path: root/include/linux/mroute.h
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2011-05-04ipv4: Pass explicit saddr/daddr args to ipmr_get_route().David S. Miller
This eliminates the need to use rt->rt_{src,dst}. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-30net: Add compat ioctl support for the ipv4 multicast ioctl SIOCGETSGCNTEric W. Biederman
SIOCGETSGCNT is not a unique ioctl value as it it maps tio SIOCPROTOPRIVATE +1, which unfortunately means the existing infrastructure for compat networking ioctls is insufficient. A trivial compact ioctl implementation would conflict with: SIOCAX25ADDUID SIOCAIPXPRISLT SIOCGETSGCNT_IN6 SIOCGETSGCNT SIOCRSSCAUSE SIOCX25SSUBSCRIP SIOCX25SDTEFACILITIES To make this work I have updated the compat_ioctl decode path to mirror the the normal ioctl decode path. I have added an ipv4 inet_compat_ioctl function so that I can have ipv4 specific compat ioctls. I have added a compat_ioctl function into struct proto so I can break out ioctls by which kind of ip socket I am using. I have added a compat_raw_ioctl function because SIOCGETSGCNT only works on raw sockets. I have added a ipmr_compat_ioctl that mirrors the normal ipmr_ioctl. This was necessary because unfortunately the struct layout for the SIOCGETSGCNT has unsigned longs in it so changes between 32bit and 64bit kernels. This change was sufficient to run a 32bit ip multicast routing daemon on a 64bit kernel. Reported-by: Bill Fenner <fenner@aristanetworks.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-03ipmr: RCU protection for mfc_cache_arrayEric Dumazet
Use RCU & RTNL protection for mfc_cache_array[] ipmr_cache_find() is called under rcu_read_lock(); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13ipv4: ipmr: support multiple tablesPatrick McHardy
This patch adds support for multiple independant multicast routing instances, named "tables". Userspace multicast routing daemons can bind to a specific table instance by issuing a setsockopt call using a new option MRT_TABLE. The table number is stored in the raw socket data and affects all following ipmr setsockopt(), getsockopt() and ioctl() calls. By default, a single table (RT_TABLE_DEFAULT) is created with a default routing rule pointing to it. Newly created pimreg devices have the table number appended ("pimregX"), with the exception of devices created in the default table, which are named just "pimreg" for compatibility reasons. Packets are directed to a specific table instance using routing rules, similar to how regular routing rules work. Currently iif, oif and mark are supported as keys, source and destination addresses could be supported additionally. Example usage: - bind pimd/xorp/... to a specific table: uint32_t table = 123; setsockopt(fd, IPPROTO_IP, MRT_TABLE, &table, sizeof(table)); - create routing rules directing packets to the new table: # ip mrule add iif eth0 lookup 123 # ip mrule add oif eth0 lookup 123 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13ipv4: ipmr: convert struct mfc_cache to struct list_headPatrick McHardy
2010-04-13ipv4: ipmr: remove net pointer from struct mfc_cachePatrick McHardy
Now that cache entries in unres_queue don't need to be distinguished by their network namespace pointer anymore, we can remove it from struct mfc_cache add pass the namespace as function argument to the functions that need it. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: cleanup include/linuxEric Dumazet
This cleanup patch puts struct/union/enum opening braces, in first line to ease grep games. struct something { becomes : struct something { Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07add vif using local interface index instead of IPIlia K
When routing daemon wants to enable forwarding of multicast traffic it performs something like: struct vifctl vc = { .vifc_vifi = 1, .vifc_flags = 0, .vifc_threshold = 1, .vifc_rate_limit = 0, .vifc_lcl_addr = ip, /* <--- ip address of physical interface, e.g. eth0 */ .vifc_rmt_addr.s_addr = htonl(INADDR_ANY), }; setsockopt(fd, IPPROTO_IP, MRT_ADD_VIF, &vc, sizeof(vc)); This leads (in the kernel) to calling vif_add() function call which search the (physical) device using assigned IP address: dev = ip_dev_find(net, vifc->vifc_lcl_addr.s_addr); The current API (struct vifctl) does not allow to specify an interface other way than using it's IP, and if there are more than a single interface with specified IP only the first one will be found. The attached patch (against 2.6.30.4) allows to specify an interface by its index, instead of IP address: struct vifctl vc = { .vifc_vifi = 1, .vifc_flags = VIFF_USE_IFINDEX, /* NEW */ .vifc_threshold = 1, .vifc_rate_limit = 0, .vifc_lcl_ifindex = if_nametoindex("eth0"), /* NEW */ .vifc_rmt_addr.s_addr = htonl(INADDR_ANY), }; setsockopt(fd, IPPROTO_IP, MRT_ADD_VIF, &vc, sizeof(vc)); Signed-off-by: Ilia K. <mail4ilia@gmail.com> === modified file 'include/linux/mroute.h' Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22netns: ipmr: enable namespace support in ipv4 multicast routing codeBenjamin Thery
This last patch makes the appropriate changes to use and propagate the network namespace where needed in IPv4 multicast routing code. This consists mainly in replacing all the remaining init_net occurences with current netns pointer retrieved from sockets, net devices or mfc_caches depending on the routines' contexts. Some routines receive a new 'struct net' parameter to propagate the current netns: * vif_add/vif_delete * ipmr_new_tunnel * mroute_clean_tables * ipmr_cache_find * ipmr_cache_report * ipmr_cache_unresolved * ipmr_mfc_add/ipmr_mfc_delete * ipmr_get_route * rt_fill_info (in route.c) Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22netns: ipmr: store netns in struct mfc_cacheBenjamin Thery
This patch stores into struct mfc_cache the network namespace each mfc_cache belongs to. The new member is mfc_net. mfc_net is assigned at cache allocation and doesn't change during the rest of the cache entry life. A new net parameter is added to ipmr_cache_alloc/ipmr_cache_alloc_unres. This will help to retrieve the current netns around the IPv4 multicast routing code. At the moment, all mfc_cache are allocated in init_net. Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29net: Unbreak userspace usage of linux/mroute.hDavid S. Miller
Nothing in linux/pim.h should be exported to userspace. This should fix the XORP build failure reported by Jose Calhariz, the debain package maintainer. Nothing originally in linux/mroute.h was exported to userspace ever, but some of this stuff started to be when it was moved into this new linux/pim.h, and that was wrong. If we didn't provide these definitions for 10 years we can reasonably expect that applications defined this stuff locally or used GLIBC headers providing the protocol definitions. And as such the only result of this can be conflict and userland build breakage. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-03ipv4,ipv6 mroute: Add some helper inline functions to remove ugly ifdefs.YOSHIFUJI Hideaki
ip{,v6}_mroute_{set,get}sockopt() should not matter by optimization but it would be better not to depend on optimization semantically. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-07-03ipv4: Do cleanup for ip_mr_initWang Chen
Same as ip6_mr_init(), make ip_mr_init() return errno if fails. But do not do error handling in inet_init(), just print a msg. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-04[IPV4] MROUTE: Adjust include files for user-space.YOSHIFUJI Hideaki
<linux/mroute.h> needs <linux/types.h>. Avoid including <linux/in.h> in user-space, which conflicts with standard <netinet/in.h>. Add basic struct and constant in <linux/pim.h>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-04[IPV4] MROUTE: Move PIM definitions to <linux/pim.h>.YOSHIFUJI Hideaki
2007-11-07[IPV4]: Clean the ip_sockglue.c from some ugly ifdefsPavel Emelyanov
The #idfed CONFIG_IP_MROUTE is sometimes places inside the if-s, which looks completely bad. Similar ifdefs inside the functions looks a bit better, but they are also not recommended to be used. Provide an ifdef-ed ip_mroute_opt() helper to cleanup the code. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: mroute annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: PIMv2 header annotationsAl Viro
