Fix some kernel-doc typos/spellos.
Use kernel-doc syntax in places where it was almost used.
Correct/add struct, struct field, and function param names where needed.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Fix all kernel-doc warnings in MTD headers and source files:
- add some missing struct fields;
- correct some function parameter names;
- use kernel-doc format for function doc. headers;
- nand_ecc.c contains only exported interfaces, no internal ones;
* git://git.infradead.org/hdrcleanup-2.6: (63 commits)
[S390] __FD_foo definitions.
Switch to __s32 types in joystick.h instead of C99 types for consistency.
Add <sys/types.h> to headers included for userspace in <linux/input.h>
Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h
Remove struct fddi_statistics from user view in <linux/if_fddi.h>
Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390
Revert include/media changes: Mauro says those ioctls are only used in-kernel(!)
Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h>
Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too
Remove private struct dx_hash_info from public view in <linux/ext3_fs.h>
Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h>
Use __uXX types in <linux/divert.h> for struct divert_blk et al.
Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible.
Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely
Use __uXX types in user-visible structures in <linux/nbd.h>
Don't use 'u32' in user-visible struct ip_conntrack_old_tuple.
Use __uXX types for S390 DASD volume label definitions which are user-visible
S390 BIODASDREADCMB ioctl should use __u64 not u64 type.
Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h>
Fix private integer types used in V4L2 ioctls.
Manually resolve conflict in include/linux/mtd/physmap.h
Following problems are addressed:
- wrong status caused early break out of nand_wait()
- removed the bogus status check in nand_wait() which
is a relict of the abandoned support for interrupted
erase.
- status check moved to the correct place in read_oob
- oob support for syndrom based ecc with strange layouts
- use given offset in the AUTOOOB based oob operations
Partially based on a patch from Vitaly Vool <vwool@ru.mvista.com>
Thanks to Savin Zlobec <savin@epico.si> for tracking down the
status problem.
Hopefully the last iteration on this!
The handling of out of band data on NAND was accompanied by tons of fruitless
discussions and halfarsed patches to make it work for a particular
problem. Sufficiently annoyed by I all those "I know it better" mails and the
resonable amount of discarded "it solves my problem" patches, I finally decided
to go for the big rework. After removing the _ecc variants of mtd read/write
functions the solution to satisfy the various requirements was to refactor the
read/write _oob functions in mtd.
The major change is that read/write_oob now takes a pointer to an operation
descriptor structure "struct mtd_oob_ops".instead of having a function with at
least seven arguments.
read/write_oob which should probably renamed to a more descriptive name, can do
the following tasks:
- read/write out of band data
- read/write data content and out of band data
- read/write raw data content and out of band data (ecc disabled)
struct mtd_oob_ops has a mode field, which determines the oob handling mode.
Aside of the MTD_OOB_RAW mode, which is intended to be especially for
diagnostic purposes and some internal functions e.g. bad block table creation,
the other two modes are for mtd clients:
MTD_OOB_PLACE puts/gets the given oob data exactly to/from the place which is
described by the ooboffs and ooblen fields of the mtd_oob_ops strcuture. It's
up to the caller to make sure that the byte positions are not used by the ECC
placement algorithms.
MTD_OOB_AUTO puts/gets the given oob data automaticaly to/from the places in
the out of band area which are described by the oobfree tuples in the ecclayout
data structre which is associated to the devicee.
The decision whether data plus oob or oob only handling is done depends on the
setting of the datbuf member of the data structure. When datbuf == NULL then
the internal read/write_oob functions are selected, otherwise the read/write
data routines are invoked.
Tested on a few platforms with all variants. Please be aware of possible
regressions for your particular device / application scenario
Disclaimer: Any whining will be ignored from those who just contributed "hot
air blurb" and never sat down to tackle the underlying problem of the mess in
the NAND driver grown over time and the big chunk of work to fix up the
existing users. The problem was not the holiness of the existing MTD
interfaces. The problems was the lack of time to go for the big overhaul. It's
easy to add more mess to the existing one, but it takes alot of effort to go
for a real solution.
Improvements and bugfixes are welcome!
The nand_oobinfo structure is not fitting the newer error correction
demands anymore. Replace it by struct nand_ecclayout and fixup the users
all over the place. Keep the nand_oobinfo based ioctl for user space
compability reasons.
The platform structure was lacking an oobinfo field.
The NDFC driver had some remains from another tree.
Modularize the write function and reorganaize the internal buffer
management. Remove obsolete chip options and fixup all affected
users.
Split the core of the read function out and implement
seperate handling functions for software and hardware
ECC.
Add read/write function pointers to struct nand_ecc_ctrl to
prepare the modulaization of nand_read/write functions. The
current implementation handles every type of ecc mode
software/hardware and all kinds of strange ecc placement
schemes in one switch/if construct. Thats too complex to
maintain and too inflexible to expand. Modularization will
also shorten the code pathes of the read/write functions.
The nand driver has a superflous read ready / command
delay in the read functions. This was added to handle
chips which have an automatic read forward. Newer
chips do not have this functionality anymore. Add this
option to avoid the delay / I/O operation. Mark all
large page chips with the new option flag.
The previous change of the command / hardware control allows to
remove the write_byte/word functions completely, as their only
user were nand_command and nand_command_lp.
The hwcontrol function enforced a step by step state machine
for any kind of hardware chip access. Let the hardware driver
know which control bits are set and inform it about a change
of the control lines. Let the hardware driver write out the
command and address bytes directly. This gives a peformance
advantage for address bus controlled chips and simplifies the
quirks in the hardware drivers.
MTD clients are agnostic of FLASH which needs ECC suppport.
Remove the functions and fixup the callers.
Fix the broken prototype
First step of modularizing ECC support.
- Move ECC related functionality into a seperate embedded data structure
- Get rid of the hardware dependend constants to simplify new ECC models
The NAND driver used a mix of unsigned char, u_char amd uint8_t
data types. Consolidate to uint8_t usage
Add the data structures necessary to provide platform device support
for NAND
Replace the chip lock by a the controller lock. For simple drivers a
dummy controller structure is created by the scan code.
This simplifies the locking algorithm in nand_get/release_chip().
The changes introduced allow to suspend/resume NAND flash.
A new state (FL_PM_SUSPENDED) is introduced, as well as
routines for mtd->suspend and mtd->resume to put the flash in
suspended state from software pov.
Signed-off-by: Vitaly Wool <vwool@ru.mvista.com>
The code was wrong in several aspects. The locking order was
inconsistent, the device aquire code did not reset a variable
after a wakeup and the wakeup handling was not working for
applications where multiple chips are sharing a single
hardware controller.
When a hardware controller is available the locking is now
reduced to the hardware controller lock and the waitqueue is
moved to the hardware controller structure in order to avoid
a wake_up_all().
The problem was pointed out by Ben Dooks, who also found the
missing variable reset as main cause for his deadlock problem.
Signed-off-by: Nicolas S. Dade <daden@symbol.com>
Add optional hardware specific callback routine to perform extra error
status checks on erase and write failures for devices with hardware ECC.
Signed-off-by: David A. Marlin <dmarlin@redhat.com>
Added extended commands for AG-AND device and added
option for BBT_AUTO_REFRESH.
infrastructure for it.
Let it rip!
