HPI command is defined in eMMC4.41.
This feature is important for eMMC4.5 devices.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
This patch adds cache feature of eMMC4.5 Spec.
If device supports cache capability, host can utilize some specific
operations.
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
In the v4.5, there's no secure erase & trim support.
Instead it supports the sanitize feature.
This patch adds support for the power off notify feature, available in
eMMC 4.5 devices. If the host has support for this feature, then the
mmc core will notify the device by setting the POWER_OFF_NOTIFICATION
byte in the extended csd register with a value of 1 (POWER_ON).
For suspend mode short timeout is used, whereas for the normal poweroff
long timeout is used.
Signed-off-by: Girish K S <girish.shivananjappa@linaro.org>
EXT_CSD[248] includes the default maximum timeout for CMD6.
This field is added at eMMC4.5 Spec. And it can be used for default
timeout except for some operations which don't define the timeout
(i.e. background operation, sanitize, flush cache) in eMMC4.5 Spec.
It allows gerneral purpose partitions in MMC Device. And I try to simply
make mmc_blk_alloc_parts using mmc_part structure suggested by Andrei
Warkentin. After patching, we see general purpose partitions like this:
> cat /proc/partitions
179 0 847872 mmcblk0
179 192 4096 mmcblk0gp3
179 160 4096 mmcblk0gp2
179 128 4096 mmcblk0gp1
179 96 1052672 mmcblk0gp0
179 64 1024 mmcblk0boot1
179 32 1024 mmcblk0boot0
Signed-off-by: Namjae Jeon <linkinjeon@gmail.com>
Acked-by: Andrei Warkentin <awarkentin@vmware.com>
This patch adds the power class selection feature available for mmc
versions 4.0 and above. During the enumeration stage before switching
to the lower data bus, check if the power class is supported for the
current bus width. If the power class is available then switch to the
power class and use the higher data bus. If power class is not supported
then switch to the lower data bus in a worst case.
eMMC's may have a hardware reset line. This patch provides a
host controller operation to implement hardware reset and
a function to reset and reinitialize the card. Also, for MMC,
the reset is always performed before initialization.
The host must set the new host capability MMC_CAP_HW_RESET
to enable hardware reset.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
If the MMC_SEND_STATUS command is not successful, we should not return
a zero status word, but instead allow the caller to know positively
that an error occurred.
Convert the open-coded get_card_status() to use the helper function,
and provide definitions for the card state field.
Tested-by: Pawel Moll <pawel.moll@arm.com>
Standardize the checks for multiple MMC header file inclusion,
including adding comments to terminating #endif's, and fixing
one incorrect comment.
CMD23-prefixed instead of open-ended multiblock transfers
have a performance advantage on some MMC cards.
Signed-off-by: Andrei Warkentin <andreiw@motorola.com>
Host Controller needs tuning during initialization to operate SDR50
and SDR104 UHS-I cards. Whether SDR50 mode actually needs tuning is
indicated by bit 45 of the Host Controller Capabilities register.
A new command CMD19 has been defined in the Physical Layer spec
v3.01 to request the card to send tuning pattern.
We enable Buffer Read Ready interrupt at the very begining of tuning
procedure, because that is the only interrupt generated by the Host
Controller during tuning. We program the block size to 64 in the
Block Size register. We make sure that DMA Enable and Multi Block
Select in the Transfer Mode register are set to 0 before actually
sending CMD19. The tuning block is sent by the card to the Host
Controller using DAT lines, so we set Data Present Select (bit 5) in
the Command register. The Host Controller is responsible for doing
the verfication of tuning block sent by the card at the hardware
level. After sending CMD19, we wait for Buffer Read Ready interrupt.
In case we don't receive an interrupt after the specified timeout
value, we fall back on fixed sampling clock by setting Execute
Tuning (bit 6) and Sampling Clock Select (bit 7) of Host Control2
register to 0. Before exiting the tuning procedure, we disable Buffer
Read Ready interrupt and re-enable other interrupts.
Tested by Zhangfei Gao with a Toshiba uhs card and general hs card,
on mmp2 in SDMA mode.
Signed-off-by: Arindam Nath <arindam.nath@amd.com>
Reviewed-by: Philip Rakity <prakity@marvell.com>
Tested-by: Philip Rakity <prakity@marvell.com>
Acked-by: Zhangfei Gao <zhangfei.gao@marvell.com>
Allows device MMC boot partitions to be accessed. MMC partitions are
treated effectively as separate block devices on the same MMC card.
Allows reliable writes to be used for MMC writes. Reliable writes are used
to service write REQ_FUA/REQ_META requests. Handles both the legacy and
the enhanced reliable write support in MMC cards.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
uBoot sometimes leaves eMMC pointing to the private boot partition.
Ensure we always start looking at the user partition.
Signed-off-by: Philip Rakity <prakity@marvell.com>
Signed-off-by: Bruce Clemens <bpclemens@marvell.com>
Signed-off-by: Mark F. Brown <markb@marvell.com>
Enhanced area feature is a new feature defined in eMMC4.4 standard. This
user data area provides higher performance/reliability, at the expense
of using twice the effective media space due to the area using SLC.
The MMC driver now reads out the enhanced area offset and size and adds
them to the device attributes in sysfs. Enabling the enhanced area can
only be done once, and should be done in manufacturing. To use this
feature, bit ERASE_GRP_DEF should also be set.
Documentation/ABI/testing/sysfs-devices-mmc describes the two new
attributes.
Signed-off-by: Chuanxiao Dong <chuanxiao.dong@intel.com>
Reviewed-by: Chris Ball <cjb@laptop.org>
Some old MMC devices fail with the 4/8 bits the driver tries to use
exclusively. This patch adds a test for the given bus setup and falls
back to the lower bit mode (until 1-bit mode) when the test fails.
[Major rework and refactoring by tiwai]
[Quirk addition and many fixes by prakity]
Signed-off-by: Aries Lee <arieslee@jmicron.com>
Add support for Dual Data Rate MMC cards as defined in the 4.4
specification.
Signed-off-by: Hanumath Prasad <hanumath.prasad@stericsson.com>
Cc: linux-mmc@vger.kernel.org
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Tested-by Zhangfei Gao <zhangfei.gao@marvell.com>
SD/MMC cards tend to support an erase operation. In addition, eMMC v4.4
cards can support secure erase, trim and secure trim operations that are
all variants of the basic erase command.
SD/MMC device attributes "erase_size" and "preferred_erase_size" have been
added.
"erase_size" is the minimum size, in bytes, of an erase operation. For
MMC, "erase_size" is the erase group size reported by the card. Note that
"erase_size" does not apply to trim or secure trim operations where the
minimum size is always one 512 byte sector. For SD, "erase_size" is 512
if the card is block-addressed, 0 otherwise.
SD/MMC cards can erase an arbitrarily large area up to and
including the whole card. When erasing a large area it may
be desirable to do it in smaller chunks for three reasons:
1. A single erase command will make all other I/O on the card
wait. This is not a problem if the whole card is being erased, but
erasing one partition will make I/O for another partition on the
same card wait for the duration of the erase - which could be a
several minutes.
2. To be able to inform the user of erase progress.
3. The erase timeout becomes too large to be very useful.
Because the erase timeout contains a margin which is multiplied by
the size of the erase area, the value can end up being several
minutes for large areas.
"erase_size" is not the most efficient unit to erase (especially for SD
where it is just one sector), hence "preferred_erase_size" provides a good
chunk size for erasing large areas.
For MMC, "preferred_erase_size" is the high-capacity erase size if a card
specifies one, otherwise it is based on the capacity of the card.
For SD, "preferred_erase_size" is the allocation unit size specified by
the card.
"preferred_erase_size" is in bytes.
Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com>
Acked-by: Jens Axboe <axboe@kernel.dk>
Cc: Kyungmin Park <kmpark@infradead.org>
Cc: Madhusudhan Chikkature <madhu.cr@ti.com>
Cc: Ben Gardiner <bengardiner@nanometrics.ca>
Cc: <linux-mmc@vger.kernel.org>
The eMMC spec 4.4 and 4.3 + additional feature chips has CSD structure
version 3 and version 3 have to check the CSD_STRUCTURE byte in the
EXT_CSD register.
Also fix EXT_CSD revision message.
[akpm@linux-foundation.org: fix comment, per Chris Ball]
Cc: Adrian Hunter <adrian.hunter@nokia.com>
Cc: Chris Ball <cjb@laptop.org>
In the extended CSD register the CARD_TYPE is an 8-bit value of which the
upper 6 bits were reserved in JEDEC specifications prior to version 4.4.
In version 4.4 two of the reserved bits were designated for identifying
support for the newly added High-Speed Dual Data Rate. Unfortunately the
mmc_read_ext_csd() function required that the reserved bits be zero
instead of ignoring them as it should.
This patch makes mmc_read_ext_csd() ignore the CARD_TYPE bits that are
reserved or not yet supported. It also stops the function jumping to the
end as though an error occurred, when it is only warns that the CARD_TYPE
bits (that it does interpret) are invalid.
According to the standard, the SWITCH command should be followed by a
SEND_STATUS command to check for errors.
Acked-by: Matt Fleming <matt@console-pimps.org>
Cc: Ian Molton <ian@mnementh.co.uk>
Cc: "Roberto A. Foglietta" <roberto.foglietta@gmail.com>
Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com>
Cc: Denis Karpov <ext-denis.2.karpov@nokia.com>
Cc: Pierre Ossman <pierre@ossman.eu>
Cc: Philip Langdale <philipl@overt.org>
Cc: "Madhusudhan" <madhu.cr@ti.com>
Add support for the new MMC command SLEEP_AWAKE.
Signed-off-by: Jarkko Lavinen <jarkko.lavinen@nokia.com>
This patch removes a CVS tag that wasn't updated for a long time.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
Teach the MMC/SD/SDIO system headers that some hosts use SPI mode
- New host capabilities and status bits
* MMC_CAP_SPI, with mmc_host_is_spi() test
* mmc_host.use_spi_crc flag
- SPI-specific declarations:
* Response types, MMC_RSP_SPI_R*
* Two SPI-only commands
* Status bits used native to SPI: R1_SPI_*, R2_SPI_*
- Fix a few (unrelated) whitespace bugs in the headers.
- Reorder a few mmc_host fields, removing several bytes of padding
None of these changes affect current code.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Make sure we do not try to parse a structure we do not
understand.
Move protocol operations and definitions into their own files
in an effort to separate protocol handling and bus
arbitration more clearly.
Create a "core" subdirectory to house the central bus handling
functions.
The classic MMC bus was defined as multi card bus
system, which is reflected in the design in the MMC
layer.
When SD showed up, the bus topology was abandoned
and a star topology (one card per host) was mandated.
MMC version 4 has followed this, officially deprecating
the bus topology.
As we do not have any known users of the bus
topology we can remove support for it. This will
simplify the code and rectify some incorrect
assumptions in the newer additions.
Thanks to the generous donation of an SDHC card by John Gilmore, and
the surprisingly enlightened decision by the SD Card Association to
publish useful specs, I've been able to bash out support for SDHC. The
changes are not too profound:
i) Add a card flag indicating the card uses block level addressing and
check it in the block driver. As we never took advantage of byte-level
addressing, this simply involves skipping the block -> byte
translation when sending commands.
ii) The layout of the CSD is changed - a set of fields are discarded
to make space for a larger C_SIZE. We did not reference any of the
discarded fields except those related to the C_SIZE.
iii) Read and write timeouts are fixed values and not calculated from
CSD values.
iv) Before invoking SEND_APP_OP_COND, we must invoke the new
SEND_IF_COND to inform the card we support SDHC.
Signed-off-by: Philipl Langdale <philipl@overt.org>
During development of SDHC support, it was discovered that the definition
for R6 was incorrect. This patch fixes that and patches the drivers that
do switch on the response type.
Signed-off-by: Philip Langdale <philipl@overt.org>
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Pavel Pisa <ppisa@pikron.com>
data->blksz_bits is unused now - remove it.
Rather than having two places which independently calculate the
timeout for data transfers, make it a library function instead.
Acked-by: Pierre Ossman <drzeus@drzeus.cx>
command and cleanups
Patch from Pavel Pisa
There has been problems that for some paths that clock are not stopped
during new command programming and initiation. Result is issuing
of incorrect command to the card. Some other problems are cleaned too.
Noisy report of known ERRATUM #4 has been suppressed.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
It's MMC_CMD_MASK not MMC_CMD_TYPE.
Some hosts need to know the command type, so pass it via a set of
flags in cmd->flags.
Some controllers actually check the first byte of the response (most
don't). This byte contains the command opcode for R1/R1b and all 1:s
for other types. The difference must be indicated to the controller
so it knows which reply to expect.
Some hosts need to know that a transfer will be multi-block.
Add a data flag to indicate multiple data block transfers.
Patch from Erik Hovland
I noticed that the same typo (i before c in associated) showed up twice
in the file kernel/include/linux/mmc/mmc.h.
This patch fixes both of the instances I found with this mistake. The
typos are in comments and should have no affect on working code.
E
Signed-off-by: Erik Hovland <erik@hovland.org>
Support for the Secure Digital protocol in the MMC layer.
A summary of the legal issues surrounding SD cards, as understood by yours
truly:
Members of the Secure Digital Association, hereafter SDA, are required to sign
a NDA[1] before given access to any specifications. It has been speculated
that including an SD implementation would forbid these members to redistribute
Linux. This is the basic problem with SD support so it is unclear if it even
is a problem since it has no effect on those of us that aren't members.
The SDA doesn't seem to enforce these rules though since the patches included
here are based on documentation made public by some of the members. The most
complete specs[2] are actually released by Sandisk, one of the founding
companies of the SDA.
Because of this the NDA is considered a non-issue by most involved in the
discussions concerning these patches. It might be that the SDA is only
interested in protecting the so called "secure" bits of SD, which so far
hasn't been found in any public spec. (The card is split into two sections,
one "normal" and one "secure" which has an access scheme similar to TPM:s).
(As a side note, Microsoft is working to make things easier for us since they
want to be able to include the source code for a SD driver in one of their
development kits. HP is making sure that the new NDA will allow a Linux
implementation. So far only the SDIO specs have been opened up[3]. More will
hopefully follow.)
[1] http://www.sdcard.org/membership/images/ippolicy.pdf
[2] http://www.sandisk.com/pdf/oem/ProdManualSDCardv1.9.pdf
[3] http://www.sdcard.org/sdio/Simplified%20SDIO%20Card%20Specification.pdf
This patch contains the central parts of the SD support. If no MMC cards are
found on a bus then the MMC layer proceeds looking for SD cards. Helper
functions are extended to handle the special needs of SD cards.
Cc: David Brownell <david-b@pacbell.net>
infrastructure for it.
Let it rip!
