commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream.
Jay Foad reports that the address sanitizer test (asan) sometimes gets
confused by a stack pointer that ends up being outside the stack vma
that is reported by /proc/maps.
This happens due to an interaction between RLIMIT_STACK and the guard
page: when we do the guard page check, we ignore the potential error
from the stack expansion, which effectively results in a missing guard
page, since the expected stack expansion won't have been done.
And since /proc/maps explicitly ignores the guard page (commit
d7824370e263: "mm: fix up some user-visible effects of the stack guard
page"), the stack pointer ends up being outside the reported stack area.
This is the minimal patch: it just propagates the error. It also
effectively makes the guard page part of the stack limit, which in turn
measn that the actual real stack is one page less than the stack limit.
Let's see if anybody notices. We could teach acct_stack_growth() to
allow an extra page for a grow-up/grow-down stack in the rlimit test,
but I don't want to add more complexity if it isn't needed.
Reported-and-tested-by: Jay Foad <jay.foad@gmail.com>
A follow-up patch would have changed the call signature. To save the
trouble, just fold it instead.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Cc: <stable@vger.kernel.org> [3.17.x]
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"A large number of cleanups and bug fixes, with some (minor) journal
optimizations"
[ This got sent to me before -rc1, but was stuck in my spam folder. - Linus ]
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (67 commits)
ext4: check s_chksum_driver when looking for bg csum presence
ext4: move error report out of atomic context in ext4_init_block_bitmap()
ext4: Replace open coded mdata csum feature to helper function
ext4: delete useless comments about ext4_move_extents
ext4: fix reservation overflow in ext4_da_write_begin
ext4: add ext4_iget_normal() which is to be used for dir tree lookups
ext4: don't orphan or truncate the boot loader inode
ext4: grab missed write_count for EXT4_IOC_SWAP_BOOT
ext4: optimize block allocation on grow indepth
ext4: get rid of code duplication
ext4: fix over-defensive complaint after journal abort
ext4: fix return value of ext4_do_update_inode
ext4: fix mmap data corruption when blocksize < pagesize
vfs: fix data corruption when blocksize < pagesize for mmaped data
ext4: fold ext4_nojournal_sops into ext4_sops
ext4: support freezing ext2 (nojournal) file systems
ext4: fold ext4_sync_fs_nojournal() into ext4_sync_fs()
ext4: don't check quota format when there are no quota files
jbd2: simplify calling convention around __jbd2_journal_clean_checkpoint_list
jbd2: avoid pointless scanning of checkpoint lists
For VMAs that don't want write notifications, PTEs created for read faults
have their write bit set. If the read fault happens after VM_SOFTDIRTY is
cleared, then the PTE's softdirty bit will remain clear after subsequent
writes.
Here's a simple code snippet to demonstrate the bug:
char* m = mmap(NULL, getpagesize(), PROT_READ | PROT_WRITE,
MAP_ANONYMOUS | MAP_SHARED, -1, 0);
system("echo 4 > /proc/$PPID/clear_refs"); /* clear VM_SOFTDIRTY */
assert(*m == '\0'); /* new PTE allows write access */
assert(!soft_dirty(x));
*m = 'x'; /* should dirty the page */
assert(soft_dirty(x)); /* fails */
With this patch, write notifications are enabled when VM_SOFTDIRTY is
cleared. Furthermore, to avoid unnecessary faults, write notifications
are disabled when VM_SOFTDIRTY is set.
As a side effect of enabling and disabling write notifications with
care, this patch fixes a bug in mprotect where vm_page_prot bits set by
drivers were zapped on mprotect. An analogous bug was fixed in mmap by
commit c9d0bf241451 ("mm: uncached vma support with writenotify").
Signed-off-by: Peter Feiner <pfeiner@google.com>
Reported-by: Peter Feiner <pfeiner@google.com>
Suggested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Jamie Liu <jamieliu@google.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
We have a large university system in the UK that is experiencing very long
delays modprobing the driver for a specific I/O device. The delay is from
8-10 minutes per device and there are 31 devices in the system. This 4 to
5 hour delay in starting up those I/O devices is very much a burden on the
customer.
There are two causes for requiring a restart/reload of the drivers. First
is periodic preventive maintenance (PM) and the second is if any of the
devices experience a fatal error. Both of these trigger this excessively
long delay in bringing the system back up to full capability.
The problem was tracked down to a very slow IOREMAP operation and the
excessively long ioresource lookup to insure that the user is not
attempting to ioremap RAM. These patches provide a speed up to that
function.
The modprobe time appears to be affected quite a bit by previous activity
on the ioresource list, which I suspect is due to cache preloading. While
the overall improvement is impacted by other overhead of starting the
devices, this drastically improves the modprobe time.
Also our system is considerably smaller so the percentages gained will not
be the same. Best case improvement with the modprobe on our 20 device
smallish system was from 'real 5m51.913s' to 'real 0m18.275s'.
This patch (of 2):
Since the ioremap operation is verifying that the specified address range
is NOT RAM, it will search the entire ioresource list if the condition is
true. To make matters worse, it does this one 4k page at a time. For a
128M BAR region this is 32 passes to determine the entire region does not
contain any RAM addresses.
This patch provides another resource lookup function, region_is_ram, that
searches for the entire region specified, verifying that it is completely
contained within the resource region. If it is found, then it is checked
to be RAM or not, within a single pass.
The return result reflects if it was found or not (-1), and whether it is
RAM (1) or not (0). This allows the caller to fallback to the previous
page by page search if it was not found.
[akpm@linux-foundation.org: fix spellos and typos in comment]
Signed-off-by: Mike Travis <travis@sgi.com>
Acked-by: Alex Thorlton <athorlton@sgi.com>
Reviewed-by: Cliff Wickman <cpw@sgi.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Dave Young <dyoung@redhat.com>
Sasha Levin reported KASAN splash inside isolate_migratepages_range().
Problem is in the function __is_movable_balloon_page() which tests
AS_BALLOON_MAP in page->mapping->flags. This function has no protection
against anonymous pages. As result it tried to check address space flags
inside struct anon_vma.
Further investigation shows more problems in current implementation:
* Special branch in __unmap_and_move() never works:
balloon_page_movable() checks page flags and page_count. In
__unmap_and_move() page is locked, reference counter is elevated, thus
balloon_page_movable() always fails. As a result execution goes to the
normal migration path. virtballoon_migratepage() returns
MIGRATEPAGE_BALLOON_SUCCESS instead of MIGRATEPAGE_SUCCESS,
move_to_new_page() thinks this is an error code and assigns
newpage->mapping to NULL. Newly migrated page lose connectivity with
balloon an all ability for further migration.
* lru_lock erroneously required in isolate_migratepages_range() for
isolation ballooned page. This function releases lru_lock periodically,
this makes migration mostly impossible for some pages.
* balloon_page_dequeue have a tight race with balloon_page_isolate:
balloon_page_isolate could be executed in parallel with dequeue between
picking page from list and locking page_lock. Race is rare because they
use trylock_page() for locking.
This patch fixes all of them.
Instead of fake mapping with special flag this patch uses special state of
page->_mapcount: PAGE_BALLOON_MAPCOUNT_VALUE = -256. Buddy allocator uses
PAGE_BUDDY_MAPCOUNT_VALUE = -128 for similar purpose. Storing mark
directly in struct page makes everything safer and easier.
PagePrivate is used to mark pages present in page list (i.e. not
isolated, like PageLRU for normal pages). It replaces special rules for
reference counter and makes balloon migration similar to migration of
normal pages. This flag is protected by page_lock together with link to
the balloon device.
Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Link: http://lkml.kernel.org/p/53E6CEAA.9020105@oracle.com
Cc: Rafael Aquini <aquini@redhat.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: <stable@vger.kernel.org> [3.8+]
To eliminate code duplication lets introduce check_data_rlimit helper
which we will use in brk() and prctl() syscalls.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: Vasiliy Kulikov <segoon@openwall.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Julien Tinnes <jln@google.com>
- Rename vm_is_stack() to task_of_stack() and change it to return
"struct task_struct *" rather than the global (and thus wrong in
general) pid_t.
- Add the new pid_of_stack() helper which calls task_of_stack() and
uses the right namespace to report the correct pid_t.
Unfortunately we need to define this helper twice, in task_mmu.c
and in task_nommu.c. perhaps it makes sense to add fs/proc/util.c
and move at least pid_of_stack/task_of_stack there to avoid the
code duplication.
- Change show_map_vma() and show_numa_map() to use the new helper.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
->page_mkwrite() is used by filesystems to allocate blocks under a page
which is becoming writeably mmapped in some process' address space. This
allows a filesystem to return a page fault if there is not enough space
available, user exceeds quota or similar problem happens, rather than
silently discarding data later when writepage is called.
However VFS fails to call ->page_mkwrite() in all the cases where
filesystems need it when blocksize < pagesize. For example when
blocksize = 1024, pagesize = 4096 the following is problematic:
ftruncate(fd, 0);
pwrite(fd, buf, 1024, 0);
map = mmap(NULL, 1024, PROT_WRITE, MAP_SHARED, fd, 0);
map[0] = 'a'; ----> page_mkwrite() for index 0 is called
ftruncate(fd, 10000); /* or even pwrite(fd, buf, 1, 10000) */
mremap(map, 1024, 10000, 0);
map[4095] = 'a'; ----> no page_mkwrite() called
At the moment ->page_mkwrite() is called, filesystem can allocate only
one block for the page because i_size == 1024. Otherwise it would create
blocks beyond i_size which is generally undesirable. But later at
->writepage() time, we also need to store data at offset 4095 but we
don't have block allocated for it.
This patch introduces a helper function filesystems can use to have
->page_mkwrite() called at all the necessary moments.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@vger.kernel.org
When KVM handles a tdp fault it uses FOLL_NOWAIT. If the guest memory
has been swapped out or is behind a filemap, this will trigger async
readahead and return immediately. The rationale is that KVM will kick
back the guest with an "async page fault" and allow for some other
guest process to take over.
If async PFs are enabled the fault is retried asap from an async
workqueue. If not, it's retried immediately in the same code path. In
either case the retry will not relinquish the mmap semaphore and will
block on the IO. This is a bad thing, as other mmap semaphore users
now stall as a function of swap or filemap latency.
This patch ensures both the regular and async PF path re-enter the
fault allowing for the mmap semaphore to be relinquished in the case
of IO wait.
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
Signed-off-by: Andres Lagar-Cavilla <andreslc@google.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
The core mm code will provide a default gate area based on
FIXADDR_USER_START and FIXADDR_USER_END if
!defined(__HAVE_ARCH_GATE_AREA) && defined(AT_SYSINFO_EHDR).
This default is only useful for ia64. arm64, ppc, s390, sh, tile, 64-bit
UML, and x86_32 have their own code just to disable it. arm, 32-bit UML,
and x86_64 have gate areas, but they have their own implementations.
This gets rid of the default and moves the code into ia64.
This should save some code on architectures without a gate area: it's now
possible to inline the gate_area functions in the default case.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Nathan Lynch <nathan_lynch@mentor.com>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [in principle]
Acked-by: Richard Weinberger <richard@nod.at> [for um]
Acked-by: Will Deacon <will.deacon@arm.com> [for arm64]
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nathan Lynch <Nathan_Lynch@mentor.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull x86 cdso updates from Peter Anvin:
"Vdso cleanups and improvements largely from Andy Lutomirski. This
makes the vdso a lot less ''special''"
* 'x86/vdso' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vdso, build: Make LE access macros clearer, host-safe
x86/vdso, build: Fix cross-compilation from big-endian architectures
x86/vdso, build: When vdso2c fails, unlink the output
x86, vdso: Fix an OOPS accessing the HPET mapping w/o an HPET
x86, mm: Replace arch_vma_name with vm_ops->name for vsyscalls
x86, mm: Improve _install_special_mapping and fix x86 vdso naming
mm, fs: Add vm_ops->name as an alternative to arch_vma_name
x86, vdso: Remove vestiges of VDSO_PRELINK and some outdated comments
x86, vdso: Move the vvar and hpet mappings next to the 64-bit vDSO
x86, vdso: Move the 32-bit vdso special pages after the text
x86, vdso: Reimplement vdso.so preparation in build-time C
x86, vdso: Move syscall and sysenter setup into kernel/cpu/common.c
x86, vdso: Clean up 32-bit vs 64-bit vdso params
x86, mm: Ensure correct alignment of the fixmap
Currently, in put_compound_page(), we have
if (likely(!PageTail(page))) { <------ (1)
if (put_page_testzero(page)) {
¦* By the time all refcounts have been released
¦* split_huge_page cannot run anymore from under us.
if (PageHead(page))
__put_compound_page(page);
else
__put_single_page(page);
return;
/* __split_huge_page_refcount can run under us */
page_head = compound_head(page); <------------ (2)
if at (1) , we fail the check, this means page is *likely* a tail page.
Then at (2), as compoud_head(page) is inlined, it is :
static inline struct page *compound_head(struct page *page)
if (unlikely(PageTail(page))) { <----------- (3)
struct page *head = page->first_page;
smp_rmb();
if (likely(PageTail(page)))
return head;
return page;
here, the (3) unlikely in the case is a negative hint, because it is
*likely* a tail page. So the check (3) in this case is not good, so I
introduce a helper for this case.
So this patch introduces compound_head_by_tail() which deals with a
possible tail page(though it could be spilt by a racy thread), and make
compound_head() a wrapper on it.
This patch has no functional change, and it reduces the object
size slightly:
11003 1328 16 12347 303b mm/swap.o.orig
10971 1328 16 12315 301b mm/swap.o.patched
I've ran "perf top -e branch-miss" to observe branch-miss in this case.
As Michael points out, it's a slow path, so only very few times this case
happens. But I grep'ed the code base, and found there still are some
other call sites could be benifited from this helper. And given that it
only bloating up the source by only 5 lines, but with a reduced object
size. I still believe this helper deserves to exsit.
Signed-off-by: Jianyu Zhan <nasa4836@gmail.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Merge x86/espfix into x86/vdso, due to changes in the vdso setup code
that otherwise cause conflicts.
Using arch_vma_name to give special mappings a name is awkward. x86
currently implements it by comparing the start address of the vma to
the expected address of the vdso. This requires tracking the start
address of special mappings and is probably buggy if a special vma
is split or moved.
Improve _install_special_mapping to just name the vma directly. Use
it to give the x86 vvar area a name, which should make CRIU's life
easier.
As a side effect, the vvar area will show up in core dumps. This
could be considered weird and is fixable.
[hpa: I say we accept this as-is but be prepared to deal with knocking
out the vvars from core dumps if this becomes a problem.]
Link: http://lkml.kernel.org/r/276b39b6b645fb11e345457b503f17b83c2c6fd0.1400538962.git.luto@amacapital.net
arch_vma_name sucks. It's a silly hack, and it's annoying to
implement correctly. In fact, AFAICS, even the straightforward x86
implementation is incorrect (I suspect that it breaks if the vdso
mapping is split or gets remapped).
This adds a new vm_ops->name operation that can replace it. The
followup patches will remove all uses of arch_vma_name on x86,
fixing a couple of annoyances in the process.
Link: http://lkml.kernel.org/r/2eee21791bb36a0a408c5c2bdb382a9e6a41ca4a.1400538962.git.luto@amacapital.net
too many places open-code it
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
LAST_CPUPID_MASK is calculated using LAST_CPUPID_WIDTH. However
LAST_CPUPID_WIDTH itself can be 0. (when LAST_CPUPID_NOT_IN_PAGE_FLAGS is
set). In such a case LAST_CPUPID_MASK turns out to be 0.
But with recent commit 1ae71d0319: (mm: numa: bugfix for
LAST_CPUPID_NOT_IN_PAGE_FLAGS) if LAST_CPUPID_MASK is 0,
page_cpupid_xchg_last() and page_cpupid_reset_last() causes
page->_last_cpupid to be set to 0.
This causes performance regression. Its almost as if numa_balancing is
off.
Fix LAST_CPUPID_MASK by using LAST_CPUPID_SHIFT instead of
LAST_CPUPID_WIDTH.
Some performance numbers and perf stats with and without the fix.
(3.14-rc6)
numa01
Performance counter stats for '/usr/bin/time -f %e %S %U %c %w -o start_bench.out -a ./numa01':
12,27,462 cs [100.00%]
2,41,957 migrations [100.00%]
1,68,01,713 faults [100.00%]
7,99,35,29,041 cache-misses
98,808 migrate:mm_migrate_pages [100.00%]
1407.690148814 seconds time elapsed
numa02
Performance counter stats for '/usr/bin/time -f %e %S %U %c %w -o start_bench.out -a ./numa02':
63,065 cs [100.00%]
14,364 migrations [100.00%]
2,08,118 faults [100.00%]
25,32,59,404 cache-misses
12 migrate:mm_migrate_pages [100.00%]
63.840827219 seconds time elapsed
(3.14-rc6 with fix)
numa01
9,68,911 cs [100.00%]
1,01,414 migrations [100.00%]
88,38,697 faults [100.00%]
4,42,92,51,042 cache-misses
4,25,060 migrate:mm_migrate_pages [100.00%]
685.965331189 seconds time elapsed
numa02
17,543 cs [100.00%]
2,962 migrations [100.00%]
1,17,843 faults [100.00%]
11,80,61,644 cache-misses
12,358 migrate:mm_migrate_pages [100.00%]
20.380132343 seconds time elapsed
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Liu Ping Fan <pingfank@linux.vnet.ibm.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Commit f9acc8c7b35a ("readahead: sanify file_ra_state names") left
ra_submit with a single function call.
Move ra_submit to internal.h and inline it to save some stack. Thanks
to Andrew Morton for commenting different versions.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
filemap_map_pages() is generic implementation of ->map_pages() for
filesystems who uses page cache.
It should be safe to use filemap_map_pages() for ->map_pages() if
filesystem use filemap_fault() for ->fault().
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Ning Qu <quning@gmail.com>
Here's new version of faultaround patchset. It took a while to tune it
and collect performance data.
First patch adds new callback ->map_pages to vm_operations_struct.
->map_pages() is called when VM asks to map easy accessible pages.
Filesystem should find and map pages associated with offsets from
"pgoff" till "max_pgoff". ->map_pages() is called with page table
locked and must not block. If it's not possible to reach a page without
blocking, filesystem should skip it. Filesystem should use do_set_pte()
to setup page table entry. Pointer to entry associated with offset
"pgoff" is passed in "pte" field in vm_fault structure. Pointers to
entries for other offsets should be calculated relative to "pte".
Currently VM use ->map_pages only on read page fault path. We try to
map FAULT_AROUND_PAGES a time. FAULT_AROUND_PAGES is 16 for now.
Performance data for different FAULT_AROUND_ORDER is below.
TODO:
- implement ->map_pages() for shmem/tmpfs;
- modify get_user_pages() to be able to use ->map_pages() and implement
mmap(MAP_POPULATE|MAP_NONBLOCK) on top.
Tested on 4-socket machine (120 threads) with 128GiB of RAM.
Few real-world workloads. The sweet spot for FAULT_AROUND_ORDER here is
somewhere between 3 and 5. Let's say 4 :)
Linux build (make -j60)
FAULT_AROUND_ORDER Baseline 1 3 4 5 7 9
minor-faults 283,301,572 247,151,987 212,215,789 204,772,882 199,568,944 194,703,779 193,381,485
time, seconds 151.227629483 153.920996480 151.356125472 150.863792049 150.879207877 151.150764954 151.450962358
Linux rebuild (make -j60)
minor-faults 5,396,854 4,148,444 2,855,286 2,577,282 2,361,957 2,169,573 2,112,643
time, seconds 27.404543757 27.559725591 27.030057426 26.855045126 26.678618635 26.974523490 26.761320095
Git test suite (make -j60 test)
minor-faults 129,591,823 99,200,751 66,106,718 57,606,410 51,510,808 45,776,813 44,085,515
time, seconds 66.087215026 64.784546905 64.401156567 65.282708668 66.034016829 66.793780811 67.237810413
Two synthetic tests: access every word in file in sequential/random order.
It doesn't improve much after FAULT_AROUND_ORDER == 4.
Sequential access 16GiB file
1 thread
minor-faults 4,195,437 2,098,275 525,068 262,251 131,170 32,856 8,282
time, seconds 7.250461742 6.461711074 5.493859139 5.488488147 5.707213983 5.898510832 5.109232856
8 threads
minor-faults 33,557,540 16,892,728 4,515,848 2,366,999 1,423,382 442,732 142,339
time, seconds 16.649304881 9.312555263 6.612490639 6.394316732 6.669827501 6.75078944 6.371900528
32 threads
minor-faults 134,228,222 67,526,810 17,725,386 9,716,537 4,763,731 1,668,921 537,200
time, seconds 49.164430543 29.712060103 12.938649729 10.175151004 11.840094583 9.594081325 9.928461797
60 threads
minor-faults 251,687,988 126,146,952 32,919,406 18,208,804 10,458,947 2,733,907 928,217
time, seconds 86.260656897 49.626551828 22.335007632 17.608243696 16.523119035 16.339489186 16.326390902
120 threads
minor-faults 503,352,863 252,939,677 67,039,168 35,191,827 19,170,091 4,688,357 1,471,862
time, seconds 124.589206333 79.757867787 39.508707872 32.167281632 29.972989292 28.729834575 28.042251622
Random access 1GiB file
1 thread
minor-faults 262,636 132,743 34,369 17,299 8,527 3,451 1,222
time, seconds 15.351890914 16.613802482 16.569227308 15.179220992 16.557356122 16.578247824 15.365266994
8 threads
minor-faults 2,098,948 1,061,871 273,690 154,501 87,110 25,663 7,384
time, seconds 15.040026343 15.096933500 14.474757288 14.289129964 14.411537468 14.296316837 14.395635804
32 threads
minor-faults 8,390,734 4,231,023 1,054,432 528,847 269,242 97,746 26,881
time, seconds 20.430433109 21.585235358 22.115062928 14.872878951 14.880856305 14.883370649 14.821261690
60 threads
minor-faults 15,733,258 7,892,809 1,973,393 988,266 594,789 164,994 51,691
time, seconds 26.577302548 25.692397770 18.728863715 20.153026398 21.619101933 17.745086260 17.613215273
120 threads
minor-faults 31,471,111 15,816,616 3,959,209 1,978,685 1,008,299 264,635 96,010
time, seconds 41.835322703 40.459786095 36.085306105 35.313894834 35.814445675 36.552633793 34.289210594
Touch only one page in page table in 16GiB file
1 thread
minor-faults 8,372 8,324 8,270 8,260 8,249 8,239 8,237
time, seconds 0.039892712 0.045369149 0.051846126 0.063681685 0.079095975 0.17652406 0.541213386
8 threads
minor-faults 65,731 65,681 65,628 65,620 65,608 65,599 65,596
time, seconds 0.124159196 0.488600638 0.156854426 0.191901957 0.242631486 0.543569456 1.677303984
32 threads
minor-faults 262,388 262,341 262,285 262,276 262,266 262,257 263,183
time, seconds 0.452421421 0.488600638 0.565020946 0.648229739 0.789850823 1.651584361 5.000361559
60 threads
minor-faults 491,822 491,792 491,723 491,711 491,701 491,691 491,825
time, seconds 0.763288616 0.869620515 0.980727360 1.161732354 1.466915814 3.04041448 9.308612938
120 threads
minor-faults 983,466 983,655 983,366 983,372 983,363 984,083 984,164
time, seconds 1.595846553 1.667902182 2.008959376 2.425380942 2.941368804 5.977807890 18.401846125
This patch (of 2):
Introduce new vm_ops callback ->map_pages() and uses it for mapping easy
accessible pages around fault address.
On read page fault, if filesystem provides ->map_pages(), we try to map up
to FAULT_AROUND_PAGES pages around page fault address in hope to reduce
number of minor page faults.
We call ->map_pages first and use ->fault() as fallback if page by the
offset is not ready to be mapped (cold page cache or something).
Add VM_INIT_DEF_MASK, to allow us to set the default flags for VMs. It
also adds a prctl control which allows us to set the THP disable bit in
mm->def_flags so that VMs will pick up the setting as they are created.
Signed-off-by: Alex Thorlton <athorlton@sgi.com>
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
The ifdef conditions in include/linux/mm.h presents three cases:
- !defined(CONFIG_HAVE_MEMBLOCK_NODE_MAP) && !defined(CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID)
There is no actual definition of function but include/linux/mm.h has a
static inline stub defined.
- defined(CONFIG_HAVE_MEMBLOCK_NODE_MAP) && !defined(CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID)
linux/mm.h does not define a prototype, but mm/page_alloc.c defines
the function.
Hence, compiler reports the following warning:
mm/page_alloc.c:4300:15: warning: no previous prototype for `__early_pfn_to_nid' [-Wmissing-prototypes]
- defined(CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID)
The architecture defines the function, and linux/mm.h has a
prototype.
Thus, join the conditions of Case 2 and 3 ie eliminate the ifdef
condition of CONFIG_HAVE_ARCH_EARLY_PFN_TO_NID to eliminate the missing
prototype warning from file mm/page_alloc.c.
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
shmem mappings already contain exceptional entries where swap slot
information is remembered.
To be able to store eviction information for regular page cache, prepare
every site dealing with the radix trees directly to handle entries other
than pages.
The common lookup functions will filter out non-page entries and return
NULL for page cache holes, just as before. But provide a raw version of
the API which returns non-page entries as well, and switch shmem over to
use it.
Pull x86 vdso changes from Peter Anvin:
"This is the revamp of the 32-bit vdso and the associated cleanups.
This adds timekeeping support to the 32-bit vdso that we already have
in the 64-bit vdso. Although 32-bit x86 is legacy, it is likely to
remain in the embedded space for a very long time to come.
This removes the traditional COMPAT_VDSO support; the configuration
variable is reused for simply removing the 32-bit vdso, which will
produce correct results but obviously suffer a performance penalty.
Only one beta version of glibc was affected, but that version was
unfortunately included in one OpenSUSE release.
This is not the end of the vdso cleanups. Stefani and Andy have
agreed to continue work for the next kernel cycle; in fact Andy has
already produced another set of cleanups that came too late for this
cycle.
An incidental, but arguably important, change is that this ensures
that unused space in the VVAR page is properly zeroed. It wasn't
before, and would contain whatever garbage was left in memory by BIOS
or the bootloader. Since the VVAR page is accessible to user space
this had the potential of information leaks"
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
x86, vdso: Fix the symbol versions on the 32-bit vDSO
x86, vdso, build: Don't rebuild 32-bit vdsos on every make
x86, vdso: Actually discard the .discard sections
x86, vdso: Fix size of get_unmapped_area()
x86, vdso: Finish removing VDSO32_PRELINK
x86, vdso: Move more vdso definitions into vdso.h
x86: Load the 32-bit vdso in place, just like the 64-bit vdsos
x86, vdso32: handle 32 bit vDSO larger one page
x86, vdso32: Disable stack protector, adjust optimizations
x86, vdso: Zero-pad the VVAR page
x86, vdso: Add 32 bit VDSO time support for 64 bit kernel
x86, vdso: Add 32 bit VDSO time support for 32 bit kernel
x86, vdso: Patch alternatives in the 32-bit VDSO
x86, vdso: Introduce VVAR marco for vdso32
x86, vdso: Cleanup __vdso_gettimeofday()
x86, vdso: Replace VVAR(vsyscall_gtod_data) by gtod macro
x86, vdso: __vdso_clock_gettime() cleanup
x86, vdso: Revamp vclock_gettime.c
mm: Add new func _install_special_mapping() to mmap.c
x86, vdso: Make vsyscall_gtod_data handling x86 generic
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"There are two memory management related changes, the CMMA support for
KVM to avoid swap-in of freed pages and the split page table lock for
the PMD level. These two come with common code changes in mm/.
A fix for the long standing theoretical TLB flush problem, this one
comes with a common code change in kernel/sched/.
Another set of changes is Heikos uaccess work, included is the initial
set of patches with more to come.
And fixes and cleanups as usual"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (36 commits)
s390/con3270: optionally disable auto update
s390/mm: remove unecessary parameter from pgste_ipte_notify
s390/mm: remove unnecessary parameter from gmap_do_ipte_notify
s390/mm: fixing comment so that parameter name match
s390/smp: limit number of cpus in possible cpu mask
hypfs: Add clarification for "weight_min" attribute
s390: update defconfigs
s390/ptrace: add support for PTRACE_SINGLEBLOCK
s390/perf: make print_debug_cf() static
s390/topology: Remove call to update_cpu_masks()
s390/compat: remove compat exec domain
s390: select CONFIG_TTY for use of tty in unconditional keyboard driver
s390/appldata_os: fix cpu array size calculation
s390/checksum: remove memset() within csum_partial_copy_from_user()
s390/uaccess: remove copy_from_user_real()
s390/sclp_early: Return correct HSA block count also for zero
s390: add some drivers/subsystems to the MAINTAINERS file
s390: improve debug feature usage
s390/airq: add support for irq ranges
s390/mm: enable split page table lock for PMD level
The _install_special_mapping() is the new base function for
install_special_mapping(). This function will return a pointer of the
created VMA or a error code in an ERR_PTR()
This new function will be needed by the for the vdso 32 bit support to map the
additonal vvar and hpet pages into the 32 bit address space. This will be done
with io_remap_pfn_range() and remap_pfn_range, which requieres a vm_area_struct.
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
Signed-off-by: Stefani Seibold <stefani@seibold.net>
Link: http://lkml.kernel.org/r/1395094933-14252-3-git-send-email-stefani@seibold.net
introduce get_cmdline() for retreiving the value of a processes
proc/self/cmdline value.
Acked-by: David Rientjes <rientjes@google.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: William Roberts <wroberts@tresys.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
When doing some numa tests on powerpc, I triggered an oops bug. I find
it is caused by using page->_last_cpupid. It should be initialized as
"-1 & LAST_CPUPID_MASK", but not "-1". Otherwise, in task_numa_fault(),
we will miss the checking (last_cpupid == (-1 & LAST_CPUPID_MASK)). And
finally cause an oops bug in task_numa_group(), since the online cpu is
less than possible cpu. This happen with CONFIG_SPARSE_VMEMMAP disabled
Call trace:
SMP NR_CPUS=64 NUMA PowerNV
Modules linked in:
CPU: 24 PID: 804 Comm: systemd-udevd Not tainted3.13.0-rc1+ #32
task: c000001e2746aa80 ti: c000001e32c50000 task.ti:c000001e32c50000
REGS: c000001e32c53510 TRAP: 0300 Not tainted(3.13.0-rc1+)
MSR: 9000000000009032 <SF,HV,EE,ME,IR,DR,RI> CR:28024424 XER: 20000000
CFAR: c000000000009324 DAR: 7265717569726857 DSISR:40000000 SOFTE: 1
NIP .task_numa_fault+0x1470/0x2370
LR .task_numa_fault+0x1468/0x2370
Call Trace:
.task_numa_fault+0x1468/0x2370 (unreliable)
.do_numa_page+0x480/0x4a0
.handle_mm_fault+0x4ec/0xc90
.do_page_fault+0x3a8/0x890
handle_page_fault+0x10/0x30
Instruction dump:
3c82fefb 3884b138 48d9cff1 60000000 48000574 3c62fefb3863af78 3c82fefb
3884b138 48d9cfd5 60000000 e93f0100 <812902e4> 7d2907b45529063e 7d2a07b4
---[ end trace 15f2510da5ae07cf ]---
Signed-off-by: Liu Ping Fan <pingfank@linux.vnet.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Daniel Borkmann reported a VM_BUG_ON assertion failing:
kernel BUG at mm/mlock.c:528!
invalid opcode: 0000 [#1] SMP
Modules linked in: ccm arc4 iwldvm [...]
video
CPU: 3 PID: 2266 Comm: netsniff-ng Not tainted 3.14.0-rc2+ #8
Hardware name: LENOVO 2429BP3/2429BP3, BIOS G4ET37WW (1.12 ) 05/29/2012
task: ffff8801f87f9820 ti: ffff88002cb44000 task.ti: ffff88002cb44000
RIP: 0010:[<ffffffff81171ad0>] [<ffffffff81171ad0>] munlock_vma_pages_range+0x2e0/0x2f0
Call Trace:
do_munmap+0x18f/0x3b0
vm_munmap+0x41/0x60
SyS_munmap+0x22/0x30
system_call_fastpath+0x1a/0x1f
RIP munlock_vma_pages_range+0x2e0/0x2f0
---[ end trace a0088dcf07ae10f2 ]---
because munlock_vma_pages_range() thinks it's unexpectedly in the middle
of a THP page. This can be reproduced with default config since 3.11
kernels. A reproducer can be found in the kernel's selftest directory
for networking by running ./psock_tpacket.
The problem is that an order=2 compound page (allocated by
alloc_one_pg_vec_page() is part of the munlocked VM_MIXEDMAP vma (mapped
by packet_mmap()) and mistaken for a THP page and assumed to be order=9.
The checks for THP in munlock came with commit ff6a6da60b89 ("mm:
accelerate munlock() treatment of THP pages"), i.e. since 3.9, but did
not trigger a bug. It just makes munlock_vma_pages_range() skip such
compound pages until the next 512-pages-aligned page, when it encounters
a head page. This is however not a problem for vma's where mlocking has
no effect anyway, but it can distort the accounting.
Since commit 7225522bb429 ("mm: munlock: batch non-THP page isolation
and munlock+putback using pagevec") this can trigger a VM_BUG_ON in
PageTransHuge() check.
This patch fixes the issue by adding VM_MIXEDMAP flag to VM_SPECIAL, a
list of flags that make vma's non-mlockable and non-mergeable. The
reasoning is that VM_MIXEDMAP vma's are similar to VM_PFNMAP, which is
already on the VM_SPECIAL list, and both are intended for non-LRU pages
where mlocking makes no sense anyway. Related Lkml discussion can be
found in [2].
[1] tools/testing/selftests/net/psock_tpacket
[2] https://lkml.org/lkml/2014/1/10/427
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Reported-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Thomas Hellstrom <thellstrom@vmware.com>
Cc: John David Anglin <dave.anglin@bell.net>
Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com>
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Jared Hulbert <jaredeh@gmail.com>
Tested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: <stable@vger.kernel.org> [3.11.x+]
Commit bf6bddf1924e ("mm: introduce compaction and migration for
ballooned pages") introduces page_count(page) into memory compaction
which dereferences page->first_page if PageTail(page).
This results in a very rare NULL pointer dereference on the
aforementioned page_count(page). Indeed, anything that does
compound_head(), including page_count() is susceptible to racing with
prep_compound_page() and seeing a NULL or dangling page->first_page
pointer.
This patch uses Andrea's implementation of compound_trans_head() that
deals with such a race and makes it the default compound_head()
implementation. This includes a read memory barrier that ensures that
if PageTail(head) is true that we return a head page that is neither
NULL nor dangling. The patch then adds a store memory barrier to
prep_compound_page() to ensure page->first_page is set.
This is the safest way to ensure we see the head page that we are
expecting, PageTail(page) is already in the unlikely() path and the
memory barriers are unfortunately required.
Hugetlbfs is the exception, we don't enforce a store memory barrier
during init since no race is possible.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Holger Kiehl <Holger.Kiehl@dwd.de>
Cc: Christoph Lameter <cl@linux.com>
The pmd pointer passed to pmd_lockptr/pmd_huge_pte can point to any
entry in a pmd table. With USE_SPLIT_PMD_PTLOCKS==1 the code uses
virt_to_page to get a struct page for the pmd table. The virt_to_page
function automatically masks the lower PAGE_SHIFT bits from the
address. But if the size of a pmd table is larger than PAGE_SIZE the
additional bits are not removed from the pmd address and the wrong
page struct is used.
Fix this by explicitely masking the offset in the pmd table from
the pmd pointer.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"So here's my next branch for powerpc. A bit late as I was on vacation
last week. It's mostly the same stuff that was in next already, I
just added two patches today which are the wiring up of lockref for
powerpc, which for some reason fell through the cracks last time and
is trivial.
The highlights are, in addition to a bunch of bug fixes:
- Reworked Machine Check handling on kernels running without a
hypervisor (or acting as a hypervisor). Provides hooks to handle
some errors in real mode such as TLB errors, handle SLB errors,
etc...
- Support for retrieving memory error information from the service
processor on IBM servers running without a hypervisor and routing
them to the memory poison infrastructure.
- _PAGE_NUMA support on server processors
- 32-bit BookE relocatable kernel support
- FSL e6500 hardware tablewalk support
- A bunch of new/revived board support
- FSL e6500 deeper idle states and altivec powerdown support
You'll notice a generic mm change here, it has been acked by the
relevant authorities and is a pre-req for our _PAGE_NUMA support"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (121 commits)
powerpc: Implement arch_spin_is_locked() using arch_spin_value_unlocked()
powerpc: Add support for the optimised lockref implementation
powerpc/powernv: Call OPAL sync before kexec'ing
powerpc/eeh: Escalate error on non-existing PE
powerpc/eeh: Handle multiple EEH errors
powerpc: Fix transactional FP/VMX/VSX unavailable handlers
powerpc: Don't corrupt transactional state when using FP/VMX in kernel
powerpc: Reclaim two unused thread_info flag bits
powerpc: Fix races with irq_work
Move precessing of MCE queued event out from syscall exit path.
pseries/cpuidle: Remove redundant call to ppc64_runlatch_off() in cpu idle routines
powerpc: Make add_system_ram_resources() __init
powerpc: add SATA_MV to ppc64_defconfig
powerpc/powernv: Increase candidate fw image size
powerpc: Add debug checks to catch invalid cpu-to-node mappings
powerpc: Fix the setup of CPU-to-Node mappings during CPU online
powerpc/iommu: Don't detach device without IOMMU group
powerpc/eeh: Hotplug improvement
powerpc/eeh: Call opal_pci_reinit() on powernv for restoring config space
powerpc/eeh: Add restore_config operation
Most of the VM_BUG_ON assertions are performed on a page. Usually, when
one of these assertions fails we'll get a BUG_ON with a call stack and
the registers.
I've recently noticed based on the requests to add a small piece of code
that dumps the page to various VM_BUG_ON sites that the page dump is
quite useful to people debugging issues in mm.
This patch adds a VM_BUG_ON_PAGE(cond, page) which beyond doing what
VM_BUG_ON() does, also dumps the page before executing the actual
BUG_ON.
[akpm@linux-foundation.org: fix up includes]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
bad_page() is cool in that it prints out a bunch of data about the page.
But, I can never remember which page flags are good and which are bad,
or whether ->index or ->mapping is required to be NULL.
This patch allows bad/dump_page() callers to specify a string about why
they are dumping the page and adds explanation strings to a number of
places. It also adds a 'bad_flags' argument to bad_page(), which it
then dumps out separately from the flags which are actually set.
This way, the messages will show specifically why the page was bad,
*specifically* which flags it is complaining about, if it was a page
flag combination which was the problem.
[akpm@linux-foundation.org: switch to pr_alert]
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Reviewed-by: Christoph Lameter <cl@linux.com>
Some applications that run on HPC clusters are designed around the
availability of RAM and the overcommit ratio is fine tuned to get the
maximum usage of memory without swapping. With growing memory, the
1%-of-all-RAM grain provided by overcommit_ratio has become too coarse
for these workload (on a 2TB machine it represents no less than 20GB).
This patch adds the new overcommit_kbytes sysctl variable that allow a
much finer grain.
[akpm@linux-foundation.org: fix nommu build]
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Commit 4b59e6c47309 ("mm, show_mem: suppress page counts in
non-blockable contexts") introduced SHOW_MEM_FILTER_PAGE_COUNT to
suppress PFN walks on large memory machines. Commit c78e93630d15 ("mm:
do not walk all of system memory during show_mem") avoided a PFN walk in
the generic show_mem helper which removes the requirement for
SHOW_MEM_FILTER_PAGE_COUNT in that case.
This patch removes PFN walkers from the arch-specific implementations
that report on a per-node or per-zone granularity. ARM and unicore32
still do a PFN walk as they report memory usage on each bank which is a
much finer granularity where the debugging information may still be of
use. As the remaining arches doing PFN walks have relatively small
amounts of memory, this patch simply removes SHOW_MEM_FILTER_PAGE_COUNT.
[akpm@linux-foundation.org: fix parisc]
Cc: James Bottomley <jejb@parisc-linux.org>
If DEBUG_SPINLOCK and DEBUG_LOCK_ALLOC are enabled spinlock_t on x86_64
is 72 bytes. For page->ptl they will be allocated from kmalloc-96 slab,
so we loose 24 on each. An average system can easily allocate few tens
thousands of page->ptl and overhead is significant.
Let's create a separate slab for page->ptl allocation to solve this.
To make sure that it really works this time, some numbers from my test
machine (just booted, no load):
Before:
# grep '^\(kmalloc-96\|page->ptl\)' /proc/slabinfo
kmalloc-96 31987 32190 128 30 1 : tunables 120 60 8 : slabdata 1073 1073 92
After:
page->ptl 27516 28143 72 53 1 : tunables 120 60 8 : slabdata 531 531 9
kmalloc-96 3853 5280 128 30 1 : tunables 120 60 8 : slabdata 176 176 0
Note that the patch is useful not only for debug case, but also for
PREEMPT_RT, where spinlock_t is always bloated.
get_huge_page_tail()->compound_head() looks confusing. Every caller
must check PageTail(page), otherwise atomic_inc(&page->_mapcount) is
simply wrong if this page is compound-trans-head.
Cc: Dave Jones <davej@redhat.com>
Cc: Darren Hart <dvhart@linux.intel.com>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
This skips the _mapcount mangling for slab and hugetlbfs pages.
The main trouble in doing this is to guarantee that PageSlab and
PageHeadHuge remains constant for all get_page/put_page run on the tail
of slab or hugetlbfs compound pages. Otherwise if they're set during
get_page but not set during put_page, the _mapcount of the tail page
would underflow.
PageHeadHuge will remain true until the compound page is released and
enters the buddy allocator so it won't risk to change even if the tail
page is the last reference left on the page.
PG_slab instead is cleared before the slab frees the head page with
put_page, so if the tail pin is released after the slab freed the page,
we would have a problem. But in the slab case the tail pin cannot be
the last reference left on the page. This is because the slab code is
free to reuse the compound page after a kfree/kmem_cache_free without
having to check if there's any tail pin left. In turn all tail pins
must be always released while the head is still pinned by the slab code
and so we know PG_slab will be still set too.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: Khalid Aziz <khalid.aziz@oracle.com>
Cc: Pravin Shelar <pshelar@nicira.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Johannes Weiner <jweiner@redhat.com>
Cc: Minchan Kim <minchan@kernel.org>
{,set}page_address() are macros if WANT_PAGE_VIRTUAL. If
!WANT_PAGE_VIRTUAL, they're plain C functions.
If someone calls them with a void *, this pointer is auto-converted to
struct page * if !WANT_PAGE_VIRTUAL, but causes a build failure on
architectures using WANT_PAGE_VIRTUAL (arc, m68k and sparc64):
drivers/md/bcache/bset.c: In function `__btree_sort':
drivers/md/bcache/bset.c:1190: warning: dereferencing `void *' pointer
drivers/md/bcache/bset.c:1190: error: request for member `virtual' in something not a structure or union
Convert them to static inline functions to fix this. There are already
plenty of users of struct page members inside <linux/mm.h>, so there's
no reason to keep them as macros.
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: David Rientjes <rientjes@google.com>
In struct page we have enough space to fit long-size page->ptl there,
but we use dynamically-allocated page->ptl if size(spinlock_t) is larger
than sizeof(int).
It hurts 64-bit architectures with CONFIG_GENERIC_LOCKBREAK, where
sizeof(spinlock_t) == 8, but it easily fits into struct page.
change_prot_numa should work even if _PAGE_NUMA != _PAGE_PROTNONE.
On archs like ppc64 that don't use _PAGE_PROTNONE and also have
a separate page table outside linux pagetable, we just need to
make sure that when calling change_prot_numa we flush the
hardware page table entry so that next page access result in a numa
fault.
We still need to make sure we use the numa faulting logic only
when CONFIG_NUMA_BALANCING is set. This implies the migrate-on-fault
(Lazy migration) via mbind will only work if CONFIG_NUMA_BALANCING
is set.
This reverts commit ea1e7ed33708c7a760419ff9ded0a6cb90586a50.
Al points out that while the commit *does* actually create a separate
slab for the page->ptl allocation, that slab is never actually used, and
the code continues to use kmalloc/kfree.
Damien Wyart points out that the original patch did have the conversion
to use kmem_cache_alloc/free, so it got lost somewhere on its way to me.
Revert the half-arsed attempt that didn't do anything. If we really do
want the special slab (remember: this is all relevant just for debug
builds, so it's not necessarily all that critical) we might as well redo
the patch fully.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Kirill A Shutemov <kirill.shutemov@linux.intel.com>
Use kernel/bounds.c to convert build-time spinlock_t size check into a
preprocessor symbol and apply that to properly separate the page::ptl
situation.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
If split page table lock is in use, we embed the lock into struct page
of table's page. We have to disable split lock, if spinlock_t is too
big be to be embedded, like when DEBUG_SPINLOCK or DEBUG_LOCK_ALLOC
enabled.
This patch add support for dynamic allocation of split page table lock
if we can't embed it to struct page.
page->ptl is unsigned long now and we use it as spinlock_t if
sizeof(spinlock_t) <= sizeof(long), otherwise it's pointer to spinlock_t.
The spinlock_t allocated in pgtable_page_ctor() for PTE table and in
pgtable_pmd_page_ctor() for PMD table. All other helpers converted to
support dynamically allocated page->ptl.
Reviewed-by: Peter Zijlstra <peterz@infradead.org>
Change pgtable_page_ctor() return type from void to bool. Returns true,
if initialization is successful and false otherwise.
Current implementation never fails, but it will change later.
