path: root/include/linux/mm.h
2011-11-30ashmem for 2.6.27.Robert Love
Forward port of ashmem to 2.6.27. Signed-off-by: Robert Love <rlove@google.com> ashmem: Don't install fault handler for private mmaps. Ashmem is used to create named private heaps. If this heap is backed by a tmpfs file it will allocate two pages for every page touched. In 2.6.27, the extra page would later be freed, but 2.6.29 does not scan anonymous pages when running without swap so the memory is not freed while the file is referenced. This change changes the behavior of private ashmem mmaps to match /dev/zero instead tmpfs. Signed-off-by: Arve Hjønnevåg <arve@android.com> ashmem: Add common prefix to name reported in /proc/pid/maps Signed-off-by: Arve Hjønnevåg <arve@android.com> ashmem: don't require a page aligned size This makes ashmem more similar to shmem and mmap, by not requiring the specified size to be page aligned, instead rounding it internally as needed. Signed-off-by: Marco Nelissen <marcone@android.com>
2011-11-11thp: share get_huge_page_tail()Andrea Arcangeli
commit b35a35b556f5e6b7993ad0baf20173e75c09ce8c upstream. This avoids duplicating the function in every arch gup_fast. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11mm: thp: tail page refcounting fixAndrea Arcangeli
commit 70b50f94f1644e2aa7cb374819cfd93f3c28d725 upstream. Michel while working on the working set estimation code, noticed that calling get_page_unless_zero() on a random pfn_to_page(random_pfn) wasn't safe, if the pfn ended up being a tail page of a transparent hugepage under splitting by __split_huge_page_refcount(). He then found the problem could also theoretically materialize with page_cache_get_speculative() during the speculative radix tree lookups that uses get_page_unless_zero() in SMP if the radix tree page is freed and reallocated and get_user_pages is called on it before page_cache_get_speculative has a chance to call get_page_unless_zero(). So the best way to fix the problem is to keep page_tail->_count zero at all times. This will guarantee that get_page_unless_zero() can never succeed on any tail page. page_tail->_mapcount is guaranteed zero and is unused for all tail pages of a compound page, so we can simply account the tail page references there and transfer them to tail_page->_count in __split_huge_page_refcount() (in addition to the head_page->_mapcount). While debugging this s/_count/_mapcount/ change I also noticed get_page is called by direct-io.c on pages returned by get_user_pages. That wasn't entirely safe because the two atomic_inc in get_page weren't atomic. As opposed to other get_user_page users like secondary-MMU page fault to establish the shadow pagetables would never call any superflous get_page after get_user_page returns. It's safer to make get_page universally safe for tail pages and to use get_page_foll() within follow_page (inside get_user_pages()). get_page_foll() is safe to do the refcounting for tail pages without taking any locks because it is run within PT lock protected critical sections (PT lock for pte and page_table_lock for pmd_trans_huge). The standard get_page() as invoked by direct-io instead will now take the compound_lock but still only for tail pages. The direct-io paths are usually I/O bound and the compound_lock is per THP so very finegrined, so there's no risk of scalability issues with it. A simple direct-io benchmarks with all lockdep prove locking and spinlock debugging infrastructure enabled shows identical performance and no overhead. So it's worth it. Ideally direct-io should stop calling get_page() on pages returned by get_user_pages(). The spinlock in get_page() is already optimized away for no-THP builds but doing get_page() on tail pages returned by GUP is generally a rare operation and usually only run in I/O paths. This new refcounting on page_tail->_mapcount in addition to avoiding new RCU critical sections will also allow the working set estimation code to work without any further complexity associated to the tail page refcounting with THP. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Michel Lespinasse <walken@google.com> Reviewed-by: Michel Lespinasse <walken@google.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-17mm: fix __page_to_pfn for a const struct page argumentIan Campbell
This allows the cast in lowmem_page_address (introduced as a warning fixup to 33dd4e0ec911 "mm: make some struct page's const") to be removed. Propagate const'ness to page_to_section() as well since it is required by __page_to_pfn. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Michel Lespinasse <walken@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-17mm: make HASHED_PAGE_VIRTUAL page_address' struct page argument const.Ian Campbell
Followup to 33dd4e0ec911 "mm: make some struct page's const" which missed the HASHED_PAGE_VIRTUAL case. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Michel Lespinasse <walken@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-08mm: Fix fixup_user_fault() for MMU=nPeter Zijlstra
In commit 2efaca927f5c ("mm/futex: fix futex writes on archs with SW tracking of dirty & young") we forgot about MMU=n. This patch fixes that. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: David Howells <dhowells@redhat.com> Link: http://lkml.kernel.org/r/1311761831.24752.413.camel@twins Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03Merge branch 'apei' into apei-releaseLen Brown
Some trivial conflicts due to other various merges adding to the end of common lists sooner than this one. arch/ia64/Kconfig arch/powerpc/Kconfig arch/x86/Kconfig lib/Kconfig lib/Makefile Signed-off-by: Len Brown <len.brown@intel.com>
2011-08-03HWPoison: add memory_failure_queue()Huang Ying
memory_failure() is the entry point for HWPoison memory error recovery. It must be called in process context. But commonly hardware memory errors are notified via MCE or NMI, so some delayed execution mechanism must be used. In MCE handler, a work queue + ring buffer mechanism is used. In addition to MCE, now APEI (ACPI Platform Error Interface) GHES (Generic Hardware Error Source) can be used to report memory errors too. To add support to APEI GHES memory recovery, a mechanism similar to that of MCE is implemented. memory_failure_queue() is the new entry point that can be called in IRQ context. The next step is to make MCE handler uses this interface too. Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-07-25mm/futex: fix futex writes on archs with SW tracking of dirty & youngBenjamin Herrenschmidt
I haven't reproduced it myself but the fail scenario is that on such machines (notably ARM and some embedded powerpc), if you manage to hit that futex path on a writable page whose dirty bit has gone from the PTE, you'll livelock inside the kernel from what I can tell. It will go in a loop of trying the atomic access, failing, trying gup to "fix it up", getting succcess from gup, go back to the atomic access, failing again because dirty wasn't fixed etc... So I think you essentially hang in the kernel. The scenario is probably rare'ish because affected architecture are embedded and tend to not swap much (if at all) so we probably rarely hit the case where dirty is missing or young is missing, but I think Shan has a piece of SW that can reliably reproduce it using a shared writable mapping & fork or something like that. On archs who use SW tracking of dirty & young, a page without dirty is effectively mapped read-only and a page without young unaccessible in the PTE. Additionally, some architectures might lazily flush the TLB when relaxing write protection (by doing only a local flush), and expect a fault to invalidate the stale entry if it's still present on another processor. The futex code assumes that if the "in_atomic()" access -EFAULT's, it can "fix it up" by causing get_user_pages() which would then be equivalent to taking the fault. However that isn't the case. get_user_pages() will not call handle_mm_fault() in the case where the PTE seems to have the right permissions, regardless of the dirty and young state. It will eventually update those bits ... in the struct page, but not in the PTE. Additionally, it will not handle the lazy TLB flushing that can be required by some architectures in the fault case. Basically, gup is the wrong interface for the job. The patch provides a more appropriate one which boils down to just calling handle_mm_fault() since what we are trying to do is simulate a real page fault. The futex code currently attempts to write to user memory within a pagefault disabled section, and if that fails, tries to fix it up using get_user_pages(). This doesn't work on archs where the dirty and young bits are maintained by software, since they will gate access permission in the TLB, and will not be updated by gup(). In addition, there's an expectation on some archs that a spurious write fault triggers a local TLB flush, and that is missing from the picture as well. I decided that adding those "features" to gup() would be too much for this already too complex function, and instead added a new simpler fixup_user_fault() which is essentially a wrapper around handle_mm_fault() which the futex code can call. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix some nits Darren saw, fiddle comment layout] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Shan Hai <haishan.bai@gmail.com> Tested-by: Shan Hai <haishan.bai@gmail.com> Cc: David Laight <David.Laight@ACULAB.COM> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Darren Hart <darren.hart@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: truncate functions are in truncate.cHugh Dickins
Correct comment on truncate_inode_pages*() in linux/mm.h; and remove declaration of page_unuse(), it didn't exist even in 2.2.26 or 2.4.0! Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25pagewalk: add locking-rule commentsKOSAKI Motohiro
Originally, walk_hugetlb_range() didn't require a caller take any lock. But commit d33b9f45bd ("mm: hugetlb: fix hugepage memory leak in walk_page_range") changed its rule. Because it added find_vma() call in walk_hugetlb_range(). Any locking-rule change commit should write a doc too. [akpm@linux-foundation.org: clarify comment] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Hiroyuki Kamezawa <kamezawa.hiroyuki@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25mm: make some struct page's constIan Campbell
These uses are read-only and in a subsequent patch I have a const struct page in my hand... [akpm@linux-foundation.org: fix warnings in lowmem_page_address()] Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits) vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp isofs: Remove global fs lock jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory fix IN_DELETE_SELF on overwriting rename() on ramfs et.al. mm/truncate.c: fix build for CONFIG_BLOCK not enabled fs:update the NOTE of the file_operations structure Remove dead code in dget_parent() AFS: Fix silly characters in a comment switch d_add_ci() to d_splice_alias() in "found negative" case as well simplify gfs2_lookup() jfs_lookup(): don't bother with . or .. get rid of useless dget_parent() in btrfs rename() and link() get rid of useless dget_parent() in fs/btrfs/ioctl.c fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers drivers: fix up various ->llseek() implementations fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek Ext4: handle SEEK_HOLE/SEEK_DATA generically Btrfs: implement our own ->llseek fs: add SEEK_HOLE and SEEK_DATA flags reiserfs: make reiserfs default to barrier=flush ... Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new shrinker callout for the inode cache, that clashed with the xfs code to start the periodic workers later.
2011-07-20superblock: introduce per-sb cache shrinker infrastructureDave Chinner
With context based shrinkers, we can implement a per-superblock shrinker that shrinks the caches attached to the superblock. We currently have global shrinkers for the inode and dentry caches that split up into per-superblock operations via a coarse proportioning method that does not batch very well. The global shrinkers also have a dependency - dentries pin inodes - so we have to be very careful about how we register the global shrinkers so that the implicit call order is always correct. With a per-sb shrinker callout, we can encode this dependency directly into the per-sb shrinker, hence avoiding the need for strictly ordering shrinker registrations. We also have no need for any proportioning code for the shrinker subsystem already provides this functionality across all shrinkers. Allowing the shrinker to operate on a single superblock at a time means that we do less superblock list traversals and locking and reclaim should batch more effectively. This should result in less CPU overhead for reclaim and potentially faster reclaim of items from each filesystem. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20vmscan: add customisable shrinker batch sizeDave Chinner
For shrinkers that have their own cond_resched* calls, having shrink_slab break the work down into small batches is not paticularly efficient. Add a custom batchsize field to the struct shrinker so that shrinkers can use a larger batch size if they desire. A value of zero (uninitialised) means "use the default", so behaviour is unchanged by this patch. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-12x86, numa: Implement pfn -> nid mapping granularity checkTejun Heo
SPARSEMEM w/o VMEMMAP and DISCONTIGMEM, both used only on 32bit, use sections array to map pfn to nid which is limited in granularity. If NUMA nodes are laid out such that the mapping cannot be accurate, boot will fail triggering BUG_ON() in mminit_verify_page_links(). On 32bit, it's 512MiB w/ PAE and SPARSEMEM. This seems to have been granular enough until commit 2706a0bf7b (x86, NUMA: Enable CONFIG_AMD_NUMA on 32bit too). Apparently, there is a machine which aligns NUMA nodes to 128MiB and has only AMD NUMA but not SRAT. This led to the following BUG_ON(). On node 0 totalpages: 2096615 DMA zone: 32 pages used for memmap DMA zone: 0 pages reserved DMA zone: 3927 pages, LIFO batch:0 Normal zone: 1740 pages used for memmap Normal zone: 220978 pages, LIFO batch:31 HighMem zone: 16405 pages used for memmap HighMem zone: 1853533 pages, LIFO batch:31 BUG: Int 6: CR2 (null) EDI (null) ESI 00000002 EBP 00000002 ESP c1543ecc EBX f2400000 EDX 00000006 ECX (null) EAX 00000001 err (null) EIP c16209aa CS 00000060 flg 00010002 Stack: f2400000 00220000 f7200800 c1620613 00220000 01000000 04400000 00238000 (null) f7200000 00000002 f7200b58 f7200800 c1620929 000375fe (null) f7200b80 c16395f0 00200a02 f7200a80 (null) 000375fe 00000002 (null) Pid: 0, comm: swapper Not tainted 2.6.39-rc5-00181-g2706a0b #17 Call Trace: [<c136b1e5>] ? early_fault+0x2e/0x2e [<c16209aa>] ? mminit_verify_page_links+0x12/0x42 [<c1620613>] ? memmap_init_zone+0xaf/0x10c [<c1620929>] ? free_area_init_node+0x2b9/0x2e3 [<c1607e99>] ? free_area_init_nodes+0x3f2/0x451 [<c1601d80>] ? paging_init+0x112/0x118 [<c15f578d>] ? setup_arch+0x791/0x82f [<c15f43d9>] ? start_kernel+0x6a/0x257 This patch implements node_map_pfn_alignment() which determines maximum internode alignment and update numa_register_memblks() to reject NUMA configuration if alignment exceeds the pfn -> nid mapping granularity of the memory model as determined by PAGES_PER_SECTION. This makes the problematic machine boot w/ flatmem by rejecting the NUMA config and provides protection against crazy NUMA configurations. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/20110712074534.GB2872@htj.dyndns.org LKML-Reference: <20110628174613.GP478@escobedo.osrc.amd.com> Reported-and-Tested-by: Hans Rosenfeld <hans.rosenfeld@amd.com> Cc: Conny Seidel <conny.seidel@amd.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-05-26mm: extract exe_file handling from procfsJiri Slaby
Setup and cleanup of mm_struct->exe_file is currently done in fs/proc/. This was because exe_file was needed only for /proc/<pid>/exe. Since we will need the exe_file functionality also for core dumps (so core name can contain full binary path), built this functionality always into the kernel. To achieve that move that out of proc FS to the kernel/ where in fact it should belong. By doing that we can make dup_mm_exe_file static. Also we can drop linux/proc_fs.h inclusion in fs/exec.c and kernel/fork.c. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26mm: don't access vm_flags as 'int'KOSAKI Motohiro
The type of vma->vm_flags is 'unsigned long'. Neither 'int' nor 'unsigned int'. This patch fixes such misuse. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> [ Changed to use a typedef - we'll extend it to cover more cases later, since there has been discussion about making it a 64-bit type.. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: remove last trace of shmem_get_unmapped_areaHugh Dickins
Remove noMMU declaration of shmem_get_unmapped_area() from mm.h: it fell out of use in 2.6.21 and ceased to exist in 2.6.29. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: delete non-atomic mm counter implementationMatt Fleming
The problem with having two different types of counters is that developers adding new code need to keep in mind whether it's safe to use both the atomic and non-atomic implementations. For example, when adding new callers of the *_mm_counter() functions a developer needs to ensure that those paths are always executed with page_table_lock held, in case we're using the non-atomic implementation of mm counters. Hugh Dickins introduced the atomic mm counters in commit f412ac08c986 ("[PATCH] mm: fix rss and mmlist locking"). When asked why he left the non-atomic counters around he said, | The only reason was to avoid adding costly atomic operations into a | configuration that had no need for them there: the page_table_lock | sufficed. | | Certainly it would be simpler just to delete the non-atomic variant. | | And I think it's fair to say that any configuration on which we're | measuring performance to that degree (rather than "does it boot fast?" | type measurements), would already be going the split ptlocks route. Removing the non-atomic counters eases the maintenance burden because developers no longer have to mindful of the two implementations when using *_mm_counter(). Note that all architectures provide a means of atomically updating atomic_long_t variables, even if they have to revert to the generic spinlock implementation because they don't support 64-bit atomic instructions (see lib/atomic64.c). Signed-off-by: Matt Fleming <matt.fleming@linux.intel.com> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: do not define PFN_SECTION_SHIFT if !CONFIG_SPARSEMEMDaniel Kiper
Do not define PFN_SECTION_SHIFT if !CONFIG_SPARSEMEM. Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: enable set_page_section() only if CONFIG_SPARSEMEM and ↵Daniel Kiper
!CONFIG_SPARSEMEM_VMEMMAP set_page_section() is meaningful only in CONFIG_SPARSEMEM and !CONFIG_SPARSEMEM_VMEMMAP context. Move it to proper place and amend accordingly functions which are using it. Signed-off-by: Daniel Kiper <dkiper@net-space.pl> Acked-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25vmscan: change shrinker API by passing shrink_control structYing Han
Change each shrinker's API by consolidating the existing parameters into shrink_control struct. This will simplify any further features added w/o touching each file of shrinker. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: fix warning] [kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API] [akpm@linux-foundation.org: fix xfs warning] [akpm@linux-foundation.org: update gfs2] Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25vmscan: change shrink_slab() interfaces by passing shrink_controlYing Han
Consolidate the existing parameters to shrink_slab() into a new shrink_control struct. This is needed later to pass the same struct to shrinkers. Signed-off-by: Ying Han <yinghan@google.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: break out page allocation warning codeDave Hansen
This originally started as a simple patch to give vmalloc() some more verbose output on failure on top of the plain page allocator messages. Johannes suggested that it might be nicer to lead with the vmalloc() info _before_ the page allocator messages. But, I do think there's a lot of value in what __alloc_pages_slowpath() does with its filtering and so forth. This patch creates a new function which other allocators can call instead of relying on the internal page allocator warnings. It also gives this function private rate-limiting which separates it from other printk_ratelimit() users. Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: David Rientjes <rientjes@google.com> Cc: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: Remove i_mmap_lock lockbreakPeter Zijlstra
Hugh says: "The only significant loser, I think, would be page reclaim (when concurrent with truncation): could spin for a long time waiting for the i_mmap_mutex it expects would soon be dropped? " Counter points: - cpu contention makes the spin stop (need_resched()) - zap pages should be freeing pages at a higher rate than reclaim ever can I think the simplification of the truncate code is definitely worth it. Effectively reverts: 2aa15890f3c ("mm: prevent concurrent unmap_mapping_range() on the same inode") and takes out the code that caused its problem. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: mmu_gather reworkPeter Zijlstra
Rework the existing mmu_gather infrastructure. The direct purpose of these patches was to allow preemptible mmu_gather, but even without that I think these patches provide an improvement to the status quo. The first 9 patches rework the mmu_gather infrastructure. For review purpose I've split them into generic and per-arch patches with the last of those a generic cleanup. The next patch provides generic RCU page-table freeing, and the followup is a patch converting s390 to use this. I've also got 4 patches from DaveM lined up (not included in this series) that uses this to implement gup_fast() for sparc64. Then there is one patch that extends the generic mmu_gather batching. After that follow the mm preemptibility patches, these make part of the mm a lot more preemptible. It converts i_mmap_lock and anon_vma->lock to mutexes which together with the mmu_gather rework makes mmu_gather preemptible as well. Making i_mmap_lock a mutex also enables a clean-up of the truncate code. This also allows for preemptible mmu_notifiers, something that XPMEM I think wants. Furthermore, it removes the new and universially detested unmap_mutex. This patch: Remove the first obstacle towards a fully preemptible mmu_gather. The current scheme assumes mmu_gather is always done with preemption disabled and uses per-cpu storage for the page batches. Change this to try and allocate a page for batching and in case of failure, use a small on-stack array to make some progress. Preemptible mmu_gather is desired in general and usable once i_mmap_lock becomes a mutex. Doing it before the mutex conversion saves us from having to rework the code by moving the mmu_gather bits inside the pte_lock. Also avoid flushing the tlb batches from under the pte lock, this is useful even without the i_mmap_lock conversion as it significantly reduces pte lock hold times. [akpm@linux-foundation.org: fix comment tpyo] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: make expand_downwards() symmetrical with expand_upwards()Michal Hocko
Currently we have expand_upwards exported while expand_downwards is accessible only via expand_stack or expand_stack_downwards. check_stack_guard_page is a nice example of the asymmetry. It uses expand_stack for VM_GROWSDOWN while expand_upwards is called for VM_GROWSUP case. Let's clean this up by exporting both functions and make those names consistent. Let's use expand_{upwards,downwards} because expanding doesn't always involve stack manipulation (an example is ia64_do_page_fault which uses expand_upwards for registers backing store expansion). expand_downwards has to be defined for both CONFIG_STACK_GROWS{UP,DOWN} because get_arg_page calls the downwards version in the early process initialization phase for growsup configuration. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Hugh Dickins <hughd@google.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm, mem-hotplug: recalculate lowmem_reserve when memory hotplug occursKOSAKI Motohiro
Currently, memory hotplug calls setup_per_zone_wmarks() and calculate_zone_inactive_ratio(), but doesn't call setup_per_zone_lowmem_reserve(). It means the number of reserved pages aren't updated even if memory hot plug occur. This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25x86,mm: make pagefault killableKOSAKI Motohiro
When an oom killing occurs, almost all processes are getting stuck at the following two points. 1) __alloc_pages_nodemask 2) __lock_page_or_retry 1) is not very problematic because TIF_MEMDIE leads to an allocation failure and getting out from page allocator. 2) is more problematic. In an OOM situation, zones typically don't have page cache at all and memory starvation might lead to greatly reduced IO performance. When a fork bomb occurs, TIF_MEMDIE tasks don't die quickly, meaning that a fork bomb may create new process quickly rather than the oom-killer killing it. Then, the system may become livelocked. This patch makes the pagefault interruptible by SIGKILL. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25arch, mm: filter disallowed nodes from arch specific show_mem functionsDavid Rientjes
Architectures that implement their own show_mem() function did not pass the filter argument to show_free_areas() to appropriately avoid emitting the state of nodes that are disallowed in the current context. This patch now passes the filter argument to show_free_areas() so those nodes are now avoided. This patch also removes the show_free_areas() wrapper around __show_free_areas() and converts existing callers to pass an empty filter. ia64 emits additional information for each node, so skip_free_areas_zone() must be made global to filter disallowed nodes and it is converted to use a nid argument rather than a zone for this use case. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: James Bottomley <jejb@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-09Don't lock guardpage if the stack is growing upMikulas Patocka
Linux kernel excludes guard page when performing mlock on a VMA with down-growing stack. However, some architectures have up-growing stack and locking the guard page should be excluded in this case too. This patch fixes lvm2 on PA-RISC (and possibly other architectures with up-growing stack). lvm2 calculates number of used pages when locking and when unlocking and reports an internal error if the numbers mismatch. [ Patch changed fairly extensively to also fix /proc/<pid>/maps for the grows-up case, and to move things around a bit to clean it all up and share the infrstructure with the /proc bits. Tested on ia64 that has both grow-up and grow-down segments - Linus ] Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Tested-by: Tony Luck <tony.luck@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-28mm: thp: fix /dev/zero MAP_PRIVATE and vm_flags cleanupsAndrea Arcangeli
The huge_memory.c THP page fault was allowed to run if vm_ops was null (which would succeed for /dev/zero MAP_PRIVATE, as the f_op->mmap wouldn't setup a special vma->vm_ops and it would fallback to regular anonymous memory) but other THP logics weren't fully activated for vmas with vm_file not NULL (/dev/zero has a not NULL vma->vm_file). So this removes the vm_file checks so that /dev/zero also can safely use THP (the other albeit safer approach to fix this bug would have been to prevent the THP initial page fault to run if vm_file was set). After removing the vm_file checks, this also makes huge_memory.c stricter in khugepaged for the DEBUG_VM=y case. It doesn't replace the vm_file check with a is_pfn_mapping check (but it keeps checking for VM_PFNMAP under VM_BUG_ON) because for a is_cow_mapping() mapping VM_PFNMAP should only be allowed to exist before the first page fault, and in turn when vma->anon_vma is null (so preventing khugepaged registration). So I tend to think the previous comment saying if vm_file was set, VM_PFNMAP might have been set and we could still be registered in khugepaged (despite anon_vma was not NULL to be registered in khugepaged) was too paranoid. The is_linear_pfn_mapping check is also I think superfluous (as described by comment) but under DEBUG_VM it is safe to stay. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=33682 Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Caspar Zhang <bugs@casparzhang.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Rik van Riel <riel@redhat.com> Cc: <stable@kernel.org> [2.6.38.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24lib, arch: add filter argument to show_mem and fix private implementationsDavid Rientjes
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which resulted in build warnings on all architectures that implement their own versions of show_mem(): lib/lib.a(show_mem.o): In function `show_mem': show_mem.c:(.text+0x1f4): multiple definition of `show_mem' arch/sparc/mm/built-in.o:(.text+0xd70): first defined here The fix is to remove __show_mem() and add its argument to show_mem() in all implementations to prevent this breakage. Architectures that implement their own show_mem() actually don't do anything with the argument yet, but they could be made to filter nodes that aren't allowed in the current context in the future just like the generic implementation. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: deal with races in /proc/*/{syscall,stack,personality} proc: enable writing to /proc/pid/mem proc: make check_mem_permission() return an mm_struct on success proc: hold cred_guard_mutex in check_mem_permission() proc: disable mem_write after exec mm: implement access_remote_vm mm: factor out main logic of access_process_vm mm: use mm_struct to resolve gate vma's in __get_user_pages mm: arch: rename in_gate_area_no_task to in_gate_area_no_mm mm: arch: make in_gate_area take an mm_struct instead of a task_struct mm: arch: make get_gate_vma take an mm_struct instead of a task_struct x86: mark associated mm when running a task in 32 bit compatibility mode x86: add context tag to mark mm when running a task in 32-bit compatibility mode auxv: require the target to be tracable (or yourself) close race in /proc/*/environ report errors in /proc/*/*map* sanely pagemap: close races with suid execve make sessionid permissions in /proc/*/task/* match those in /proc/* fix leaks in path_lookupat() Fix up trivial conflicts in fs/proc/base.c
2011-03-23mm: implement access_remote_vmStephen Wilson
Provide an alternative to access_process_vm that allows the caller to obtain a reference to the supplied mm_struct. Signed-off-by: Stephen Wilson <wilsons@start.ca> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23mm: arch: rename in_gate_area_no_task to in_gate_area_no_mmStephen Wilson
Now that gate vma's are referenced with respect to a particular mm and not a particular task it only makes sense to propagate the change to this predicate as well. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23mm: arch: make in_gate_area take an mm_struct instead of a task_structStephen Wilson
Morally, the question of whether an address lies in a gate vma should be asked with respect to an mm, not a particular task. Moreover, dropping the dependency on task_struct will help make existing and future operations on mm's more flexible and convenient. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-23mm: arch: make get_gate_vma take an mm_struct instead of a task_structStephen Wilson
Morally, the presence of a gate vma is more an attribute of a particular mm than a particular task. Moreover, dropping the dependency on task_struct will help make both existing and future operations on mm's more flexible and convenient. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-22pagewalk: only split huge pages when necessaryDave Hansen
Right now, if a mm_walk has either ->pte_entry or ->pmd_entry set, it will unconditionally split any transparent huge pages it runs in to. In practice, that means that anyone doing a cat /proc/$pid/smaps will unconditionally break down every huge page in the process and depend on khugepaged to re-collapse it later. This is fairly suboptimal. This patch changes that behavior. It teaches each ->pmd_entry handler (there are five) that they must break down the THPs themselves. Also, the _generic_ code will never break down a THP unless a ->pte_entry handler is actually set. This means that the ->pmd_entry handlers can now choose to deal with THPs without breaking them down. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: David Rientjes <rientjes@google.com> Reviewed-by: Eric B Munson <emunson@mgebm.net> Tested-by: Eric B Munson <emunson@mgebm.net> Cc: Michael J Wolf <mjwolf@us.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mm: allow GUP to fail instead of waiting on a pageGleb Natapov
GUP user may want to try to acquire a reference to a page if it is already in memory, but not if IO, to bring it in, is needed. For example KVM may tell vcpu to schedule another guest process if current one is trying to access swapped out page. Meanwhile, the page will be swapped in and the guest process, that depends on it, will be able to run again. This patch adds FAULT_FLAG_RETRY_NOWAIT (suggested by Linus) and FOLL_NOWAIT follow_page flags. FAULT_FLAG_RETRY_NOWAIT, when used in conjunction with VM_FAULT_ALLOW_RETRY, indicates to handle_mm_fault that it shouldn't drop mmap_sem and wait on a page, but return VM_FAULT_RETRY instead. [akpm@linux-foundation.org: improve FOLL_NOWAIT comment] Signed-off-by: Gleb Natapov <gleb@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Michel Lespinasse <walken@google.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22oom: suppress nodes that are not allowed from meminfo on oom killDavid Rientjes
The oom killer is extremely verbose for machines with a large number of cpus and/or nodes. This verbosity can often be harmful if it causes other important messages to be scrolled from the kernel log and incurs a signicant time delay, specifically for kernels with CONFIG_NODES_SHIFT > 8. This patch causes only memory information to be displayed for nodes that are allowed by current's cpuset when dumping the VM state. Information for all other nodes is irrelevant to the oom condition; we don't care if there's an abundance of memory elsewhere if we can't access it. This only affects the behavior of dumping memory information when an oom is triggered. Other dumps, such as for sysrq+m, still display the unfiltered form when using the existing show_mem() interface. Additionally, the per-cpu pageset statistics are extremely verbose in oom killer output, so it is now suppressed. This removes nodes_weight(current->mems_allowed) * (1 + nr_cpus) lines from the oom killer output. Callers may use __show_mem(SHOW_MEM_FILTER_NODES) to filter disallowed nodes. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17Merge branch 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (55 commits) KVM: unbreak userspace that does not sets tss address KVM: MMU: cleanup pte write path KVM: MMU: introduce a common function to get no-dirty-logged slot KVM: fix rcu usage in init_rmode_* functions KVM: fix kvmclock regression due to missing clock update KVM: emulator: Fix permission checking in io permission bitmap KVM: emulator: Fix io permission checking for 64bit guest KVM: SVM: Load %gs earlier if CONFIG_X86_32_LAZY_GS=n KVM: x86: Remove useless regs_page pointer from kvm_lapic KVM: improve comment on rcu use in irqfd_deassign KVM: MMU: remove unused macros KVM: MMU: cleanup page alloc and free KVM: MMU: do not record gfn in kvm_mmu_pte_write KVM: MMU: move mmu pages calculated out of mmu lock KVM: MMU: set spte accessed bit properly KVM: MMU: fix kvm_mmu_slot_remove_write_access dropping intermediate W bits KVM: Start lock documentation KVM: better readability of efer_reserved_bits KVM: Clear async page fault hash after switching to real mode KVM: VMX: Initialize vm86 TSS only once. ...
2011-03-17mm: PageBuddy and mapcount robustnessAndrea Arcangeli
Change the _mapcount value indicating PageBuddy from -2 to -128 for more robusteness against page_mapcount() undeflows. Use reset_page_mapcount instead of __ClearPageBuddy in bad_page to ignore the previous retval of PageBuddy(). Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Reported-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17mm: remove is_hwpoison_addressHuang Ying
Unused. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-03-17mm: make __get_user_pages return -EHWPOISON for HWPOISON page optionallyHuang Ying
Make __get_user_pages return -EHWPOISON for HWPOISON page only if FOLL_HWPOISON is specified. With this patch, the interested callers can distinguish HWPOISON pages from general FAULT pages, while other callers will still get -EFAULT for all these pages, so the user space interface need not to be changed. This feature is needed by KVM, where UCR MCE should be relayed to guest for HWPOISON page, while instruction emulation and MMIO will be tried for general FAULT page. The idea comes from Andrew Morton. Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17mm: export __get_user_pagesHuang Ying
In most cases, get_user_pages and get_user_pages_fast should be used to pin user pages in memory. But sometimes, some special flags except FOLL_GET, FOLL_WRITE and FOLL_FORCE are needed, for example in following patch, KVM needs FOLL_HWPOISON. To support these users, __get_user_pages is exported directly. There are some symbol name conflicts in infiniband driver, fixed them too. Signed-off-by: Huang Ying <ying.huang@intel.com> CC: Andrew Morton <akpm@linux-foundation.org> CC: Michel Lespinasse <walken@google.com> CC: Roland Dreier <roland@kernel.org> CC: Ralph Campbell <infinipath@qlogic.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-02-24bootmem: Move __alloc_memory_core_early() to nobootmem.cYinghai Lu
Now that bootmem.c and nobootmem.c are separate, there's no reason to define __alloc_memory_core_early(), which is used only by nobootmem, inside #ifdef in page_alloc.c. Move it to nobootmem.c and make it static. This patch doesn't introduce any behavior change. -tj: Updated commit description. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2011-01-21mm: System without MMU do not need pte_mkwriteMichal Simek
The patch "thp: export maybe_mkwrite" (commit 14fd403f2146) breaks systems without MMU. Error log: CC arch/microblaze/mm/init.o In file included from include/linux/mman.h:14, from arch/microblaze/mm/consistent.c:24: include/linux/mm.h: In function 'maybe_mkwrite': include/linux/mm.h:482: error: implicit declaration of function 'pte_mkwrite' include/linux/mm.h:482: error: incompatible types in assignment Signed-off-by: Michal Simek <monstr@monstr.eu> CC: Andrea Arcangeli <aarcange@redhat.com> Reviewed-by: Rik van Riel <riel@redhat.com> CC: Andrew Morton <akpm@linux-foundation.org> CC: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
