path: root/include/linux/netfilter_ipv4.h
2015-09-29ipv4: Pass struct net into ip_route_me_harderEric W. Biederman
Don't make ip_route_me_harder guess which network namespace it is routing in, pass the network namespace in. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2013-09-26netfilter: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-08-30netfilter: add protocol independent NAT corePatrick McHardy
Convert the IPv4 NAT implementation to a protocol independent core and address family specific modules. Signed-off-by: Patrick McHardy <kaber@trash.net>
2012-06-16netfilter: add user-space connection tracking helper infrastructurePablo Neira Ayuso
There are good reasons to supports helpers in user-space instead: * Rapid connection tracking helper development, as developing code in user-space is usually faster. * Reliability: A buggy helper does not crash the kernel. Moreover, we can monitor the helper process and restart it in case of problems. * Security: Avoid complex string matching and mangling in kernel-space running in privileged mode. Going further, we can even think about running user-space helpers as a non-root process. * Extensibility: It allows the development of very specific helpers (most likely non-standard proprietary protocols) that are very likely not to be accepted for mainline inclusion in the form of kernel-space connection tracking helpers. This patch adds the infrastructure to allow the implementation of user-space conntrack helpers by means of the new nfnetlink subsystem `nfnetlink_cthelper' and the existing queueing infrastructure (nfnetlink_queue). I had to add the new hook NF_IP6_PRI_CONNTRACK_HELPER to register ipv[4|6]_helper which results from splitting ipv[4|6]_confirm into two pieces. This change is required not to break NAT sequence adjustment and conntrack confirmation for traffic that is enqueued to our user-space conntrack helpers. Basic operation, in a few steps: 1) Register user-space helper by means of `nfct': nfct helper add ftp inet tcp [ It must be a valid existing helper supported by conntrack-tools ] 2) Add rules to enable the FTP user-space helper which is used to track traffic going to TCP port 21. For locally generated packets: iptables -I OUTPUT -t raw -p tcp --dport 21 -j CT --helper ftp For non-locally generated packets: iptables -I PREROUTING -t raw -p tcp --dport 21 -j CT --helper ftp 3) Run the test conntrackd in helper mode (see example files under doc/helper/conntrackd.conf conntrackd 4) Generate FTP traffic going, if everything is OK, then conntrackd should create expectations (you can check that with `conntrack': conntrack -E expect [NEW] 301 proto=6 src=192.168.1.136 dst=130.89.148.12 sport=0 dport=54037 mask-src=255.255.255.255 mask-dst=255.255.255.255 sport=0 dport=65535 master-src=192.168.1.136 master-dst=130.89.148.12 sport=57127 dport=21 class=0 helper=ftp [DESTROY] 301 proto=6 src=192.168.1.136 dst=130.89.148.12 sport=0 dport=54037 mask-src=255.255.255.255 mask-dst=255.255.255.255 sport=0 dport=65535 master-src=192.168.1.136 master-dst=130.89.148.12 sport=57127 dport=21 class=0 helper=ftp This confirms that our test helper is receiving packets including the conntrack information, and adding expectations in kernel-space. The user-space helper can also store its private tracking information in the conntrack structure in the kernel via the CTA_HELP_INFO. The kernel will consider this a binary blob whose layout is unknown. This information will be included in the information that is transfered to user-space via glue code that integrates nfnetlink_queue and ctnetlink. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-08-26headers, netfilter: Add missing #include <limits.h> for userlandBen Hutchings
Various headers use INT_MIN and INT_MAX, which are defined for userland in <limits.h>. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-09netfilter: ip_tables: add iptables security table for mandatory access ↵James Morris
control rules The following patch implements a new "security" table for iptables, so that MAC (SELinux etc.) networking rules can be managed separately to standard DAC rules. This is to help with distro integration of the new secmark-based network controls, per various previous discussions. The need for a separate table arises from the fact that existing tools and usage of iptables will likely clash with centralized MAC policy management. The SECMARK and CONNSECMARK targets will still be valid in the mangle table to prevent breakage of existing users. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[NETFILTER]: nf_nat: kill helper and seq_adjust hooksPatrick McHardy
Connection tracking helpers (specifically FTP) need to be called before NAT sequence numbers adjustments are performed to be able to compare them against previously seen ones. We've introduced two new hooks around 2.6.11 to maintain this ordering when NAT modules were changed to get called from conntrack helpers directly. The cost of netfilter hooks is quite high and sequence number adjustments are only rarely needed however. Add a RCU-protected sequence number adjustment function pointer and call it from IPv4 conntrack after calling the helper. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-01-28[NETFILTER]: Introduce NF_INET_ hook valuesPatrick McHardy
The IPv4 and IPv6 hook values are identical, yet some code tries to figure out the "correct" value by looking at the address family. Introduce NF_INET_* values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__ section for userspace compatibility. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[NETFILTER]: bridge-netfilter: remove deferred hooksPatrick McHardy
Remove the deferred hooks and all related code as scheduled in feature-removal-schedule. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate __skb_checksum_complete() and friends.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[NETFILTER]: add type parameter to ip_route_me_harderSimon Horman
By adding a type parameter to ip_route_me_harder() the expensive call to inet_addr_type() can be avoided in some cases. A followup patch where ip_route_me_harder() is called from within ip_vs_out() is one such example. Signed-off-By: Simon Horman <horms@verge.net.au> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-09[NETFILTER]: Add address family specific checksum helpersPatrick McHardy
Add checksum operation which takes care of verifying the checksum and dealing with HW checksum errors and avoids multiple checksum operations by setting ip_summed to CHECKSUM_UNNECESSARY after successful verification. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-15[NETFILTER]: Fix xfrm lookup after SNATPatrick McHardy
To find out if a packet needs to be handled by IPsec after SNAT, packets are currently rerouted in POST_ROUTING and a new xfrm lookup is done. This breaks SNAT of non-unicast packets to non-local addresses because the packet is routed as incoming packet and no neighbour entry is bound to the dst_entry. In general, it seems to be a bad idea to replace the dst_entry after the packet was already sent to the output routine because its state might not match what's expected. This patch changes the xfrm lookup in POST_ROUTING to re-use the original dst_entry without routing the packet again. This means no policy routing can be used for transport mode transforms (which keep the original route) when packets are SNATed to match the policy, but it looks like the best we can do for now. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Rename skb_ip_make_writable() to skb_make_writable()Harald Welte
There is nothing IPv4-specific in it. In fact, it was already used by IPv6, too... Upcoming nfnetlink_queue code will use it for any kind of packet. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: reduce netfilter sk_buff enlargementHarald Welte
As discussed at netconf'05, we're trying to save every bit in sk_buff. The patch below makes sk_buff 8 bytes smaller. I did some basic testing on my notebook and it seems to work. The only real in-tree user of nfcache was IPVS, who only needs a single bit. Unfortunately I couldn't find some other free bit in sk_buff to stuff that bit into, so I introduced a separate field for them. Maybe the IPVS guys can resolve that to further save space. Initially I wanted to shrink pkt_type to three bits (PACKET_HOST and alike are only 6 values defined), but unfortunately the bluetooth code overloads pkt_type :( The conntrack-event-api (out-of-tree) uses nfcache, but Rusty just came up with a way how to do it without any skb fields, so it's safe to remove it. - remove all never-implemented 'nfcache' code - don't have ipvs code abuse 'nfcache' field. currently get's their own compile-conditional skb->ipvs_property field. IPVS maintainers can decide to move this bit elswhere, but nfcache needs to die. - remove skb->nfcache field to save 4 bytes - move skb->nfctinfo into three unused bits to save further 4 bytes Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[NETFILTER]: Kill nf_debugPatrick McHardy
2005-04-24[NETFILTER]: Fix NAT sequence number adjustmentPatrick McHardy
The NAT changes in 2.6.11 changed the position where helpers are called and perform packet mangling. Before 2.6.11, a NAT helper was called before the packet was NATed and had its sequence number adjusted. Since 2.6.11, the helpers get packets with already adjusted sequence numbers. This breaks sequence number adjustment, adjust_tcp_sequence() needs the original sequence number to determine whether a packet was a retransmission and to store it for further corrections. It can't be reconstructed without more information than available, so this patch restores the old order by calling helpers from a new conntrack hook two priorities below ip_conntrack_confirm() and adjusting the sequence number from a new NAT hook one priority below ip_conntrack_confirm(). Tracked down by Phil Oester <kernel@linuxace.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
