The values of ops->hooknum and state->hook are guaraneted to be equal
making the hook argument to ip6t_do_table, arp_do_table, and
ipt_do_table is unnecessary. Remove the unnecessary hook argument.
In the callers use state->hook instead of ops->hooknum for clarity and
to reduce the number of cachelines the callers touch.
Remove non-UAPI Kbuild files that have become empty as a result of UAPI
disintegration. They used to have only header-y lines in them and those have
now moved to the Kbuild files in the corresponding uapi/ directories.
Possibly these should not be removed but rather have a comment inserted to say
they are intentionally left blank. This would make it easier to add generated
header lines in future without having to restore the infrastructure.
Note that at this point not all the UAPI disintegration parts have been merged,
so it is likely that more empty Kbuild files will turn up.
It is probably necessary to make the files non-empty to prevent the patch
program from automatically deleting them when it reduces them to nothing.
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
It was scheduled to be removed.
Acked-by: Florian Westphal <fw@strlen.de>
This patch removes ip_queue support which was marked as obsolete
years ago. The nfnetlink_queue modules provides more advanced
user-space packet queueing mechanism.
This patch also removes capability code included in SELinux that
refers to ip_queue. Otherwise, we break compilation.
Several warning has been sent regarding this to the mailing list
in the past month without anyone rising the hand to stop this
with some strong argument.
These two headers are not required anymore, they have been
replaced by xt_SAME.h and xt_realm.h.
Florian Westphal pointed out this.
Cc: Florian Westphal <fw@strlen.de>
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.
ipt_LOG and ip6_LOG have a lot of common code, merge them
to reduce duplicate code.
Signed-off-by: Richard Weinberger <richard@nod.at>
Use the new macro and struct names in xt_ecn.h, and put the old
definitions into a definition-forwarding ipt_ecn.h.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Prepare the ECN match for augmentation by an IPv6 counterpart. Since
no symbol dependencies to ipv6.ko are added, having a single ecn match
module is the more so welcome.
Export the NAT definitions to userspace. So far userspace (specifically,
iptables) has been copying the headers files from include/net. Also
rename some structures and definitions in preparation for IPv6 NAT.
Since these have never been officially exported, this doesn't affect
existing userspace code.
This patch exports several definitions that used to live under
include/net/netfilter/nf_nat.h. These definitions, although not
exported, have been used by iptables and other userspace
applications like miniupnpd since long time. Basically, these
userspace tools included some internal definition of the required
structures and they assume no changes in the binary representation
(which is OK indeed).
To resolve this situation, this patch makes public the required
structure and install them in INSTALL_HDR_PATH.
See: https://bugs.gentoo.org/376873, for more information.
This patch is heavily based on the initial patch sent by:
Anthony G. Basile <blueness@gentoo.org>
Which was entitled:
netfilter: export sanitized nf_nat.h to INSTALL_HDR_PATH
These types are guaranteed to be defined by <linux/types.h> for
both userland and kernel, unlike u_intN_t.
Acked-by: Patrick McHardy <kaber@trash.net>
Resolve these warnings on `make headers_check`:
usr/include/linux/netfilter/xt_CT.h:7: found __[us]{8,16,32,64} type
without #include <linux/types.h>
Unification of struct *_error_target was forgotten in
v2.6.16-1689-g1e30a01.
Many of the used macros are just there for userspace compatibility.
Substitute the in-kernel code to directly use the terminal macro
and stuff the defines into #ifndef __KERNEL__ sections.
unifdef-y and header-y has same semantic.
So there is no need to have both.
Drop the unifdef-y variant and sort all lines again
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
The LOG targets print the entire MAC header as one long string, which is not
readable very well:
IN=eth0 OUT= MAC=00:15:f2:24:91:f8:00:1b:24:dc:61:e6:08:00 ...
Add an option to decode known header formats (currently just ARPHRD_ETHER devices)
in their individual fields:
IN=eth0 OUT= MACSRC=00:1b:24:dc:61:e6 MACDST=00:15:f2:24:91:f8 MACPROTO=0800 ...
IN=eth0 OUT= MACSRC=00:1b:24:dc:61:e6 MACDST=00:15:f2:24:91:f8 MACPROTO=86dd ...
The option needs to be explicitly enabled by userspace to avoid breaking
existing parsers.
The macro is replaced by a list.h-like foreach loop. This makes
the code more inspectable.
the code much more inspectable.
The static initial tables are pretty large, and after the net
namespace has been instantiated, they just hang around for nothing.
This commit removes them and creates tables on-demand at runtime when
needed.
Size shrinks by 7735 bytes (x86_64).
Add ->net to match destructor list like ->net in constructor list.
Make sure it's set in ebtables/iptables/ip6tables, this requires to
propagate netns up to *_unregister_table().
This cleanup patch puts struct/union/enum opening braces,
in first line to ease grep games.
struct something
becomes :
struct something {
The inputted table is never modified, so should be considered const.
When IPv4 and IPv6 matches were unified approx. 3.5 years ago, they
received new header filenames (e.g. xt_CLASSIFY.h). Let's remove the
old ones now.
Superseded by xt_owner v1 (v2.6.24-2388-g0265ab4).
Superseded by xt_iprange v1 (v2.6.24-2928-g1a50c5a1).
Superseded by xt_TOS v1 (v2.6.24-2396-g5c350e5).
A number of standard posix types are used in exported headers, which
is not allowed if __STRICT_KERNEL_NAMES is defined. In order to
get rid of the non-__STRICT_KERNEL_NAMES part and to make sane headers
the default, we have to change them all to safe types.
There are also still some leftovers in reiserfs_fs.h, elfcore.h
and coda.h, but these files have not compiled in user space for
a long time.
This leaves out the various integer types ({u_,u,}int{8,16,32,64}_t),
which we take care of separately.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Cc: netdev@vger.kernel.org
Cc: linux-ppp@vger.kernel.org
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
It seems that all of the include/netfilter_{ipv4,ipv6}/{ipt,ip6t}_*.h which
share constants include the corresponding include/netfilter/xp_*.h files.
Neither ipt_policy.h not ip6t_policy.h do. Make these consistant with
the norm.
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Like with other modules (such as ipt_state), ipt_recent.h is changed
to forward definitions to (IOW include) xt_recent.h, and xt_recent.c
is changed to use the new constant names.
Greg Steuck <greg@nest.cx> points out that some of the netfilter
headers can't be used in userspace without including linux/types.h
first. The headers include their own linux/types.h include statements,
these are stripped by make headers-install because they are inside
#ifdef __KERNEL__ however. Move them out to fix this.
Reported and Tested by Greg Steuck.
Typical table module registers xt_table structure (i.e. packet_filter)
and link it to list during it. We can't use one template for it because
corresponding list_head will become corrupted. We also can't unregister
with template because it wasn't changed at all and thus doesn't know in
which list it is.
So, we duplicate template at the very first step of table registration.
Table modules will save it for use during unregistration time and actual
filtering.
Do it at once to not screw bisection.
P.S.: renaming i.e. packet_filter => __packet_filter is temporary until
full netnsization of table modules is done.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
This patch moves ipt_iprange to xt_iprange, in preparation for adding
IPv6 support to xt_iprange.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Use compat types and compat iterators when dealing with compat entries for
clarity. This doesn't actually make a difference for ip_tables, but is
needed for ip6_tables and arp_tables.
Addrtype match has a new revision (1), which lets address type checking
limited to the interface the current packet belongs to. Either incoming
or outgoing interface can be used depending on the current hook. In the
FORWARD hook two maches should be used if both interfaces have to be checked.
The new structure is ipt_addrtype_info_v1.
Revision 0 lets older userspace programs use the match as earlier.
ipt_addrtype_info is used.
Signed-off-by: Laszlo Attila Toth <panther@balabit.hu>
The IPv4 and IPv6 hook values are identical, yet some code tries to figure
out the "correct" value by looking at the address family. Introduce NF_INET_*
values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__
section for userspace compatibility.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Sort matches and targets in the Kbuild file.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
ipt_iprange.h must #include <linux/types.h> since it uses __be32.
This patch fixes kernel Bugzilla #7604.
Adjust structure size and don't expect pointers passed in from
userspace to be valid. Also replace an enum in an ABI structure
by a fixed size type.
check_compat_entry_size_and_hooks iterates over the matches and calls
compat_check_calc_match, which loads the match and calculates the
compat offsets, but unlike the non-compat version, doesn't call
->checkentry yet. On error however it calls cleanup_matches, which in
turn calls ->destroy, which can result in crashes if the destroy
function (validly) expects to only get called after the checkentry
function.
Add a compat_release_match function that only drops the module reference
on error and rename compat_check_calc_match to compat_find_calc_match to
reflect the fact that it doesn't call the checkentry function.
Reported by Jan Engelhardt <jengelh@linux01.gwdg.de>
Signed-off-by: Dmitry Mishin <dim@openvz.org>
- move arp_tables initial table structure definitions to arp_tables.h
similar to ip_tables and ip6_tables
- use C99 initializers
- use initializer macros where possible
Remove the obsolete IPv4 only connection tracking/NAT as scheduled in
feature-removal-schedule.
