path: root/include/linux/mdio-gpio.h
2008-11-16phylib: make mdio-gpio work without OF (v4)Paulius Zaleckas
make mdio-gpio work with non OpenFirmware gpio implementation. Aditional changes to mdio-gpio: - use gpio_request() and gpio_free() - place irq[] array in struct mdio_gpio_info - add module description, author and license - add note about compiling this driver as module - rename mdc and mdio function (were ugly names) - change MII to MDIO in bus name - add __init __exit to module (un)loading functions - probe fails if no phys added to the bus - kzalloc bitbang with sizeof(*bitbang) Changes since v3: - keep bus naming "%x" to be compatible with existing drivers. Changes since v2: - more #ifdefs reduction - platform driver will be registered on OF platforms also - unified platform and OF bus_id to phy%i Changes since v1: - removed NO_IRQ - reduced #idefs Laurent, please test this driver under OF. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: David S. Miller <davem@davemloft.net>
