These types are guaranteed to be defined by <linux/types.h> for
both userland and kernel, unlike u_intN_t.
Acked-by: Patrick McHardy <kaber@trash.net>
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Unification of struct *_error_target was forgotten in
v2.6.16-1689-g1e30a01.
Many of the used macros are just there for userspace compatibility.
Substitute the in-kernel code to directly use the terminal macro
and stuff the defines into #ifndef __KERNEL__ sections.
The macro is replaced by a list.h-like foreach loop. This makes
the code much more inspectable.
The static initial tables are pretty large, and after the net
namespace has been instantiated, they just hang around for nothing.
This commit removes them and creates tables on-demand at runtime when
needed.
Size shrinks by 7735 bytes (x86_64).
This cleanup patch puts struct/union/enum opening braces,
in first line to ease grep games.
struct something
becomes :
struct something {
The inputted table is never modified, so should be considered const.
Greg Steuck <greg@nest.cx> points out that some of the netfilter
headers can't be used in userspace without including linux/types.h
first. The headers include their own linux/types.h include statements,
these are stripped by make headers-install because they are inside
#ifdef __KERNEL__ however. Move them out to fix this.
Reported and Tested by Greg Steuck.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
* Propagate netns from userspace.
* arpt_register_table() registers table in supplied netns.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Typical table module registers xt_table structure (i.e. packet_filter)
and link it to list during it. We can't use one template for it because
corresponding list_head will become corrupted. We also can't unregister
with template because it wasn't changed at all and thus doesn't know in
which list it is.
So, we duplicate template at the very first step of table registration.
Table modules will save it for use during unregistration time and actual
filtering.
Do it at once to not screw bisection.
P.S.: renaming i.e. packet_filter => __packet_filter is temporary until
full netnsization of table modules is done.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
- move arp_tables initial table structure definitions to arp_tables.h
similar to ip_tables and ip6_tables
- use C99 initializers
- use initializer macros where possible
The included patch translates arpt_counters to xt_counters, making
userspace arptables compile against recent kernels.
Signed-off-by: Bart De Schuymer <bdschuym@pandora.be>
66 and 67 for getsockopt on IPv6 socket is doubly used for IPv6 Advanced
API and ip6tables. This moves numbers for ip6tables to 68 and 69.
This also kills XT_SO_* because {ip,ip6,arp}_tables doesn't have so much
common numbers now.
The old userland tools keep to behave as ever, because old kernel always
calls functions of IPv6 Advanced API for their numbers.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
This patch moves {ip,ip6,arp}t_entry_{match,target} definitions to
x_tables.h. This move simplifies code and future compatibility fixes.
Signed-off-by: Dmitry Mishin <dim@openvz.org>
Acked-off-by: Kirill Korotaev <dev@openvz.org>
Set the family field in xt_[matches|targets] registered.
This monster-patch tries to do the best job for unifying the data
structures and backend interfaces for the three evil clones ip_tables,
ip6_tables and arp_tables. In an ideal world we would never have
allowed this kind of copy+paste programming... but well, our world
isn't (yet?) ideal.
o introduce a new x_tables module
o {ip,arp,ip6}_tables depend on this x_tables module
o registration functions for tables, matches and targets are only
wrappers around x_tables provided functions
o all matches/targets that are used from ip_tables and ip6_tables
are now implemented as xt_FOOBAR.c files and provide module aliases
to ipt_FOOBAR and ip6t_FOOBAR
o header files for xt_matches are in include/linux/netfilter/,
include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers
around the xt_FOOBAR.h headers
Based on this patchset we're going to further unify the code,
gradually getting rid of all the layer 3 specific assumptions.
Signed-off-by: Harald Welte <laforge@netfilter.org>
Like ip_tables already has it for some time, this adds support for
having multiple revisions for each match/target. We steal one byte from
the name in order to accomodate a 8 bit version number.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
infrastructure for it.
Let it rip!
