The JEDEC MMC v4 spec defines a new PRV value in place of the original
fwrev and hwrev specified in v1. We can expose this in the kernel to enable
user space to more easily determine the product revision of a given MMC.
Signed-off-by: Bernie Thompson <bhthompson@chromium.org>
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
This patch supports packed write command of eMMC4.5 devices. Several
writes can be grouped in packed command and all data of the individual
commands can be sent in a single transfer on the bus. Large amounts of
data in one transfer rather than several data of small size are
effective for eMMC write internally. As a result, packed command help
write throughput be improved. The following tables show the results
of packed write.
Type A:
test none | packed
iozone 25.8 | 31
tiotest 27.6 | 31.2
lmdd 31.2 | 35.4
Type B:
test none | packed
iozone 44.1 | 51.1
tiotest 47.9 | 52.5
lmdd 51.6 | 59.2
Type C:
test none | packed
iozone 19.5 | 32
tiotest 19.9 | 34.5
lmdd 22.8 | 40.7
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
Reviewed-by: Maya Erez <merez@codeaurora.org>
Reviewed-by: Namjae Jeon <linkinjeon@gmail.com>
This patch adds packed command feature of eMMC4.5. The maximum number
for packing read (or write) is offered and exception event relevant to
packed command which is used for error handling is enabled. If host
wants to use this feature, MMC_CAP2_PACKED_CMD should be set.
Reviewed-by: Subhash Jadavani <subhashj@codeaurora.org>
The right value is 54 according to eMMC 4.5 specification.
Signed-off-by: ZhangYi <yix.x.zhang@intel.com>
When current request is running on the bus and if next request fetched
by mmcqd is NULL, mmc context (mmcqd thread) gets blocked until the
current request completes. This means that if new request comes in while
the mmcqd thread is blocked, this new request can not be prepared in
parallel to current ongoing request. This may result in delaying the new
request execution and increase it's latency.
This change allows to wake up the MMC thread on new request arrival.
Now once the MMC thread is woken up, a new request can be fetched and
prepared in parallel to the current running request which means this new
request can be started immediately after the current running request
completes.
With this change read throughput is improved by 16%.
Signed-off-by: Konstantin Dorfman <kdorfman@codeaurora.org>
Reviewed-by: Seungwon Jeon <tgih.jun@samsung.com>
Following JEDEC standard, if the mmc supports RPMB partition,
a new interface is created and exposed via /dev/block.
Users will be able to access RPMB partition using standard
mmc IOCTL commands.
Signed-off-by: Alex Macro <alex.macro@stericsson.com>
Signed-off-by: Loic Pallardy <loic.pallardy@stericsson.com>
Acked-by: Johan Rudholm <johan.rudholm@stericsson.com>
Acked-by: Krishna Konda <kkonda@codeaurora.org>
This patch fixes up the broken suspend sequence for eMMC with sleep
support. Additionally it reworks the eMMC4.5 Power Off Notification
feature so it fits together with the existing sleep feature.
The CMD0 based re-initialization of the eMMC at resume is re-introduced
to maintain compatiblity for devices using sleep.
A host shall use MMC_CAP2_POWEROFF_NOTIFY to enable the Power Off
Notification feature. We might be able to remove this cap later on,
if we think that Power Off Notification always is preferred over
sleep, even if the host is not able to cut the eMMC VCCQ power.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Signed-off-by: Saugata Das <saugata.das@linaro.org>
Enable eMMC background operations (BKOPS) feature.
If URGENT_BKOPS is set after a response, note that BKOPS are required.
Immediately run BKOPS if required. Read/write operations should be
requested during BKOPS(LEVEL-1), then issue HPI to interrupt the
ongoing BKOPS and service the foreground operation.
(This patch only controls the LEVEL2/3.)
When repeating the writing 1GB data, at a certain time, performance is
decreased. At that time, card triggers the Level-3 or Level-2. After
running bkops, performance is recovered.
Future considerations:
* Check BKOPS_LEVEL=1 and start BKOPS in a preventive manner.
* Interrupt ongoing BKOPS before powering off the card.
* How do we get BKOPS_STATUS value (periodically send ext_csd command)?
* If using periodic bkops, also consider runtime_pm control.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
For several MoviNAND eMMC parts, there are known issues with secure
erase and secure trim. For these specific MoviNAND devices, we skip
these operations.
Specifically, there is a bug in the eMMC firmware that causes
unrecoverable corruption when the MMC is erased with MMC_CAP_ERASE
enabled.
References:
http://forum.xda-developers.com/showthread.php?t=1644364
https://plus.google.com/111398485184813224730/posts/21pTYfTsCkB#111398485184813224730/posts/21pTYfTsCkB
Signed-off-by: Ian Chen <ian.cy.chen@samsung.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Cc: stable <stable@vger.kernel.org> [3.0+]
max_current_caps can return 0 if not available from the sd controller.
If no regulator is present or the regulator specifies a current
less then 200ma, we no longer still set the 200mA caps bit anyway.
Signed-off-by: Philip Rakity <prakity@marvell.com>
Reviewed-by: Aaron Lu <aaron_lu@amd.com>
Current implementation decides the card type exclusively. Even though
eMMC device can support both HS200 and DDR mode, card type will be
set only for HS200. If the host doesn't support HS200 but has DDR
capability, then DDR mode can't be selected.
MMC bus is using legacy suspend/resume method, which is not compatible if
runtime pm callbacks are used. In this scenario, MMC bus suspend/resume
callbacks cannot be called when system entering S3. So change to use the
new defined dev_pm_ops for system sleeping mode.
Tested on AM335x Platform. Solves major issue/crash reported at
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg65425.html
Signed-off-by: Chuanxiao Dong <chuanxiao.dong@intel.com>
Tested-by: Hebbar, Gururaja <gururaja.hebbar@ti.com>
Acked-by: Ulf Hansson <ulf.hansson@stericsson.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
Core:
* Support for MMC 4.5 Data Tag feature -- we tag REQ_META, so devices
that support Data Tag will provide increased throughput for metadata.
* Faster detection of card removal on I/O errors.
Drivers:
* dw_mmc now supports eMMC Power Off Notify, has PCI support, and
implements pre_req and post_req for asynchronous requests.
* omap_hsmmc now supports device tree.
* esdhc now has power management support.
* sdhci-tegra now supports Tegra30 devices.
* sdhci-spear now supports hibernation.
* tmio_mmc now supports using a GPIO for card detection.
* Intel PCH now supports 8-bit bus transfers.
* tag 'mmc-merge-for-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (53 commits)
mmc: sh_mmcif: simplify bitmask macros
mmc: sh_mobile_sdhi: support modular mmc-core with non-standard hotplug
mmc: sh_mobile_sdhi: add a callback for board specific init code
mmc: tmio: cosmetic: prettify the tmio_mmc_set_ios() function
mmc: sh_mobile_sdhi: do not manage PM clocks manually
mmc: tmio_mmc: remove unused sdio_irq_enabled flag
mmc: tmio_mmc: power status flag doesn't have to be exposed in platform data
mmc: sh_mobile_sdhi: pass card hotplug GPIO number to TMIO MMC
mmc: tmio_mmc: support the generic MMC GPIO card hotplug helper
mmc: tmio: calculate the native hotplug condition only once
mmc: simplify mmc_cd_gpio_request() by removing two parameters
mmc: sdhci-pci: allow 8-bit bus width for Intel PCH
mmc: sdhci: check interrupt flags in ISR again
mmc: sdhci-pci: Add MSI support
mmc: core: warn when card doesn't support HPI
mmc: davinci: Poll status for small size transfers
mmc: davinci: Eliminate spurious interrupts
mmc: omap_hsmmc: Avoid a regulator voltage change with dt
mmc: omap_hsmmc: Convert hsmmc driver to use device tree
mmc: sdhci-pci: add SDHCI_QUIRK2_HOST_OFF_CARD_ON for Medfield SDIO
MMC-4.5 data tag feature will be used to store the file system meta-data
in the tagged region of eMMC. This will improve the write and subsequent
read transfer time for the meta data.
Tested-by: Venkatraman S <svenkatr@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/device.h> avoidance patches from Paul Gortmaker:
"Nearly every subsystem has some kind of header with a proto like:
void foo(struct device *dev);
and yet there is no reason for most of these guys to care about the
sub fields within the device struct. This allows us to significantly
reduce the scope of headers including headers. For this instance, a
reduction of about 40% is achieved by replacing the include with the
simple fact that the device is some kind of a struct.
Unlike the much larger module.h cleanup, this one is simply two
commits. One to fix the implicit <linux/device.h> users, and then one
to delete the device.h includes from the linux/include/ dir wherever
possible."
* tag 'device-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
device.h: audit and cleanup users in main include dir
device.h: cleanup users outside of linux/include (C files)
The <linux/device.h> header includes a lot of stuff, and
it in turn gets a lot of use just for the basic "struct device"
which appears so often.
Clean up the users as follows:
1) For those headers only needing "struct device" as a pointer
in fcn args, replace the include with exactly that.
2) For headers not really using anything from device.h, simply
delete the include altogether.
3) For headers relying on getting device.h implicitly before
being included themselves, now explicitly include device.h
4) For files in which doing #1 or #2 uncovers an implicit
dependency on some other header, fix by explicitly adding
the required header(s).
Any C files that were implicitly relying on device.h to be
present have already been dealt with in advance.
Total removals from #1 and #2: 51. Total additions coming
from #3: 9. Total other implicit dependencies from #4: 7.
As of 3.3-rc1, there were 110, so a net removal of 42 gives
about a 38% reduction in device.h presence in include/*
Modified the mmc_poweroff to resume before sending the poweroff
notification command. In sleep mode only AWAKE and RESET commands are
allowed, so before sending the poweroff notification command resume from
sleep mode and then send the notification command.
PowerOff Notify is tested on a Synopsis Designware Host Controller
(eMMC 4.5). The suspend to RAM and resume works fine.
Signed-off-by: Girish K S <girish.shivananjappa@linaro.org>
Tested-by: Girish K S <girish.shivananjappa@linaro.org>
Reviewed-by: Saugata Das <saugata.das@linaro.org>
This patch adds the support of the HS200 bus speed for eMMC 4.5 devices.
The eMMC 4.5 devices have support for 200MHz bus speed. The function
prototype of the tuning function is modified to handle the tuning
command number which is different in sd and mmc case.
Enable boot partitions to be read-only locked until next power on via
a sysfs entry. There will be one sysfs entry for each boot partition:
/sys/block/mmcblkXbootY/ro_lock_until_next_power_on
Each boot partition is locked by writing 1 to its file.
Signed-off-by: Johan Rudholm <johan.rudholm@stericsson.com>
Signed-off-by: John Beckett <john.beckett@stericsson.com>
Add a function mmc_detect_card_removed() which upper layers can use to
determine immediately if a card has been removed. This function should
be called after an I/O request fails so that all queued I/O requests
can be errored out immediately instead of waiting for the card device
to be removed.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Acked-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
This patch adds support for sdio UHS cards per the version 3.0
spec.
UHS mode is only enabled for version 3.0 cards when both the
host and the controller support UHS modes.
1.8v signaling support is removed if both the card and the
host do not support UHS. This is done to maintain
compatibility and some system/card combinations break when
1.8v signaling is enabled when the host does not support UHS.
Signed-off-by: Aaron Lu <Aaron.lu@amd.com>
Reviewed-by: Arindam Nath <arindam.nath@amd.com>
Tested-by: Bing Zhao <bzhao@marvell.com>
Add new macros for the high speed 50MHz case, rather than having
a confusing reuse of the value for UHS SDR50, which is 100MHz.
Reported-by: Aaron Lu <aaron.lu@amd.com>
Adds a quirk that sets the data read timeout to a fixed value instead
of relying on the information in the CSD. The timeout value chosen
is 300ms since that has proven enough for the problematic cards found,
but could be increased if other cards require this.
This patch also enables this quirk for certain Micron cards known to
have this problem.
Signed-off-by: Stefan Nilsson XK <stefan.xk.nilsson@stericsson.com>
Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com>
Cc: <stable@kernel.org>
'DISK_NAME_LEN' is undeclared when CONFIG_BLOCK is disabled; its use was
introduced via genhd.h by the general purpose partition patch.
To fix, we just add our own MAX_MMC_PART_NAME_LEN macro instead of using
DISK_NAME_LEN.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Namjae Jeon <linkinjeon@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Andrei Warkentin <andreiw@vmware.com>
HPI command is defined in eMMC4.41.
This feature is important for eMMC4.5 devices.
This patch adds cache feature of eMMC4.5 Spec.
If device supports cache capability, host can utilize some specific
operations.
MMC v4.5 supports the DISCARD feature (CMD38). It's different from
trim and there's no check bit. Currently it's only supported at v4.5.
This patch adds support for the power off notify feature, available in
eMMC 4.5 devices. If the host has support for this feature, then the
mmc core will notify the device by setting the POWER_OFF_NOTIFICATION
byte in the extended csd register with a value of 1 (POWER_ON).
For suspend mode short timeout is used, whereas for the normal poweroff
long timeout is used.
EXT_CSD[248] includes the default maximum timeout for CMD6.
This field is added at eMMC4.5 Spec. And it can be used for default
timeout except for some operations which don't define the timeout
(i.e. background operation, sanitize, flush cache) in eMMC4.5 Spec.
It allows gerneral purpose partitions in MMC Device. And I try to simply
make mmc_blk_alloc_parts using mmc_part structure suggested by Andrei
Warkentin. After patching, we see general purpose partitions like this:
> cat /proc/partitions
179 0 847872 mmcblk0
179 192 4096 mmcblk0gp3
179 160 4096 mmcblk0gp2
179 128 4096 mmcblk0gp1
179 96 1052672 mmcblk0gp0
179 64 1024 mmcblk0boot1
179 32 1024 mmcblk0boot0
Acked-by: Andrei Warkentin <awarkentin@vmware.com>
eMMC's may have a hardware reset line. This patch provides a
host controller operation to implement hardware reset and
a function to reset and reinitialize the card. Also, for MMC,
the reset is always performed before initialization.
The host must set the new host capability MMC_CAP_HW_RESET
to enable hardware reset.
Adds a quirk which can be turned on for SDIO devices that do not support
512 byte requests in byte mode during CMD53. These requests will always
be sent in block mode instead.
This patch also enables this quirk for ST-Ericsson CW1200 WLAN device.
Signed-off-by: Ulf HANSSON <ulf.hansson@stericsson.com>
Standardize the checks for multiple MMC header file inclusion,
including adding comments to terminating #endif's, and fixing
one incorrect comment.
On reading the ext_csd for the first time (in 1 bit mode), save the
ext_csd information needed for bus width compare.
On every pass we make re-reading the ext_csd, compare the data
against the saved ext_csd data.
This fixes a regression introduced in 3.0-rc1 by 08ee80cc397ac1a3
("mmc: core: eMMC bus width may not work on all platforms"), which
incorrectly assumed we would be re-reading the ext_csd at resume-
time.
Tested-by: Jaehoon Chung <jh80.chung@samsung.com>
SD cards operating at UHS104 or better support SET_BLOCK_COUNT.
Signed-off-by: Andrei Warkentin <andreiw@motorola.com>
CMD23-prefixed instead of open-ended multiblock transfers
have a performance advantage on some MMC cards.
Conditional add/remove quirks for MMC and SD.
If there is only 1 function interrupt registered it is possible to
improve performance by directly calling the irq handler and avoiding
the overhead of reading the CCCR registers.
Signed-off-by: Per Forlin <per.forlin@linaro.org>
Reviewed-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Since only UHS-I cards respond with S18A set in response to ACMD41,
we set the card as ultra-high-speed after successfull initialization.
We need to decide whether a card is SDXC based on the C_SIZE field
of CSDv2.0 register. According to Physical Layer spec v3.01, the
minimum value of C_SIZE for SDXC card is 00FFFFh.
Tested by Zhangfei Gao with a Toshiba uhs card and general hs card,
on mmp2 in SDMA mode.
Signed-off-by: Arindam Nath <arindam.nath@amd.com>
Reviewed-by: Philip Rakity <prakity@marvell.com>
Tested-by: Philip Rakity <prakity@marvell.com>
Acked-by: Zhangfei Gao <zhangfei.gao@marvell.com>
We decide on the current limit to be set for the card based on the
Capability of Host Controller to provide current at 1.8V signalling,
and the maximum current limit of the card as indicated by CMD6
mode 0. We then set the current limit for the card using CMD6 mode 1.
As per the Physical Layer Spec v3.01, the current limit switch is
only applicable for SDR50, SDR104, and DDR50 bus speed modes. For
other UHS-I modes, we set the default current limit of 200mA.
This patch adds support for setting UHS-I bus speed mode during UHS-I
initialization procedure. Since both the host and card can support
more than one bus speed, we select the highest speed based on both of
their capabilities. First we set the bus speed mode for the card using
CMD6 mode 1, and then we program the host controller to support the
required speed mode. We also set High Speed Enable in case one of the
UHS-I modes is selected. We take care to reset SD clock before setting
UHS mode in the Host Control2 register, and then re-enable it as per
the Host Controller spec v3.00. We then set the clock frequency for
the UHS-I mode selected.
This patch adds support for setting driver strength during UHS-I
initialization procedure. Since UHS-I cards set S18A (bit 24) in
response to ACMD41, we use this as a base for UHS-I initialization.
We modify the parameter list of mmc_sd_get_cid() so that we can
save the ROCR from ACMD41 to check whether bit 24 is set.
We decide whether the Host Controller supports A, C, or D driver
type depending on the Capabilities register. Driver type B is
suported by default. We then set the appropriate driver type for
the card using CMD6 mode 1. As per Host Controller spec v3.00, we
set driver type for the host only if Preset Value Enable in the
Host Control2 register is not set. SDHCI_HOST_CONTROL has been
renamed to SDHCI_HOST_CONTROL1 to conform to the spec.
SD cards which conform to Physical Layer Spec v3.01 can support
additional Bus Speed Modes, Driver Strength, and Current Limit
other than the default values. We use CMD6 mode 0 to read these
additional card functions. The values read here will be used
during UHS-I initialization steps.
CMD38 argument is passed through EXT_CSD[113].
Allows device MMC boot partitions to be accessed. MMC partitions are
treated effectively as separate block devices on the same MMC card.
Fix data truncation warnings: .manfid is not unsigned long:
drivers/mmc/core/quirks.c:36: warning: large integer implicitly truncated to unsigned type
drivers/mmc/core/quirks.c:40: warning: large integer implicitly truncated to unsigned type
drivers/mmc/core/quirks.c:43: warning: large integer implicitly truncated to unsigned type
drivers/mmc/core/quirks.c:46: warning: large integer implicitly truncated to unsigned type
The current mechanism is SDIO-only. This allows us to create
function-specific quirks, without creating messy Kconfig dependencies,
or polluting core/ with function-specific code.
006ebd5d introduced sdio_disable_cd(), which disconnects the pull-up
resistor on CD/DAT[3] (pin 1) of the card.
Make it possible to start using sdio_disable_cd() by introducing
MMC_QUIRK_DISABLE_CD.
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Introduce MMC_QUIRK_NONSTD_FUNC_IF to ignore the "SDIO Standard Function
interface code" as indicated by the card's FBR, and instead treat all
functions as non-standard interfaces.
This is required to prevent standard drivers from facing
errors when trying to communicate with SDIO cards that erroneously
indicate standard function interface codes.
Allows reliable writes to be used for MMC writes. Reliable writes are used
to service write REQ_FUA/REQ_META requests. Handles both the legacy and
the enhanced reliable write support in MMC cards.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
