path: root/include/linux/moduleparam.h
2008-02-13moduleparam: fix alpha, ia64 and ppc64 compile failuresIvan Kokshaysky
On alpha, ia64 and ppc64 only relocations to local data can go into read-only sections. The vast majority of module parameters use the global generic param_set_*/param_get_* functions, so the 'const' attribute for struct kernel_param is not only useless, but it also causes compile failures due to 'section type conflict' in those rare cases where param_set/get are local functions. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=8964 Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Anton Blanchard <anton@samba.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28remove __attribute_used__Adrian Bunk
Remove the deprecated __attribute_used__. [Introduce __section in a few places to silence checkpatch /sam] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-17constify string/array kparam tracking structuresJan Beulich
.. in an effort to make read-only whatever can be made, so that CONFIG_DEBUG_RODATA can catch as many issues as possible. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) Documentation/kernel-docs.txt update. arch/cris: typo in KERN_INFO Storage class should be before const qualifier kernel/printk.c: comment fix update I/O sched Kconfig help texts - CFQ is now default, not AS. Remove duplicate listing of Cris arch from README kbuild: more doc. cleanups doc: make doc. for maxcpus= more visible drivers/net/eexpress.c: remove duplicate comment add a help text for BLK_DEV_GENERIC correct a dead URL in the IP_MULTICAST help text fix the BAYCOM_SER_HDX help text fix SCSI_SCAN_ASYNC help text trivial documentation patch for platform.txt Fix typos concerning hierarchy Fix comment typo "spin_lock_irqrestore". Fix misspellings of "agressive". drivers/scsi/a100u2w.c: trivial typo patch Correct trivial typo in log2.h. Remove useless FIND_FIRST_BIT() macro from cardbus.c. ...
2007-02-17Replace remaining references to "driverfs" with "sysfs".Robert P. J. Day
Globally, s/driverfs/sysfs/g. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-02-16sysfs: fix build errors: uevent with CONFIG_SYSFS=nRandy Dunlap
Fix source files to build with CONFIG_SYSFS=n. module_subsys is not available. SYSFS=n, MODULES=y: T:y SYSFS=n, MODULES=n: T:y SYSFS=y, MODULES=y: T:y SYSFS=y, MODULES=n: T:y Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-07[PATCH] Compile-time check re world-writeable module paramsAlexey Dobriyan
One of the mistakes a module_param() user can make is to supply default value of module parameter as the last argument. module_param() accepts permissions instead. If default value is, say, 3 (-------wx), parameter becomes world-writeable. So far, the only remedy was to apply grep(1) and read drivers submitted to -mm. BTDT. With this patch applied, compiler will finally do some job. *) bounds checking on permissions *) world-writeable bit checking on permissions *) compile breakage if checks trigger First version of this check (only "& 2" part) directly caught 4 out of 7 places during my last grep. Subject: Neverending module_param() bugs [X] drivers/acpi/sbs.c:101:module_param(capacity_mode, int, CAPACITY_UNIT); [X] drivers/acpi/sbs.c:102:module_param(update_mode, int, UPDATE_MODE); [ ] drivers/acpi/sbs.c:103:module_param(update_info_mode, int, UPDATE_INFO_MODE); [ ] drivers/acpi/sbs.c:104:module_param(update_time, int, UPDATE_TIME); [ ] drivers/acpi/sbs.c:105:module_param(update_time2, int, UPDATE_TIME2); [X] drivers/char/watchdog/sbc8360.c:203:module_param(timeout, int, 27); [X] drivers/media/video/tuner-simple.c:13:module_param(offset, int, 0666); Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] kernel/params.c: make param_array() staticAdrian Bunk
param_array() in kernel/params.c can now become static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06kbuild: un-stringnify KBUILD_MODNAMESam Ravnborg
Now when kbuild passes KBUILD_MODNAME with "" do not __stringify it when used. Remove __stringnify for all users. This also fixes the output of: $ ls -l /sys/module/ drwxr-xr-x 4 root root 0 2006-01-05 14:24 pcmcia drwxr-xr-x 4 root root 0 2006-01-05 14:24 pcmcia_core drwxr-xr-x 3 root root 0 2006-01-05 14:24 "processor" drwxr-xr-x 3 root root 0 2006-01-05 14:24 "psmouse" The quoting of the module names will be gone again. Thanks to GregKH + Kay Sievers for reproting this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
