commit a96dfddbcc04336bbed50dc2b24823e45e09e80c upstream.
Reading a sysfs "memoryN/valid_zones" file leads to the following oops
when the first page of a range is not backed by struct page.
show_valid_zones() assumes that 'start_pfn' is always valid for
page_zone().
BUG: unable to handle kernel paging request at ffffea017a000000
IP: show_valid_zones+0x6f/0x160
This issue may happen on x86-64 systems with 64GiB or more memory since
their memory block size is bumped up to 2GiB. [1] An example of such
systems is desribed below. 0x3240000000 is only aligned by 1GiB and
this memory block starts from 0x3200000000, which is not backed by
struct page.
BIOS-e820: [mem 0x0000003240000000-0x000000603fffffff] usable
Since test_pages_in_a_zone() already checks holes, fix this issue by
extending this function to return 'valid_start' and 'valid_end' for a
given range. show_valid_zones() then proceeds with the valid range.
[1] 'Commit bdee237c0343 ("x86: mm: Use 2GB memory block size on
large-memory x86-64 systems")'
Link: http://lkml.kernel.org/r/20170127222149.30893-3-toshi.kani@hpe.com
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Zhang Zhen <zhenzhang.zhang@huawei.com>
Cc: Reza Arbab <arbab@linux.vnet.ibm.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: <stable@vger.kernel.org> [4.4+]
Add add_memory_resource() to add memory using an existing "System RAM"
resource. This is useful if the memory region is being located by
finding a free resource slot with allocate_resource().
Xen guests will make use of this in their balloon driver to hotplug
arbitrary amounts of memory in response to toolstack requests.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Daniel Kiper <daniel.kiper@oracle.com>
Reviewed-by: Tang Chen <tangchen@cn.fujitsu.com>
While pmem is usable as a block device or via DAX mappings to userspace
there are several usage scenarios that can not target pmem due to its
lack of struct page coverage. In preparation for "hot plugging" pmem
into the vmemmap add ZONE_DEVICE as a new zone to tag these pages
separately from the ones that are subject to standard page allocations.
Importantly "device memory" can be removed at will by userspace
unbinding the driver of the device.
Having a separate zone prevents allocation and otherwise marks these
pages that are distinct from typical uniform memory. Device memory has
different lifetime and performance characteristics than RAM. However,
since we have run out of ZONES_SHIFT bits this functionality currently
depends on sacrificing ZONE_DMA.
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Jerome Glisse <j.glisse@gmail.com>
[hch: various simplifications in the arch interface]
There's a deadlock when concurrently hot-adding memory through the probe
interface and switching a memory block from offline to online.
When hot-adding memory via the probe interface, add_memory() first takes
mem_hotplug_begin() and then device_lock() is later taken when registering
the newly initialized memory block. This creates a lock dependency of (1)
mem_hotplug.lock (2) dev->mutex.
When switching a memory block from offline to online, dev->mutex is first
grabbed in device_online() when the write(2) transitions an existing
memory block from offline to online, and then online_pages() will take
mem_hotplug_begin().
This creates a lock inversion between mem_hotplug.lock and dev->mutex.
Vitaly reports that this deadlock can happen when kworker handling a probe
event races with systemd-udevd switching a memory block's state.
This patch requires the state transition to take mem_hotplug_begin()
before dev->mutex. Hot-adding memory via the probe interface creates a
memory block while holding mem_hotplug_begin(), there is no way to take
dev->mutex first in this case.
online_pages() and offline_pages() are only called when transitioning
memory block state. We now require that mem_hotplug_begin() is taken
before calling them -- this requires exporting the mem_hotplug_begin() and
mem_hotplug_done() to generic code. In all hot-add and hot-remove cases,
mem_hotplug_begin() is done prior to device_online(). This is all that is
needed to avoid the deadlock.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Tested-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Cc: Wang Nan <wangnan0@huawei.com>
Currently memory-hotplug has two limits:
1. If the memory block is in ZONE_NORMAL, you can change it to
ZONE_MOVABLE, but this memory block must be adjacent to ZONE_MOVABLE.
2. If the memory block is in ZONE_MOVABLE, you can change it to
ZONE_NORMAL, but this memory block must be adjacent to ZONE_NORMAL.
With this patch, we can easy to know a memory block can be onlined to
which zone, and don't need to know the above two limits.
Updated the related Documentation.
[akpm@linux-foundation.org: use conventional comment layout]
[akpm@linux-foundation.org: fix build with CONFIG_MEMORY_HOTREMOVE=n]
[akpm@linux-foundation.org: remove unused local zone_prev]
Signed-off-by: Zhang Zhen <zhenzhang.zhang@huawei.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
This series of patches fixes a problem when adding memory in bad manner.
For example: for a x86_64 machine booted with "mem=400M" and with 2GiB
memory installed, following commands cause problem:
# echo 0x40000000 > /sys/devices/system/memory/probe
[ 28.613895] init_memory_mapping: [mem 0x40000000-0x47ffffff]
# echo 0x48000000 > /sys/devices/system/memory/probe
[ 28.693675] init_memory_mapping: [mem 0x48000000-0x4fffffff]
# echo online_movable > /sys/devices/system/memory/memory9/state
# echo 0x50000000 > /sys/devices/system/memory/probe
[ 29.084090] init_memory_mapping: [mem 0x50000000-0x57ffffff]
# echo 0x58000000 > /sys/devices/system/memory/probe
[ 29.151880] init_memory_mapping: [mem 0x58000000-0x5fffffff]
# echo online_movable > /sys/devices/system/memory/memory11/state
# echo online> /sys/devices/system/memory/memory8/state
# echo online> /sys/devices/system/memory/memory10/state
# echo offline> /sys/devices/system/memory/memory9/state
[ 30.558819] Offlined Pages 32768
# free
total used free shared buffers cached
Mem: 780588 18014398509432020 830552 0 0 51180
-/+ buffers/cache: 18014398509380840 881732
Swap: 0 0 0
This is because the above commands probe higher memory after online a
section with online_movable, which causes ZONE_HIGHMEM (or ZONE_NORMAL
for systems without ZONE_HIGHMEM) overlaps ZONE_MOVABLE.
After the second online_movable, the problem can be observed from
zoneinfo:
# cat /proc/zoneinfo
Node 0, zone Movable
pages free 65491
min 250
low 312
high 375
scanned 0
spanned 18446744073709518848
present 65536
managed 65536
This series of patches solve the problem by checking ZONE_MOVABLE when
choosing zone for new memory. If new memory is inside or higher than
ZONE_MOVABLE, makes it go there instead.
After applying this series of patches, following are free and zoneinfo
result (after offlining memory9):
bash-4.2# free
Mem: 780956 80112 700844 0 0 51180
-/+ buffers/cache: 28932 752024
Swap: 0 0 0
bash-4.2# cat /proc/zoneinfo
Node 0, zone DMA
pages free 3389
min 14
low 17
high 21
scanned 0
spanned 4095
present 3998
managed 3977
nr_free_pages 3389
start_pfn: 1
inactive_ratio: 1
Node 0, zone DMA32
pages free 73724
min 341
low 426
high 511
scanned 0
spanned 98304
present 98304
managed 92958
nr_free_pages 73724
start_pfn: 4096
inactive_ratio: 1
Node 0, zone Normal
pages free 32630
min 120
low 150
high 180
scanned 0
spanned 32768
present 32768
managed 32768
nr_free_pages 32630
start_pfn: 262144
inactive_ratio: 1
pages free 65476
min 241
low 301
high 361
scanned 0
spanned 98304
present 65536
managed 65536
nr_free_pages 65476
start_pfn: 294912
inactive_ratio: 1
This patch (of 7):
Introduce zone_for_memory() in arch independent code for
arch_add_memory() use.
Many arch_add_memory() function simply selects ZONE_HIGHMEM or
ZONE_NORMAL and add new memory into it. However, with the existance of
ZONE_MOVABLE, the selection method should be carefully considered: if
new, higher memory is added after ZONE_MOVABLE is setup, the default
zone and ZONE_MOVABLE may overlap each other.
should_add_memory_movable() checks the status of ZONE_MOVABLE. If it
has already contain memory, compare the address of new memory and
movable memory. If new memory is higher than movable, it should be
added into ZONE_MOVABLE instead of default zone.
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: "Mel Gorman" <mgorman@suse.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
In store_mem_state(), we have:
334 else if (!strncmp(buf, "offline", min_t(int, count, 7)))
335 online_type = -1;
355 case -1:
356 ret = device_offline(&mem->dev);
357 break;
Here, "offline" is hard coded as -1.
This patch does the following renaming:
ONLINE_KEEP -> MMOP_ONLINE_KEEP
ONLINE_KERNEL -> MMOP_ONLINE_KERNEL
ONLINE_MOVABLE -> MMOP_ONLINE_MOVABLE
and introduces MMOP_OFFLINE = -1 to avoid hard coding.
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Hu Tao <hutao@cn.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Gu Zheng <guz.fnst@cn.fujitsu.com>
kmem_cache_{create,destroy,shrink} need to get a stable value of
cpu/node online mask, because they init/destroy/access per-cpu/node
kmem_cache parts, which can be allocated or destroyed on cpu/mem
hotplug. To protect against cpu hotplug, these functions use
{get,put}_online_cpus. However, they do nothing to synchronize with
memory hotplug - taking the slab_mutex does not eliminate the
possibility of race as described in patch 2.
What we need there is something like get_online_cpus, but for memory.
We already have lock_memory_hotplug, which serves for the purpose, but
it's a bit of a hammer right now, because it's backed by a mutex. As a
result, it imposes some limitations to locking order, which are not
desirable, and can't be used just like get_online_cpus. That's why in
patch 1 I substitute it with get/put_online_mems, which work exactly
like get/put_online_cpus except they block not cpu, but memory hotplug.
[ v1 can be found at https://lkml.org/lkml/2014/4/6/68. I NAK'ed it by
myself, because it used an rw semaphore for get/put_online_mems,
making them dead lock prune. ]
This patch (of 2):
{un}lock_memory_hotplug, which is used to synchronize against memory
hotplug, is currently backed by a mutex, which makes it a bit of a
hammer - threads that only want to get a stable value of online nodes
mask won't be able to proceed concurrently. Also, it imposes some
strong locking ordering rules on it, which narrows down the set of its
usage scenarios.
This patch introduces get/put_online_mems, which are the same as
get/put_online_cpus, but for memory hotplug, i.e. executing a code
inside a get/put_online_mems section will guarantee a stable value of
online nodes, present pages, etc.
lock_memory_hotplug()/unlock_memory_hotplug() are removed altogether.
Signed-off-by: Vladimir Davydov <vdavydov@parallels.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
For below functions,
- sparse_add_one_section()
- kmalloc_section_memmap()
- __kmalloc_section_memmap()
- __kfree_section_memmap()
they are always invoked to operate on one memory section, so it is
redundant to always pass a nr_pages parameter, which is the page numbers
in one section. So we can directly use predefined macro PAGES_PER_SECTION
instead of passing the parameter.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Andy Whitcroft <apw@shadowen.org>
cpu_up() has #ifdef CONFIG_MEMORY_HOTPLUG code blocks, which call
mem_online_node() to put its node online if offlined and then call
build_all_zonelists() to initialize the zone list.
These steps are specific to memory hotplug, and should be managed in
mm/memory_hotplug.c. lock_memory_hotplug() should also be held for the
whole steps.
For this reason, this patch replaces mem_online_node() with
try_online_node(), which performs the whole steps with
lock_memory_hotplug() held. try_online_node() is named after
try_offline_node() as they have similar purpose.
There is no functional change in this patch.
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Move the definitions of offline_pages() and remove_memory()
for CONFIG_MEMORY_HOTREMOVE to memory_hotplug.h, where they belong,
and make them static inline.
Now that the memory offlining should be taken care of by the
companion device offlining code in acpi_scan_hot_remove(), the
ACPI memory hotplug driver doesn't need to offline it in
remove_memory() any more. Moreover, since the return value of
remove_memory() is not used, it's better to make it be a void
function and trigger a BUG() if the memory scheduled for removal is
not offline.
Change the code in accordance with the above observations.
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Since offline_memory_block(mem) is functionally equivalent to
device_offline(&mem->dev), make the only caller of the former use
the latter instead and drop offline_memory_block() entirely.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Toshi Kani <toshi.kani@hp.com>
During ACPI memory hotplug configuration bind memory blocks residing
in modules removable through the standard ACPI mechanism to struct
acpi_device objects associated with ACPI namespace objects
representing those modules. Accordingly, unbind those memory blocks
from the struct acpi_device objects when the memory modules in
question are being removed.
When "offline" operation for devices representing memory blocks is
introduced, this will allow the ACPI core's device hot-remove code to
use it to carry out remove_memory() for those memory blocks and check
the results of that before it actually removes the modules holding
them from the system.
Since walk_memory_range() is used for accessing all memory blocks
corresponding to a given ACPI namespace object, it is exported from
memory_hotplug.c so that the code in acpi_memhotplug.c can use it.
Tested-by: Vasilis Liaskovitis <vasilis.liaskovitis@profitbricks.com>
__remove_pages() is only necessary for CONFIG_MEMORY_HOTREMOVE. PowerPC
pseries will return -EOPNOTSUPP if unsupported.
Adding an #ifdef causes several other functions it depends on to also
become unnecessary, which saves in .text when disabled (it's disabled in
most defconfigs besides powerpc, including x86). remove_memory_block()
becomes static since it is not referenced outside of
drivers/base/memory.c.
Build tested on x86 and powerpc with CONFIG_MEMORY_HOTREMOVE both enabled
and disabled.
try_offline_node() will be needed in the tristate
drivers/acpi/processor_driver.c.
The node will be offlined when all memory/cpu on the node have been
hotremoved. So we need the function try_offline_node() in cpu-hotplug
path.
If the memory-hotplug is disabled, and cpu-hotplug is enabled
1. no memory no the node
we don't online the node, and cpu's node is the nearest node.
2. the node contains some memory
the node has been onlined, and cpu's node is still needed
to migrate the sleep task on the cpu to the same node.
So we do nothing in try_offline_node() in this case.
[rientjes@google.com: export the function try_offline_node() fix]
Signed-off-by: Wen Congyang <wency@cn.fujitsu.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Len Brown <lenb@kernel.org>
Introduce a new function try_offline_node() to remove sysfs file of node
when all memory sections of this node are removed. If some memory
sections of this node are not removed, this function does nothing.
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Jianguo Wu <wujianguo@huawei.com>
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Wu Jianguo <wujianguo@huawei.com>
For removing memmap region of sparse-vmemmap which is allocated bootmem,
memmap region of sparse-vmemmap needs to be registered by
get_page_bootmem(). So the patch searches pages of virtual mapping and
registers the pages by get_page_bootmem().
NOTE: register_page_bootmem_memmap() is not implemented for ia64,
ppc, s390, and sparc. So introduce CONFIG_HAVE_BOOTMEM_INFO_NODE
and revert register_page_bootmem_info_node() when platform doesn't
support it.
It's implemented by adding a new Kconfig option named
CONFIG_HAVE_BOOTMEM_INFO_NODE, which will be automatically selected
by memory-hotplug feature fully supported archs(currently only on
x86_64).
Since we have 2 config options called MEMORY_HOTPLUG and
MEMORY_HOTREMOVE used for memory hot-add and hot-remove separately,
and codes in function register_page_bootmem_info_node() are only
used for collecting infomation for hot-remove, so reside it under
MEMORY_HOTREMOVE.
Besides page_isolation.c selected by MEMORY_ISOLATION under
MEMORY_HOTPLUG is also such case, move it too.
[mhocko@suse.cz: put register_page_bootmem_memmap inside CONFIG_MEMORY_HOTPLUG_SPARSE]
[linfeng@cn.fujitsu.com: introduce CONFIG_HAVE_BOOTMEM_INFO_NODE and revert register_page_bootmem_info_node()]
[mhocko@suse.cz: remove the arch specific functions without any implementation]
[linfeng@cn.fujitsu.com: mm/Kconfig: move auto selects from MEMORY_HOTPLUG to MEMORY_HOTREMOVE as needed]
[rientjes@google.com: fix defined but not used warning]
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reviewed-by: Wu Jianguo <wujianguo@huawei.com>
Signed-off-by: Lin Feng <linfeng@cn.fujitsu.com>
For removing memory, we need to remove page tables. But it depends on
architecture. So the patch introduce arch_remove_memory() for removing
page table. Now it only calls __remove_pages().
Note: __remove_pages() for some archtecuture is not implemented
(I don't know how to implement it for s390).
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
removing memory
We remove the memory like this:
1. lock memory hotplug
2. offline a memory block
3. unlock memory hotplug
4. repeat 1-3 to offline all memory blocks
5. lock memory hotplug
6. remove memory(TODO)
7. unlock memory hotplug
All memory blocks must be offlined before removing memory. But we don't
hold the lock in the whole operation. So we should check whether all
memory blocks are offlined before step6. Otherwise, kernel maybe
panicked.
Offlining a memory block and removing a memory device can be two
different operations. Users can just offline some memory blocks without
removing the memory device. For this purpose, the kernel has held
lock_memory_hotplug() in __offline_pages(). To reuse the code for
memory hot-remove, we repeat step 1-3 to offline all the memory blocks,
repeatedly lock and unlock memory hotplug, but not hold the memory
hotplug lock in the whole operation.
Add online_movable and online_kernel for logic memory hotplug. This is
the dynamic version of "movablecore" & "kernelcore".
We have the same reason to introduce it as to introduce "movablecore" &
"kernelcore". It has the same motive as "movablecore" & "kernelcore", but
it is dynamic/running-time:
o We can configure memory as kernelcore or movablecore after boot.
Userspace workload is increased, we need more hugepage, we can't use
"online_movable" to add memory and allow the system use more
THP(transparent-huge-page), vice-verse when kernel workload is increase.
Also help for virtualization to dynamic configure host/guest's memory,
to save/(reduce waste) memory.
Memory capacity on Demand
o When a new node is physically online after boot, we need to use
"online_movable" or "online_kernel" to configure/portion it as we
expected when we logic-online it.
This configuration also helps for physically-memory-migrate.
o all benefit as the same as existed "movablecore" & "kernelcore".
o Preparing for movable-node, which is very important for power-saving,
hardware partitioning and high-available-system(hardware fault
management).
(Note, we don't introduce movable-node here.)
Action behavior:
When a memoryblock/memorysection is onlined by "online_movable", the kernel
will not have directly reference to the page of the memoryblock,
thus we can remove that memory any time when needed.
When it is online by "online_kernel", the kernel can use it.
When it is online by "online", the zone type doesn't changed.
Current constraints:
Only the memoryblock which is adjacent to the ZONE_MOVABLE
can be online from ZONE_NORMAL to ZONE_MOVABLE.
[akpm@linux-foundation.org: use min_t, cleanups]
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Greg KH <greg@kroah.com>
remove_memory() will be called when hot removing a memory device. But
even if offlining memory, we cannot notice it. So the patch updates the
memory block's state and sends notification to userspace.
Additionally, the memory device may contain more than one memory block.
If the memory block has been offlined, __offline_pages() will fail. So we
should try to offline one memory block at a time.
Thus remove_memory() also check each memory block's state. So there is no
need to check the memory block's state before calling remove_memory().
Cc: Len Brown <len.brown@intel.com>
remove_memory() is called in two cases:
1. echo offline >/sys/devices/system/memory/memoryXX/state
2. hot remove a memory device
In the 1st case, the memory block's state is changed and the notification
that memory block's state changed is sent to userland after calling
remove_memory(). So user can notice memory block is changed.
But in the 2nd case, the memory block's state is not changed and the
notification is not also sent to userspcae even if calling
remove_memory(). So user cannot notice memory block is changed.
For adding the notification at memory hot remove, the patch just prepare
as follows:
1st case uses offline_pages() for offlining memory.
2nd case uses remove_memory() for offlining memory and changing memory block's
state and notifing the information.
The patch does not implement notification to remove_memory().
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
This patch contains online_page_callback and apropriate functions for
registering/unregistering online page callbacks. It allows to do some
machine specific tasks during online page stage which is required to
implement memory hotplug in virtual machines. Currently this patch is
required by latest memory hotplug support for Xen balloon driver patch
which will be posted soon.
Additionally, originial online_page() function was splited into
following functions doing "atomic" operations:
- __online_page_set_limits() - set new limits for memory management code,
- __online_page_increment_counters() - increment totalram_pages and totalhigh_pages,
- __online_page_free() - free page to allocator.
It was done to:
- not duplicate existing code,
- ease hotplug code devolpment by usage of well defined interface,
- avoid stupid bugs which are unavoidable when the same code
(by design) is developed in many places.
[akpm@linux-foundation.org: use explicit indirect-call syntax]
Signed-off-by: Daniel Kiper <dkiper@net-space.pl>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
PG_buddy can be converted to _mapcount == -2. So the PG_compound_lock can
be added to page->flags without overflowing (because of the sparse section
bits increasing) with CONFIG_X86_PAE=y and CONFIG_X86_PAT=y. This also
has to move the memory hotplug code from _mapcount to lru.next to avoid
any risk of clashes. We can't use lru.next for PG_buddy removal, but
memory hotplug can use lru.next even more easily than the mapcount
instead.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Now, memory_hotplug_(un)lock() is used for add/remove/offline pages
for avoiding races with hibernation. But this should be held in
online_pages(), too. It seems asymmetric.
There are cases where one has to avoid a race with memory hotplug
notifier and his own local code, and hotplug v.s. hotplug.
This will add a generic solution for avoiding races. In other view,
having lock here has no big impacts. online pages is tend to be
done by udev script at el against each memory section one by one.
Then, it's better to have lock here, too.
Cc: <stable@kernel.org> # 2.6.37
Reviewed-by: Christoph Lameter <cl@linux.com>
Acked-by: David Rientjes <rientjes@google.com>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Presently hwpoison is using lock_system_sleep() to prevent a race with
memory hotplug. However lock_system_sleep() is a no-op if
CONFIG_HIBERNATION=n. Therefore we need a new lock.
Suggested-by: Hugh Dickins <hughd@google.com>
Now, sysfs interface of memory hotplug shows whether the section is
removable or not. But it checks only migrateype of pages and doesn't
check details of cluster of pages.
Next, memory hotplug's set_migratetype_isolate() has the same kind of
check, too.
This patch adds the function __count_unmovable_pages() and makes above 2
checks to use the same logic. Then, is_removable and hotremove code uses
the same logic. No changes in the hotremove logic itself.
TODO: need to find a way to check RECLAMABLE. But, considering bit,
calling shrink_slab() against a range before starting memory hotremove
sounds better. If so, this patch's logic doesn't need to be changed.
Reported-by: Michal Hocko <mhocko@suse.cz>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Enable users to online CPUs even if the CPUs belongs to a numa node which
doesn't have onlined local memory.
The zonlists(pg_data_t.node_zonelists[]) of a numa node are created either
in system boot/init period, or at the time of local memory online. For a
numa node without onlined local memory, its zonelists are not initialized
at present. As a result, any memory allocation operations executed by
CPUs within this node will fail. In fact, an out-of-memory error is
triggered when attempt to online CPUs before memory comes to online.
This patch tries to create zonelists for such numa nodes, so that the
memory allocation for this node can be fallback'ed to other nodes.
[akpm@linux-foundation.org: remove unneeded export]
Signed-off-by: minskey guo<chaohong.guo@intel.com>
Cc: Tejun Heo <tj@kernel.org>
It has no references outside memory_hotplug.c.
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Originally, walk_memory_resource() was introduced to traverse all memory
of "System RAM" for detecting memory hotplug/unplug range. For doing so,
flags of IORESOUCE_MEM|IORESOURCE_BUSY was used and this was enough for
memory hotplug.
But for using other purpose, /proc/kcore, this may includes some firmware
area marked as IORESOURCE_BUSY | IORESOUCE_MEM. This patch makes the
check strict to find out busy "System RAM".
Note: PPC64 keeps their own walk_memory_resouce(), which walk through
ppc64's lmb informaton. Because old kclist_add() is called per lmb, this
patch makes no difference in behavior, finally.
And this patch removes CONFIG_MEMORY_HOTPLUG check from this function.
Because pfn_valid() just show "there is memmap or not* and cannot be used
for "there is physical memory or not", this function is useful in generic
to scan physical memory range.
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Américo Wang <xiyou.wangcong@gmail.com>
Cc: Roland Dreier <rolandd@cisco.com>
Show node to memory section relationship with symlinks in sysfs
Add /sys/devices/system/node/nodeX/memoryY symlinks for all
the memory sections located on nodeX. For example:
/sys/devices/system/node/node1/memory135 -> ../../memory/memory135
indicates that memory section 135 resides on node1.
Also revises documentation to cover this change as well as updating
Documentation/ABI/testing/sysfs-devices-memory to include descriptions
of memory hotremove files 'phys_device', 'phys_index', and 'state'
that were previously not described there.
In addition to it always being a good policy to provide users with
the maximum possible amount of physical location information for
resources that can be hot-added and/or hot-removed, the following
are some (but likely not all) of the user benefits provided by
this change.
Immediate:
- Provides information needed to determine the specific node
on which a defective DIMM is located. This will reduce system
downtime when the node or defective DIMM is swapped out.
- Prevents unintended onlining of a memory section that was
previously offlined due to a defective DIMM. This could happen
during node hot-add when the user or node hot-add assist script
onlines _all_ offlined sections due to user or script inability
to identify the specific memory sections located on the hot-added
node. The consequences of reintroducing the defective memory
could be ugly.
- Provides information needed to vary the amount and distribution
of memory on specific nodes for testing or debugging purposes.
Future:
- Will provide information needed to identify the memory
sections that need to be offlined prior to physical removal
of a specific node.
Symlink creation during boot was tested on 2-node x86_64, 2-node
ppc64, and 2-node ia64 systems. Symlink creation during physical
memory hot-add tested on a 2-node x86_64 system.
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
Memory may be hot-removed on a per-memory-block basis, particularly on
POWER where the SPARSEMEM section size often matches the memory-block
size. A user-level agent must be able to identify which sections of
memory are likely to be removable before attempting the potentially
expensive operation. This patch adds a file called "removable" to the
memory directory in sysfs to help such an agent. In this patch, a memory
block is considered removable if;
o It contains only MOVABLE pageblocks
o It contains only pageblocks with free pages regardless of pageblock type
On the other hand, a memory block starting with a PageReserved() page will
never be considered removable. Without this patch, the user-agent is
forced to choose a memory block to remove randomly.
Sample output of the sysfs files:
./memory/memory0/removable: 0
./memory/memory1/removable: 0
./memory/memory2/removable: 0
./memory/memory3/removable: 0
./memory/memory4/removable: 0
./memory/memory5/removable: 0
./memory/memory6/removable: 0
./memory/memory7/removable: 1
./memory/memory8/removable: 0
./memory/memory9/removable: 0
./memory/memory10/removable: 0
./memory/memory11/removable: 0
./memory/memory12/removable: 0
./memory/memory13/removable: 0
./memory/memory14/removable: 0
./memory/memory15/removable: 0
./memory/memory16/removable: 0
./memory/memory17/removable: 1
./memory/memory18/removable: 1
./memory/memory19/removable: 1
./memory/memory20/removable: 1
./memory/memory21/removable: 1
./memory/memory22/removable: 1
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
- Change some naming
* Magic -> types
* MIX_INFO -> MIX_SECTION_INFO
* Change definition of bootmem type from direct hex value
- __free_pages_bootmem() becomes __meminit.
Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Johannes Weiner <hannes@saeurebad.de>
The ehea driver was recently changed[1] to use walk_memory_resource() to
detect the system's memory layout. However, walk_memory_resource() is
available only when memory hotplug is enabled. So CONFIG_EHEA was
made to depend on MEMORY_HOTPLUG [2], but it is inappropriate for a
network driver to have such a dependency.
Make the declaration of walk_memory_resource() and its powerpc
implementation (ehea is powerpc-specific) unconditionally available.
[1] 48cfb14f8b89d4d5b3df6c16f08b258686fb12ad
"ehea: Add DLPAR memory remove support"
[2] fb7b6ca2b6b7c23b52be143bdd5f55a23b9780c8
"ehea: Add dependency to Kconfig"
Signed-off-by: Nathan Lynch <ntl@pobox.com>
Acked-by: Badari Pulavarty <pbadari@us.ibm.com>
This patch set is to free pages which is allocated by bootmem for
memory-hotremove. Some structures of memory management are allocated by
bootmem. ex) memmap, etc.
To remove memory physically, some of them must be freed according to
circumstance. This patch set makes basis to free those pages, and free
memmaps.
Basic my idea is using remain members of struct page to remember information
of users of bootmem (section number or node id). When the section is
removing, kernel can confirm it. By this information, some issues can be
solved.
1) When the memmap of removing section is allocated on other
section by bootmem, it should/can be free.
2) When the memmap of removing section is allocated on the
same section, it shouldn't be freed. Because the section has to be
logical memory offlined already and all pages must be isolated against
page allocater. If it is freed, page allocator may use it which will
be removed physically soon.
3) When removing section has other section's memmap,
kernel will be able to show easily which section should be removed
before it for user. (Not implemented yet)
4) When the above case 2), the page isolation will be able to check and skip
memmap's page when logical memory offline (offline_pages()).
Current page isolation code fails in this case because this page is
just reserved page and it can't distinguish this pages can be
removed or not. But, it will be able to do by this patch.
(Not implemented yet.)
5) The node information like pgdat has similar issues. But, this
will be able to be solved too by this.
(Not implemented yet, but, remembering node id in the pages.)
Fortunately, current bootmem allocator just keeps PageReserved flags,
and doesn't use any other members of page struct. The users of
bootmem doesn't use them too.
This patch:
This is to register information which is node or section's id. Kernel can
distinguish which node/section uses the pages allcated by bootmem. This is
basis for hot-remove sections or nodes.
Generic helper function to remove section mappings and sysfs entries for the
section of the memory we are removing. offline_pages() correctly adjusted
zone and marked the pages reserved.
TODO: Yasunori Goto is working on patches to free up allocations from bootmem.
Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Now, arch dependent code around CONFIG_MEMORY_HOTREMOVE is a mess.
This patch cleans up them. This is against 2.6.23-rc6-mm1.
- fix compile failure on ia64/ CONFIG_MEMORY_HOTPLUG && !CONFIG_MEMORY_HOTREMOVE case.
- For !CONFIG_MEMORY_HOTREMOVE, add generic no-op remove_memory(),
which returns -EINVAL.
- removed remove_pages() only used in powerpc.
- removed no-op remove_memory() in i386, sh, sparc64, x86_64.
- only powerpc returns -ENOSYS at memory hot remove(no-op). changes it
to return -EINVAL.
Note:
Currently, only ia64 supports CONFIG_MEMORY_HOTREMOVE. I welcome other
archs if there are requirements and testers.
Logic.
- set all pages in [start,end) as isolated migration-type.
by this, all free pages in the range will be not-for-use.
- Migrate all LRU pages in the range.
- Test all pages in the range's refcnt is zero or not.
Todo:
- allocate migration destination page from better area.
- confirm page_count(page)== 0 && PageReserved(page) page is safe to be freed..
(I don't like this kind of page but..
- Find out pages which cannot be migrated.
- more running tests.
- Use reclaim for unplugging other memory type area.
A clean up patch for "scanning memory resource [start, end)" operation.
Now, find_next_system_ram() function is used in memory hotplug, but this
interface is not easy to use and codes are complicated.
This patch adds walk_memory_resouce(start,len,arg,func) function.
The function 'func' is called per valid memory resouce range in [start,pfn).
[pbadari@us.ibm.com: Error handling in walk_memory_resource()]
This patch cleans up duplicate includes in
include/linux/memory_hotplug.h
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Fix up externs in memory_hotplug.c. Cleanup.
Signed-off-by: Keith Mannthey <kmannth@us.ibm.com>
Cc: Andi Kleen <ak@muc.de>
pgdat and per node data
This is a patch to allocate pgdat and per node data area for ia64. The size
for them can be calculated by compute_pernodesize().
address array
This is to refresh node_data[] array for ia64. As I mentioned previous
patches, ia64 has copies of information of pgdat address array on each node as
per node data.
At v2 of node_add, this function used stop_machine_run() to update them. (I
wished that they were copied safety as much as possible.) But, in this patch,
this arrays are just copied simply, and set node_online_map bit after
completion of pgdat initialization.
So, kernel must touch NODE_DATA() macro after checking node_online_map().
(Current code has already done it.) This is more simple way for just
hot-add.....
Note : It will be problem when hot-remove will occur,
because, even if online_map bit is set, kernel may
touch NODE_DATA() due to race condition. :-(
Refresh NODE_DATA() for generic archs. In this case, NODE_DATA(nid) ==
node_data[nid]. node_data[] is array of address of pgdat. So, refresh is
quite simple.
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: "Brown, Len" <len.brown@intel.com>
For node hotplug, basically we have to allocate new pgdat. But, there are
several types of implementations of pgdat.
1. Allocate only pgdat.
This style allocate only pgdat area.
And its address is recorded in node_data[].
It is most popular style.
2. Static array of pgdat
In this case, all of pgdats are static array.
Some archs use this style.
3. Allocate not only pgdat, but also per node data.
To increase performance, each node has copy of some data as
a per node data. So, this area must be allocated too.
Ia64 is this style. Ia64 has the copies of node_data[] array
on each per node data to increase performance.
In this series of patches, treat (1) as generic arch.
generic archs can use generic function. (2) and (3) should have
its own if necessary.
This patch defines pgdat allocator.
Updating NODE_DATA() macro function is in other patch.
Signed-off-by: Yasonori Goto <y-goto@jp.fujitsu.com>
Change the name of old add_memory() to arch_add_memory. And use node id to
get pgdat for the node at NODE_DATA().
Note: Powerpc's old add_memory() is defined as __devinit. However,
add_memory() is usually called only after bootup.
I suppose it may be redundant. But, I'm not well known about powerpc.
So, I keep it. (But, __meminit is better at least.)
We don't have to #if guard prototypes.
This also fixes a bug observed by Randy Dunlap due to a misspelled
option in the #if.
