path: root/include/linux/netfilter_ipv4/ipt_LOG.h
2006-12-02[NETFILTER]: x_tables: add NFLOG targetPatrick McHardy
Add new NFLOG target to allow use of nfnetlink_log for both IPv4 and IPv6. Currently we have two (unsupported by userspace) hacks in the LOG and ULOG targets to optionally call to the nflog API. They lack a few features, namely the IPv4 and IPv6 LOG targets can not specify a number of arguments related to nfnetlink_log, while the ULOG target is only available for IPv4. Remove those hacks and add a clean way to use nfnetlink_log. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-02-27[NETFILTER]: Restore {ipt,ip6t,ebt}_LOG compatibilityPatrick McHardy
The nfnetlink_log infrastructure changes broke compatiblity of the LOG targets. They currently use whatever log backend was registered first, which means that if ipt_ULOG was loaded first, no messages will be printed to the ring buffer anymore. Restore compatiblity by using the old log functions by default and only use the nf_log backend if the user explicitly said so. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Extend netfilter logging APIHarald Welte
This patch is in preparation to nfnetlink_log: - loggers now have to register struct nf_logger instead of nf_logfn - nf_log_unregister() replaced by nf_log_unregister_pf() and nf_log_unregister_logger() - add comment to ip[6]t_LOG.h to assure nobody redefines flags - add /proc/net/netfilter/nf_log to tell user which logger is currently registered for which address family - if user has configured logging, but no logging backend (logger) is available, always spit a message to syslog, not just the first time. - split ip[6]t_LOG.c into two parts: Backend: Always try to register as logger for the respective address family Frontend: Always log via nf_log_packet() API - modify all users of nf_log_packet() to accomodate additional argument Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
