path: root/include/linux/mm.h
2008-04-29procfs task exe symlinkMatt Helsley
The kernel implements readlink of /proc/pid/exe by getting the file from the first executable VMA. Then the path to the file is reconstructed and reported as the result. Because of the VMA walk the code is slightly different on nommu systems. This patch avoids separate /proc/pid/exe code on nommu systems. Instead of walking the VMAs to find the first executable file-backed VMA we store a reference to the exec'd file in the mm_struct. That reference would prevent the filesystem holding the executable file from being unmounted even after unmapping the VMAs. So we track the number of VM_EXECUTABLE VMAs and drop the new reference when the last one is unmapped. This avoids pinning the mounted filesystem. [akpm@linux-foundation.org: improve comments] [yamamoto@valinux.co.jp: fix dup_mmap] Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: David Howells <dhowells@redhat.com> Cc:"Eric W. Biederman" <ebiederm@xmission.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29fs/drop_caches.c: make 2 functions staticAdrian Bunk
Make the following needlessly global functions static: - drop_pagecache() - drop_slab() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mempolicy: document {set|get}_policy() vm_ops APIsLee Schermerhorn
Document mempolicy return value reference semantics assumed by the rest of the mempolicy code for the set_ and get_policy vm_ops in <linux/mm.h>--where the prototypes are defined--to inform any future mempolicy vm_op writers what the rest of the subsystem expects of them. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: add vm_insert_mixedNick Piggin
vm_insert_mixed will insert either a raw pfn or a refcounted struct page into the page tables, depending on whether vm_normal_page() will return the page or not. With the introduction of the new pte bit, this is now a too tricky for drivers to be doing themselves. filemap_xip uses this in a subsequent patch. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce VM_MIXEDMAPJared Hulbert
This series introduces some important infrastructure work. The overall result is that: 1. We now support XIP backed filesystems using memory that have no struct page allocated to them. And patches 6 and 7 actually implement this for s390. This is pretty important in a number of cases. As far as I understand, in the case of virtualisation (eg. s390), each guest may mount a readonly copy of the same filesystem (eg. the distro). Currently, guests need to allocate struct pages for this image. So if you have 100 guests, you already need to allocate more memory for the struct pages than the size of the image. I think. (Carsten?) For other (eg. embedded) systems, you may have a very large non- volatile filesystem. If you have to have struct pages for this, then your RAM consumption will go up proportionally to fs size. Even though it is just a small proportion, the RAM can be much more costly eg in terms of power, so every KB less that Linux uses makes it more attractive to a lot of these guys. 2. VM_MIXEDMAP allows us to support mappings where you actually do want to refcount _some_ pages in the mapping, but not others, and support COW on arbitrary (non-linear) mappings. Jared needs this for his NVRAM filesystem in progress. Future iterations of this filesystem will most likely want to migrate pages between pagecache and XIP backing, which is where the requirement for mixed (some refcounted, some not) comes from. 3. pte_special also has a peripheral usage that I need for my lockless get_user_pages patch. That was shown to speed up "oltp" on db2 by 10% on a 2 socket system, which is kind of significant because they scrounge for months to try to find 0.1% improvement on these workloads. I'm hoping we might finally be faster than AIX on pSeries with this :). My reference to lockless get_user_pages is not meant to justify this patchset (which doesn't include lockless gup), but just to show that pte_special is not some s390 specific thing that should be hidden in arch code or xip code: I definitely want to use it on at least x86 and powerpc as well. This patch: Introduce a new type of mapping, VM_MIXEDMAP. This is unlike VM_PFNMAP in that it can support COW mappings of arbitrary ranges including ranges without struct page *and* ranges with a struct page that we actually want to refcount (PFNMAP can only support COW in those cases where the un-COW-ed translations are mapped linearly in the virtual address, and can only support non refcounted ranges). VM_MIXEDMAP achieves this by refcounting all pfn_valid pages, and not refcounting !pfn_valid pages (which is not an option for VM_PFNMAP, because it needs to avoid refcounting pfn_valid pages eg. for /dev/mem mappings). Signed-off-by: Jared Hulbert <jaredeh@gmail.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28pageflags: get rid of FLAGS_RESERVEDChristoph Lameter
NR_PAGEFLAGS specifies the number of page flags we are using. From that we can calculate the number of bits leftover that can be used for zone, node (and maybe the sections id). There is no need anymore for FLAGS_RESERVED if we use NR_PAGEFLAGS. Use the new methods to make NR_PAGEFLAGS available via the preprocessor. NR_PAGEFLAGS is used to calculate field boundaries in the page flags fields. These field widths have to be available to the preprocessor. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: David Miller <davem@davemloft.net> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28page_mapping(): add ifdef around reference to swapper_spaceAndrew Morton
This fixes the superh build when the pageflags patches are applied. But it shouldn't unless it's a gcc bug. Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28sparsemem: vmemmap does not need section bitsChristoph Lameter
A set of patches that attempts to improve page flag handling. First of all a method is introduced to generate the page flag functions using macros. Then the number of page flags used by sparsemem is reduced. All page flag operations will no longer be macros. All flags will use inline function. Then we add a way to export enum constants to the preprocessor which allows us to get rid of __ZONE_COUNT and use the NR_PAGEFLAGS for the dynamic calculation of actually available page flags for fields. This patch: Sparsemem vmemmap does not need any section bits. This patch has the effect of reducing the number of bits used in page->flags by at least 6. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: remove nopageNick Piggin
Nothing in the tree uses nopage any more. Remove support for it in the core mm code and documentation (and a few stray references to it in comments). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26x86_64/mm: check and print vmemmap allocation continuousYinghai Lu
On big systems with lots of memory, don't print out too much during bootup, and make it easy to find if it is continuous. on 256G 8 sockets system will get [ffffe20000000000-ffffe20002bfffff] PMD -> [ffff810001400000-ffff810003ffffff] on node 0 [ffffe2001c700000-ffffe2001c7fffff] potential offnode page_structs [ffffe20002c00000-ffffe2001c7fffff] PMD -> [ffff81000c000000-ffff8100255fffff] on node 0 [ffffe20038700000-ffffe200387fffff] potential offnode page_structs [ffffe2001c800000-ffffe200387fffff] PMD -> [ffff810820200000-ffff81083c1fffff] on node 1 [ffffe20040000000-ffffe2007fffffff] PUD ->ffff811027a00000 on node 2 [ffffe20038800000-ffffe2003fffffff] PMD -> [ffff811020200000-ffff8110279fffff] on node 2 [ffffe20054700000-ffffe200547fffff] potential offnode page_structs [ffffe20040000000-ffffe200547fffff] PMD -> [ffff811027c00000-ffff81103c3fffff] on node 2 [ffffe20070700000-ffffe200707fffff] potential offnode page_structs [ffffe20054800000-ffffe200707fffff] PMD -> [ffff811820200000-ffff81183c1fffff] on node 3 [ffffe20080000000-ffffe200bfffffff] PUD ->ffff81202fa00000 on node 4 [ffffe20070800000-ffffe2007fffffff] PMD -> [ffff812020200000-ffff81202f9fffff] on node 4 [ffffe2008c700000-ffffe2008c7fffff] potential offnode page_structs [ffffe20080000000-ffffe2008c7fffff] PMD -> [ffff81202fc00000-ffff81203c3fffff] on node 4 [ffffe200a8700000-ffffe200a87fffff] potential offnode page_structs [ffffe2008c800000-ffffe200a87fffff] PMD -> [ffff812820200000-ffff81283c1fffff] on node 5 [ffffe200c0000000-ffffe200ffffffff] PUD ->ffff813037a00000 on node 6 [ffffe200a8800000-ffffe200bfffffff] PMD -> [ffff813020200000-ffff8130379fffff] on node 6 [ffffe200c4700000-ffffe200c47fffff] potential offnode page_structs [ffffe200c0000000-ffffe200c47fffff] PMD -> [ffff813037c00000-ffff81303c3fffff] on node 6 [ffffe200c4800000-ffffe200e07fffff] PMD -> [ffff813820200000-ffff81383c1fffff] on node 7 instead of a very long print out... Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-03-12nommu: Provide is_vmalloc_addr() stub.Paul Mundt
Introduced in commit-id 9e2779fa281cfda13ac060753d674bbcaa23367e and ifdef'ed out for nommu in 8ca3ed87db062201e1fa15b64a9214e193fc3a8a, both approaches end up breaking the nommu build in different ways. An impressive feat for a 2-liner. Current is_vmalloc_addr() users fall in to two camps: - Determining whether to use vfree()/kfree() - Whether to do vmlist traversal (only /proc/kcore). Since we don't support /proc/kcore on nommu, that leaves the vfree()/kfree() determination use cases. nommu vfree() happens to be a wrapper to kfree() anyways, so is_vmalloc_addr() can always return 0 and end up with the right behaviour. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23NOMMU: is_vmalloc_addr() won't compile if !MMUDavid Howells
Make is_vmalloc_addr() contingent on CONFIG_MMU=y, as it won't compile in !MMU mode. [ Bug introduced in commit 9e2779fa281cfda13ac060753d674bbcaa23367e: "is_vmalloc_addr(): Check if an address is within the vmalloc boundaries" ]. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-21Hibernation: Handle DEBUG_PAGEALLOC on x86Rafael J. Wysocki
Make hibernation work with CONFIG_DEBUG_PAGEALLOC set on x86, by checking if the pages to be copied are marked as present in the kernel mapping and temporarily marking them as present if that's not the case. No functional modifications are introduced if CONFIG_DEBUG_PAGEALLOC is unset. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-13include/linux: Remove all users of FASTCALL() macroHarvey Harrison
FASTCALL() is always expanded to empty, remove it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05maps4: introduce a generic page walkerMatt Mackall
Introduce a general page table walker Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05VM: allow get_page_unless_zero on compound pagesChristoph Lameter
Both slab defrag and the large blocksize patches need to ability to take refcounts on compound pages. May be useful in other places as well. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05is_vmalloc_addr(): Check if an address is within the vmalloc boundariesChristoph Lameter
Checking if an address is a vmalloc address is done in a couple of places. Define a common version in mm.h and replace the other checks. Again the include structures suck. The definition of VMALLOC_START and VMALLOC_END is not available in vmalloc.h since highmem.c cannot be included there. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05vmalloc: add const to void* parametersChristoph Lameter
Make vmalloc functions work the same way as kfree() and friends that take a const void * argument. [akpm@linux-foundation.org: fix consts, coding-style] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Move vmalloc_to_page() to mm/vmalloc.Christoph Lameter
We already have page table manipulation for vmalloc in vmalloc.c. Move the vmalloc_to_page() function there as well. Move the definitions for vmalloc related functions in mm.h to a newly created section. A better place would be vmalloc.h but mm.h is basic and may depend on these functions. An alternative would be to include vmalloc.h in mm.h (like done for vmstat.h). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30x86: do not PSE on CONFIG_DEBUG_PAGEALLOC=yIngo Molnar
get more testing of the c_p_a() code done by not turning off PSE on DEBUG_PAGEALLOC. this simplifies the early pagetable setup code, and tests the largepage-splitup code quite heavily. In the end, all the largepages will be split up pretty quickly, so there's no difference to how DEBUG_PAGEALLOC worked before. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: print which shared library/executable faulted in segfault etc. messages v3Andi Kleen
They now look like: hal-resmgr[13791]: segfault at 3c rip 2b9c8caec182 rsp 7fff1e825d30 error 4 in libacl.so.1.1.0[2b9c8caea000+6000] This makes it easier to pinpoint bugs to specific libraries. And printing the offset into a mapping also always allows to find the correct fault point in a library even with randomized mappings. Previously there was no way to actually find the correct code address inside the randomized mapping. Relies on earlier patch to shorten the printk formats. They are often now longer than 80 characters, but I think that's worth it. [includes fix from Eric Dumazet to check d_path error value] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-25Security: remove security.h include from mm.hJames Morris
Remove security.h include from mm.h, as it is only needed for a single extern declaration, and pulls in all kinds of crud. Fine-by-me: David Chinner <dgc@sgi.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-12-06Security: round mmap hint address above mmap_min_addrEric Paris
If mmap_min_addr is set and a process attempts to mmap (not fixed) with a non-null hint address less than mmap_min_addr the mapping will fail the security checks. Since this is just a hint address this patch will round such a hint address above mmap_min_addr. gcj was found to try to be very frugal with vm usage and give hint addresses in the 8k-32k range. Without this patch all such programs failed and with the patch they happily get a higher address. This patch is wrappad in CONFIG_SECURITY since mmap_min_addr doesn't exist without it and there would be no security check possible no matter what. So we should not bother compiling in this rounding if it is just a waste of time. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-10-17Drop some headers from mm.hAlexey Dobriyan
mm.h doesn't use directly anything from mutex.h and backing-dev.h, so remove them and add them back to files which need them. Cross-compile tested on many configs and archs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16mm/shmem.c: make 3 functions staticAdrian Bunk
This patch makes three needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16memory hotplug: Hot-add with sparsemem-vmemmapYasunori Goto
This patch is to avoid panic when memory hot-add is executed with sparsemem-vmemmap. Current vmemmap-sparsemem code doesn't support memory hot-add. Vmemmap must be populated when hot-add. This is for 2.6.23-rc2-mm2. Todo: # Even if this patch is applied, the message "[xxxx-xxxx] potential offnode page_structs" is displayed. To allocate memmap on its node, memmap (and pgdat) must be initialized itself like chicken and egg relationship. # vmemmap_unpopulate will be necessary for followings. - For cancel hot-add due to error. - For unplug. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@sgi.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16SLUB: Do not use page->mappingChristoph Lameter
After moving the lockless_freelist to kmem_cache_cpu we no longer need page->lockless_freelist. Restructure the use of the struct page fields in such a way that we never touch the mapping field. This is turn allows us to remove the special casing of SLUB when determining the mapping of a page (needed for corner cases of virtual caches machines that need to flush caches of processors mapping a page). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16move mm_struct and vm_area_structMartin Schwidefsky
Move the definitions of struct mm_struct and struct vma_area_struct to include/mm_types.h. This allows to define more function in asm/pgtable.h and friends with inline assemblies instead of macros. Compile tested on i386, powerpc, powerpc64, s390-32, s390-64 and x86_64. [aurelien@aurel32.net: build fix] Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16remove ZERO_PAGENick Piggin
The commit b5810039a54e5babf428e9a1e89fc1940fabff11 contains the note A last caveat: the ZERO_PAGE is now refcounted and managed with rmap (and thus mapcounted and count towards shared rss). These writes to the struct page could cause excessive cacheline bouncing on big systems. There are a number of ways this could be addressed if it is an issue. And indeed this cacheline bouncing has shown up on large SGI systems. There was a situation where an Altix system was essentially livelocked tearing down ZERO_PAGE pagetables when an HPC app aborted during startup. This situation can be avoided in userspace, but it does highlight the potential scalability problem with refcounting ZERO_PAGE, and corner cases where it can really hurt (we don't want the system to livelock!). There are several broad ways to fix this problem: 1. add back some special casing to avoid refcounting ZERO_PAGE 2. per-node or per-cpu ZERO_PAGES 3. remove the ZERO_PAGE completely I will argue for 3. The others should also fix the problem, but they result in more complex code than does 3, with little or no real benefit that I can see. Why? Inserting a ZERO_PAGE for anonymous read faults appears to be a false optimisation: if an application is performance critical, it would not be doing many read faults of new memory, or at least it could be expected to write to that memory soon afterwards. If cache or memory use is critical, it should not be working with a significant number of ZERO_PAGEs anyway (a more compact representation of zeroes should be used). As a sanity check -- mesuring on my desktop system, there are never many mappings to the ZERO_PAGE (eg. 2 or 3), thus memory usage here should not increase much without it. When running a make -j4 kernel compile on my dual core system, there are about 1,000 mappings to the ZERO_PAGE created per second, but about 1,000 ZERO_PAGE COW faults per second (less than 1 ZERO_PAGE mapping per second is torn down without being COWed). So removing ZERO_PAGE will save 1,000 page faults per second when running kbuild, while keeping it only saves less than 1 page clearing operation per second. 1 page clear is cheaper than a thousand faults, presumably, so there isn't an obvious loss. Neither the logical argument nor these basic tests give a guarantee of no regressions. However, this is a reasonable opportunity to try to remove the ZERO_PAGE from the pagefault path. If it is found to cause regressions, we can reintroduce it and just avoid refcounting it. The /dev/zero ZERO_PAGE usage and TLB tricks also get nuked. I don't see much use to them except on benchmarks. All other users of ZERO_PAGE are converted just to use ZERO_PAGE(0) for simplicity. We can look at replacing them all and maybe ripping out ZERO_PAGE completely when we are more satisfied with this solution. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus "snif" Torvalds <torvalds@linux-foundation.org>
2007-10-16readahead: remove several readahead macrosFengguang Wu
Remove VM_MAX_CACHE_HIT, MAX_RA_PAGES and MIN_RA_PAGES. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16vmemmap: generify initialisation via helpersAndy Whitcroft
Convert the common vmemmap population into initialisation helpers for use by architecture vmemmap populators. All architecture implementing the SPARSEMEM_VMEMMAP variant supply an architecture specific vmemmap_populate() initialiser, which may make use of the helpers. This allows us to clean up and remove the initialisation Kconfig entries. With this patch there is a single SPARSEMEM_VMEMMAP_ENABLE Kconfig option to indicate use of that variant. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Generic Virtual Memmap support for SPARSEMEMChristoph Lameter
SPARSEMEM is a pretty nice framework that unifies quite a bit of code over all the arches. It would be great if it could be the default so that we can get rid of various forms of DISCONTIG and other variations on memory maps. So far what has hindered this are the additional lookups that SPARSEMEM introduces for virt_to_page and page_address. This goes so far that the code to do this has to be kept in a separate function and cannot be used inline. This patch introduces a virtual memmap mode for SPARSEMEM, in which the memmap is mapped into a virtually contigious area, only the active sections are physically backed. This allows virt_to_page page_address and cohorts become simple shift/add operations. No page flag fields, no table lookups, nothing involving memory is required. The two key operations pfn_to_page and page_to_page become: #define __pfn_to_page(pfn) (vmemmap + (pfn)) #define __page_to_pfn(page) ((page) - vmemmap) By having a virtual mapping for the memmap we allow simple access without wasting physical memory. As kernel memory is typically already mapped 1:1 this introduces no additional overhead. The virtual mapping must be big enough to allow a struct page to be allocated and mapped for all valid physical pages. This vill make a virtual memmap difficult to use on 32 bit platforms that support 36 address bits. However, if there is enough virtual space available and the arch already maps its 1-1 kernel space using TLBs (f.e. true of IA64 and x86_64) then this technique makes SPARSEMEM lookups even more efficient than CONFIG_FLATMEM. FLATMEM needs to read the contents of the mem_map variable to get the start of the memmap and then add the offset to the required entry. vmemmap is a constant to which we can simply add the offset. This patch has the potential to allow us to make SPARSMEM the default (and even the only) option for most systems. It should be optimal on UP, SMP and NUMA on most platforms. Then we may even be able to remove the other memory models: FLATMEM, DISCONTIG etc. [apw@shadowen.org: config cleanups, resplit code etc] [kamezawa.hiroyu@jp.fujitsu.com: Fix sparsemem_vmemmap init] [apw@shadowen.org: vmemmap: remove excess debugging] [apw@shadowen.org: simplify initialisation code and reduce duplication] [apw@shadowen.org: pull out the vmemmap code into its own file] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22fix NULL pointer dereference in __vm_enough_memory()Alan Cox
The new exec code inserts an accounted vma into an mm struct which is not current->mm. The existing memory check code has a hard coded assumption that this does not happen as does the security code. As the correct mm is known we pass the mm to the security method and the helper function. A new security test is added for the case where we need to pass the mm and the existing one is modified to pass current->mm to avoid the need to change large amounts of code. (Thanks to Tobias for fixing rejects and testing) Signed-off-by: Alan Cox <alan@redhat.com> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Cc: James Morris <jmorris@redhat.com> Cc: Tobias Diedrich <ranma+kernel@tdiedrich.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-29Remove fs.h from mm.hAlexey Dobriyan
Remove fs.h from mm.h. For this, 1) Uninline vma_wants_writenotify(). It's pretty huge anyway. 2) Add back fs.h or less bloated headers (err.h) to files that need it. As result, on x86_64 allyesconfig, fs.h dependencies cut down from 3929 files rebuilt down to 3444 (-12.3%). Cross-compile tested without regressions on my two usual configs and (sigh): alpha arm-mx1ads mips-bigsur powerpc-ebony alpha-allnoconfig arm-neponset mips-capcella powerpc-g5 alpha-defconfig arm-netwinder mips-cobalt powerpc-holly alpha-up arm-netx mips-db1000 powerpc-iseries arm arm-ns9xxx mips-db1100 powerpc-linkstation arm-assabet arm-omap_h2_1610 mips-db1200 powerpc-lite5200 arm-at91rm9200dk arm-onearm mips-db1500 powerpc-maple arm-at91rm9200ek arm-picotux200 mips-db1550 powerpc-mpc7448_hpc2 arm-at91sam9260ek arm-pleb mips-ddb5477 powerpc-mpc8272_ads arm-at91sam9261ek arm-pnx4008 mips-decstation powerpc-mpc8313_rdb arm-at91sam9263ek arm-pxa255-idp mips-e55 powerpc-mpc832x_mds arm-at91sam9rlek arm-realview mips-emma2rh powerpc-mpc832x_rdb arm-ateb9200 arm-realview-smp mips-excite powerpc-mpc834x_itx arm-badge4 arm-rpc mips-fulong powerpc-mpc834x_itxgp arm-carmeva arm-s3c2410 mips-ip22 powerpc-mpc834x_mds arm-cerfcube arm-shannon mips-ip27 powerpc-mpc836x_mds arm-clps7500 arm-shark mips-ip32 powerpc-mpc8540_ads arm-collie arm-simpad mips-jazz powerpc-mpc8544_ds arm-corgi arm-spitz mips-jmr3927 powerpc-mpc8560_ads arm-csb337 arm-trizeps4 mips-malta powerpc-mpc8568mds arm-csb637 arm-versatile mips-mipssim powerpc-mpc85xx_cds arm-ebsa110 i386 mips-mpc30x powerpc-mpc8641_hpcn arm-edb7211 i386-allnoconfig mips-msp71xx powerpc-mpc866_ads arm-em_x270 i386-defconfig mips-ocelot powerpc-mpc885_ads arm-ep93xx i386-up mips-pb1100 powerpc-pasemi arm-footbridge ia64 mips-pb1500 powerpc-pmac32 arm-fortunet ia64-allnoconfig mips-pb1550 powerpc-ppc64 arm-h3600 ia64-bigsur mips-pnx8550-jbs powerpc-prpmc2800 arm-h7201 ia64-defconfig mips-pnx8550-stb810 powerpc-ps3 arm-h7202 ia64-gensparse mips-qemu powerpc-pseries arm-hackkit ia64-sim mips-rbhma4200 powerpc-up arm-integrator ia64-sn2 mips-rbhma4500 s390 arm-iop13xx ia64-tiger mips-rm200 s390-allnoconfig arm-iop32x ia64-up mips-sb1250-swarm s390-defconfig arm-iop33x ia64-zx1 mips-sead s390-up arm-ixp2000 m68k mips-tb0219 sparc arm-ixp23xx m68k-amiga mips-tb0226 sparc-allnoconfig arm-ixp4xx m68k-apollo mips-tb0287 sparc-defconfig arm-jornada720 m68k-atari mips-workpad sparc-up arm-kafa m68k-bvme6000 mips-wrppmc sparc64 arm-kb9202 m68k-hp300 mips-yosemite sparc64-allnoconfig arm-ks8695 m68k-mac parisc sparc64-defconfig arm-lart m68k-mvme147 parisc-allnoconfig sparc64-up arm-lpd270 m68k-mvme16x parisc-defconfig um-x86_64 arm-lpd7a400 m68k-q40 parisc-up x86_64 arm-lpd7a404 m68k-sun3 powerpc x86_64-allnoconfig arm-lubbock m68k-sun3x powerpc-cell x86_64-defconfig arm-lusl7200 mips powerpc-celleb x86_64-up arm-mainstone mips-atlas powerpc-chrp32 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26fix 'dynreloc miscount' link error on PowerpcSam Ravnborg
Nathan Lynch <ntl@pobox.com> reported: 2.6.23-rc1 breaks the build for 64-bit powerpc for me (using maple_defconfig): LD vmlinux.o powerpc64-unknown-linux-gnu-ld: dynreloc miscount for kernel/built-in.o, section .opd powerpc64-unknown-linux-gnu-ld: can not edit opd Bad value make: *** [vmlinux.o] Error 1 However, I see a possibly related binutils patch: http://article.gmane.org/gmane.comp.gnu.binutils/33650 It was tracked down to be caused by the weak prototype declaration in mm.h: __attribute__((weak)) const char *arch_vma_name(struct vm_area_struct *vma); But there is no need to make the declaration weak - only the definition needs to be marked weak. So drop the weak declaration. And in the process drop the duplicate definition in page.h for powerpc. Note: the arch_vma_name fix for x86_64 needs to be applied first to avoid breaking x86_64 Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Nathan Lynch <ntl@pobox.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: variable length argument supportOllie Wild
Remove the arg+env limit of MAX_ARG_PAGES by copying the strings directly from the old mm into the new mm. We create the new mm before the binfmt code runs, and place the new stack at the very top of the address space. Once the binfmt code runs and figures out where the stack should be, we move it downwards. It is a bit peculiar in that we have one task with two mm's, one of which is inactive. [a.p.zijlstra@chello.nl: limit stack size] Signed-off-by: Ollie Wild <aaw@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <linux-arch@vger.kernel.org> Cc: Hugh Dickins <hugh@veritas.com> [bunk@stusta.de: unexport bprm_mm_init] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: split ondemand readahead interface into two functionsRusty Russell
Split ondemand readahead interface into two functions. I think this makes it a little clearer for non-readahead experts (like Rusty). Internally they both call ondemand_readahead(), but the page argument is changed to an obvious boolean flag. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: remove the old algorithmFengguang Wu
Remove the old readahead algorithm. Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19readahead: on-demand readahead logicFengguang Wu
This is a minimal readahead algorithm that aims to replace the current one. It is more flexible and reliable, while maintaining almost the same behavior and performance. Also it is full integrated with adaptive readahead. It is designed to be called on demand: - on a missing page, to do synchronous readahead - on a lookahead page, to do asynchronous readahead In this way it eliminated the awkward workarounds for cache hit/miss, readahead thrashing, retried read, and unaligned read. It also adopts the data structure introduced by adaptive readahead, parameterizes readahead pipelining with `lookahead_index', and reduces the current/ahead windows to one single window. HEURISTICS The logic deals with four cases: - sequential-next found a consistent readahead window, so push it forward - random standalone small read, so read as is - sequential-first create a new readahead window for a sequential/oversize request - lookahead-clueless hit a lookahead page not associated with the readahead window, so create a new readahead window and ramp it up In each case, three parameters are determined: - readahead index: where the next readahead begins - readahead size: how much to readahead - lookahead size: when to do the next readahead (for pipelining) BEHAVIORS The old behaviors are maximally preserved for trivial sequential/random reads. Notable changes are: - It no longer imposes strict sequential checks. It might help some interleaved cases, and clustered random reads. It does introduce risks of a random lookahead hit triggering an unexpected readahead. But in general it is more likely to do good than to do evil. - Interleaved reads are supported in a minimal way. Their chances of being detected and proper handled are still low. - Readahead thrashings are better handled. The current readahead leads to tiny average I/O sizes, because it never turn back for the thrashed pages. They have to be fault in by do_generic_mapping_read() one by one. Whereas the on-demand readahead will redo readahead for them. OVERHEADS The new code reduced the overheads of - excessively calling the readahead routine on small sized reads (the current readahead code insists on seeing all requests) - doing a lot of pointless page-cache lookups for small cached files (the current readahead only turns itself off after 256 cache hits, unfortunately most files are < 1MB, so never see that chance) That accounts for speedup of - 0.3% on 1-page sequential reads on sparse file - 1.2% on 1-page cache hot sequential reads - 3.2% on 256-page cache hot sequential reads - 1.3% on cache hot `tar /lib` However, it does introduce one extra page-cache lookup per cache miss, which impacts random reads slightly. That's 1% overheads for 1-page random reads on sparse file. PERFORMANCE The basic benchmark setup is - 2.6.20 kernel with on-demand readahead - 1MB max readahead size - 2.9GHz Intel Core 2 CPU - 2GB memory - 160G/8M Hitachi SATA II 7200 RPM disk The benchmarks show that - it maintains the same performance for trivial sequential/random reads - sysbench/OLTP performance on MySQL gains up to 8% - performance on readahead thrashing gains up to 3 times iozone throughput (KB/s): roughly the same ========================================== iozone -c -t1 -s 4096m -r 64k 2.6.20 on-demand gain first run " Initial write " 61437.27 64521.53 +5.0% " Rewrite " 47893.02 48335.20 +0.9% " Read " 62111.84 62141.49 +0.0% " Re-read " 62242.66 62193.17 -0.1% " Reverse Read " 50031.46 49989.79 -0.1% " Stride read " 8657.61 8652.81 -0.1% " Random read " 13914.28 13898.23 -0.1% " Mixed workload " 19069.27 19033.32 -0.2% " Random write " 14849.80 14104.38 -5.0% " Pwrite " 62955.30 65701.57 +4.4% " Pread " 62209.99 62256.26 +0.1% second run " Initial write " 60810.31 66258.69 +9.0% " Rewrite " 49373.89 57833.66 +17.1% " Read " 62059.39 62251.28 +0.3% " Re-read " 62264.32 62256.82 -0.0% " Reverse Read " 49970.96 50565.72 +1.2% " Stride read " 8654.81 8638.45 -0.2% " Random read " 13901.44 13949.91 +0.3% " Mixed workload " 19041.32 19092.04 +0.3% " Random write " 14019.99 14161.72 +1.0% " Pwrite " 64121.67 68224.17 +6.4% " Pread " 62225.08 62274.28 +0.1% In summary, writes are unstable, reads are pretty close on average: access pattern 2.6.20 on-demand gain Read 62085.61 62196.38 +0.2% Re-read 62253.49 62224.99 -0.0% Reverse Read 50001.21 50277.75 +0.6% Stride read 8656.21 8645.63 -0.1% Random read 13907.86 13924.07 +0.1% Mixed workload 19055.29 19062.68 +0.0% Pread 62217.53 62265.27 +0.1% aio-stress: roughly the same ============================ aio-stress -l -s4096 -r128 -t1 -o1 knoppix511-dvd-cn.iso aio-stress -l -s4096 -r128 -t1 -o3 knoppix511-dvd-cn.iso 2.6.20 on-demand delta sequential 92.57s 92.54s -0.0% random 311.87s 312.15s +0.1% sysbench fileio: roughly the same ================================= sysbench --test=fileio --file-io-mode=async --file-test-mode=rndrw \ --file-total-size=4G --file-block-size=64K \ --num-threads=001 --max-requests=10000 --max-time=900 run threads 2.6.20 on-demand delta first run 1 59.1974s 59.2262s +0.0% 2 58.0575s 58.2269s +0.3% 4 48.0545s 47.1164s -2.0% 8 41.0684s 41.2229s +0.4% 16 35.8817s 36.4448s +1.6% 32 32.6614s 32.8240s +0.5% 64 23.7601s 24.1481s +1.6% 128 24.3719s 23.8225s -2.3% 256 23.2366s 22.0488s -5.1% second run 1 59.6720s 59.5671s -0.2% 8 41.5158s 41.9541s +1.1% 64 25.0200s 23.9634s -4.2% 256 22.5491s 20.9486s -7.1% Note that the numbers are not very stable because of the writes. The overall performance is close when we sum all seconds up: sum all up 495.046s 491.514s -0.7% sysbench oltp (trans/sec): up to 8% gain ======================================== sysbench --test=oltp --oltp-table-size=10000000 --oltp-read-only \ --mysql-socket=/var/run/mysqld/mysqld.sock \ --mysql-user=root --mysql-password=readahead \ --num-threads=064 --max-requests=10000 --max-time=900 run 10000-transactions run threads 2.6.20 on-demand gain 1 62.81 64.56 +2.8% 2 67.97 70.93 +4.4% 4 81.81 85.87 +5.0% 8 94.60 97.89 +3.5% 16 99.07 104.68 +5.7% 32 95.93 104.28 +8.7% 64 96.48 103.68 +7.5% 5000-transactions run 1 48.21 48.65 +0.9% 8 68.60 70.19 +2.3% 64 70.57 74.72 +5.9% 2000-transactions run 1 37.57 38.04 +1.3% 2 38.43 38.99 +1.5% 4 45.39 46.45 +2.3% 8 51.64 52.36 +1.4% 16 54.39 55.18 +1.5% 32 52.13 54.49 +4.5% 64 54.13 54.61 +0.9% That's interesting results. Some investigations show that - MySQL is accessing the db file non-uniformly: some parts are more hot than others - It is mostly doing 4-page random reads, and sometimes doing two reads in a row, the latter one triggers a 16-page readahead. - The on-demand readahead leaves many lookahead pages (flagged PG_readahead) there. Many of them will be hit, and trigger more readahead pages. Which might save more seeks. - Naturally, the readahead windows tend to lie in hot areas, and the lookahead pages in hot areas is more likely to be hit. - The more overall read density, the more possible gain. That also explains the adaptive readahead tricks for clustered random reads. readahead thrashing: 3 times better =================================== We boot kernel with "mem=128m single", and start a 100KB/s stream on every second, until reaching 200 streams. max throughput min avg I/O size 2.6.20: 5MB/s 16KB on-demand: 15MB/s 140KB Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Steven Pratt <slpratt@austin.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fault feedback #2Nick Piggin
This patch completes Linus's wish that the fault return codes be made into bit flags, which I agree makes everything nicer. This requires requires all handle_mm_fault callers to be modified (possibly the modifications should go further and do things like fault accounting in handle_mm_fault -- however that would be for another patch). [akpm@linux-foundation.org: fix alpha build] [akpm@linux-foundation.org: fix s390 build] [akpm@linux-foundation.org: fix sparc build] [akpm@linux-foundation.org: fix sparc64 build] [akpm@linux-foundation.org: fix ia64 build] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Still apparently needs some ARM and PPC loving - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fault feedback #1Nick Piggin
Change ->fault prototype. We now return an int, which contains VM_FAULT_xxx code in the low byte, and FAULT_RET_xxx code in the next byte. FAULT_RET_ code tells the VM whether a page was found, whether it has been locked, and potentially other things. This is not quite the way he wanted it yet, but that's changed in the next patch (which requires changes to arch code). This means we no longer set VM_CAN_INVALIDATE in the vma in order to say that a page is locked which requires filemap_nopage to go away (because we can no longer remain backward compatible without that flag), but we were going to do that anyway. struct fault_data is renamed to struct vm_fault as Linus asked. address is now a void __user * that we should firmly encourage drivers not to use without really good reason. The page is now returned via a page pointer in the vm_fault struct. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: merge populate and nopage into fault (fixes nonlinear)Nick Piggin
Nonlinear mappings are (AFAIKS) simply a virtual memory concept that encodes the virtual address -> file offset differently from linear mappings. ->populate is a layering violation because the filesystem/pagecache code should need to know anything about the virtual memory mapping. The hitch here is that the ->nopage handler didn't pass down enough information (ie. pgoff). But it is more logical to pass pgoff rather than have the ->nopage function calculate it itself anyway (because that's a similar layering violation). Having the populate handler install the pte itself is likewise a nasty thing to be doing. This patch introduces a new fault handler that replaces ->nopage and ->populate and (later) ->nopfn. Most of the old mechanism is still in place so there is a lot of duplication and nice cleanups that can be removed if everyone switches over. The rationale for doing this in the first place is that nonlinear mappings are subject to the pagefault vs invalidate/truncate race too, and it seemed stupid to duplicate the synchronisation logic rather than just consolidate the two. After this patch, MAP_NONBLOCK no longer sets up ptes for pages present in pagecache. Seems like a fringe functionality anyway. NOPAGE_REFAULT is removed. This should be implemented with ->fault, and no users have hit mainline yet. [akpm@linux-foundation.org: cleanup] [randy.dunlap@oracle.com: doc. fixes for readahead] [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19mm: fix fault vs invalidate race for linear mappingsNick Piggin
Fix the race between invalidate_inode_pages and do_no_page. Andrea Arcangeli identified a subtle race between invalidation of pages from pagecache with userspace mappings, and do_no_page. The issue is that invalidation has to shoot down all mappings to the page, before it can be discarded from the pagecache. Between shooting down ptes to a particular page, and actually dropping the struct page from the pagecache, do_no_page from any process might fault on that page and establish a new mapping to the page just before it gets discarded from the pagecache. The most common case where such invalidation is used is in file truncation. This case was catered for by doing a sort of open-coded seqlock between the file's i_size, and its truncate_count. Truncation will decrease i_size, then increment truncate_count before unmapping userspace pages; do_no_page will read truncate_count, then find the page if it is within i_size, and then check truncate_count under the page table lock and back out and retry if it had subsequently been changed (ptl will serialise against unmapping, and ensure a potentially updated truncate_count is actually visible). Complexity and documentation issues aside, the locking protocol fails in the case where we would like to invalidate pagecache inside i_size. do_no_page can come in anytime and filemap_nopage is not aware of the invalidation in progress (as it is when it is outside i_size). The end result is that dangling (->mapping == NULL) pages that appear to be from a particular file may be mapped into userspace with nonsense data. Valid mappings to the same place will see a different page. Andrea implemented two working fixes, one using a real seqlock, another using a page->flags bit. He also proposed using the page lock in do_no_page, but that was initially considered too heavyweight. However, it is not a global or per-file lock, and the page cacheline is modified in do_no_page to increment _count and _mapcount anyway, so a further modification should not be a large performance hit. Scalability is not an issue. This patch implements this latter approach. ->nopage implementations return with the page locked if it is possible for their underlying file to be invalidated (in that case, they must set a special vm_flags bit to indicate so). do_no_page only unlocks the page after setting up the mapping completely. invalidation is excluded because it holds the page lock during invalidation of each page (and ensures that the page is not mapped while holding the lock). This also allows significant simplifications in do_no_page, because we have the page locked in the right place in the pagecache from the start. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Add VM_BUG_ON in case someone uses page_mapping on a slab pageChristoph Lameter
Detect slab objects being passed to the page oriented functions of the VM. It is not sufficient to simply return NULL because the functions calling page_mapping may depend on other items of the page_struct also to be setup properly. Moreover slab object may not be properly aligned. The page oriented functions of the VM expect to operate on page aligned, page sized objects. Operations on object straddling page boundaries may only affect the objects partially which may lead to surprising results. It is better to detect eventually remaining uses and eliminate them. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17mm: clean up and kernelify shrinker registrationRusty Russell
I can never remember what the function to register to receive VM pressure is called. I have to trace down from __alloc_pages() to find it. It's called "set_shrinker()", and it needs Your Help. 1) Don't hide struct shrinker. It contains no magic. 2) Don't allocate "struct shrinker". It's not helpful. 3) Call them "register_shrinker" and "unregister_shrinker". 4) Call the function "shrink" not "shrinker". 5) Reduce the 17 lines of waffly comments to 13, but document it properly. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: David Chinner <dgc@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17handle kernelcore=: genericMel Gorman
This patch adds the kernelcore= parameter for x86. Once all patches are applied, a new command-line parameter exist and a new sysctl. This patch adds the necessary documentation. From: Yasunori Goto <y-goto@jp.fujitsu.com> When "kernelcore" boot option is specified, kernel can't boot up on ia64 because of an infinite loop. In addition, the parsing code can be handled in an architecture-independent manner. This patch uses common code to handle the kernelcore= parameter. It is only available to architectures that support arch-independent zone-sizing (i.e. define CONFIG_ARCH_POPULATES_NODE_MAP). Other architectures will ignore the boot parameter. [bunk@stusta.de: make cmdline_parse_kernelcore() static] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Create the ZONE_MOVABLE zoneMel Gorman
The following 8 patches against 2.6.20-mm2 create a zone called ZONE_MOVABLE that is only usable by allocations that specify both __GFP_HIGHMEM and __GFP_MOVABLE. This has the effect of keeping all non-movable pages within a single memory partition while allowing movable allocations to be satisfied from either partition. The patches may be applied with the list-based anti-fragmentation patches that groups pages together based on mobility. The size of the zone is determined by a kernelcore= parameter specified at boot-time. This specifies how much memory is usable by non-movable allocations and the remainder is used for ZONE_MOVABLE. Any range of pages within ZONE_MOVABLE can be released by migrating the pages or by reclaiming. When selecting a zone to take pages from for ZONE_MOVABLE, there are two things to consider. First, only memory from the highest populated zone is used for ZONE_MOVABLE. On the x86, this is probably going to be ZONE_HIGHMEM but it would be ZONE_DMA on ppc64 or possibly ZONE_DMA32 on x86_64. Second, the amount of memory usable by the kernel will be spread evenly throughout NUMA nodes where possible. If the nodes are not of equal size, the amount of memory usable by the kernel on some nodes may be greater than others. By default, the zone is not as useful for hugetlb allocations because they are pinned and non-migratable (currently at least). A sysctl is provided that allows huge pages to be allocated from that zone. This means that the huge page pool can be resized to the size of ZONE_MOVABLE during the lifetime of the system assuming that pages are not mlocked. Despite huge pages being non-movable, we do not introduce additional external fragmentation of note as huge pages are always the largest contiguous block we care about. Credit goes to Andy Whitcroft for catching a large variety of problems during review of the patches. This patch creates an additional zone, ZONE_MOVABLE. This zone is only usable by allocations which specify both __GFP_HIGHMEM and __GFP_MOVABLE. Hot-added memory continues to be placed in their existing destination as there is no mechanism to redirect them to a specific zone. [y-goto@jp.fujitsu.com: Fix section mismatch of memory hotplug related code] [akpm@linux-foundation.org: various fixes] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Remove capability.h from mm.hAlexey Dobriyan
I forgot to remove capability.h from mm.h while removing sched.h! This patch remedies that, because the only inline function which was using CAP_something was made out of line. Cross-compile tested without regressions on: all powerpc defconfigs all mips defconfigs all m68k defconfigs all arm defconfigs all ia64 defconfigs alpha alpha-allnoconfig alpha-defconfig alpha-up arm i386 i386-allnoconfig i386-defconfig i386-up ia64 ia64-allnoconfig ia64-defconfig ia64-up m68k mips parisc parisc-allnoconfig parisc-defconfig parisc-up powerpc powerpc-up s390 s390-allnoconfig s390-defconfig s390-up sparc sparc-allnoconfig sparc-defconfig sparc-up sparc64 sparc64-allnoconfig sparc64-defconfig sparc64-up um-x86_64 x86_64 x86_64-allnoconfig x86_64-defconfig x86_64-up as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
