commit 50ab8ec74a153eb30db26529088bc57dd700b24c upstream.
See http: //www.infradead.org/rpr.html
X-Evolution-Source: 1451162204.2173.11@leira.trondhjem.org
Content-Transfer-Encoding: 8bit
Mime-Version: 1.0
We support OFFSET_MAX just fine, so don't round down below it. Also
switch to using min_t to make the helper more readable.
Fixes: 433c92379d9c ("NFS: Clean up nfs_size_to_loff_t()")
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
And call nfs_file_clear_open_context() directly. This makes it obvious
that nfs_file_release() will always return 0.
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
I'm not aware of any existing bugs around this, but the expectation is
that nfs_mark_for_revalidate() should always force a revalidation of
the cached metadata.
There is no need to report concurrently.
Reviewed-by: Jeff Layton <jeff.layton@primarydata.com>
Signed-off-by: Peng Tao <tao.peng@primarydata.com>
Pull NFS client updates from Trond Myklebust:
"Another set of mainly bugfixes and a couple of cleanups. No new
functionality in this round.
Highlights include:
Stable patches:
- Fix a regression in /proc/self/mountstats
- Fix the pNFS flexfiles O_DIRECT support
- Fix high load average due to callback thread sleeping
Bugfixes:
- Various patches to fix the pNFS layoutcommit support
- Do not cache pNFS deviceids unless server notifications are enabled
- Fix a SUNRPC transport reconnection regression
- make debugfs file creation failure non-fatal in SUNRPC
- Another fix for circular directory warnings on NFSv4 "junctioned"
mountpoints
- Fix locking around NFSv4.2 fallocate() support
- Truncating NFSv4 file opens should also sync O_DIRECT writes
- Prevent infinite loop in rpcrdma_ep_create()
Features:
- Various improvements to the RDMA transport code's handling of
memory registration
- Various code cleanups"
* tag 'nfs-for-4.1-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (55 commits)
fs/nfs: fix new compiler warning about boolean in switch
nfs: Remove unneeded casts in nfs
NFS: Don't attempt to decode missing directory entries
Revert "nfs: replace nfs_add_stats with nfs_inc_stats when add one"
NFS: Rename idmap.c to nfs4idmap.c
NFS: Move nfs_idmap.h into fs/nfs/
NFS: Remove CONFIG_NFS_V4 checks from nfs_idmap.h
NFS: Add a stub for GETDEVICELIST
nfs: remove WARN_ON_ONCE from nfs_direct_good_bytes
nfs: fix DIO good bytes calculation
nfs: Fetch MOUNTED_ON_FILEID when updating an inode
sunrpc: make debugfs file creation failure non-fatal
nfs: fix high load average due to callback thread sleeping
NFS: Reduce time spent holding the i_mutex during fallocate()
NFS: Don't zap caches on fallocate()
xprtrdma: Make rpcrdma_{un}map_one() into inline functions
xprtrdma: Handle non-SEND completions via a callout
xprtrdma: Add "open" memreg op
xprtrdma: Add "destroy MRs" memreg op
xprtrdma: Add "reset MRs" memreg op
Now that no one is using rw, remove it completely.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
We don't just want to sync out buffered writes, but also O_DIRECT ones.
When invalidating the page cache for a regular file, we want to first
sync all dirty data to disk and then call invalidate_inode_pages2().
The latter relies on nfs_launder_page() and nfs_release_page() to deal
respectively with dirty pages, and unstable written pages.
When commit 9590544694bec ("NFS: avoid deadlocks with loop-back mounted
NFS filesystems.") changed the behaviour of nfs_release_page(), then it
made it possible for invalidate_inode_pages2() to fail with an EBUSY.
Unfortunately, that error is then propagated back to read().
Let's therefore work around the problem for now by protecting the call
to sync the data and invalidate_inode_pages2() so that they are atomic
w.r.t. the addition of new writes.
Later on, we can revisit whether or not we still need nfs_launder_page()
and nfs_release_page().
Ensure that other operations that race with our write RPC calls
cannot revert the file size updates that were made on the server.
Tested-by: Chuck Lever <chuck.lever@oracle.com>
Ensure that other operations which raced with our setattr RPC call
cannot revert the file attribute changes that were made on the server.
To do so, we artificially bump the attribute generation counter on
the inode so that all calls to nfs_fattr_init() that precede ours
will be dropped.
The motivation for the patch came from Chuck Lever's reports of readaheads
racing with truncate operations and causing the file size to be reverted.
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Recent work in the pgio layer made it possible for there to be more than one
request per page. This caused a subtle change in commit behavior, because
write.c:nfs_commit_unstable_pages compares the number of *pages* waiting for
writeback against the number of requests on a commit list to choose when to
send a COMMIT in a non-blocking flush.
This is probably hard to hit in normal operation - you have to be using
rsize/wsize < PAGE_SIZE, or pnfs with lots of boundaries that are not page
aligned to have a noticeable change in behavior.
Signed-off-by: Weston Andros Adamson <dros@primarydata.com>
Pull core block layer changes from Jens Axboe:
"This is the core block IO pull request for 3.18. Apart from the new
and improved flush machinery for blk-mq, this is all mostly bug fixes
and cleanups.
- blk-mq timeout updates and fixes from Christoph.
- Removal of REQ_END, also from Christoph. We pass it through the
->queue_rq() hook for blk-mq instead, freeing up one of the request
bits. The space was overly tight on 32-bit, so Martin also killed
REQ_KERNEL since it's no longer used.
- blk integrity updates and fixes from Martin and Gu Zheng.
- Update to the flush machinery for blk-mq from Ming Lei. Now we
have a per hardware context flush request, which both cleans up the
code should scale better for flush intensive workloads on blk-mq.
- Improve the error printing, from Rob Elliott.
- Backing device improvements and cleanups from Tejun.
- Fixup of a misplaced rq_complete() tracepoint from Hannes.
- Make blk_get_request() return error pointers, fixing up issues
where we NULL deref when a device goes bad or missing. From Joe
Lawrence.
- Prep work for drastically reducing the memory consumption of dm
devices from Junichi Nomura. This allows creating clone bio sets
without preallocating a lot of memory.
- Fix a blk-mq hang on certain combinations of queue depths and
hardware queues from me.
- Limit memory consumption for blk-mq devices for crash dump
scenarios and drivers that use crazy high depths (certain SCSI
shared tag setups). We now just use a single queue and limited
depth for that"
* 'for-3.18/core' of git://git.kernel.dk/linux-block: (58 commits)
block: Remove REQ_KERNEL
blk-mq: allocate cpumask on the home node
bio-integrity: remove the needless fail handle of bip_slab creating
block: include func name in __get_request prints
block: make blk_update_request print prefix match ratelimited prefix
blk-merge: don't compute bi_phys_segments from bi_vcnt for cloned bio
block: fix alignment_offset math that assumes io_min is a power-of-2
blk-mq: Make bt_clear_tag() easier to read
blk-mq: fix potential hang if rolling wakeup depth is too high
block: add bioset_create_nobvec()
block: use bio_clone_fast() in blk_rq_prep_clone()
block: misplaced rq_complete tracepoint
sd: Honor block layer integrity handling flags
block: Replace strnicmp with strncasecmp
block: Add T10 Protection Information functions
block: Don't merge requests if integrity flags differ
block: Integrity checksum flag
block: Relocate bio integrity flags
block: Add a disk flag to block integrity profile
block: Add prefix to block integrity profile flags
REQ_KERNEL is no longer used. Remove it and drop the redundant uio
argument to nfs_file_direct_{read,write}.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
This code is internal to the v3 module, so other parts of the client
shouldn't have any knowledge of it.
nfs3_getxattr(), nfs3_setxattr(), and nfs3_removexattr() no longer exist
anywhere so I remove the declarations while I'm here.
The goal is to create a generic NFS module with code that does not
depend on what versions of NFS are enabled.
The access cache is used during RCU-walk path lookups, so it is best
to avoid locking if possible as taking a lock kills concurrency.
The rbtree is not rcu-safe and cannot easily be made so.
Instead we simply check the last (i.e. most recent) entry on the LRU
list. If this doesn't match, then we return -ECHILD and retry in
lock/refcount mode.
This requires freeing the nfs_access_entry struct with rcu, and
requires using rcu access primatives when adding entries to the lru, and
when examining the last entry.
Calling put_rpccred before kfree_rcu looks a bit odd, but as
put_rpccred already provides rcu protection, we know that the cred will
not actually be freed until the next grace period, so any concurrent
access will be safe.
This patch provides about 5% performance improvement on a stat-heavy
synthetic work load with 4 threads on a 2-core CPU.
Signed-off-by: NeilBrown <neilb@suse.de>
This requires nfs_check_verifier to take an rcu_walk flag, and requires
an rcu version of nfs_revalidate_inode which returns -ECHILD rather
than making an RPC call.
With this, nfs_lookup_revalidate can call nfs_neg_need_reval in
RCU-walk mode.
We can also move the LOOKUP_RCU check past the nfs_check_verifier()
call in nfs_lookup_revalidate.
If RCU_WALK prevents nfs_check_verifier or nfs_neg_need_reval from
doing a full check, they return a status indicating that a revalidation
is required. As this revalidation will not be possible in RCU_WALK
mode, -ECHILD will ultimately be returned, which is the desired result.
Pull vfs updates from Al Viro:
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
Combining these functions will let me make a single nfs_rw_common_ops
struct (see the next patch).
At this point, the only difference between nfs_read_data and
nfs_write_data is the write verifier.
unmodified, for now
...and move the prototype for nfs_sillyrename to internal.h.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Tested-by: Anna Schumaker <Anna.Schumaker@netapp.com>
Try to detect 'ls -l' by having nfs_getattr() look at whether or not
there is an opendir() file descriptor for the parent directory.
If so, then assume that we want to force use of readdirplus in order
to avoid the multiple GETATTR calls over the wire.
Pull NFS client bugfixes from Trond Myklebust:
"Highlights:
- Fix several races in nfs_revalidate_mapping
- NFSv4.1 slot leakage in the pNFS files driver
- Stable fix for a slot leak in nfs40_sequence_done
- Don't reject NFSv4 servers that support ACLs with only ALLOW aces"
* tag 'nfs-for-3.14-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
nfs: initialize the ACL support bits to zero.
NFSv4.1: Cleanup
NFSv4.1: Clean up nfs41_sequence_done
NFSv4: Fix a slot leak in nfs40_sequence_done
NFSv4.1 free slot before resending I/O to MDS
nfs: add memory barriers around NFS_INO_INVALID_DATA and NFS_INO_INVALIDATING
NFS: Fix races in nfs_revalidate_mapping
sunrpc: turn warn_gssd() log message into a dprintk()
NFS: fix the handling of NFS_INO_INVALID_DATA flag in nfs_revalidate_mapping
nfs: handle servers that support only ALLOW ACE type.
There is a possible race in how the nfs_invalidate_mapping function is
handled. Currently, we go and invalidate the pages in the file and then
clear NFS_INO_INVALID_DATA.
The problem is that it's possible for a stale page to creep into the
mapping after the page was invalidated (i.e., via readahead). If another
writer comes along and sets the flag after that happens but before
invalidate_inode_pages2 returns then we could clear the flag
without the cache having been properly invalidated.
So, we must clear the flag first and then invalidate the pages. Doing
this however, opens another race:
It's possible to have two concurrent read() calls that end up in
nfs_revalidate_mapping at the same time. The first one clears the
NFS_INO_INVALID_DATA flag and then goes to call nfs_invalidate_mapping.
Just before calling that though, the other task races in, checks the
flag and finds it cleared. At that point, it trusts that the mapping is
good and gets the lock on the page, allowing the read() to be satisfied
from the cache even though the data is no longer valid.
These effects are easily manifested by running diotest3 from the LTP
test suite on NFS. That program does a series of DIO writes and buffered
reads. The operations are serialized and page-aligned but the existing
code fails the test since it occasionally allows a read to come out of
the cache incorrectly. While mixing direct and buffered I/O isn't
recommended, I believe it's possible to hit this in other ways that just
use buffered I/O, though that situation is much harder to reproduce.
The problem is that the checking/clearing of that flag and the
invalidation of the mapping really need to be atomic. Fix this by
serializing concurrent invalidations with a bitlock.
At the same time, we also need to allow other places that check
NFS_INO_INVALID_DATA to check whether we might be in the middle of
invalidating the file, so fix up a couple of places that do that
to look for the new NFS_INO_INVALIDATING flag.
Doing this requires us to be careful not to set the bitlock
unnecessarily, so this code only does that if it believes it will
be doing an invalidation.
This causes a small behaviour change in that we don't bother to set
ACLs on file creation if the mode bit can express the access permissions
fully, and thus behaving identical to local filesystems.
When CONFIG_NFS_V4_2 is toggled nfsd and lockd will be recompiled,
instead of only the nfs client. This patch moves a small amount of code
into the client directory to avoid unnecessary recompiles.
Signed-off-by: Anna Schumaker <bjschuma@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Use i_writecount to control whether to get an fscache cookie in nfs_open() as
NFS does not do write caching yet. I *think* this is the cause of a problem
encountered by Mark Moseley whereby __fscache_uncache_page() gets a NULL
pointer dereference because cookie->def is NULL:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
IP: [<ffffffff812a1903>] __fscache_uncache_page+0x23/0x160
PGD 0
Thread overran stack, or stack corrupted
Oops: 0000 [#1] SMP
Modules linked in: ...
CPU: 7 PID: 18993 Comm: php Not tainted 3.11.1 #1
Hardware name: Dell Inc. PowerEdge R420/072XWF, BIOS 1.3.5 08/21/2012
task: ffff8804203460c0 ti: ffff880420346640
RIP: 0010:[<ffffffff812a1903>] __fscache_uncache_page+0x23/0x160
RSP: 0018:ffff8801053af878 EFLAGS: 00210286
RAX: 0000000000000000 RBX: ffff8800be2f8780 RCX: ffff88022ffae5e8
RDX: 0000000000004c66 RSI: ffffea00055ff440 RDI: ffff8800be2f8780
RBP: ffff8801053af898 R08: 0000000000000001 R09: 0000000000000003
R10: 0000000000000000 R11: 0000000000000000 R12: ffffea00055ff440
R13: 0000000000001000 R14: ffff8800c50be538 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88042fc60000(0063) knlGS:00000000e439c700
CS: 0010 DS: 002b ES: 002b CR0: 0000000080050033
CR2: 0000000000000010 CR3: 0000000001d8f000 CR4: 00000000000607f0
Stack:
Call Trace:
[<ffffffff81365a72>] __nfs_fscache_invalidate_page+0x42/0x70
[<ffffffff813553d5>] nfs_invalidate_page+0x75/0x90
[<ffffffff811b8f5e>] truncate_inode_page+0x8e/0x90
[<ffffffff811b90ad>] truncate_inode_pages_range.part.12+0x14d/0x620
[<ffffffff81d6387d>] ? __mutex_lock_slowpath+0x1fd/0x2e0
[<ffffffff811b95d3>] truncate_inode_pages_range+0x53/0x70
[<ffffffff811b969d>] truncate_inode_pages+0x2d/0x40
[<ffffffff811b96ff>] truncate_pagecache+0x4f/0x70
[<ffffffff81356840>] nfs_setattr_update_inode+0xa0/0x120
[<ffffffff81368de4>] nfs3_proc_setattr+0xc4/0xe0
[<ffffffff81357f78>] nfs_setattr+0xc8/0x150
[<ffffffff8122d95b>] notify_change+0x1cb/0x390
[<ffffffff8120a55b>] do_truncate+0x7b/0xc0
[<ffffffff8121f96c>] do_last+0xa4c/0xfd0
[<ffffffff8121ffbc>] path_openat+0xcc/0x670
[<ffffffff81220a0e>] do_filp_open+0x4e/0xb0
[<ffffffff8120ba1f>] do_sys_open+0x13f/0x2b0
[<ffffffff8126aaf6>] compat_SyS_open+0x36/0x50
[<ffffffff81d7204c>] sysenter_dispatch+0x7/0x24
The code at the instruction pointer was disassembled:
> (gdb) disas __fscache_uncache_page
> Dump of assembler code for function __fscache_uncache_page:
> 0xffffffff812a18ff <+31>: mov 0x48(%rbx),%rax
> 0xffffffff812a1903 <+35>: cmpb $0x0,0x10(%rax)
> 0xffffffff812a1907 <+39>: je 0xffffffff812a19cd <__fscache_uncache_page+237>
These instructions make up:
ASSERTCMP(cookie->def->type, !=, FSCACHE_COOKIE_TYPE_INDEX);
That cmpb is the faulting instruction (%rax is 0). So cookie->def is NULL -
which presumably means that the cookie has already been at least partway
through __fscache_relinquish_cookie().
What I think may be happening is something like a three-way race on the same
file:
PROCESS 1 PROCESS 2 PROCESS 3
open(O_TRUNC|O_WRONLY)
open(O_RDONLY)
open(O_WRONLY)
-->nfs_open()
-->nfs_fscache_set_inode_cookie()
nfs_fscache_inode_lock()
nfs_fscache_disable_inode_cookie()
nfs_inode->fscache = NULL
<--nfs_fscache_set_inode_cookie()
-->nfs_open()
nfs_fscache_enable_inode_cookie()
__fscache_acquire_cookie()
nfs_inode->fscache = cookie
<--nfs_open()
-->nfs_setattr()
-->nfs_invalidate_page()
-->__nfs_fscache_invalidate_page()
cookie = nfsi->fscache
-->nfs_open()
-->__fscache_relinquish_cookie()
-->__fscache_uncache_page(cookie)
<crash>
<--__fscache_relinquish_cookie()
What is needed is something to prevent process #2 from reacquiring the cookie
- and I think checking i_writecount should do the trick.
It's also possible to have a two-way race on this if the file is opened
O_TRUNC|O_RDONLY instead.
Reported-by: Mark Moseley <moseleymark@gmail.com>
If an NFS client does
mkdir("dir");
fd = open("dir/file");
unlink("dir/file");
close(fd);
rmdir("dir");
then the asynchronous nature of the sillyrename operation means that
we can end up getting EBUSY for the rmdir() in the above test. Fix
that by ensuring that we wait for any in-progress sillyrenames
before sending the rmdir() to the server.
NFS: Make nfs_attribute_cache_expired() non-static so we can call it from
nfs_readdir().
Signed-off-by: Scott Mayhew <smayhew@redhat.com>
* labeled-nfs:
NFS: Apply v4.1 capabilities to v4.2
NFS: Add in v4.2 callback operation
NFS: Make callbacks minor version generic
Kconfig: Add Kconfig entry for Labeled NFS V4 client
NFS: Extend NFS xattr handlers to accept the security namespace
NFS: Client implementation of Labeled-NFS
NFS: Add label lifecycle management
NFS:Add labels to client function prototypes
NFSv4: Extend fattr bitmaps to support all 3 words
NFSv4: Introduce new label structure
NFSv4: Add label recommended attribute and NFSv4 flags
NFSv4.2: Added NFS v4.2 support to the NFS client
SELinux: Add new labeling type native labels
LSM: Add flags field to security_sb_set_mnt_opts for in kernel mount data.
Security: Add Hook to test if the particular xattr is part of a MAC model.
Security: Add hook to calculate context based on a negative dentry.
NFS: Add NFSv4.2 protocol constants
fs/nfs/nfs4proc.c
This patch implements the client transport and handling support for labeled
NFS. The patch adds two functions to encode and decode the security label
recommended attribute which makes use of the LSM hooks added earlier. It also
adds code to grab the label from the file attribute structures and encode the
label to be sent back to the server.
Acked-by: James Morris <james.l.morris@oracle.com>
Signed-off-by: Matthew N. Dodd <Matthew.Dodd@sparta.com>
Signed-off-by: Miguel Rodel Felipe <Rodel_FM@dsi.a-star.edu.sg>
Signed-off-by: Phua Eu Gene <PHUA_Eu_Gene@dsi.a-star.edu.sg>
Signed-off-by: Khin Mi Mi Aung <Mi_Mi_AUNG@dsi.a-star.edu.sg>
Signed-off-by: Steve Dickson <steved@redhat.com>
After looking at all of the nfsv4 operations the label structure has been added
to the prototypes of the functions which can transmit label data.
In order to mimic the way that NFSv4 ACLs are implemented we have created a
structure to be used to pass label data up and down the call chain. This patch
adds the new structure and new members to the required NFSv4 call structures.
State recovery currently relies on being able to find a valid
nfs_open_context in the inode->open_files list.
We therefore need to put the nfs_open_context on the list while
we're still protected by the sp->so_reclaim_seqcount in order
to avoid reboot races.
This will later allow NFS locking code to wait for readahead to complete
before releasing byte range locks.
If the state recovery failed, we want to ensure that the application
doesn't try to use the same file descriptor for more reads or writes.
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
The OPEN operation has no way to differentiate an open for read and an
open for execution - both look like read to the server. This allowed
users to read files that didn't have READ access but did have EXEC access,
which is obviously wrong.
This patch adds an ACCESS call to the OPEN compound to handle the
difference between OPENs for reading and execution. Since we're going
through the trouble of calling ACCESS, we check all possible access bits
and cache the results hopefully avoiding an ACCESS call in the future.
Signed-off-by: Weston Andros Adamson <dros@netapp.com>
If the server reboots before it can commit the unstable writes to disk,
then nfs_commit_release_pages() will detect this when it compares the
verifier returned by COMMIT to the one returned by WRITE. When this
happens, the client needs to resend those writes in order to guarantee
that they make it to stable storage.
This patch adds a signalling mechanism to notify fsync() that it
needs to retry all writes before it can exit.
We want to be able to pass on the information that the page was not
dirtied under a lock. Instead of adding a flag parameter, do this
by passing a pointer to a 'struct nfs_lock_owner' that may be NULL.
Also reuse this structure in struct nfs_lock_context to carry the
fl_owner_t and pid_t.
When the NFS_COOKIEVERF helper macro was converted into a static
inline function in commit 99fadcd764 (nfs: convert NFS_*(inode)
helpers to static inline), we broke the initialisation of the
readdir cookies, since that depended on doing a memset with an
argument of 'sizeof(NFS_COOKIEVERF(inode))' which therefore
changed from sizeof(be32 cookieverf[2]) to sizeof(be32 *).
At this point, NFS_COOKIEVERF seems to be more of an obfuscation
than a helper, so the best thing would be to just get rid of it.
Also see: https://bugzilla.kernel.org/show_bug.cgi?id=46881
Reported-by: Andi Kleen <andi@firstfloor.org>
Reported-by: David Binderman <dcb314@hotmail.com>
Cc: stable@vger.kernel.org
Merge Andrew's second set of patches:
- MM
- a few random fixes
- a couple of RTC leftovers
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (120 commits)
rtc/rtc-88pm80x: remove unneed devm_kfree
rtc/rtc-88pm80x: assign ret only when rtc_register_driver fails
mm: hugetlbfs: close race during teardown of hugetlbfs shared page tables
tmpfs: distribute interleave better across nodes
mm: remove redundant initialization
mm: warn if pg_data_t isn't initialized with zero
mips: zero out pg_data_t when it's allocated
memcg: gix memory accounting scalability in shrink_page_list
mm/sparse: remove index_init_lock
mm/sparse: more checks on mem_section number
mm/sparse: optimize sparse_index_alloc
memcg: add mem_cgroup_from_css() helper
memcg: further prevent OOM with too many dirty pages
memcg: prevent OOM with too many dirty pages
mm: mmu_notifier: fix freed page still mapped in secondary MMU
mm: memcg: only check anon swapin page charges for swap cache
mm: memcg: only check swap cache pages for repeated charging
mm: memcg: split swapin charge function into private and public part
mm: memcg: remove needless !mm fixup to init_mm when charging
mm: memcg: remove unneeded shmem charge type
Implement the new swapfile a_ops for NFS and hook up ->direct_IO. This
will set the NFS socket to SOCK_MEMALLOC and run socket reconnect under
PF_MEMALLOC as well as reset SOCK_MEMALLOC before engaging the protocol
->connect() method.
PF_MEMALLOC should allow the allocation of struct socket and related
objects and the early (re)setting of SOCK_MEMALLOC should allow us to
receive the packets required for the TCP connection buildup.
[jlayton@redhat.com: Restore PF_MEMALLOC task flags in all cases]
[dfeng@redhat.com: Fix handling of multiple swap files]
[a.p.zijlstra@chello.nl: Original patch]
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Eric Paris <eparis@redhat.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Neil Brown <neilb@suse.de>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Xiaotian Feng <dfeng@redhat.com>
This patch exports symbols needed by the v4 module. In addition, I also
switch over to using IS_ENABLED() to check if CONFIG_NFS_V4 or
CONFIG_NFS_V4_MODULE are set.
The module (nfs4.ko) will be created in the same directory as nfs.ko and
will be automatically loaded the first time you try to mount over NFS v4.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
This patch moves the NFS v3 file and directory inode functions into
files that are only compiled whet CONFIG_NFS_V3 is enabled.
