path: root/include/linux/n_r3964.h
2015-10-17tty: r3964: Replace/remove bogus tty lock usePeter Hurley
The tty lock is strictly for serializing tty lifetime events (open/close/hangup), and not for line discipline serialization. The tty core already provides serialization of concurrent writes to the same tty, and line discipline lifetime management (by ldisc references), so pinning the tty via tty_lock() is unnecessary and counter-productive; remove tty lock use. However, the line discipline is responsible for serializing reads (if required by the line discipline); add read_lock mutex to serialize calls of r3964_read(). Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17tty: r3964: Use tty->read_wait waitqueuePeter Hurley
The tty core provides read_wait waitqueue specifically for line disciplines to wait readers; otherwise, the line discipline may miss wakeups generated by the tty core. NB: The tty core already provides serialization for the line discipline's close() method, and guarantees no readers or writers will be using the closing instance of the line discipline. Completely remove that wakeup. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2006-12-13[PATCH] n_r3964: Use struct pid to track user space clientsEric W. Biederman
Currently this driver tracks user space clients it should send signals to. In the presenct of file descriptor passing this is appears susceptible to confusion from pid wrap around issues. Replacing this with a struct pid prevents us from getting confused, and prepares for a pid namespace implementation. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-24[PATCH] n_r3964: fixed usage of HZ; removed bad includeKurt Huwig
Fix n_r3964 timeouts (hardcoded for 100Hz) Also the include of <asm/termios.h> in 'n_r3964.h' is unnecessary and prevents using the header file in any application that has to include <termios.h> due to duplicate definition of 'struct termio'. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
