path: root/include/linux/mmzone.h
2007-08-22Apply memory policies to top two highest zones when highest zone is ZONE_MOVABLEMel Gorman
The NUMA layer only supports NUMA policies for the highest zone. When ZONE_MOVABLE is configured with kernelcore=, the the highest zone becomes ZONE_MOVABLE. The result is that policies are only applied to allocations like anonymous pages and page cache allocated from ZONE_MOVABLE when the zone is used. This patch applies policies to the two highest zones when the highest zone is ZONE_MOVABLE. As ZONE_MOVABLE consists of pages from the highest "real" zone, it's always functionally equivalent. The patch has been tested on a variety of machines both NUMA and non-NUMA covering x86, x86_64 and ppc64. No abnormal results were seen in kernbench, tbench, dbench or hackbench. It passes regression tests from the numactl package with and without kernelcore= once numactl tests are patched to wait for vmstat counters to update. akpm: this is the nasty hack to fix NUMA mempolicies in the presence of ZONE_MOVABLE and kernelcore= in 2.6.23. Christoph says "For .24 either merge the mobility or get the other solution that Mel is working on. That solution would only use a single zonelist per node and filter on the fly. That may help performance and also help to make memory policies work better." Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Tested-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31Remove the arm26 portAdrian Bunk
The arm26 port has been in a state where it was far from even compiling for quite some time. Ian Molton agreed with the removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Lumpy Reclaim V4Andy Whitcroft
When we are out of memory of a suitable size we enter reclaim. The current reclaim algorithm targets pages in LRU order, which is great for fairness at order-0 but highly unsuitable if you desire pages at higher orders. To get pages of higher order we must shoot down a very high proportion of memory; >95% in a lot of cases. This patch set adds a lumpy reclaim algorithm to the allocator. It targets groups of pages at the specified order anchored at the end of the active and inactive lists. This encourages groups of pages at the requested orders to move from active to inactive, and active to free lists. This behaviour is only triggered out of direct reclaim when higher order pages have been requested. This patch set is particularly effective when utilised with an anti-fragmentation scheme which groups pages of similar reclaimability together. This patch set is based on Peter Zijlstra's lumpy reclaim V2 patch which forms the foundation. Credit to Mel Gorman for sanitity checking. Mel said: The patches have an application with hugepage pool resizing. When lumpy-reclaim is used used with ZONE_MOVABLE, the hugepages pool can be resized with greater reliability. Testing on a desktop machine with 2GB of RAM showed that growing the hugepage pool with ZONE_MOVABLE on it's own was very slow as the success rate was quite low. Without lumpy-reclaim, each attempt to grow the pool by 100 pages would yield 1 or 2 hugepages. With lumpy-reclaim, getting 40 to 70 hugepages on each attempt was typical. [akpm@osdl.org: ia64 pfn_to_nid fixes and loop cleanup] [bunk@stusta.de: static declarations for internal functions] [a.p.zijlstra@chello.nl: initial lumpy V2 implementation] Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Create the ZONE_MOVABLE zoneMel Gorman
The following 8 patches against 2.6.20-mm2 create a zone called ZONE_MOVABLE that is only usable by allocations that specify both __GFP_HIGHMEM and __GFP_MOVABLE. This has the effect of keeping all non-movable pages within a single memory partition while allowing movable allocations to be satisfied from either partition. The patches may be applied with the list-based anti-fragmentation patches that groups pages together based on mobility. The size of the zone is determined by a kernelcore= parameter specified at boot-time. This specifies how much memory is usable by non-movable allocations and the remainder is used for ZONE_MOVABLE. Any range of pages within ZONE_MOVABLE can be released by migrating the pages or by reclaiming. When selecting a zone to take pages from for ZONE_MOVABLE, there are two things to consider. First, only memory from the highest populated zone is used for ZONE_MOVABLE. On the x86, this is probably going to be ZONE_HIGHMEM but it would be ZONE_DMA on ppc64 or possibly ZONE_DMA32 on x86_64. Second, the amount of memory usable by the kernel will be spread evenly throughout NUMA nodes where possible. If the nodes are not of equal size, the amount of memory usable by the kernel on some nodes may be greater than others. By default, the zone is not as useful for hugetlb allocations because they are pinned and non-migratable (currently at least). A sysctl is provided that allows huge pages to be allocated from that zone. This means that the huge page pool can be resized to the size of ZONE_MOVABLE during the lifetime of the system assuming that pages are not mlocked. Despite huge pages being non-movable, we do not introduce additional external fragmentation of note as huge pages are always the largest contiguous block we care about. Credit goes to Andy Whitcroft for catching a large variety of problems during review of the patches. This patch creates an additional zone, ZONE_MOVABLE. This zone is only usable by allocations which specify both __GFP_HIGHMEM and __GFP_MOVABLE. Hot-added memory continues to be placed in their existing destination as there is no mechanism to redirect them to a specific zone. [y-goto@jp.fujitsu.com: Fix section mismatch of memory hotplug related code] [akpm@linux-foundation.org: various fixes] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16change zonelist order: zonelist order selection logicKAMEZAWA Hiroyuki
Make zonelist creation policy selectable from sysctl/boot option v6. This patch makes NUMA's zonelist (of pgdat) order selectable. Available order are Default(automatic)/ Node-based / Zone-based. [Default Order] The kernel selects Node-based or Zone-based order automatically. [Node-based Order] This policy treats the locality of memory as the most important parameter. Zonelist order is created by each zone's locality. This means lower zones (ex. ZONE_DMA) can be used before higher zone (ex. ZONE_NORMAL) exhausion. IOW. ZONE_DMA will be in the middle of zonelist. current 2.6.21 kernel uses this. Pros. * A user can expect local memory as much as possible. Cons. * lower zone will be exhansted before higher zone. This may cause OOM_KILL. Maybe suitable if ZONE_DMA is relatively big and you never see OOM_KILL because of ZONE_DMA exhaution and you need the best locality. (example) assume 2 node NUMA. node(0) has ZONE_DMA/ZONE_NORMAL, node(1) has ZONE_NORMAL. *node(0)'s memory allocation order: node(0)'s NORMAL -> node(0)'s DMA -> node(1)'s NORMAL. *node(1)'s memory allocation order: node(1)'s NORMAL -> node(0)'s NORMAL -> node(0)'s DMA. [Zone-based order] This policy treats the zone type as the most important parameter. Zonelist order is created by zone-type order. This means lower zone never be used bofere higher zone exhaustion. IOW. ZONE_DMA will be always at the tail of zonelist. Pros. * OOM_KILL(bacause of lower zone) occurs only if the whole zones are exhausted. Cons. * memory locality may not be best. (example) assume 2 node NUMA. node(0) has ZONE_DMA/ZONE_NORMAL, node(1) has ZONE_NORMAL. *node(0)'s memory allocation order: node(0)'s NORMAL -> node(1)'s NORMAL -> node(0)'s DMA. *node(1)'s memory allocation order: node(1)'s NORMAL -> node(0)'s NORMAL -> node(0)'s DMA. bootoption "numa_zonelist_order=" and proc/sysctl is supporetd. command: %echo N > /proc/sys/vm/numa_zonelist_order Will rebuild zonelist in Node-based order. command: %echo Z > /proc/sys/vm/numa_zonelist_order Will rebuild zonelist in Zone-based order. Thanks to Lee Schermerhorn, he gives me much help and codes. [Lee.Schermerhorn@hp.com: add check_highest_zone to build_zonelists_in_zone_order] [akpm@linux-foundation.org: build fix] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: "jesse.barnes@intel.com" <jesse.barnes@intel.com> Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Move remote node draining out of slab allocatorsChristoph Lameter
Currently the slab allocators contain callbacks into the page allocator to perform the draining of pagesets on remote nodes. This requires SLUB to have a whole subsystem in order to be compatible with SLAB. Moving node draining out of the slab allocators avoids a section of code in SLUB. Move the node draining so that is is done when the vm statistics are updated. At that point we are already touching all the cachelines with the pagesets of a processor. Add a expire counter there. If we have to update per zone or global vm statistics then assume that the pageset will require subsequent draining. The expire counter will be decremented on each vm stats update pass until it reaches zero. Then we will drain one batch from the pageset. The draining will cause vm counter updates which will then cause another expiration until the pcp is empty. So we will drain a batch every 3 seconds. Note that remote node draining is a somewhat esoteric feature that is required on large NUMA systems because otherwise significant portions of system memory can become trapped in pcp queues. The number of pcp is determined by the number of processors and nodes in a system. A system with 4 processors and 2 nodes has 8 pcps which is okay. But a system with 1024 processors and 512 nodes has 512k pcps with a high potential for large amount of memory being caught in them. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07add pfn_valid_within helper for sub-MAX_ORDER hole detectionAndy Whitcroft
Generally we work under the assumption that memory the mem_map array is contigious and valid out to MAX_ORDER_NR_PAGES block of pages, ie. that if we have validated any page within this MAX_ORDER_NR_PAGES block we need not check any other. This is not true when CONFIG_HOLES_IN_ZONE is set and we must check each and every reference we make from a pfn. Add a pfn_valid_within() helper which should be used when scanning pages within a MAX_ORDER_NR_PAGES block when we have already checked the validility of the block normally with pfn_valid(). This can then be optimised away when we do not have holes within a MAX_ORDER_NR_PAGES block of pages. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Bob Picco <bob.picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] optional ZONE_DMA: optional ZONE_DMA in the VMChristoph Lameter
Make ZONE_DMA optional in core code. - ifdef all code for ZONE_DMA and related definitions following the example for ZONE_DMA32 and ZONE_HIGHMEM. - Without ZONE_DMA, ZONE_HIGHMEM and ZONE_DMA32 we get to a ZONES_SHIFT of 0. - Modify the VM statistics to work correctly without a DMA zone. - Modify slab to not create DMA slabs if there is no ZONE_DMA. [akpm@osdl.org: cleanup] [jdike@addtoit.com: build fix] [apw@shadowen.org: Simplify calculation of the number of bits we need for ZONES_SHIFT] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Drop __get_zone_counts()Christoph Lameter
Values are readily available via ZVC per node and global sums. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Reorder ZVCs according to cachelineChristoph Lameter
The global and per zone counter sums are in arrays of longs. Reorder the ZVCs so that the most frequently used ZVCs are put into the same cacheline. That way calculations of the global, node and per zone vm state touches only a single cacheline. This is mostly important for 64 bit systems were one 128 byte cacheline takes only 8 longs. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Use ZVC for free_pagesChristoph Lameter
This is again simplifies some of the VM counter calculations through the use of the ZVC consolidated counters. [michal.k.k.piotrowski@gmail.com: build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Use ZVC for inactive and active countsChristoph Lameter
The determination of the dirty ratio to determine writeback behavior is currently based on the number of total pages on the system. However, not all pages in the system may be dirtied. Thus the ratio is always too low and can never reach 100%. The ratio may be particularly skewed if large hugepage allocations, slab allocations or device driver buffers make large sections of memory not available anymore. In that case we may get into a situation in which f.e. the background writeback ratio of 40% cannot be reached anymore which leads to undesired writeback behavior. This patchset fixes that issue by determining the ratio based on the actual pages that may potentially be dirty. These are the pages on the active and the inactive list plus free pages. The problem with those counts has so far been that it is expensive to calculate these because counts from multiple nodes and multiple zones will have to be summed up. This patchset makes these counters ZVC counters. This means that a current sum per zone, per node and for the whole system is always available via global variables and not expensive anymore to calculate. The patchset results in some other good side effects: - Removal of the various functions that sum up free, active and inactive page counts - Cleanup of the functions that display information via the proc filesystem. This patch: The use of a ZVC for nr_inactive and nr_active allows a simplification of some counter operations. More ZVC functionality is used for sums etc in the following patches. [akpm@osdl.org: UP build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] Fix sparsemem on CellDave Hansen
Fix an oops experienced on the Cell architecture when init-time functions, early_*(), are called at runtime. It alters the call paths to make sure that the callers explicitly say whether the call is being made on behalf of a hotplug even, or happening at boot-time. It has been compile tested on ppc64, ia64, s390, i386 and x86_64. Acked-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Acked-by: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] memory page_alloc zonelist caching reorder structurePaul Jackson
Rearrange the struct members in the 'struct zonelist_cache' structure, so as to put the readonly (once initialized) z_to_n[] array first, where it will come right after the zones[] array in struct zonelist. This pretty much eliminates the chance that the two frequently written elements of 'struct zonelist_cache', the fullzones bitmap and last_full_zap times, will end up on the same cache line as the performance sensitive, frequently read, never (after init) written zones[] array. Keeping frequently written data off frequently read cache lines is good for performance. Thanks to Rohit Seth for the suggestion. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: Rohit Seth <rohitseth@google.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] memory page_alloc zonelist caching speedupPaul Jackson
Optimize the critical zonelist scanning for free pages in the kernel memory allocator by caching the zones that were found to be full recently, and skipping them. Remembers the zones in a zonelist that were short of free memory in the last second. And it stashes a zone-to-node table in the zonelist struct, to optimize that conversion (minimize its cache footprint.) Recent changes: This differs in a significant way from a similar patch that I posted a week ago. Now, instead of having a nodemask_t of recently full nodes, I have a bitmask of recently full zones. This solves a problem that last weeks patch had, which on systems with multiple zones per node (such as DMA zone) would take seeing any of these zones full as meaning that all zones on that node were full. Also I changed names - from "zonelist faster" to "zonelist cache", as that seemed to better convey what we're doing here - caching some of the key zonelist state (for faster access.) See below for some performance benchmark results. After all that discussion with David on why I didn't need them, I went and got some ;). I wanted to verify that I had not hurt the normal case of memory allocation noticeably. At least for my one little microbenchmark, I found (1) the normal case wasn't affected, and (2) workloads that forced scanning across multiple nodes for memory improved up to 10% fewer System CPU cycles and lower elapsed clock time ('sys' and 'real'). Good. See details, below. I didn't have the logic in get_page_from_freelist() for various full nodes and zone reclaim failures correct. That should be fixed up now - notice the new goto labels zonelist_scan, this_zone_full, and try_next_zone, in get_page_from_freelist(). There are two reasons I persued this alternative, over some earlier proposals that would have focused on optimizing the fake numa emulation case by caching the last useful zone: 1) Contrary to what I said before, we (SGI, on large ia64 sn2 systems) have seen real customer loads where the cost to scan the zonelist was a problem, due to many nodes being full of memory before we got to a node we could use. Or at least, I think we have. This was related to me by another engineer, based on experiences from some time past. So this is not guaranteed. Most likely, though. The following approach should help such real numa systems just as much as it helps fake numa systems, or any combination thereof. 2) The effort to distinguish fake from real numa, using node_distance, so that we could cache a fake numa node and optimize choosing it over equivalent distance fake nodes, while continuing to properly scan all real nodes in distance order, was going to require a nasty blob of zonelist and node distance munging. The following approach has no new dependency on node distances or zone sorting. See comment in the patch below for a description of what it actually does. Technical details of note (or controversy): - See the use of "zlc_active" and "did_zlc_setup" below, to delay adding any work for this new mechanism until we've looked at the first zone in zonelist. I figured the odds of the first zone having the memory we needed were high enough that we should just look there, first, then get fancy only if we need to keep looking. - Some odd hackery was needed to add items to struct zonelist, while not tripping up the custom zonelists built by the mm/mempolicy.c code for MPOL_BIND. My usual wordy comments below explain this. Search for "MPOL_BIND". - Some per-node data in the struct zonelist is now modified frequently, with no locking. Multiple CPU cores on a node could hit and mangle this data. The theory is that this is just performance hint data, and the memory allocator will work just fine despite any such mangling. The fields at risk are the struct 'zonelist_cache' fields 'fullzones' (a bitmask) and 'last_full_zap' (unsigned long jiffies). It should all be self correcting after at most a one second delay. - This still does a linear scan of the same lengths as before. All I've optimized is making the scan faster, not algorithmically shorter. It is now able to scan a compact array of 'unsigned short' in the case of many full nodes, so one cache line should cover quite a few nodes, rather than each node hitting another one or two new and distinct cache lines. - If both Andi and Nick don't find this too complicated, I will be (pleasantly) flabbergasted. - I removed the comment claiming we only use one cachline's worth of zonelist. We seem, at least in the fake numa case, to have put the lie to that claim. - I pay no attention to the various watermarks and such in this performance hint. A node could be marked full for one watermark, and then skipped over when searching for a page using a different watermark. I think that's actually quite ok, as it will tend to slightly increase the spreading of memory over other nodes, away from a memory stressed node. =============== Performance - some benchmark results and analysis: This benchmark runs a memory hog program that uses multiple threads to touch alot of memory as quickly as it can. Multiple runs were made, touching 12, 38, 64 or 90 GBytes out of the total 96 GBytes on the system, and using 1, 19, 37, or 55 threads (on a 56 CPU system.) System, user and real (elapsed) timings were recorded for each run, shown in units of seconds, in the table below. Two kernels were tested - 2.6.18-mm3 and the same kernel with this zonelist caching patch added. The table also shows the percentage improvement the zonelist caching sys time is over (lower than) the stock *-mm kernel. number 2.6.18-mm3 zonelist-cache delta (< 0 good) percent GBs N ------------ -------------- ---------------- systime mem threads sys user real sys user real sys user real better 12 1 153 24 177 151 24 176 -2 0 -1 1% 12 19 99 22 8 99 22 8 0 0 0 0% 12 37 111 25 6 112 25 6 1 0 0 -0% 12 55 115 25 5 110 23 5 -5 -2 0 4% 38 1 502 74 576 497 73 570 -5 -1 -6 0% 38 19 426 78 48 373 76 39 -53 -2 -9 12% 38 37 544 83 36 547 82 36 3 -1 0 -0% 38 55 501 77 23 511 80 24 10 3 1 -1% 64 1 917 125 1042 890 124 1014 -27 -1 -28 2% 64 19 1118 138 119 965 141 103 -153 3 -16 13% 64 37 1202 151 94 1136 150 81 -66 -1 -13 5% 64 55 1118 141 61 1072 140 58 -46 -1 -3 4% 90 1 1342 177 1519 1275 174 1450 -67 -3 -69 4% 90 19 2392 199 192 2116 189 176 -276 -10 -16 11% 90 37 3313 238 175 2972 225 145 -341 -13 -30 10% 90 55 1948 210 104 1843 213 100 -105 3 -4 5% Notes: 1) This test ran a memory hog program that started a specified number N of threads, and had each thread allocate and touch 1/N'th of the total memory to be used in the test run in a single loop, writing a constant word to memory, one store every 4096 bytes. Watching this test during some earlier trial runs, I would see each of these threads sit down on one CPU and stay there, for the remainder of the pass, a different CPU for each thread. 2) The 'real' column is not comparable to the 'sys' or 'user' columns. The 'real' column is seconds wall clock time elapsed, from beginning to end of that test pass. The 'sys' and 'user' columns are total CPU seconds spent on that test pass. For a 19 thread test run, for example, the sum of 'sys' and 'user' could be up to 19 times the number of 'real' elapsed wall clock seconds. 3) Tests were run on a fresh, single-user boot, to minimize the amount of memory already in use at the start of the test, and to minimize the amount of background activity that might interfere. 4) Tests were done on a 56 CPU, 28 Node system with 96 GBytes of RAM. 5) Notice that the 'real' time gets large for the single thread runs, even though the measured 'sys' and 'user' times are modest. I'm not sure what that means - probably something to do with it being slow for one thread to be accessing memory along ways away. Perhaps the fake numa system, running ostensibly the same workload, would not show this substantial degradation of 'real' time for one thread on many nodes -- lets hope not. 6) The high thread count passes (one thread per CPU - on 55 of 56 CPUs) ran quite efficiently, as one might expect. Each pair of threads needed to allocate and touch the memory on the node the two threads shared, a pleasantly parallizable workload. 7) The intermediate thread count passes, when asking for alot of memory forcing them to go to a few neighboring nodes, improved the most with this zonelist caching patch. Conclusions: * This zonelist cache patch probably makes little difference one way or the other for most workloads on real numa hardware, if those workloads avoid heavy off node allocations. * For memory intensive workloads requiring substantial off-node allocations on real numa hardware, this patch improves both kernel and elapsed timings up to ten per-cent. * For fake numa systems, I'm optimistic, but will have to leave that up to Rohit Seth to actually test (once I get him a 2.6.18 backport.) Signed-off-by: Paul Jackson <pj@sgi.com> Cc: Rohit Seth <rohitseth@google.com> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: David Rientjes <rientjes@cs.washington.edu> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] vmscan: Fix temp_priority raceMartin Bligh
The temp_priority field in zone is racy, as we can walk through a reclaim path, and just before we copy it into prev_priority, it can be overwritten (say with DEF_PRIORITY) by another reclaimer. The same bug is contained in both try_to_free_pages and balance_pgdat, but it is fixed slightly differently. In balance_pgdat, we keep a separate priority record per zone in a local array. In try_to_free_pages there is no need to do this, as the priority level is the same for all zones that we reclaim from. Impact of this bug is that temp_priority is copied into prev_priority, and setting this artificially high causes reclaimers to set distress artificially low. They then fail to reclaim mapped pages, when they are, in fact, under severe memory pressure (their priority may be as low as 0). This causes the OOM killer to fire incorrectly. From: Andrew Morton <akpm@osdl.org> __zone_reclaim() isn't modifying zone->prev_priority. But zone->prev_priority is used in the decision whether or not to bring mapped pages onto the inactive list. Hence there's a risk here that __zone_reclaim() will fail because zone->prev_priority ir large (ie: low urgency) and lots of mapped pages end up stuck on the active list. Fix that up by decreasing (ie making more urgent) zone->prev_priority as __zone_reclaim() scans the zone's pages. This bug perhaps explains why ZONE_RECLAIM_PRIORITY was created. It should be possible to remove that now, and to just start out at DEF_PRIORITY? Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Christoph Lameter <clameter@engr.sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-21[PATCH] Reintroduce NODES_SPAN_OTHER_NODES for powerpcAndy Whitcroft
Reintroduce NODES_SPAN_OTHER_NODES for powerpc Revert "[PATCH] Remove SPAN_OTHER_NODES config definition" This reverts commit f62859bb6871c5e4a8e591c60befc8caaf54db8c. Revert "[PATCH] mm: remove arch independent NODES_SPAN_OTHER_NODES" This reverts commit a94b3ab7eab4edcc9b2cb474b188f774c331adf7. Also update the comments to indicate that this is still required and where its used. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Kravetz <kravetz@us.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Acked-by: Will Schmidt <will_schmidt@vnet.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Add node to zone for the NUMA caseChristoph Lameter
Add the node in order to optimize zone_to_nid. Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] own header file for struct pageHeiko Carstens
This moves the definition of struct page from mm.h to its own header file page-struct.h. This is a prereq to fix SetPageUptodate which is broken on s390: #define SetPageUptodate(_page) do { struct page *__page = (_page); if (!test_and_set_bit(PG_uptodate, &__page->flags)) page_test_and_clear_dirty(_page); } while (0) _page gets used twice in this macro which can cause subtle bugs. Using __page for the page_test_and_clear_dirty call doesn't work since it causes yet another problem with the page_test_and_clear_dirty macro as well. In order to avoid all these problems caused by macros it seems to be a good idea to get rid of them and convert them to static inline functions. Because of header file include order it's necessary to have a seperate header file for the struct page definition. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] vm: add per-zone writeout counterAndrew Morton
The VM is supposed to minimise the number of pages which get written off the LRU (for IO scheduling efficiency, and for high reclaim-success rates). But we don't actually have a clear way of showing how true this is. So add `nr_vmscan_write' to /proc/vmstat and /proc/zoneinfo - the number of pages which have been written by the vm scanner in this zone and globally. Cc: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] Introduce mechanism for registering active regions of memoryMel Gorman
At a basic level, architectures define structures to record where active ranges of page frames are located. Once located, the code to calculate zone sizes and holes in each architecture is very similar. Some of this zone and hole sizing code is difficult to read for no good reason. This set of patches eliminates the similar-looking architecture-specific code. The patches introduce a mechanism where architectures register where the active ranges of page frames are with add_active_range(). When all areas have been discovered, free_area_init_nodes() is called to initialise the pgdat and zones. The zone sizes and holes are then calculated in an architecture independent manner. Patch 1 introduces the mechanism for registering and initialising PFN ranges Patch 2 changes ppc to use the mechanism - 139 arch-specific LOC removed Patch 3 changes x86 to use the mechanism - 136 arch-specific LOC removed Patch 4 changes x86_64 to use the mechanism - 74 arch-specific LOC removed Patch 5 changes ia64 to use the mechanism - 52 arch-specific LOC removed Patch 6 accounts for mem_map as a memory hole as the pages are not reclaimable. It adjusts the watermarks slightly Tony Luck has successfully tested for ia64 on Itanium with tiger_defconfig, gensparse_defconfig and defconfig. Bob Picco has also tested and debugged on IA64. Jack Steiner successfully boot tested on a mammoth SGI IA64-based machine. These were on patches against 2.6.17-rc1 and release 3 of these patches but there have been no ia64-changes since release 3. There are differences in the zone sizes for x86_64 as the arch-specific code for x86_64 accounts the kernel image and the starting mem_maps as memory holes but the architecture-independent code accounts the memory as present. The big benefit of this set of patches is a sizable reduction of architecture-specific code, some of which is very hairy. There should be a greater reduction when other architectures use the same mechanisms for zone and hole sizing but I lack the hardware to test on. Additional credit; Dave Hansen for the initial suggestion and comments on early patches Andy Whitcroft for reviewing early versions and catching numerous errors Tony Luck for testing and debugging on IA64 Bob Picco for fixing bugs related to pfn registration, reviewing a number of patch revisions, providing a number of suggestions on future direction and testing heavily Jack Steiner and Robin Holt for testing on IA64 and clarifying issues related to memory holes Yasunori for testing on IA64 Andi Kleen for reviewing and feeding back about x86_64 Christian Kujau for providing valuable information related to ACPI problems on x86_64 and testing potential fixes This patch: Define the structure to represent an active range of page frames within a node in an architecture independent manner. Architectures are expected to register active ranges of PFNs using add_active_range(nid, start_pfn, end_pfn) and call free_area_init_nodes() passing the PFNs of the end of each zone. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Bob Picco <bob.picco@hp.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Andi Kleen <ak@muc.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Keith Mannthey" <kmannth@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] zone_reclaim: dynamic slab reclaimChristoph Lameter
Currently one can enable slab reclaim by setting an explicit option in /proc/sys/vm/zone_reclaim_mode. Slab reclaim is then used as a final option if the freeing of unmapped file backed pages is not enough to free enough pages to allow a local allocation. However, that means that the slab can grow excessively and that most memory of a node may be used by slabs. We have had a case where a machine with 46GB of memory was using 40-42GB for slab. Zone reclaim was effective in dealing with pagecache pages. However, slab reclaim was only done during global reclaim (which is a bit rare on NUMA systems). This patch implements slab reclaim during zone reclaim. Zone reclaim occurs if there is a danger of an off node allocation. At that point we 1. Shrink the per node page cache if the number of pagecache pages is more than min_unmapped_ratio percent of pages in a zone. 2. Shrink the slab cache if the number of the nodes reclaimable slab pages (patch depends on earlier one that implements that counter) are more than min_slab_ratio (a new /proc/sys/vm tunable). The shrinking of the slab cache is a bit problematic since it is not node specific. So we simply calculate what point in the slab we want to reach (current per node slab use minus the number of pages that neeed to be allocated) and then repeately run the global reclaim until that is unsuccessful or we have reached the limit. I hope we will have zone based slab reclaim at some point which will make that easier. The default for the min_slab_ratio is 5% Also remove the slab option from /proc/sys/vm/zone_reclaim_mode. [akpm@osdl.org: cleanups] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] ZVC: Support NR_SLAB_RECLAIMABLE / NR_SLAB_UNRECLAIMABLEChristoph Lameter
Remove the atomic counter for slab_reclaim_pages and replace the counter and NR_SLAB with two ZVC counter that account for unreclaimable and reclaimable slab pages: NR_SLAB_RECLAIMABLE and NR_SLAB_UNRECLAIMABLE. Change the check in vmscan.c to refer to to NR_SLAB_RECLAIMABLE. The intend seems to be to check for slab pages that could be freed. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] Replace min_unmapped_ratio by min_unmapped_pages in struct zoneChristoph Lameter
*_pages is a better description of the role of the variable. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] linearly index zone->node_zonelists[]Christoph Lameter
I wonder why we need this bitmask indexing into zone->node_zonelists[]? We always start with the highest zone and then include all lower zones if we build zonelists. Are there really cases where we need allocation from ZONE_DMA or ZONE_HIGHMEM but not ZONE_NORMAL? It seems that the current implementation of highest_zone() makes that already impossible. If we go linear on the index then gfp_zone() == highest_zone() and a lot of definitions fall by the wayside. We can now revert back to the use of gfp_zone() in mempolicy.c ;-) Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] reduce MAX_NR_ZONES: make ZONE_HIGHMEM optionalChristoph Lameter
Make ZONE_HIGHMEM optional - ifdef out code and definitions related to CONFIG_HIGHMEM - __GFP_HIGHMEM falls back to normal allocations if there is no ZONE_HIGHMEM - GFP_ZONEMASK becomes 0x01 if there is no DMA32 and no HIGHMEM zone. [jdike@addtoit.com: build fix] Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Christoph Lameter <clameter@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] reduce MAX_NR_ZONES: make ZONE_DMA32 optionalChristoph Lameter
Make ZONE_DMA32 optional - Add #ifdefs around ZONE_DMA32 specific code and definitions. - Add CONFIG_ZONE_DMA32 config option and use that for x86_64 that alone needs this zone. - Remove the use of CONFIG_DMA_IS_DMA32 and CONFIG_DMA_IS_NORMAL for ia64 and fix up the way per node ZVCs are calculated. - Fall back to prior GFP_ZONEMASK of 0x03 if there is no DMA32 zone. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] reduce MAX_NR_ZONES: use enum to define zones, reformat and commentChristoph Lameter
Use enum for zones and reformat zones dependent information Add comments explaning the use of zones and add a zones_t type for zone numbers. Line up information that will be #ifdefd by the following patches. [akpm@osdl.org: comment cleanups] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-01[PATCH] ZVC: Scale thresholds depending on the size of the systemChristoph Lameter
The ZVC counter update threshold is currently set to a fixed value of 32. This patch sets up the threshold depending on the number of processors and the sizes of the zones in the system. With the current threshold of 32, I was able to observe slight contention when more than 130-140 processors concurrently updated the counters. The contention vanished when I either increased the threshold to 64 or used Andrew's idea of overstepping the interval (see ZVC overstep patch). However, we saw contention again at 220-230 processors. So we need higher values for larger systems. But the current default is already a bit of an overkill for smaller systems. Some systems have tiny zones where precision matters. For example i386 and x86_64 have 16M DMA zones and either 900M ZONE_NORMAL or ZONE_DMA32. These are even present on SMP and NUMA systems. The patch here sets up a threshold based on the number of processors in the system and the size of the zone that these counters are used for. The threshold should grow logarithmically, so we use fls() as an easy approximation. Results of tests on a system with 1024 processors (4TB RAM) The following output is from a test allocating 1GB of memory concurrently on each processor (Forking the process. So contention on mmap_sem and the pte locks is not a factor): X MIN TYPE: CPUS WALL WALL SYS USER TOTCPU fork 1 0.552 0.552 0.540 0.012 0.552 fork 4 0.552 0.548 2.164 0.036 2.200 fork 16 0.564 0.548 8.812 0.164 8.976 fork 128 0.580 0.572 72.204 1.208 73.412 fork 256 1.300 0.660 310.400 2.160 312.560 fork 512 3.512 0.696 1526.836 4.816 1531.652 fork 1020 20.024 0.700 17243.176 6.688 17249.863 So a threshold of 32 is fine up to 128 processors. At 256 processors contention becomes a factor. Overstepping the counter (earlier patch) improves the numbers a bit: fork 4 0.552 0.548 2.164 0.040 2.204 fork 16 0.552 0.548 8.640 0.148 8.788 fork 128 0.556 0.548 69.676 0.956 70.632 fork 256 0.876 0.636 212.468 2.108 214.576 fork 512 2.276 0.672 997.324 4.260 1001.584 fork 1020 13.564 0.680 11586.436 6.088 11592.523 Still contention at 512 and 1020. Contention at 1020 is down by a third. 256 still has a slight bit of contention. After this patch the counter threshold will be set to 125 which reduces contention significantly: fork 128 0.560 0.548 69.776 0.932 70.708 fork 256 0.636 0.556 143.460 2.036 145.496 fork 512 0.640 0.548 284.244 4.236 288.480 fork 1020 1.500 0.588 1326.152 8.892 1335.044 [akpm@osdl.org: !SMP build fix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] ZVC/zone_reclaim: Leave 1% of unmapped pagecache pages for file I/OChristoph Lameter
It turns out that it is advantageous to leave a small portion of unmapped file backed pages if all of a zone's pages (or almost all pages) are allocated and so the page allocator has to go off-node. This allows recently used file I/O buffers to stay on the node and reduces the times that zone reclaim is invoked if file I/O occurs when we run out of memory in a zone. The problem is that zone reclaim runs too frequently when the page cache is used for file I/O (read write and therefore unmapped pages!) alone and we have almost all pages of the zone allocated. Zone reclaim may remove 32 unmapped pages. File I/O will use these pages for the next read/write requests and the unmapped pages increase. After the zone has filled up again zone reclaim will remove it again after only 32 pages. This cycle is too inefficient and there are potentially too many zone reclaim cycles. With the 1% boundary we may still remove all unmapped pages for file I/O in zone reclaim pass. However. it will take a large number of read and writes to get back to 1% again where we trigger zone reclaim again. The zone reclaim 2.6.16/17 does not show this behavior because we have a 30 second timeout. [akpm@osdl.org: rename the /proc file and the variable] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] Use Zoned VM Counters for NUMA statisticsChristoph Lameter
The numa statistics are really event counters. But they are per node and so we have had special treatment for these counters through additional fields on the pcp structure. We can now use the per zone nature of the zoned VM counters to realize these. This will shrink the size of the pcp structure on NUMA systems. We will have some room to add additional per zone counters that will all still fit in the same cacheline. Bits Prior pcp size Size after patch We can add ------------------------------------------------------------------ 64 128 bytes (16 words) 80 bytes (10 words) 48 32 76 bytes (19 words) 56 bytes (14 words) 8 (64 byte cacheline) 72 (128 byte) Remove the special statistics for numa and replace them with zoned vm counters. This has the side effect that global sums of these events now show up in /proc/vmstat. Also take the opportunity to move the zone_statistics() function from page_alloc.c into vmstat.c. Discussions: V2 http://marc.theaimsgroup.com/?t=115048227000002&r=1&w=2 Signed-off-by: Christoph Lameter <clameter@sgi.com> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_bounce to per zone counterChristoph Lameter
Conversion of nr_bounce to a per zone counter nr_bounce is only used for proc output. So it could be left as an event counter. However, the event counters may not be accurate and nr_bounce is categorizing types of pages in a zone. So we really need this to also be a per zone counter. [akpm@osdl.org: bugfix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_unstable to per zone counterChristoph Lameter
Conversion of nr_unstable to a per zone counter We need to do some special modifications to the nfs code since there are multiple cases of disposition and we need to have a page ref for proper accounting. This converts the last critical page state of the VM and therefore we need to remove several functions that were depending on GET_PAGE_STATE_LAST in order to make the kernel compile again. We are only left with event type counters in page state. [akpm@osdl.org: bugfixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_writeback to per zone counterChristoph Lameter
Conversion of nr_writeback to per zone counter. This removes the last page_state counter from arch/i386/mm/pgtable.c so we drop the page_state from there. [akpm@osdl.org: bugfix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_dirty to per zone counterChristoph Lameter
This makes nr_dirty a per zone counter. Looping over all processors is avoided during writeback state determination. The counter aggregation for nr_dirty had to be undone in the NFS layer since we summed up the page counts from multiple zones. Someone more familiar with NFS should probably review what I have done. [akpm@osdl.org: bugfix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_pagetables to per zone counterChristoph Lameter
Conversion of nr_page_table_pages to a per zone counter [akpm@osdl.org: bugfix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_slab to per zone counterChristoph Lameter
- Allows reclaim to access counter without looping over processor counts. - Allows accurate statistics on how many pages are used in a zone by the slab. This may become useful to balance slab allocations over various zones. [akpm@osdl.org: bugfix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: zone_reclaim: remove ↵Christoph Lameter
/proc/sys/vm/zone_reclaim_interval The zone_reclaim_interval was necessary because we were not able to determine how many unmapped pages exist in a zone. Therefore we had to scan in intervals to figure out if any pages were unmapped. With the zoned counters and NR_ANON_PAGES we now know the number of pagecache pages and the number of mapped pages in a zone. So we can simply skip the reclaim if there is an insufficient number of unmapped pages. We use SWAP_CLUSTER_MAX as the boundary. Drop all support for /proc/sys/vm/zone_reclaim_interval. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: split NR_ANON_PAGES off from NR_FILE_MAPPEDChristoph Lameter
The current NR_FILE_MAPPED is used by zone reclaim and the dirty load calculation as the number of mapped pagecache pages. However, that is not true. NR_FILE_MAPPED includes the mapped anonymous pages. This patch separates those and therefore allows an accurate tracking of the anonymous pages per zone. It then becomes possible to determine the number of unmapped pages per zone and we can avoid scanning for unmapped pages if there are none. Also it may now be possible to determine the mapped/unmapped ratio in get_dirty_limit. Isnt the number of anonymous pages irrelevant in that calculation? Note that this will change the meaning of the number of mapped pages reported in /proc/vmstat /proc/meminfo and in the per node statistics. This may affect user space tools that monitor these counters! NR_FILE_MAPPED works like NR_FILE_DIRTY. It is only valid for pagecache pages. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: conversion of nr_pagecache to per zone counterChristoph Lameter
Currently a single atomic variable is used to establish the size of the page cache in the whole machine. The zoned VM counters have the same method of implementation as the nr_pagecache code but also allow the determination of the pagecache size per zone. Remove the special implementation for nr_pagecache and make it a zoned counter named NR_FILE_PAGES. Updates of the page cache counters are always performed with interrupts off. We can therefore use the __ variant here. Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: convert nr_mapped to per zone counterChristoph Lameter
nr_mapped is important because it allows a determination of how many pages of a zone are not mapped, which would allow a more efficient means of determining when we need to reclaim memory in a zone. We take the nr_mapped field out of the page state structure and define a new per zone counter named NR_FILE_MAPPED (the anonymous pages will be split off from NR_MAPPED in the next patch). We replace the use of nr_mapped in various kernel locations. This avoids the looping over all processors in try_to_free_pages(), writeback, reclaim (swap + zone reclaim). [akpm@osdl.org: bugfix] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: basic ZVC (zoned vm counter) implementationChristoph Lameter
Per zone counter infrastructure The counters that we currently have for the VM are split per processor. The processor however has not much to do with the zone these pages belong to. We cannot tell f.e. how many ZONE_DMA pages are dirty. So we are blind to potentially inbalances in the usage of memory in various zones. F.e. in a NUMA system we cannot tell how many pages are dirty on a particular node. If we knew then we could put measures into the VM to balance the use of memory between different zones and different nodes in a NUMA system. For example it would be possible to limit the dirty pages per node so that fast local memory is kept available even if a process is dirtying huge amounts of pages. Another example is zone reclaim. We do not know how many unmapped pages exist per zone. So we just have to try to reclaim. If it is not working then we pause and try again later. It would be better if we knew when it makes sense to reclaim unmapped pages from a zone. This patchset allows the determination of the number of unmapped pages per zone. We can remove the zone reclaim interval with the counters introduced here. Futhermore the ability to have various usage statistics available will allow the development of new NUMA balancing algorithms that may be able to improve the decision making in the scheduler of when to move a process to another node and hopefully will also enable automatic page migration through a user space program that can analyse the memory load distribution and then rebalance memory use in order to increase performance. The counter framework here implements differential counters for each processor in struct zone. The differential counters are consolidated when a threshold is exceeded (like done in the current implementation for nr_pageache), when slab reaping occurs or when a consolidation function is called. Consolidation uses atomic operations and accumulates counters per zone in the zone structure and also globally in the vm_stat array. VM functions can access the counts by simply indexing a global or zone specific array. The arrangement of counters in an array also simplifies processing when output has to be generated for /proc/*. Counters can be updated by calling inc/dec_zone_page_state or _inc/dec_zone_page_state analogous to *_page_state. The second group of functions can be called if it is known that interrupts are disabled. Special optimized increment and decrement functions are provided. These can avoid certain checks and use increment or decrement instructions that an architecture may provide. We also add a new CONFIG_DMA_IS_NORMAL that signifies that an architecture can do DMA to all memory and therefore ZONE_NORMAL will not be populated. This is only currently set for IA64 SGI SN2 and currently only affects node_page_state(). In the best case node_page_state can be reduced to retrieving a single counter for the one zone on the node. [akpm@osdl.org: cleanups] [akpm@osdl.org: export vm_stat[] for filesystems] Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] sparsemem: record nid during memory presentAndy Whitcroft
Record the node id as we mark sections for instantiation. Use this nid during instantiation to direct allocations. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Cc: Mike Kravetz <kravetz@us.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Bob Picco <bob.picco@hp.com> Cc: Jack Steiner <steiner@sgi.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Martin Bligh <mbligh@google.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] wait_table and zonelist initializing for memory hotadd: add return ↵Yasunori Goto
code for init_current_empty_zone When add_zone() is called against empty zone (not populated zone), we have to initialize the zone which didn't initialize at boot time. But, init_currently_empty_zone() may fail due to allocation of wait table. So, this patch is to catch its error code. Changes against wait_table is in the next patch. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] wait_table and zonelist initializing for memory hotadd: change name ↵Yasunori Goto
of wait_table_size() This is just to rename from wait_table_size() to wait_table_hash_nr_entries(). Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20Merge git://git.infradead.org/hdrcleanup-2.6Linus Torvalds
* git://git.infradead.org/hdrcleanup-2.6: (63 commits) [S390] __FD_foo definitions. Switch to __s32 types in joystick.h instead of C99 types for consistency. Add <sys/types.h> to headers included for userspace in <linux/input.h> Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h Remove struct fddi_statistics from user view in <linux/if_fddi.h> Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390 Revert include/media changes: Mauro says those ioctls are only used in-kernel(!) Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h> Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too Remove private struct dx_hash_info from public view in <linux/ext3_fs.h> Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h> Use __uXX types in <linux/divert.h> for struct divert_blk et al. Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible. Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely Use __uXX types in user-visible structures in <linux/nbd.h> Don't use 'u32' in user-visible struct ip_conntrack_old_tuple. Use __uXX types for S390 DASD volume label definitions which are user-visible S390 BIODASDREADCMB ioctl should use __u64 not u64 type. Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h> Fix private integer types used in V4L2 ioctls. ... Manually resolve conflict in include/linux/mtd/physmap.h
2006-06-05[PATCH] Sparsemem build fixRalf Baechle
From: Ralf Baechle <ralf@linux-mips.org> <linux/mmzone.h> uses PAGE_SIZE, PAGE_SHIFT from <asm/page.h> without including that header itself. For some sparsemem configurations this may result in build errors like: CC init/initramfs.o In file included from include/linux/gfp.h:4, from include/linux/slab.h:15, from include/linux/percpu.h:4, from include/linux/rcupdate.h:41, from include/linux/dcache.h:10, from include/linux/fs.h:226, from init/initramfs.c:2: include/linux/mmzone.h:498:22: warning: "PAGE_SHIFT" is not defined In file included from include/linux/gfp.h:4, from include/linux/slab.h:15, from include/linux/percpu.h:4, from include/linux/rcupdate.h:41, from include/linux/dcache.h:10, from include/linux/fs.h:226, from init/initramfs.c:2: include/linux/mmzone.h:526: error: `PAGE_SIZE' undeclared here (not in a function) include/linux/mmzone.h: In function `__pfn_to_section': include/linux/mmzone.h:573: error: `PAGE_SHIFT' undeclared (first use in this function) include/linux/mmzone.h:573: error: (Each undeclared identifier is reported only once include/linux/mmzone.h:573: error: for each function it appears in.) include/linux/mmzone.h: In function `pfn_valid': include/linux/mmzone.h:578: error: `PAGE_SHIFT' undeclared (first use in this function) make[1]: *** [init/initramfs.o] Error 1 make: *** [init] Error 2 Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Seems-reasonable-to: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-24Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: include/asm-powerpc/unistd.h include/asm-sparc/unistd.h include/asm-sparc64/unistd.h Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-05-21[PATCH] Align the node_mem_map endpoints to a MAX_ORDER boundaryBob Picco
Andy added code to buddy allocator which does not require the zone's endpoints to be aligned to MAX_ORDER. An issue is that the buddy allocator requires the node_mem_map's endpoints to be MAX_ORDER aligned. Otherwise __page_find_buddy could compute a buddy not in node_mem_map for partial MAX_ORDER regions at zone's endpoints. page_is_buddy will detect that these pages at endpoints are not PG_buddy (they were zeroed out by bootmem allocator and not part of zone). Of course the negative here is we could waste a little memory but the positive is eliminating all the old checks for zone boundary conditions. SPARSEMEM won't encounter this issue because of MAX_ORDER size constraint when SPARSEMEM is configured. ia64 VIRTUAL_MEM_MAP doesn't need the logic either because the holes and endpoints are handled differently. This leaves checking alloc_remap and other arches which privately allocate for node_mem_map. Signed-off-by: Bob Picco <bob.picco@hp.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Andy Whitcroft <apw@shadowen.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
