Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Unification of struct *_error_target was forgotten in
v2.6.16-1689-g1e30a01.
Many of the used macros are just there for userspace compatibility.
Substitute the in-kernel code to directly use the terminal macro
and stuff the defines into #ifndef __KERNEL__ sections.
unifdef-y and header-y has same semantic.
So there is no need to have both.
Drop the unifdef-y variant and sort all lines again
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
The LOG targets print the entire MAC header as one long string, which is not
readable very well:
IN=eth0 OUT= MAC=00:15:f2:24:91:f8:00:1b:24:dc:61:e6:08:00 ...
Add an option to decode known header formats (currently just ARPHRD_ETHER devices)
in their individual fields:
IN=eth0 OUT= MACSRC=00:1b:24:dc:61:e6 MACDST=00:15:f2:24:91:f8 MACPROTO=0800 ...
IN=eth0 OUT= MACSRC=00:1b:24:dc:61:e6 MACDST=00:15:f2:24:91:f8 MACPROTO=86dd ...
The option needs to be explicitly enabled by userspace to avoid breaking
existing parsers.
The macro is replaced by a list.h-like foreach loop. This makes
the code more inspectable.
the code much more inspectable.
The static initial tables are pretty large, and after the net
namespace has been instantiated, they just hang around for nothing.
This commit removes them and creates tables on-demand at runtime when
needed.
Size shrinks by 7735 bytes (x86_64).
Add ->net to match destructor list like ->net in constructor list.
Make sure it's set in ebtables/iptables/ip6tables, this requires to
propagate netns up to *_unregister_table().
This cleanup patch puts struct/union/enum opening braces,
in first line to ease grep games.
struct something
becomes :
struct something {
The inputted table is never modified, so should be considered const.
When IPv4 and IPv6 matches were unified approx. 3.5 years ago, they
received new header filenames (e.g. xt_CLASSIFY.h). Let's remove the
old ones now.
Superseded by xt_owner v1 (v2.6.24-2388-g0265ab4).
Superseded by xt_iprange v1 (v2.6.24-2928-g1a50c5a1).
Superseded by xt_TOS v1 (v2.6.24-2396-g5c350e5).
A number of standard posix types are used in exported headers, which
is not allowed if __STRICT_KERNEL_NAMES is defined. In order to
get rid of the non-__STRICT_KERNEL_NAMES part and to make sane headers
the default, we have to change them all to safe types.
There are also still some leftovers in reiserfs_fs.h, elfcore.h
and coda.h, but these files have not compiled in user space for
a long time.
This leaves out the various integer types ({u_,u,}int{8,16,32,64}_t),
which we take care of separately.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Cc: netdev@vger.kernel.org
Cc: linux-ppp@vger.kernel.org
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
It seems that all of the include/netfilter_{ipv4,ipv6}/{ipt,ip6t}_*.h which
share constants include the corresponding include/netfilter/xp_*.h files.
Neither ipt_policy.h not ip6t_policy.h do. Make these consistant with
the norm.
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Like with other modules (such as ipt_state), ipt_recent.h is changed
to forward definitions to (IOW include) xt_recent.h, and xt_recent.c
is changed to use the new constant names.
Greg Steuck <greg@nest.cx> points out that some of the netfilter
headers can't be used in userspace without including linux/types.h
first. The headers include their own linux/types.h include statements,
these are stripped by make headers-install because they are inside
#ifdef __KERNEL__ however. Move them out to fix this.
Reported and Tested by Greg Steuck.
Typical table module registers xt_table structure (i.e. packet_filter)
and link it to list during it. We can't use one template for it because
corresponding list_head will become corrupted. We also can't unregister
with template because it wasn't changed at all and thus doesn't know in
which list it is.
So, we duplicate template at the very first step of table registration.
Table modules will save it for use during unregistration time and actual
filtering.
Do it at once to not screw bisection.
P.S.: renaming i.e. packet_filter => __packet_filter is temporary until
full netnsization of table modules is done.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
This patch moves ipt_iprange to xt_iprange, in preparation for adding
IPv6 support to xt_iprange.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Use compat types and compat iterators when dealing with compat entries for
clarity. This doesn't actually make a difference for ip_tables, but is
needed for ip6_tables and arp_tables.
Addrtype match has a new revision (1), which lets address type checking
limited to the interface the current packet belongs to. Either incoming
or outgoing interface can be used depending on the current hook. In the
FORWARD hook two maches should be used if both interfaces have to be checked.
The new structure is ipt_addrtype_info_v1.
Revision 0 lets older userspace programs use the match as earlier.
ipt_addrtype_info is used.
Signed-off-by: Laszlo Attila Toth <panther@balabit.hu>
The IPv4 and IPv6 hook values are identical, yet some code tries to figure
out the "correct" value by looking at the address family. Introduce NF_INET_*
values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__
section for userspace compatibility.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Sort matches and targets in the Kbuild file.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
ipt_iprange.h must #include <linux/types.h> since it uses __be32.
This patch fixes kernel Bugzilla #7604.
Adjust structure size and don't expect pointers passed in from
userspace to be valid. Also replace an enum in an ABI structure
by a fixed size type.
check_compat_entry_size_and_hooks iterates over the matches and calls
compat_check_calc_match, which loads the match and calculates the
compat offsets, but unlike the non-compat version, doesn't call
->checkentry yet. On error however it calls cleanup_matches, which in
turn calls ->destroy, which can result in crashes if the destroy
function (validly) expects to only get called after the checkentry
function.
Add a compat_release_match function that only drops the module reference
on error and rename compat_check_calc_match to compat_find_calc_match to
reflect the fact that it doesn't call the checkentry function.
Reported by Jan Engelhardt <jengelh@linux01.gwdg.de>
Signed-off-by: Dmitry Mishin <dim@openvz.org>
- move arp_tables initial table structure definitions to arp_tables.h
similar to ip_tables and ip6_tables
- use C99 initializers
- use initializer macros where possible
Remove the obsolete IPv4 only connection tracking/NAT as scheduled in
feature-removal-schedule.
Fix {nf,ip}_ct_iterate_cleanup unconfirmed list handling:
- unconfirmed entries can not be killed manually, they are removed on
confirmation or final destruction of the conntrack entry, which means
we might iterate forever without making forward progress.
This can happen in combination with the conntrack event cache, which
holds a reference to the conntrack entry, which is only released when
the packet makes it all the way through the stack or a different
packet is handled.
- taking references to an unconfirmed entry and using it outside the
locked section doesn't work, the list entries are not refcounted and
another CPU might already be waiting to destroy the entry
What the code really wants to do is make sure the references of the hash
table to the selected conntrack entries are released, so they will be
destroyed once all references from skbs and the event cache are dropped.
Since unconfirmed entries haven't even entered the hash yet, simply mark
them as dying and skip confirmation based on that.
Reported and tested by Chuck Ebbert <cebbert@redhat.com>
CONNTRACK_STAT_INC assumes rcu_read_lock in nf_hook_slow disables
preemption as well, making it legal to use __get_cpu_var without
disabling preemption manually. The assumption is not correct anymore
with preemptable RCU, additionally we need to protect against softirqs
when not holding ip_conntrack_lock.
Add CONNTRACK_STAT_INC_ATOMIC macro, which disables local softirqs,
and use where necessary.
function
structure names
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Use the x_tables functions directly to make it better visible which
parts are shared between ip_tables and ip6_tables.
This patch adds support to NAT to randomize source ports.
Signed-off-by: Eric Leblond <eric@inl.fr>
With the introduction of x_tables we accidentally broke compatibility
by defining IPT_TABLE_MAXNAMELEN to XT_FUNCTION_MAXNAMELEN instead of
XT_TABLE_MAXNAMELEN, which is two bytes larger.
On most architectures it doesn't really matter since we don't have
any tables with names that long in the kernel and the structure
layout didn't change because of alignment requirements of following
members. On CRIS however (and other architectures that don't align
data) this changed the structure layout and thus broke compatibility
with old iptables binaries.
Changing it back will break compatibility with binaries compiled
against recent kernels again, but since the breakage has only been
there for three releases this seems like the better choice.
Spotted by Jonas Berlin <xkr47@outerspace.dyndns.org>.
Add IPv4 and IPv6 capable nf_conntrack port of the H.323 conntrack/NAT helper.
Add FTP NAT helper.
Split out from Jozsef's big nf_nat patch with a few small fixes by myself.
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Add new NFLOG target to allow use of nfnetlink_log for both IPv4 and IPv6.
Currently we have two (unsupported by userspace) hacks in the LOG and ULOG
targets to optionally call to the nflog API. They lack a few features,
namely the IPv4 and IPv6 LOG targets can not specify a number of arguments
related to nfnetlink_log, while the ULOG target is only available for IPv4.
Remove those hacks and add a clean way to use nfnetlink_log.
The NAT handling of the SIP helper has a few problems:
- Request headers are only mangled in the reply direction, From/To headers
not at all, which can lead to authentication failures with DNAT in case
the authentication domain is the IP address
- Contact headers in responses are only mangled for REGISTER responses
- Headers may be mangled even though they contain addresses not
participating in the connection, like alternative addresses
- Packets are droppen when domain names are used where the helper expects
IP addresses
This patch takes a different approach, instead of fixed rules what field
to mangle to what content, it adds symetric mapping of From/To/Via/Contact
headers, which allows to deal properly with echoed addresses in responses
and foreign addresses not belonging to the connection.
SIP headers are generally case-insensitive, only SDP headers are
case sensitive.
