup_pow_of_two() so that it can make use of ilog2() on a constant to
produce a constant value, retaining the ability for an arch to override it in
the non-const case.
This permits the function to be used to initialise variables.
This facility provides three entry points:
ilog2() Log base 2 of unsigned long
ilog2_u32() Log base 2 of u32
ilog2_u64() Log base 2 of u64
These facilities can either be used inside functions on dynamic data:
int do_something(long q)
y = ilog2(x)
Or can be used to statically initialise global variables with constant values:
unsigned n = ilog2(27);
When performing static initialisation, the compiler will report "error:
initializer element is not constant" if asked to take a log of zero or of
something not reducible to a constant. They treat negative numbers as
unsigned.
When not dealing with a constant, they fall back to using fls() which permits
them to use arch-specific log calculation instructions - such as BSR on
x86/x86_64 or SCAN on FRV - if available.
[akpm@osdl.org: MMC fix]
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Wojtek Kaniewski <wojtekka@toxygen.net>
