path: root/include/linux/mfd
2008-04-19[ARM] 4964/1: htc-pasic3: MFD driver for PASIC3 LED control + DS1WM chipPhilipp Zabel
This driver will provide registers, clocks and GPIOs of the HTC PASIC3 (AIC3) and PASIC2 (AIC2) chips to the ds1wm and leds-pasic3 drivers. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] 4947/1: htc-egpio, a driver for GPIO/IRQ expanders with fixed ↵Philipp Zabel
input/output pins implemented in CPLD chips on several HTC devices. The original driver was written by Kevin O'Connor, I have adapted it to use gpiolib and made the bus/register widths configurable. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-07ASIC3 driverSamuel Ortiz
This is a patch for the Compaq ASIC3 multi function chip, found in many PDAs (iPAQs, HTCs...). It is a simplified version of Paul Sokolovsky's first proposal [1]. With this code, it is basically a GPIO and IRQ expander. My plan is to add more features once this patch gets reviewed and accepted. [1] http://lkml.org/lkml/2007/5/1/46 Signed-off-by: Samuel Ortiz <sameo@openedhand.com> Cc: Paul Sokolovsky <pmiscml@gmail.com> Cc: Ben Dooks <ben@trinity.fluff.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
